5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Apr 10, 2009 | 06:25 PM
  #8241
dcnded's Avatar
rattle
so as stated on the last page, i did the STS mod today and while under my hood i noticed what has been making as awful racket in my engine bay, most of the time under part throttle. hopefully someone can help.
while standing looking into the engine bay on the passenger side of the intake manifold the is a vaccuum solenoid or something that attaches to a lever that disappears into the intake.now not knowing what its called its hard to do a search for it otherwise i would, so if someone can point me in the right direction...many thanks this noise its making is driving me insane i can hear it while driving ...lol
Old Apr 10, 2009 | 06:26 PM
  #8242
kjunior's Avatar
problem!?!
hi guys,
is it normal that my engine move a lot when i change gear like P to R or R to D. Even when i drive and the car change speed i feel that the engine give hit. I don't know if it is the same problem. What will be the problem ?
Thank you to take the time to read me
Junior
Old Apr 10, 2009 | 06:41 PM
  #8243
denny_1986's Avatar
Originally Posted by kjunior
hi guys,
Junior
your motor mounts are probably worn-out
Old Apr 10, 2009 | 07:04 PM
  #8244
Teddie18's Avatar
hi guys,
Junior
No, your engine should not move much at all. And you certainly shouldn't be able to notice it from inside the car. One or more of your engine and or transmission mounts is defective and needs to be replaced.
Old Apr 10, 2009 | 07:10 PM
  #8245
Teddie18's Avatar
Originally Posted by d.sull
Yea, it had the P140 or whatever it is code stored. He wanted me to pay him $700+ to put in three O2 sensors and a MAF. I just bought the MAF and put it in myself and the codes are gone.
Anyway, you're saying the induction cleaning thing is bullsh*t too, correct? He said it would clean the carbon or something from the motor and make it run a lot better. If that's the truth then I'm down for doing it but it sounds sketch. Thanks for the info, Progress.
As was peviously mentioned the dealership is trying to upsell you. The induction cleaning is a profit center (a way to make money) for the service department. It is something good to do but you probably don't need it.
As long as you replace the parts that caused the problem (O2 sensor and MAF) you're fine.
Old Apr 10, 2009 | 08:37 PM
  #8246
RiDe DaH MaX's Avatar
where is the ECU located at on a 2001 GLE???
thanxx
Old Apr 10, 2009 | 08:50 PM
  #8247
pmohr's Avatar
No more Maximas...
thanxx
So search didn't give you an answer? That's odd. It does for me
http://forums.maxima.org/5th-generat...ation-ecu.html
http://forums.maxima.org/5th-generat...u-removal.html
Old Apr 10, 2009 | 11:35 PM
  #8248
thanxx pmohr...question #2 how can u check if your motor mounts have gone bad???do u have 2 replace all or witch ever is bad
Old Apr 11, 2009 | 09:19 AM
  #8249
maxima415's Avatar
Originally Posted by pmohr
Did you search at all? Look at the Nitrous forum? Look at the stickies?
http://forums.maxima.org/nitrous-40/
http://forums.maxima.org/nitrous/123...rous-faqs.html
i did look through the faqs but i didnt see anyone ask my question
Old Apr 11, 2009 | 09:57 AM
  #8250
Canadian Max's Avatar
Hi All,
Having serious issues with my 2000 max SE. A while ago (months) I got a misfire code for cylinder #3. So I replaced the Coil in the cylinder. Once I did that and took the car out for a spin, the code came back, this time with a multiple misfire code, p0300. I replaced the rest of my coils. Still getting the multiple misfire.
So yesterday I tried some trial and error tests, taking out each coil one by one and starting the engine but still no change.
I checked the codes again and this time got a new code... P0433. "EVAP Canister Purge Volume Control Solenoid Valve"
I drove the car around the block and the engine was suddenly very heavy and rough. Parked the car back on the driveway and now it wont even start. When I turn it all I get is lights on the dash board. No response at all from the engine though.
Help Please!
Old Apr 11, 2009 | 10:39 AM
  #8251
pmohr's Avatar
No more Maximas...
You only have to replace those that are worn. You can check by keeping your foot on the brake while in gear, and giving it some gas. The engine shouldn't move an extreme amount.
There are relevant discussions in the thread I linked.
Failing that, again, did you search?
Some reading...
http://forums.maxima.org/5th-generat...k2-maxima.html
http://forums.maxima.org/nitrous/365...t-75-06-a.html
Lots of reading, and you'll find your answer. Short answer: you don't need to change anything.
Originally Posted by Canadian Max
Hi All,
Help Please!
So it doesn't click or anything when you turn the key to start?
Have you tried checking the connections at the starter? Hitting it to see if it will start up then?
Pull it out and bench test it.
Old Apr 11, 2009 | 10:43 AM
  #8252
Progress's Avatar
It's business time.
Hi All,
Help Please!
I grabbed this:
P0433- EVAP Canister Purge Control Valve and Solenoid Valve Circuit
This malfunction is detected when one of two things happens. Type A Malfunction is detected when an improper voltage signal is sent to the ECM through the Solenoid Valve circuit, and Type B malfunction is detected when the EVAP Canister Purge Control Valve does not operate properly and is stuck open. Keep in mind the Canister Purge Control Valve is a mechanical, vacuum operated valve, NOT electrically operated.
Possible Causes:
For Malfunction Type A
-Harness or Connectors (The Solenoid Valve circuit is open or shorted)
-EVAP Canister Purge Control Solenoid Valve
- - - - - - - - - - - - - - - - - - - OR - - - - - - - - - - - - -
For Malfunction Type B
-EVAP Canister Purge Control Valve
-Vacuum Hoses clogged or disconnected
-EVAP control system Pressure Sensor
Malfunction Type A is detected as soon as the key is in the ON position. Malfunction Type B is detected only when test driven or when running the vehicle in the air. This is simply used in the diagnosis process. Since the two Nissan shops have come to the same conclusion that the ECM is not grounding properly, they have probably detected a Type A problem, with the Canister Purge Control Solenoid Valve.
Now, this is where I believe that the shop had you prepay and replace Canister Purge Solenoid Control Valve, believing that the solenoid/valve was internally faulted. The solenoid/valve can be tested by a simple bench test of supplying power and ground to its terminals and checking if air can be blown between the two passages. Either they did not test it in this manner or the solenoid/valve actually tested bad and so it was replaced. The simplest and fastest fix (and usually more logical) is to simply replace this valve because it may be intermittently sticking open with age or dust/debris internally. This is the most common occurrence. But, upon replacement of this solenoid/valve the code still returned.
They have at this point concluded the Canister Purge Control Solenoid Valve is not at fault but is not operating properly. The only possibilities left are a problem in the harness or connector to the solenoid/valve, or the ECM not supplying the proper power and ground to it. This can be checked simply by looking for power at the solenoid/valve, and checking continuity of the harness from the solenoid/valve to the ECM. The ECM will only apply ground when certain conditions (that are programmed into the ECM) are met. It will NOT apply ground when any of the following occur:
-Ignition is "ON" and engine is stopped
-Closed throttle is detected
-Low or High engine coolant temp is detected
-During deceleration
-Low vehicle speed (M/T models)
At this point the shop has detected power to the solenoid/valve but has not found ground. They should have also done a continuity check of the circuit, between the solenoid/valve and the ECM, to ensure the harness is ok and not broken, as well as a pin fit test on the connectors at the ECM and the Canister Purge Control Solenoid Valve to ensure they are not damaged. Thus, making sure that the communication between the ECM and the solenoid/valve is ok.
If, at this point they have concluded that there are no harness problems, or connector problems, they should use the Nissan Consult to activate the Canister Purge Control Solenoid Valve and look for the ECM to provide a ground. The Consult diagnosis computer can tell the ECM to activate the solenoid/valve upon command of the technician. Assuming that they have done all of this and they still do not receive ground to the Canister Purge Control Solenoid Valve, the conclusion is that the ECM is internally faulted and needs to be replaced.
OK! I think that is explained as best I can. I hope you understand that ECM failures are not very common but do happen sometimes, and that for a technician they can demand a lot of skill and patience to figure out. Sometimes, it is good to get a second opinion on something like this because it is not an everyday occurrence. I would suggest possibly seeing if you can get a used ECM, as they can be very pricey. Hopefully this answers your question and I hope you enjoy your Nissan overall. If there is anything else, just let me know. Thanks
http://www.justanswer.com/questions/...ht-1996-nissan
Old Apr 11, 2009 | 11:19 AM
  #8253
Some reading...
Yeah it does click...
I have to say im just learning about engines now so I wouldn't know how to check the starter connections... I'll see if I can find a guide for it...
Thanks for the reply.
Old Apr 11, 2009 | 11:23 AM
  #8254
Originally Posted by Progress
Thanks for the info!.
I guess my problem is a Malfunction A because it wont even start up.
I'll try this stuff out and get back to you guys.
Old Apr 11, 2009 | 08:23 PM
  #8255
Roly's Avatar
i was wondering if a 3rd brake light cover was available for our cars since i have the 3rd brake on the spoiler i'd rather get rid of the the one on the rear deck.
Old Apr 11, 2009 | 08:34 PM
  #8256
pmohr's Avatar
No more Maximas...
This was on the front page:
http://forums.maxima.org/5th-generat...ght-cover.html
Even has a part number:
B6595-2Y011, $25.92 each at Courtesy
Old Apr 12, 2009 | 05:54 PM
  #8257
bjr's Avatar
bjr
Been searching for awhile now....could someone please direct me to the How-To for the Lexus yellow capsules. Thanks
-Brian
Old Apr 12, 2009 | 06:15 PM
  #8258
pmohr's Avatar
No more Maximas...
-Brian
You mean the one listed in the stickies?
http://forums.maxima.org/5th-generat...n-how-diy.html to
http://forums.maxima.org/5th-generat...t-reviews.html to
http://www.cardomain.com/ride/442543/15
Also I searched 'lexus capsules', these were all on the front page
http://forums.maxima.org/5th-generat...sules-how.html
http://forums.maxima.org/5th-generat...-fogs-not.html
http://forums.maxima.org/5th-generat...-capsules.html
Old Apr 12, 2009 | 07:01 PM
  #8259
maxdriver10's Avatar
this is such a noob question but when am i gonna get to do attachments? lol Im a senior member with over 300 posts....i think i should be able to do attachments...
Old Apr 12, 2009 | 07:05 PM
  #8260
pmohr's Avatar
No more Maximas...
I think 'senior' is a bit of a stretch, you've only been here a year.
It's likely a donating member only option.
Old Apr 12, 2009 | 07:35 PM
  #8261
WildJuice's Avatar
new rims, lots of shaking
So yesterday I went from having 16" rims (the honeycomb looking ones) on my max to the 350z 35th anniversary ones, but while driving today on the FDR at around 40 - 45 mph the steering wheel started to shake left and right, and it felt like I was losing control. Also whenever I hit a pothole the steering wheels would start turning to the right and again I felt out of control. At first I though that it could be the fact that I didnt get my wheels balanced, but today while driving at around 10 - 15 mph, trying to avoid a pothole, I slightly stepped over the pothole and the steering wheels completely turned to the right by itself. Could this be a case of me not having by wheels balanced by a professional? or is there something else I should be looking at?
Thanks.
Old Apr 12, 2009 | 07:45 PM
  #8262
pmohr's Avatar
No more Maximas...
Thanks.
Your bump steer when you hit a pothole isn't caused by a balancing issue, but I'd get them balanced anyway to try to eliminate the shaking at speed.
Have you done any other work to it right before this happened? Have you made sure the lugnuts are torqued down?
Old Apr 12, 2009 | 07:54 PM
  #8263
WildJuice's Avatar
No previous work was done, and this was not happening before the wheels change. I will defitnely do a wheel balance asap, but I just don't feel confortable driving without the proper control of the car. Anyone else might have an idea of what might be causing this. All the lugs where tightened down with air pressured tools.
Old Apr 12, 2009 | 07:56 PM
  #8264
pmohr's Avatar
No more Maximas...
So you just hammered them down with an impact? You know, there exists a torque spec for a reason.
Old Apr 12, 2009 | 08:43 PM
  #8265
I just used the word senior becuase that's what it says under my username lol I realize I am not really a senior member
Old Apr 13, 2009 | 04:39 AM
  #8266
kpmikey808's Avatar
las vegas
new to this forum and trying to see if there are any members in vegas
Old Apr 13, 2009 | 06:24 AM
  #8267
SoonerFan's Avatar
Cletus
lug nuts are probably not on tight enough since you didnt tighten then properly
Old Apr 13, 2009 | 06:29 AM
  #8268
datbayboi's Avatar
i have a silver 03 max... Does anybody know where i can get some hid fog lights? and any suggestions on the grill selection?
Old Apr 13, 2009 | 06:34 AM
  #8269
SoonerFan's Avatar
Cletus
welcome
your answers are all here...spend a few days looking around and learning...
Old Apr 13, 2009 | 07:55 AM
  #8270
pmohr's Avatar
No more Maximas...
Originally Posted by SoonerFan
welcome
Where ya been at, Sooner?
Old Apr 13, 2009 | 12:39 PM
  #8271
SoonerFan's Avatar
Cletus
work...house stuff...dog...
Old Apr 13, 2009 | 02:09 PM
  #8272
CoolMax's Avatar
is invisible
http://forums.maxima.org/west-coast/...out-there.html
Old Apr 13, 2009 | 07:43 PM
  #8273
kpmikey808's Avatar
thanks ccolmax!!!
Old Apr 13, 2009 | 07:48 PM
  #8274
kpmikey808's Avatar
MAF?
Recently changed the IDLE AVC- car was running better- couple of weeks ago ECU light came on(the codes form autozone were P0171-TWICE)- Tried the MAF 10$ MAF cleaning- light went off-
car is a little smoother changing gears when im not punching it- when im flooring it 1st to 2nd & 2nd to 3rd ia a little rough.
I also have slight pinging especially when ac is on and car has been running for awhile. the pinging was worse when i used reg. gas but not as bad when i use premium- any suggestions?
Old Apr 13, 2009 | 07:50 PM
  #8275
pmohr's Avatar
No more Maximas...
Stop using crap gas
Old Apr 13, 2009 | 09:02 PM
  #8276
bonez82's Avatar
01 SES light after refueling
So just bought an 01 max se 5 speed about a week ago w/ 105k miles. Filled up with 87 gas and now throwing an SES light. I've read that I probably shouldnt burn cheap gas as our max's don't like it, but would that be enough to throw a SES code? Also noticed that the car hesistates somewhat in 1st-3rd noticeably when cold (car pulsing a bit at lower rpm's, power increases and smoother after 3500rpms.) I dont live near an auto zone and refuse to pay the dealer to pull the code. I've also done quite a bit of reading on this forum and noted what it possibly could be..MAF, coil packs, sensors etc. Any suggestions as to what I should look for first?
Old Apr 13, 2009 | 09:11 PM
  #8277
pmohr's Avatar
No more Maximas...
The first thing you need to do is pull the code. Seriously.
The CEL could come on for any number of things. There's absolutely no point in trying to randomly diagnose something, while also completely ignoring what the ECU is trying to say is the problem.
At the very least a local Walmart or similar should have a cheap OBD-II code reader.
Old Apr 14, 2009 | 07:50 AM
  #8278
Rion's Avatar
i need help on this one i have a 00 nissan maxima and my headlights and fog lights wont come on but when i turn the switch the park light is the only thing that comes on the dash light on the inside are ok and i check all the fuse under the hood and dash and i check the relays by switch them to the park light relay and the are fine but there is no click nose come from them when i put them back in the oringinal place can the switch be bad and still turn on the park light
Old Apr 14, 2009 | 01:40 PM
  #8279
TheOnlyMax88's Avatar
I might post a WTB, but i was just wondering im pretty sure im gettin the obx's but im not really up to par with info on tuning and im not sure where to buy a device and id rather not buy it new... are those things installed in your car or somthing you get hooked up to?
Old Apr 14, 2009 | 03:14 PM
  #8280
IHAVEA2KMAXIMA's Avatar
I have a question regarding my coils.
CEL came on, so I took it to dealership and I was told it was for p0420 and p1320. They told me to get my software updated which can possibly get rid of the p0420. I agreed and they reset the CEL after the update. No light still after 300miles of driving. My question is if my ignition coils are still bad? That was the first time I ever got the p1320. I just hit 100k last week. Is it a good time to change the coils out or just wait till they crap out?
