5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Dec 18, 2007 | 12:13 PM
  #4281
sutiban's Avatar
Originally Posted by Kyle00
Thank you good sir. :-)
Old Dec 18, 2007 | 12:19 PM
  #4282
loveswatching's Avatar
Hello everyone!
my coworker owns a 2003 Nissan Maxima GLE and the other day he fused out his left headlight. He bought the car from carmax so he took it there and they told him he needs a "Zenia Philips 35W" bulb to replace it. Would anyone here be kind enough to give me some information on this buld like Where can i purchase it from? Is there a generic version available?
He did install a generic one a philips 35W one and he aint satisfied cause according to him the lightening looks a lil off in color plus they charged him $200 for the bulb alone!!
Any help would be appreciated and if you can provide a link then even better
Old Dec 18, 2007 | 12:21 PM
  #4283
Kyle00's Avatar
WSH for teh cup
Originally Posted by loveswatching
Hello everyone!
he has HID bulbs which change in color over a period of time. 200 a bulb is steep, check the GD on here. The only way to fix the variation in color of the bulbs is to but two new bulbs at once.
Old Dec 18, 2007 | 12:49 PM
  #4284
Kyle00's Avatar
WSH for teh cup
http://forums.maxima.org/showthread.php?t=388232
$60 for a pair
Old Dec 18, 2007 | 12:50 PM
  #4285
MoeBelikeMax's Avatar
Originally Posted by NmexMAX
Of course they have, and it would make no difference whether it’s 5MT or 4AT.
i know some people have but who ...i would like to know the feedback on that mod
Old Dec 18, 2007 | 01:11 PM
  #4286
merlin2375's Avatar
/\/\ Not sure what that means, the VIAS fix is not really mod so much as it is fixing the variable intake that the 00/01 Maxima's came with (regardless of transmission). The VIAS system is well written about and is the only reason 5th gens have more HP than 4th gens. It is the "-k" in "VQ30DE-K". The VIAS system kicks in at high RPMs allowing the engine to breath easier.
Old Dec 18, 2007 | 01:16 PM
  #4287
Kyle00's Avatar
WSH for teh cup
it's not a mod.... but a fix. here's a write up http://www.cardomain.com/ride/763858/5
Old Dec 18, 2007 | 01:34 PM
  #4288
fast responses, i love it!
Thank you Kyle. I gave him a call and he is an excellent guy who helped me out quite a bit.
Old Dec 18, 2007 | 01:37 PM
  #4289
Kyle00's Avatar
WSH for teh cup
Glad I could help. Don't let your fingers come into contact with the bulb when installing!
  #4290
phatboislim's Avatar
why does VIAS sound like V TEC, when that guy explained it?
PS i'm reading and learning
  #4291
DID you do it
Old Dec 18, 2007 | 01:38 PM
  #4292
Kyle00's Avatar
WSH for teh cup
DID you do it
No, not me personally.
Old Dec 18, 2007 | 01:41 PM
  #4293
Kyle00's Avatar
WSH for teh cup
Our VIAS doesn't sound like VTEC... I'm confused by your post
  #4294
every thought about it
Old Dec 18, 2007 | 01:50 PM
  #4295
i'm talking about the way it was described in that link that was posted above:
VIAS stands for Variable Intake Air System. It is made up of a power rod going through your intake manifold that holds a series of butterfly valves. A solenoid turns the rod at 5000 rpm to open the valves to allow the engine to breathe better
Old Dec 18, 2007 | 02:06 PM
  #4296
Kyle00's Avatar
WSH for teh cup
Mine works fine.....
Old Dec 18, 2007 | 02:10 PM
  #4297
Kyle00's Avatar
WSH for teh cup
Exactly, i know all of this. VTEC uses variable valve timing which produces a sound which is more noticeable.
Old Dec 18, 2007 | 02:25 PM
  #4298
yea thats all i was saying...it KIND OF sounds alike in its function
Old Dec 18, 2007 | 03:53 PM
  #4299
Little John's Avatar
Got an '03 GLE - 91k miles. It's been running a touch on the rough side, and tonight on the way home I got the "check engine" light. What's it mean? Or do I have to go to the dealer?
Old Dec 18, 2007 | 04:01 PM
  #4300
dawntherockets's Avatar
Hi this is my frist post. I am on here trying to figure out what might be causing my mom maxima to throw differnt cylinder fault codes. it started out a cylinder 2, then moved to 3 after reseting the ECU, then after that was reset it moved to 4?
WHAT IS GOING ON?!
oh and I am a VW guy so I dont know anything about nissan engines.
its a 2000 Maxima GLE V6.
Old Dec 18, 2007 | 04:18 PM
  #4301
spdfreak's Avatar
WHAT IS GOING ON?!
What codes?
First thing you should do....search.
Old Dec 18, 2007 | 04:20 PM
  #4302
spdfreak's Avatar
First, go to AutoZone and have them scan your car for codes. It's free.
Next, search.
Old Dec 18, 2007 | 05:15 PM
  #4303
NmexMAX's Avatar
dot dot dot ...
DID you do it
Verify that your VIAS is faulty, whether it be through a dyno, or seat of the pants, then fix it. I would personally get a dyno.
  #4304
Kyle00's Avatar
WSH for teh cup
WHAT IS GOING ON?!
It's most likely the coils. I had the same problem. I ordered updated coils from Dave B from Southpoint Nissan.
Old Dec 18, 2007 | 05:17 PM
  #4305
Kyle00's Avatar
WSH for teh cup
You don't need to go to the dealer. Have Autozone pull the codes and you can go from there
Old Dec 18, 2007 | 05:20 PM
  #4306
NmexMAX's Avatar
dot dot dot ...
I see a pattern here, use it.
Old Dec 19, 2007 | 01:05 AM
  #4307
Memphis2k1's Avatar
Where can I find the Wiring Diagram - Color Codes?
I searched and found nothing. I need to find out what exactly the color codes in the FSM (Service manual) are. Google helped me find some BMW ones just fine.
Like "L" huh?
and "Pu" I'm assuing its purple.
I would like an entire list of all of them if anyone knows. Much appreciated.
I'm just trying to get my AstroStart Program Utility 1 set to my Rear defogger/defroster and figuring out how the place where I got it installed, did it... rather weird I think.
Old Dec 19, 2007 | 07:35 AM
  #4308
CCS2k1Max's Avatar
From my 01 FSM:
Code:
� This shows a code for the color of the wire.
B = Black 	BR = Brown
W = White 	OR = Orange
R = Red 	P = Pink
G = Green 	PU = Purple
L = Blue 	GY = Gray
Y = Yellow 	SB = Sky Blue
LG = Light Green 	CH = Dark Brown
	DG = Dark Green
When the wire color is striped, the base color is given first, followed by the stripe color as
shown below:
Example: L/W = Blue with White Stripe
Old Dec 19, 2007 | 07:53 AM
  #4309
is this the part number for the MAF for the 00-01? 22680-2Y001??
i can get it for $100 shipped on this one..i havent tried the other number kyle gave me yet...
Old Dec 19, 2007 | 07:59 AM
  #4310
Kyle00's Avatar
WSH for teh cup
Yes, thats the part number. I haven't bought a MAF, but I'd try Dave B, it may be cheaper from him
Old Dec 19, 2007 | 08:14 AM
  #4311
ok i'm going to call him today after i call the insurance company. thanks man
*edit*
why when i click "new posts" i can't see them, it still tells me i have restrictions?
Old Dec 19, 2007 | 03:38 PM
  #4312
sloan70's Avatar
Hi...I'm new to the forum. My 2002 Maxima's sunroof recently started opening on its own. I'd be driving along and suddenly I hear the sunroof opening. This has happened three times in the last two months. Any help with this problem would be greatly appreciated.
Old Dec 19, 2007 | 04:11 PM
  #4313
spdfreak's Avatar
*edit*
Your not a donating member?
Old Dec 19, 2007 | 04:13 PM
  #4314
spdfreak's Avatar
I don't have a sun roof, but IIRC the switches are on the center console. You may have hit them accidently, or something is shorting out causing it to open.
Old Dec 19, 2007 | 04:45 PM
  #4315
NmexMAX's Avatar
dot dot dot ...
Sun roof switches are on the roof, next to the dome light. Try resetting it, do you have an owners manual? If not, download one here,:http://www.courtesyparts.com/nissan-...san-Maxima.pdf
read it, and see what it tells re: sunroof reset.
Old Dec 19, 2007 | 04:54 PM
  #4316
spdfreak's Avatar
Oh. Sorry for the mistake. I thought the two blank covers on the armrest were for the sun roof.
Old Dec 19, 2007 | 05:25 PM
  #4317
NmexMAX's Avatar
dot dot dot ...
Reset procedure re soonerfan:
http://forums.maxima.org/showpost.ph...postcount=3478
Old Dec 19, 2007 | 05:55 PM
  #4318
bigjoe87865's Avatar
Iv replaced my incabin filter... and im having a really really hard time getting the glove box back on...
the top right hand fastener is giving me a problem.... if i get the fastener inserted... then the bottom right wont get lined up... and iv been trying to wrestle with this thing for an hour and i wanna cry..... also the right side that goes under the weather stripping doesnt line up properly when the bottom does.
anyone have any tips for me?...
Old Dec 19, 2007 | 06:14 PM
  #4319
spdfreak's Avatar
Go inside, take a beer, and go back outside and work it through real slow, looking for what isn't letting it line up. Forcing it will only break something so take it slow.
You can always call over a .org member if you know of one in your neighborehood.
Old Dec 19, 2007 | 06:21 PM
  #4320
SoonerFan's Avatar
Cletus
