5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Oct 12, 2007 | 12:49 PM
  #3321
User 12822's Avatar
Originally Posted by Kyle00
Do you have power seats? do they work?
I don't think I do because they would have been connected when we got the car? The seats were never power before...
Old Oct 12, 2007 | 03:00 PM
  #3322
AaronL's Avatar
Long term fuel trim of 33%???
Just got a check engline light on my 2001 GLE:
I pulled code P0171 - System too lean, Bank 1. Both banks have a long term fuel trim of 33.6%. (What's a normal long term trim? ~5%? Is 33.6% crazy?)
I have always gotten horrible mileage, 320km/tank (~14 mpg), stop and go driving.
Car surges for maybe 15s when the engine/outside is cold, but it runs fine after.
Where should I start with this? O2 sensor? Fuel injectors? MAF?
Thanks for your help!
Old Oct 12, 2007 | 08:51 PM
  #3323
majesticmaxima's Avatar
Originally Posted by GigEmAgs07
i know we're ''supposed" to use 55w fog bulbs, but is there any harm in gettin some that draw 80 watts? i know there is a 'threat' of melting harnesses and junk, but i'm sure most of you guys do it. any insight?
go HID!!
Old Oct 12, 2007 | 08:57 PM
  #3324
irish44j's Avatar
retired moderator
do you have "gray dot" coils or not?
Old Oct 12, 2007 | 09:33 PM
  #3325
AaronL's Avatar
I don't think so. The previous owner replaced a couple of the coils, but not all of them, so I don't think they're all gray dot coils.
Should I start by replacing the non-gray dot coils? I'm sure they'll go bad soon enough anyways
Old Oct 12, 2007 | 09:39 PM
  #3326
AceofSpds's Avatar
wat
I dont think coils would have much to do w/ the motor running too lean, although you should probably go ahead and change them. Sounds to me like fuel delivery issues would be my first guess.
Dont our cars go into safe mode when the maf goes bad and run pretty rich?
Old Oct 13, 2007 | 10:25 AM
  #3327
khes's Avatar
2001 maxima SE idle problems
I have a 2001 Maxima SE it had a high idle (1500 rpm) and the check engine light on and it said that the air idle control vavle needed to be change so i changed it and now it idles back and forth between 1200 to 1500 rpm. I thought that the new air idle control vavle was bad so I had it replaced again but the problem was still there. any help would be great
Old Oct 13, 2007 | 03:47 PM
  #3328
KRRZ350's Avatar
Several .org members have had a bad IACV damage that section of the ECU, a costly replacement, but first I must ask.......... Did you perform the Idle Air Volume relearn procedure? Download the FSM from VQ35DE.com
Old Oct 13, 2007 | 03:53 PM
  #3329
KRRZ350's Avatar
Yes, around 3-5% is average for the LTFT's, IIRC +/-25% is when the ecu will throw a rich/lean code. Maf gets my vote, it's such a common issue for the 5th gens and gives those exact symptoms. However, the surging when cold could be three things...
1: Fuel delivery problem, engines need more fuel when they are cold
2: Vacuum leak that get's better when parts heat up and expand
3: Bad maf, since during this time the ecu is functioning in open-loop mode and does not use o2's, it uses maf etc even under 3k/wot
As you can see, all three of those things can also cause a system lean code.... but maf get's my vote.
Old Oct 13, 2007 | 04:47 PM
  #3330
bomball's Avatar
Hi guys
I have a question, my car (2002 maxima SE) just made some strange noise for the first time. It happened when my friend entered the passenger side of the car, a squeeky or a cranking type of noise came from the bottom of the car or around there, and when he entered it stopped, and when I entered the driver side it made a the same kinda squeeky/cranking noise, I told him to get out and to enter again, then the noise stopped after like the 3rd time of him getting in and out, I figured it might be my tire pressure? After a few errands and getting in and out of the car, the noise has not returned.
any advice?? Thank You in advance
Old Oct 13, 2007 | 08:12 PM
  #3331
zheka's Avatar
i just put in a new alternator in my 2000 max. but for some reason the alty turns off after "sprinted driving" or sometimes it randomly turns off. i turn the car off, turn it back on and everything returns to normal. i can tell it shuts off because the battery, break and airbag light goes on, and the headlights are dim. i cheaked the connections to the alty, it seems they are okay. any idea?
Old Oct 13, 2007 | 10:44 PM
  #3332
machinehead131's Avatar
Was it a remanufactured alt?
get it tested at autozone or something check to see if its good.
Old Oct 14, 2007 | 11:55 AM
  #3333
AaronL's Avatar
I just read through this thread: http://forums.maxima.org/showthread.php?t=538422 about the MIL and P0171 code and the MAF was the problem there too, so I think I'll replace my MAF and see if that clears it up.
I'm not too worried about the surging, since I only get that if the engine is cold and I start driving immediately - if I let the engine idle for even 30s it's ok. If it gets worse then I'll start worrying
Is replacing the MAF a pretty easy job? I tried searching but couldn't find any howto's on it - which is surprising, given how many must have been replaced.
Old Oct 14, 2007 | 12:55 PM
  #3334
zheka's Avatar
i think it's remanufactured or a aftermarket alt, but do you think that could be the issue?
Old Oct 14, 2007 | 01:46 PM
  #3335
its possible, sometimes remanufactured alt's can be faulty. I would bring it somewhere and see if they can check the alt.
Old Oct 14, 2007 | 03:48 PM
  #3336
shoult's Avatar
Originally Posted by pt929mm
I just want to add that some may say that the ECU shouldn't have to be reprogrammed, but a tech in my shop has the same car with the same problem, he replaced the MAF and an two of the four O2 sensors. He refused to go get the ECU reprogrammed and his car is still throwin check engine lights no matter how many times he clears them.
It could also be none of those are the problem.
Old Oct 14, 2007 | 04:08 PM
  #3337
paulpearl's Avatar
maf instructions
Speaking of replacing MAF's....Does anyone have a good link on how to replace the MAF because I am replacing mine this coming week...Just ordered one from Dave B. for my 01....
Old Oct 14, 2007 | 04:29 PM
  #3338
shoult's Avatar
Originally Posted by chris in va
It's definitely the MAF. Previous owner said he replaced it, but I'm not convinced after tearing out the airbox last night. Looks like it hasn't been touched in years.
The bolts I'm talking about are the two on either side of the MAF sensor holding it in the tube. Torx style with the center post. Maybe they include the tube with the MAF when you buy one?
I did a little searching and it's called a 'Tamper Resistant Torx' bolt.
Go to Harbor freight (or http://www.harborfreight.com/cpi/cta...emnumber=91310) and get a set of Security bits for cheap. They're a good addition to your toolbox and you won't have to grind anything.
Old Oct 14, 2007 | 05:09 PM
  #3339
shoult's Avatar
Originally Posted by VaporHead
The 195 represents the width of the tire, the portion contacting the pavement. The 15 is the rim size, and the 65 is the width from the top of the rim to the top of the tire.
65 is the RATIO of tire width to tire height. This is what's normally referred to as the PROFILE. The lower the profile the less sidewall compared to the tire contact patch width.
Old Oct 14, 2007 | 06:13 PM
  #3340
shoult's Avatar
Originally Posted by MaReK 1R
im having problems with my trnny can anyone help me..???:
Any description of the problem?
Auto or manual?
Slipping? Not shifting? Missing gears? Noises?
Any kind of description at all?
Old Oct 14, 2007 | 06:17 PM
  #3341
shoult's Avatar
Originally Posted by Daniel514bama
Time to change cv axles on my auto 2000 max. With no leaking from tranny axle seal, should I be concerned with causing a leak? Should I go ahead and replace these seals if they are okay since I'm already there? Thanks.
This is one of those things that you just go ahead and replace. They shouldn't cost that much, even at the dealer but will pay you back shedloads later on. Like 3 months down the road when you start getting a little drip that you KNOW wouldn't be there if you'd just gone ahead and replaced them.
Old Oct 14, 2007 | 06:27 PM
  #3342
shoult's Avatar
105 sounds about right for 1 hour shop labor and turning the rotors. Turning (cutting) the rotors will get rid of uneven pad buildup left from stock pads. It's a good idea.
Turning rotors is a BAD idea for several reasons.
Rotors today have barely enough mass to dissapte the heat generated already. Manufacturers started doing this is the late 70 to cut weight and rotating mass to increase fuel mileage for CAFE requirements.
When the rotors can't disapate heat fast enough they have a tendancy to warp.
Even those crappy Autozone/Advanced Auto/Kragen/O'reilly generic blanks are better then turned OEM units.
While I haven't checked prices for gen5/5.5 vehicles, typical aftermarket prices for generic rotors usually runs $20-30 each for other vehicles.
Old Oct 14, 2007 | 07:13 PM
  #3343
shoult's Avatar
Originally Posted by wawacito
thankx for your replies. I have another question for manual tranny fluid change. I read the DIY for doing the fluid change and it seems almost identical to doing an engine oil change - except for one part - there are no instructions to change a filter. Is there a filter for manual tranny fluid that needs to be changed as part of regular maintenance like engine oil filters?
I haven't read the DIY FAQ, but hopefully it instructs you to remove the filler plug as the FIRST step. Nothing like draining out all the trany fluid and then finding that you don't have the right tool or the filler just won't come out. Shouldn't happen on a vehicle of this era, but Murphy can show up ANYWHERE and ANYTIME.
Old Oct 14, 2007 | 07:45 PM
  #3344
shoult's Avatar
My stock clutch has dealt with 120,000 miles and about 20 autocrosses, plus ALOT of city and bumper-to-bumper traffic. When it eventually goes, I will put another OEM clutch in.
As for what others are using, here's a few links that should help you out, though I don't think a big percentage of guys here have aftermarket clutches.
edit: well, after doing a search for you, I found pretty much JACK for clutch discussion on the 5th gen forum....so here are some links from the 4th gen guys. i haven't read them, so sorry if they don't have much info...
Most 5.5gen guys haven't had to replace their clutches (most 5.0 gen guys haven't either), hence the lack of information.
I have a 92 SE (VSLD) with a 165K on it and it STILL has the original clutch. And believe me, I drive hard. Hope I can get the same out of my future Gen5/5.5.
Old Oct 14, 2007 | 07:50 PM
  #3345
Armon's Avatar
Q: Why is this forum so utterly frustrating to use?
Yes, I am new here. Yes, I notice the 50 threads directing me how to find information. The problem is it doesn't work. For example, in the FAQ sticky, all 6 of the links under "Intake" go to the wrong pages, or sometimes no page at all. Same result in the how-to sticky. Same result when I find links using the search button.
I can't even find my previous posts in this thread, for crying out loud! I went to my profile and clicked on "view previous posts" and it said I didn't have permission.
What's a newb to do?
Q: What happened to Cattman's website? Is the company still up and running? I had sent a few emails back and forth with the guy there and he stopped responding a few days ago when the website went down.
Old Oct 15, 2007 | 12:36 AM
  #3346
seby86's Avatar
from what i hear, this website crashed several weeks back and had to be completely overhauled..... they are apparently still working on restoring as many of the stickies and original links as they can...(it may take some time) so be patient my friend and ask your questions here for the time being.... just dont post anything too stoopid...
Old Oct 15, 2007 | 06:14 AM
  #3347
bigjoe87865's Avatar
is this a good deal?
Hi... i am in need of a new car... and want something really reliable nice and efficient...
i had been looking at various honda accords for a while... i finally found one... and the deal fell apart at the last minute... was really upset about that.... anyways...
now im looking at the maximas... i see a really nice condition 2002 SE... fully loaded... except for nav... 118,000 miles... the guy has no maintance records of it... it was bought at dealership auction by another small dealership... the carfax shows that it is a single owner car....
and drives flawlessly... not a single problem in the driving... but then again... no records of what was done...
NOW my problem is... i KNOW that the maximas have all sorts of electronic problems... my friend has a 2001 that he is paying left and right for 02 sensors and MAF , and valve coils...
i want to know if the newer 2002 with the vq35de have the same things going on...
the car is being sold at 8grand... im gonna try haggling it down.... its the 6sp manual
thank you.
i just wanna steer clear of it.. .if there are known problems to that particular model....cause i cant afford 500$ repairs every few months... im a college student.
Old Oct 15, 2007 | 11:31 AM
  #3348
shoult's Avatar
Originally Posted by AcidJake75
or you can just check Crutchfield.com punch in your car make and model and they tell you what fits - if you think their too pricey right down the unit you want and search for the best deal..Crutchfield is the best - I installed my own and Im not the handiest when it comes to installing anything - then again this site has helped me out BIGTIME.. I got me an ALPINE MP3 player for 150 with the install kit and an extra adapter since I had the BOSE unit..
Remember that Crutchfield includes a dash adapter and wiring harness adaptor (if either are needed) in the price of their head units. That's about $25 if you have to go down to your local super whiz bang big box electronics store.
Old Oct 15, 2007 | 12:28 PM
  #3349
Iceman420's Avatar
(insert witty one liner)
When you click on the link and get sent to the wrong page. In the address bar, change "showthread" to "oldthread" and that will usually get you to the right page. Don't know if this will always be the case, but has worked for me for a lot of the FAQ links.
Old Oct 15, 2007 | 01:08 PM
  #3350
shoult's Avatar
Hey all, hate to sound like a noob - but i am one - thus the reason i post here on this thread.
anyways - i been reading about some people on this board saying the want to go "one step colder" with their spark plugs. Could somebody explain to me what this is about? Spark plugs have temperature ratings? are we talking about the temperature of the spark? the temperature that spark plug can tolerate? what is meant by "going colder"? What is the advantage of going colder? Where on the spark plug specs does it mention anything about temperature? When I buy spark plugs - do I have to check that the spark plug temperature matches OEM specs? I cant just go anywhere and ask for NGK's or Denso's?
This is a common trick that people with Supercharged or Turbo'd cars use to keep from pre-detonation. They can also retard the timing a degree or two for a similar effect.
On normally aspirated vehicles you wouldn't want to use a colder plug. It probably would decrease you mileage since it wouldn't burn the fuel as completely. It might even lead to plug fouling.
Old Oct 15, 2007 | 01:11 PM
  #3351
NmexMAX's Avatar
dot dot dot ...
Also:
http://www.ngk.de/Spark_plugs.649.0.html
Old Oct 15, 2007 | 01:41 PM
  #3352
shoult's Avatar
Originally Posted by Patrick.R
Anyone? Is my tranny toast?
like i said it was running perfectly fine then this.
Anytime you have a pool of fluid under your vehicle that's supposed to be IN your car, it's bad.
You may not need to replace your tranny, but it's going to need work for sure.
Old Oct 15, 2007 | 01:58 PM
  #3353
6SPD02SE's Avatar
Ok, guys, Im desperate. I need a passenger side axle for my car. I called all the auto parts stores and most of them cant even get one. I got one from a parts store today, but it was not long enough?!?! Now im getting desperate. I have an 02 SE with 6 speed. Anyone know of a place i can get one?
Old Oct 15, 2007 | 03:38 PM
  #3354
KRRZ350's Avatar
car-part.com, searches inventory of local junkyards, average is $65 w/1-year warranty
Old Oct 15, 2007 | 04:04 PM
  #3355
MoeBelikeMax's Avatar
Oil Change
How many miles should i do an oil change....and what is da best oil 2 use on my 2k maxima
Old Oct 15, 2007 | 04:14 PM
  #3356
CoolMax's Avatar
is invisible
every 5k miles should be fine.
http://forums.maxima.org/showthread.php?t=166313
Old Oct 15, 2007 | 04:21 PM
  #3357
Originally Posted by CoolMax
but what is better Synthetic oil or just oil ..I'm new 2 all this stuff
Old Oct 15, 2007 | 04:32 PM
  #3358
merlin2375's Avatar
Well I'm new...
I am new here but have some questions
1) Google search all messed up?
When I use google search, none of the threads seem to match. Also, some of the thread in the FAQ don't match the title. Is there a thread explaining why they are out of sync? In other words, I click the link and it either tells me its an invalid thread or the thread is different.
2) 2000 versus 2000.5+
I have read that there was a change in 2000.5+ models, is there a thread or can someone explain to me the differences
3) Do 02/03 HID headlights fit 00/01 cleanly, is it just a matter of wiring? Is there a write up somewhere?
4) Are those HID headlights on ebay any good fit and quality wise?
5) Is there a thread outlining some of the smaller differences between the 00/01 and 02/03 other than the obvious more hp, HID headlights, taillights, etc?
6) In the 00/01 world, DID any trim level other than the '01 Anniversary Edition come with the VLSD? It seems like in previous years more trims/models had it, why did nissan get rid of it?
7) When looking at 00/01 any things I should check carefully visually/mechanically, what are common problems. I have heard coil packs are very common.
8)What is the "-K" in VQ30DE-K, I know the rest of it, but not sure on that...
Thanks a lot for your help, I hope I can contribute something to the forum. Currently I am looking at 00/01 Maxima SEs. I do appreciate it! FWIW, I did search and have read a lot of stuff, but with the links being out of sync, searching got tiring real fast. I guess I need to become a sponsor ASAP
Old Oct 15, 2007 | 04:58 PM
  #3359
KL77's Avatar
2 odd problems, are they linked?
When I put on my rear defroster, my radio goes fuzzy and it barely defrosts the rear window. Second problem is, my keyfob will lock my car and the panic button works, but the unlock will not work. I bought a new keyfob, and same problem. Are these problems linked? I did a few searches and it seems like it could either be the BCM or the SECU, any ideas? Thanks.
Old Oct 15, 2007 | 08:25 PM
  #3360
AaronL's Avatar
It's really straightforward: here's a video showing how to remove, clean and re-install it:
http://videos.streetfire.net/video/4...6f015c3dac.htm
