- brake fluid?..how often to change..
- oil capacity
- castrol syntec blend
- any one use royal purple?
- Summer Fluid Question
- Maintenance Gurus. Short Distance Drives?
- oil change
- tranny rebuild... question about metal shavings and tranny oil
- 15k oil change
- finally the lazy admin gets off his HICAS and makes an oil forum
- anyone use AUTO-RX in their max?
- VQ35DE new engine break-in - why 3750 for the 1st oil change?
- Warning about fitment issues of the Mobil 1 M1-105 oil filter on VQ30DE Maximas
- FRAM oil filter question...
- Engine Cleaning Additive?
- STP S6941 Fittment Issue in a VQ35 Maxima
- Nissan has discontinued the VE30DE - specific 15208-60U00 OEM oil filter.....
- Amsoil OIL filter help needed!! ASAFP
- Valvoline MaxLife Oil & ATF, Nissan Oil Filter
- OIl filter top by-pass valve. How important?
- Just hit 123456 and changed oil with a BIG filter
- Changing Oil Filter before Oil
- BlackStone Report: NOT good!
- Motor oil, does it play a big part in performance? yes or no ?
- First Oil Change
- 70K on my Max..can I switch back to regular oil from Mobil 1?
- Can I switch to synthetic oil at 58,000 miles???
- Best Oil for 2k2 6 speed
- K&N oil filters
- Oil change questions.....
- The Amsoil SDF-44, SuperTech ST3950 and STP S3950 filter do not work on VQ engines...
- Note on VQ35 Oil Filter Selection: VQ30 filters should cross reference....
- 3.5L Oil Filters Revisited
- How to flush automatic transmission fluid? What ATF to use? How to check the level?
- Engine Oil .....OMG help!
- 1st oil change
- Nissan Oil Filter vs. Others (ie. Mobil 1)
- How to flush automatic transmission oil and using Royal purple ATF....
- Help w/Tranny Fluid Change - Automatic
- Best Conventional Motor Oil
- Questions about Sythetic Oil Weights
- Synthetic Oil
- Just a little something for CFster (OIL)
- *12/30/04* Oil Spreadsheet-How do I take a sample? What lab? How to do more research?
- Just switched to Syntetic Blend
- Oil Changing question
- made the jump to sythetic
- Brand new 02 SE - Have initial oil questions
- AMSOIL API Certification
- 2001 Pathfinder VQ35DE problem!
- spark plugs and engine oil
- oil change
- Oil level very low
- Mobile1 -> I put my money where my mouth is...
- Royal Purple
- What Kinda Oil You guys Use?
- Synthetic Oil?
- Redline Oil
