View Full Version : Fluids and Lubricants
Pages :
5]
- Ok mabye a dumb Q..... but....
- cant decide between oils
- can you use dot4 brake fluid in the clutch lines?
- Nissan Coolant Life Expectancy
- cant fig out what the problem is
- Recommendations on Power steering fluid w/ stop-leak and conditioner?????
- Tranny Flush/????
- Octane cocktail
- My 2K2 is drinking oil
- Seafoam/brake booster/oil change q...
- Has anyone flushed there antifreeze yet??
- Where to buy MOBILE Oil Filter ?
- ATF change
- DEI Radiator Relief vs. Red Line WaterWetter...
- Royal Purple Gear Oil
- From 3750 miles to 5000 for an oil change?
- mobil 1 Oil for maxima?
- Octane Number and what it means
- Tranny pan
- Auto Rx and new rattle?
- Need advice on oil and oil filter
- interval with new mobil 1 oil?
- Will changing back to dino help my leak?
- Tranny fluid color???
- power steering fluid vs. ATF for power steering
- Gurgling noise on acceleration..
- Anyone else running synthetic and what miles are you at?
- Changed Transmission Fluid
- what tire shine do stealerships use?
- Anybody heard of TORCO?
- Mobil 1 Syn vs Quaker State Q Syn????
- anyone run into trouble after using SEAFOAM ???
- what brake fluid do you use??? need some help in deciding..
- what if i overfilled the motor oil?
- Oil Change
- How to bleed brakes?
- For you that use 93+ octane fuel...
- AMsoil vs. Mobil1 (repeated)
- Temperature of firewall higher after coolant flush
- New Oil Filter Type Coming Out?
- question about chevron with techron fuell injector cleaner
- flushing transmission
- Which oil???
- opinions on new M1 synth.. 15K?
- How much Motul?
- how much brake fluid do i need to bleed the brakes?
- How to dispose of used tranny oil.
- Changing from DOT3 to DOT5
- Redline MT-90 and Motul DOT 5.1
- trouble starting after oil change
- Amsoil filter question...
- how often are you supposed to change your mt tranny fluid?
- Lucas ATF additive
- how to flush cooling sys and brake sys
- Q
- Marvel Mystery Oil... on gas tank?
- When should i check my oil??
- oxygenated fuel???
- 5 spd gear oil
- mobil oil
- Redline MT-90 Fluid - Does it REALLY work?
- Can I use synthetic oil in my new MAX ?
- Changing trany fluid, when, which, and how many qts?
- Oil thickness advice for -10F all the way to 102F
- Anyone changed manual trans. gear oil?
- Amsoil Power Foam: Any experience?
- Octaine boosters and fuel additives...
- Interesting Oil Advice from Dealer
- Synthetic Oil
- Changing to synthetic oil after 125k miles?
- A different Auto-RX ? -Filter changing
- Does myoilshop.com really take this long to ship?
- Synthetic gear lube
- 96 Tranny Oil Change.
- What Brand of Gas do you use?
- Maxima 95 Automatic Transmission Refill
- 01 Max AE 5sp MTF?
- oil
- Fist Oil Change Questions for 05 Maxima SE
- 4 quarts of oil
- Time for an Oil Change....
- shell motor oil?
- i want to put in new tranny fluid and filter
- Aussie Oils
- Deal on Mobil1 filters
- OEM A/T fluid
- Veruspeed Engine Oil By Nismo...
- maintenance
- Lucas oil with GTX any thoughts?
- Best type of oil
- What type of oil should be used?
- tranny problems
- 99 5spd check trani fluids where??
- changing gear oil on 99
- Does amsoil make a GL4 compliant synthetic manual transmission oil?
- Gaskets
- Transmission: Passive Drain or Full Drain?
- Synthetic Oil and Mileage
- Oil change tio
- 99 MAX(Manual Trans Question)
- New Mobil1 EP on shelves at local AutoZone...
- Mobil 1 for under $4 /qt
- another good seafoam experiance :-D
- Pics of Auto-Rx Rinse Cycle Oil!
- Oil change on '05 Maxima SE
- Mobil 1 Supersyn Extended Performance??
- Losing engine oil
- When to start using synthetic?
- synthetic atf worth it?
- Mobil 1 15W-30 Full Synthetic ??
- Differential fluid
- Amsoil Users Step In!
- 2005/General Newbie Q's
- Need To Change Oil. Need Ur Help, Come On In
- 5w30 or 10w30, which one do you use?
- Oversized oil filter for VQ?
- best oil for oil change??
- cannot find how'to's on replacing power steering and alternator belts
- Oil Change Interval
- Automatic Trans Fluid Capacity?
- cleaning engine oil
- Do I need to replace filter and gasket while changing ATF?
- A Different Twist on Oil Analysis -- Particle Counts
- Cleaning tranny pan, magnet, screen, etc.
- ? about synthetic trans fluid
- switching grades frequently
- need help
- lucas oil products
- Frozen freakin windshield washer
- Popped head off bolt - Now what do I do ?
- Power steering pump leak
- Changing Clutch Fluid?
- what causes drain plug to leak?
- New Line of Mobil-1 Oils Just Out!
- JWT oil pan spacer adds 1Qt. capacity...
- overfilled engine oil...what now?
- Windshield Wiper Fluid
- When to flush trans? What to use?
- few questions regarding pwr stearing/clutch/brake/coolant fluids
- Slick 50 - Transmission Repair
- ps fluid - leak?
- Anyone know any links on how to add seafoam for my car?
- Cost of synthetic oil not worth it
- 5 Speed Tranny Oil Change?
- Fuel Power, Fuel Power, Fuel Power
- GL-4...Redline MT90 vs AMSOIL Marine
- Syn. Oil Switch Plan... good approach?
- Oil question
- 10w-30 users, step in
- Anyone use Auto-RX engine cleaner?
- Replace Brake fluid
- Is it true?
- auto tranny fluid change or not?
- Seafowm how much
- Seafowm how much
- Synthetic Oil = Bad for the Maxima???
- Sale on Toyota Red Coolant
- High Glycol level in Coolant
- Atf Flush
- Did my first Oil Change...Ever!
- Someone help w/ seafoam please...
- Lucas oil Transmission Fix
- Oil filter part number for 98 I30
- Seafoam just after putting Techron?
- LubeGard black bottle
- 16400-0M200 fuel filter
- Mobil 1 vs. Amsoil
- anybody run 0w30? if so where do you live?
- K&N Filter Test
- NAPA oil fliter ?
- Is the K&N oil filter worth the $11
- Manual Transmission Gear Oil Type
- Is it ok to switch to synthetic? any benefits?
- purolator oil fliter any good ?
- Place to buy Redline.
- M1 0w30 and M1 ATF, wow
- 112k atf flush okay to do?
- Engine Restore etc...
- suspension fluid/oil
- Auto Fluid Change At 54k?
- should i use redline for notchy feel?
- What kind of oil for winter
- Lubeguard comment
- Oil Question
- Bleeding clutch quick questionl.
- quick question about chevron techron
- changing oil soon...got a question
- Power Steering FLuid
- Changing oil tomorrow...
- Mobil 1 Atf
- Replaced clutch, but...(GL-4/GL-5 question)
- ATF Service on Max
- Power Steering flush info???
- Manual Trans Fluid
- My next oil change (Question)
- Superchargers must be good for VQ30's
- FI cleaner...not the stuff you pour in the tank
- Power Steering and Coolant Fluid change and fill
- Seafoam. The 8th wonder of the world?
- Completed ATF Flush with Mobil 1 ATF...
- Mobil 1 results...opened my valve covers today and...
- Matic
- thoughts on synethic and oil?
- Low Oil Pressure?
- ATF Flush tomorrow -- Mobil 1 ok?
- Mobil 1 Filters
- Switching between syn. oil & regular oil
- 1st OIL CHANGE Complete report!
- did I syn too soon?
- Oil Type Question
- Gear oil question.
- People who are sick of hearing about seafoam, and all its BS, step inside
- Using Seafoam on an Auto-Rx treatment
- what do u think about redline power steergin fluid
- Marvel Mystery Oil (gas additive) make your engine knock?1
- Mobil 1 users, come on in!
- 3,500 miles Oil Change.
- engine oil flush liquid
- finally switched to amsoil ATF.
- Seafoam Transmission Lube
- draining antifreeze procedure question
- restore
- Having transmission flushed tomarow...
- where to buy chevron techron for good price
- Fuel system and tranny flush..
- Found Royal Pruple for $5/ quart
- Higher Mileage Oils? Worth it or Not?
- Lucas Additives?
- Wix oil filter any good?
- Where to buy NIssan Trans Fluid
- TX7 anyone know anything about it?
- another seafoam question???
- What kind of oil do you use?
- OEM Oil Filter Question (Part # 15208-9E000)
- Best Fuel Injector Cleaner????
- Oil Filter part number??
- what kind of manual transmission oil are we suppose to use
- gettin new clutch put in....what type of tranny oil do i need?
- Amsoil Tranny Fluid
- what oil should i be using!
- Rislone Engine Treatment
- When do you pour in BG 44k?
- Synthetic or Dino?
- Ruff Starting
- trying to find redline mtf....
- Best oil?
- should I switch to a high mileage oil
- Where to get Seafoam?
- PEPBOYS MOBIL 1 Synthetic Motoroil - $2.33 a quart
