View Full Version : Fluids and Lubricants
Pages :
4]
- BG Air Intake Cleaner
- 6qts of pennzoil Full synthetic motor oil + oil filter for 2.94
- 5w-40 syn
- anyone know where to get amsoil mtg manual tranny oil
- Brake Fluid Problem
- i have found a nice thread for oil filter comparisons take a look
- Damm MPG
- Those who have used auto-rx...
- Does Premium Give Better Highway Mileage?
- looking for cheap oil filters for change intervals of 5000 miles in NY...
- will lucas 75/90 Gear Synthetic Oil work smooth
- auto-rx cold starts
- Do you use Mobil 1?
- volunteers needed -- cold flow data
- Question
- how to read ATF level on 97??!!
- Switch from syn back to dino
- Correct Oil Weight..
- How Bad is This?
- GM Transmission Fluid In Our Tranny's
- Amsoil Vs. Redline Manual Trans FLuid
- cheap oil
- latest oil filters
- learned my lesson
- My recent experience with switching to synthetic oil.
- Gear oils -- GL4/GL5/MT1?
- Amsoil MTG 75w90 Tranny Fluid...any experiences here?
- Oil consumption or not being level during change?
- Good or Bad?
- AutoRX discount code inside
- What grade of oil for mostly city miles?
- Price Difference Between Pennzoil SYN, and Mobil 1 SYN ?
- One more vote for Amsoil...
- Redline Water Wetter
- What was the most gas you ever pumped into your max?
- Atf Fluid
- Royal Purple: GL4??
- Morning lag ...
- Door Lube.
- Wasn't parked on level ground...
- got a newbe question...
- What's the secret to checking the oil?
- Should i change gearbox fluid myself or worth it to have done?
- oil change ... please help me (97 max)
- Adding Auto-RX to powersteering, transmission...anyone done it?
- DexronIII(H) is wonderful!!!
- Brakes and Brake Fluid
- Mobile 1 oil in 6th Gen
- oil additive cleaners....good or bad?
- Tranny fluid question
- Switched to Valvoline....negative effects
- Finally switched
- Question about AutoRx..
- changed my 6-speed gear oil today...
- What GAS do you use???
- How much Gear Oil for 95 GXE?
- Anybody in here use German Castrol?
- PepBoys Oil Coupon question
- Affordable bypass filter?
- Best Oil For VE In Winter, With Toyota Filter???
- Shifts as smooth as butter.
- Best Oil For VG30E Max
- 0w-40, answers needed quick
- Oil additives
- Another Oil Question, Oh My!
- Need help with synthetic oil.....
- ATF: drain & fill w/ dropping pan or do I have to flush?
- Have you tried this yet?
- valvoline synpower motor oil?
- 00 maxima, brake fluid + coolant
- GL-4 not avail. @ dealer
- Power steering fluid replacement
- How bad is 87 for our cars
- Mixing synthetic oils?
- 03 6speed Transmission Fluid Change, Dealer Or Local
- Blackstone results!!! Need help!!!
- Octane Booster
- Switchin grades of oil Winter/Summer ?
- ATF change question not asked before
- Confused regarding what oil filter I should be using. (87 Maxima VG30E) Need Help.
- FP and LC
- UOA, SuperTech 10W30 SYN, '99 72kmi, 3k OCI
- Synthetics, risky or not
- Motor oil in manual tranny?
- Flush or transmission kit?
- brake calipers
- Where to get Amsoil ATF
- Nippon oem oil filters
- Atf Uoa
- Best Auto Trans Oil for 2001??
- Fill up Now
- New Mobil 1 Filter?
- atf in a 5spd???
- Question about changing MT fluid in a 5th Gen...should I drop the pan?
- 91, 93, & 94 octane. What would you choose?
- FUel injector cleaner?
- Bigger oil filters
- Oil Filter
- Topping off my Gear Oil
- Viscosity choice
- Conventional and Synthetic ATF blend
- waste oil
- kendal oil
- ARX/flush for gen 4 tranny
- Delo in a VQ?
- Type K Transmission Fluid????
- Using Kerosene for a Motor FLush?
- Engine restore product
- Recommended gear oil for frequent drag racing?
- Changing Oil in the MAX for the 1st Time
- $ Redline MT-90 $
- Oil Level Questions
- New Mobil oil filter anyone use it yet?
- Gas Prices
- OEM Filter
- Basic Motor Oil Question
- wuts a running price on a qt. of oil?
- longest interval between oil changes
- Changed manual tranny gear oil last week, now having issues.
- synthetic blend question.
- Acetone In Fuel Said to Increase Mileage
- Crystal Clear has ethanol in it??
- Changing Front Brake Pads, Do I Need To Bleed The Brakes?
- IS there a shelf life for unopened oil ?
- Ses-too much octane?
- Question on Castrol Syntec ATF and Amsoil Synthetic ATF
- Switching Octane
- oil filter wrenches?
- Going in for first oil change.
- Cleanup Question
- Changing the brake fluid...stuff i bought is a different color
- which grease for battery terminals?
- Seafoam
- oil leak repair question
- Help... Diagnose me..
- VOA for SuperTech Synth
- Best place to get Amsoil?
- Conklin Oil
- can i mix 5W with 10W
- help on ATF for a 97 maxima..
- Oil Filter in 5.5 Gen w/ HLSD
- NEWS FLASH: "Automobile experts says it's OK to use regular instead of premium"
- Conventional or Synthetic?
- quick help w. auto tranny flush
- Amsoil Synthetic Universal ATF
- H specs for Dexron III
- Anyone use 0W40 Mobil 1 synthetic oil?
- Mechanic - Tranny Flush
- oil filter
- Basic Maintenance, 15,000 miles (15K)
- Changing oil and need some advise on grade
- gas stations in NY
- The best way to switch to synthetic.
- Switch to synthetic?
- 10w40
- MT-90 VS Amsoil!?!?!Which One for tranny
- Altitude + Octane
- good engine/tranny oil
- thoughts after tranny flush
- Tranny oil drain and fill
- Ten Myths About Synthetic Lubrication
- The Low-Down on High Octane Gasoline
- transmission fluid level
- oil filters on ebay
- Can I use Mobil 1 Synthetic 75W90 Gear Oil in my transmission?
- F.R.E.E. Engine Additive. Thoughts???
- fuel filter
- Why does the dealer have to check AT Fluid?
- Redline heavy shock proof oil
- Spark Knock beneficial?
- Should I switch to synthetic oil
- oil change: 99 auto w/ 99k miles, what oil to use?
- Switch to synthetic 0W30 oil
- Opinion: redline products
- GC in VQ
- Nissan Oil Filter or Nippon?
- How much fluid for brake flush?
- Chevron Techron
- quaker state oil
- power steering confusion
- Er need some advice
- Where to get mobil1 filters online (canada)?
- synthetic or regular oil
- ok to use 10W30 and 5W30 back and forth?
- Quick question about Tranny oil
- Brake Fluid = Brown, Brake Fulid = Clear
- Top Tier Gasoline
- 2K2 Radiator flush how to......???
- synthetic blends
- Additives? TRIBOTECH IJP or Bi-tron any good?
- transmission flushing questions
- Octane-will there be a noticible difference between...
- What oil type/brand do you use?
- Coolant Temperature
- royal purple???
- Mobil 5000 oil
- Mobile Clean High Mileage
- Seafoam and long distance
- Maintenance List?
- Should I or Shouldnt I
- started to proceed with first oil change....
- VQ35 4th gen (Synthetic)
- gas cap open in car wash, help
- too late to use synthetic motor oil?
- API Service SM Motor Oils = GF4
- SeaFoam right place?
- Bleeding PS System(fluid)
- Amsoil antifreeze?
- 104 octane booster...
- Crush washers needed for M/T fluid change?
- Which brake fluid to get?
- Power Steering Fluid Clarification
- Switch to synthetic tranny fluid??
- I'm ready to go 15000 intervals (Mobil 1 Extended)
- Can't get brake booster off? Seafoam suggestion.
- Torque Converter
- First oil change.
- Tranny and Rad Flush
- price of amsoil vs mobile 1
- GTX-start up + LUCAS = BAD?
- High Mile Max Questions
- anybody running Mobil 1 Extended Performance Oil?
- Importance of using a genuine Nissan oill filter
- 89 octane
- Kinda O/T but Seafoam in Camry
- Which is the best tranny fluid that has the most "material" in it
- Is anyone here running Amsoil at 35K or 1 year change intervals?
- freon??
- About to change the oil, but...
- Best Brake Fluid Brand/Type
- Lucas - To use, or not to use
- Informative writeup on on 20 different oil filters
- Which oil filter?
- how the f*ck do i change my oil pan seal
- My Oil Shop = no more discount?
- Online store to buy mass quantities.
- 3rd Gen Oil & Oil Filter
- mobile 1 15k oil after 7k miles
- Nismaticj????????????
- oil pan seal change
- how do i disconnect the abs actuator in 1998 max?
- 83,000 miles just changed to Mobil 1
- changing brake fluid
- What a stupid place to put the oil filter!!!
- Mobile ATF
- Auto Tranny Flush Question
- Wanna use amsoil
- Switching To SYNTHETIC
