View Full Version : Fluids and Lubricants
Pages :
1]
- 2021 Maxima SR
- CVT Fluid Cooler Cleaning and Diagnosis Procedures
- CVT fluid volume
- i30 oil dipstick reading
- 2005 Maxima Correct Oil Filter.
- Dipstick level changed with engine swap
- How many liters of CVT fluid? 2014 Maxima
- 2010 CVT fluid change
- USB stick
- Oil Filter Bypass Pressure
- maxima 99 flush or full drain at 450k miles?
- K&N fanatic.
- What Aackshun Uses
- Help with CVT please!
- Who uses Royal purple?
- 98 radiator flush/fluid change
- $12.70 Pennzoil Full Syn
- I'm new to the 7th gen
- Sunroof Lubricant
- Changing brake fluid Help
- What oil should I get for the next oil change?
- Coolant/anti
- Napa and Purolator Oil Filter Review
- Nissan Genuine Lubricants and Fluids: Explained
- 2001 Nissan maxima 6 c antifreeze issue?
- 2002 se liquid leak
- what type grease for links?
- Coolant 999mp L25500p for a 2017 model
- 2013 Maxima Oil Change
- High-Tech Pressurized Brake Fluid Changing System
- '97 Auto Transmission filter change
- oil issues
- Best super coolant?
- Which color coolant is best?
- tranny fluid
- 300,000+ mile club question: fluids...
- Fuel treatment vs Motor treatment additives? Are they same?
- Amsoil Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid
- Maxima sitting for over a year
- anyone use 75W-85 Nissan MT fluid?
- Any alternative to K matic fluid for a auto 5 speed?
- Engines and oil
- High oil level?
- 1990 Max tranny fluid leaving trail
- old member returning with a new question about MT
- what type of motor oil is recommended for my maxima?
- Brake fluid ok to talk in here?
- Fuel system
- 2009 Maxima rough idle and loss of power
- Clutch Fluid Replacement
- Dipstick Issues
- 2001 nissan maxima se.where should I buy my suspensiom
- Pennzoil Synchromesh MTF
- diesel oils in gas engines
- Oil and Other Fluid Extractors
- Ticking Lifter Noise - The Easy Fix!! All Generation
- Help! snapped coolant lines near heater core
- 1995 auto tranny fluid
- What kind of fluid for '03 clutch master cylinder?
- Anyone here tried Boostane in their car?
- Will 10w 40 be best
- My first Nissan - oil filter question
- What is best transmission fluid for Nissan Maxima (Infiniti I30) 97?
- gear oil additive? need recommendations
- Fuel additive
- radiator fluid
- 91 and oil
- amount of oil
- 2004 Maxima Oil Change Recomendations
- coolant flush,transmission flush, and oil change
- AFT fluid in CVT HELP
- AT Check light comes on intermittenly...
- Manual Trans Fluid?
- power steering leak
- valvoline gear oil-best choice?
- 05 manual transmission fill plug picture
- Air Conditioning Specs 5th Gen
- Good brands synthetic oil?
- 6th Gen fuel filter
- water pouring from behind motor
- Filters
- What oil would you suggest for a 280k 97 maxima
- This may open a can but, Why Matic K only?
- Which oil does your engine like?
- Can i use automatic transmission fluid to put in my power steering?
- 99 max 130k best oil and oil filter
- Motor oil
- Anyone have experience with BG products?
- drain and fill transmission fluid
- what kind of transmission fluid for a 2001 manual
- 2012 Maxima oil change question
- Transmission
- mixing of atf fluids?
- Question
- Seafoam review
- Why is my engine oil leaking?
- Maxima 1998-Oil change necessary every 3000 miles
- Nissan Maxima 1998 What type of engine oil
- Fuel Tank Additives
- Marine TC-W3 two stroke oil as a gasoline additive - NEW
- Synthetic!??
- Extreme noob question (easy points)
- Brake fluid for a 4th Gen
- Lucas in 5 Speed 01 Maxima?
- ATE Super Blue Racing Brake Fluid?
- Oem 15208-9e000 filter discontinued?
- New OCI with Napa 1182 oversize filter
- Running Seafoam through PCV between oil changes?
- Oil Filters - Wix or Purolator Pure 1's?!
- Oil issues
- Another "What oil filter" thread
- a/c compressor cycles too often
- Power Stearing Hose
- 4th gen auto tranny changing differential and/or transfer case fluid
- ZDDP Additive - Can we reduce concentration?
- Cheap sites to buy Matic D ATF?
- Cvt question
- My latest oil/filter change - 2011 Max.
- FLUID LEAK IN FLOORBOARD
- please help ATF gone wrong
- Need help with oil search
- Engine Oil and Gas Tank Additive and Conditioner: Does this work?
- Oil recommendation
- I used wrong coolant
- Prestone silicate, phosphate, & borate free
- Frion Leak
- can I use Majic S fluid on 97 maxima
- Nothing in life really is free
- ATF drain and fill question
- Royal Purple HPS--good idea to use??
- Redline D4 ATF?
- Oil in oil pan
- Anybody used AMSOIL BRAKE FLUID (DOT 3)?
- Is this enough fluid for a drain & fill?
- 167k miles, switching from/types of synthetic oil?
- Blackstone analysis Maxima VQ35DE - 227,500 miles
- Interesting read..
- Green Earth Technologies G-Oil Synthetic
- With all respect , why Amsoil oils seem too shady ?
- Mashimoto radiators
- QUESTION: Oil burning on a 5gen
- Thicker oil for summer
- Radiator Problem!
- Needing extra oil between oil changes?
- Redline MT-85 75W85 GL4
- Factory oil
- shell 5w30 fully synthetic motor oil
- Seafoam causing precat and heated O2 sensor codes?
- Great oil analysis thread on my350Z
- Servicing CVT Trans
- 01 Nissan Maxima 20th AE - Switching to F/S oil
- AMSOIL Reintroduces Ea Oil filters
- Mobil 1 Extended Performance Oil - $4/Qt
- "Three months or"
- Safe to switch to full synthetic after 40k miles?
- How to change power steering fluid?
- Stupid question - Synthetic mtx with dino engine
- Steering fluid... too late?
- Bars Leaks?
- Lucas Oil Stabalizer to help cure valve tap?
- whats your favorite oil?
- Sea Foaming question and oil change?
- Radiator leaking?
- oil for break in
- How much oil does your 3.5L burn?
- 100k tune up
- for those that change their own oil
- What engine oil is recommend for our 6th max?
- USA Castrol GTX is apparently a poor dino oil choice?
- the question of oil grade... again...
- Penzoil Ultra
- Brake fluid
- My Maxima started smoking!!!
- Infiniti I35 Sport power steering fluid issue.
- Oil help
- Should I only use Synthetic?
- What gasoline you drive?
- non-aqueous propylene glycol
- use this oil. all the girls will want to ride in your car.
- What Specs Should Her Oil Filter Have?
- castrol gtx high milege any good?
- high miliage oil
- oreilly deal
- Post info about your longest Oil Change Interval (OCI)
- SeaFoam Trans Tune
- 98 SE auto Transmission Drain and Fill advice
- Would like some advice on oil change/maintainence
- Lucas Synthetic oil
- How To Reduce Knocking/Pinging/Clinging?
- Gear oil...Help!!!!
- What weight of oil should I change to?
- Oil Change
- Oil Filters
- Any body places to grease?
- Gas Grade
- OIL CHANGE FOR A 2005?
- Auto-rx Coupons
- How to change Automatic Transmission Fluid
- Pennzoil ultra
- oil analysis for Nissan Ester Oil
- VQ35 Oil Selection
- What grade of engine oil should I used?
- Burning Oil?
- Who's got experience with Castrol Edge?
- Oil Analysis for Built Motor result
- mobil 1 deal @ advanced auto parts or autozone
- How Much Brake Fluid
- pennzoil platinum oil
- Fluids For 5th gen
- What oil should i use on my 2000 i30
- Royal Purple
- Shell Rotella T (ZDDP)
- 5w-20, what happens?
- Oil Deal! - Castrol Edge + Purolator Pure1 for $2.66 Total!
- Just Changed Oil, But May Have Made Mistake - What Now?
- Walmart supertech 7317 filter vs Mobil 110 and Supertech Synthetic
- Filter Alternatives
- Nissan Esther Oil??
- Oil Cleanup - How do you clean your Oil change materials?
- any recommendation of oil for 123K with oil burning?
- switch back & forth from synthetic to regular oil?
- Castrol Synthetic or Castrol Edge Synthetic??
- HOW TO: ATF Drain and Refill
- Due for an Oil Change in 1500 Miles
- YOUR CHOICE IN MOTOR OIL
- Synthetic gear oil
- 2004-2008 Oil / Filter
- M1 EP test results..
- CAN AMSOIL REALLY DO THIS??? Please share your Amsoil stories...
- Changed to Amsoil GL4 + Amsoil 0W-30 and got 35 mpg!
- Mobil1 deal
- all castrol oils $12/5qt at walmart
- First Mobil 1 5W-30 synthetic oil change
- Shell "Nitrogen Enriched Gas" ?
- mobil 1 ATF?
- Best deal on redline mt 90 trans fluid?
- quick Q about oil change
- Summer Gas Blend & Better MPGs
- Best engine oil to use with 167Kmile Max 97
- recent price of fluids (tune-up)
- Mobil 1 on sale at Costco
- how much oil do I need?
- NEED a simple answer??
- Greased Lightning (synthetic magic grease!)
- Reserve Fuel Capacity 02 SE (U.S.)
- Motul Products
- What Exactly is Nissan Matic-D Fluid?
- diff. oil visc for a 3.5 that burns oil?
- Lube Gard AT Protectant
- NPN Filters
