PDA
View Full Version : Infiniti I30/I35
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. Wondering which o2 sensor to replace
  2. Halo headlights on i30
  3. Newbie purchasing used I-35... help me out.
  4. 2000 i30 and 2002 i35
  5. dimmer not working
  6. Maxima v I30 transmission question
  7. 2000 i30 headlight swap to hid
  8. Weird car problem
  9. 200,000.
  10. Can't find clear side markers anywhere!
  11. 2001 i30, squealing sound at times.
  12. Best Resonator for my I30?
  13. 2000 i30 Radio not working. Fuse?
  14. running power wire to amp location
  15. Koni Yellow Stiffness Setting
  16. Cefiro Dash Kit with single DIN stereo?
  17. '01 "blu" eye-30 retro-ish projector job
  18. Engine pinging around 2000 RPMs
  19. Who here has replaced the factory NAV / Bose with Aftermarket? Lets see some pics
  20. I30 owner needs help about exhaust and rims
  21. Quick Question About Clearing Headlights
  22. i35 Steering wheel control
  23. Injen intake placement
  24. Plastidipped My Grill
  25. Maxima MT mounts on i30?
  26. Service engine light blinking I30T
  27. Let's see here who has...
  28. Where Can I buy Plastic Rivet Fastener for my trunk - Infininiti i30 99
  29. cant seem to figure it out
  30. 99 Infiniti I30 axles
  31. Advice with Tire Size??
  32. Opinions on wheel?
  33. Who has replaced the radiator?
  34. Rear Turn Signal Bulbs Driving Me Crazy (What Kind Is It?)
  35. low wiper fluid light...
  36. Will 40 Offset be OK?
  37. Anyone parting a i30?
  38. Just bought an 02 I35 with Nav, need help on Aftermarket radio
  39. LED Taillight Install?
  40. Lets see those i30/i35's!
  41. A few questions for my 2002 I35
  42. 96 I30 won't start but cranks all day.
  43. Infiniti Wantabe?
  44. Power Valve Assembly repair VQ35DE
  45. 01 i30 and an i35 grille?
  46. Car hard starting questions???
  47. TCS switch/light
  48. 2000 Inifiniti i30t AC Relay
  49. i30 HID swap
  50. I35 Suspension Setup
  51. "ghost" revving?
  52. questions about both i30s
  53. looking for a cold air intake...
  54. 2003 I30 Stalling, Not Starting, Rough Idle, Etc.
  55. AC and Heater
  56. Installed Progress Technology RSB on '01 I30
  57. Different A32 I30 grilles, blacked out and retrofitted headlights and fogs, and more!
  58. suggested HID kit for '01 i30?
  59. Give me your opinions...
  60. polyurethane motor mounts
  61. Ghetto Short Ram Intake
  62. HID light sometimes not working
  63. eibach pro kit
  64. Binding Ignition Lock
  65. The inside of my ride
  66. help me solve my headlight problem
  67. URGENT: 1999 to 1997 I30 Engine Swap ECU
  68. I30 Guru's
  69. tire question
  70. headlight problem
  71. 2001 infiniti i30t amp installation
  72. In Japan!!!
  73. Ebay headlights?
  74. ABS or Carbon Creations CF hood?
  75. Battery constantly dying
  76. Pic Request: All-Weather Mats
  77. Help, I need a little assistance. AGAIN
  78. i35 6speed swap??
  79. Time to toss my spare tire cover ^^
  80. 2000 I30 Stock Exhaust Diameter?
  81. 99 i30 / 99Maxima Contol Arm
  82. Transmission TSB - Is this the fix?
  83. What Do I Need to Fix P0158?
  84. I35 parts
  85. HELP: *Axle Nut Keeps Coming Loose*
  86. The bleeding continues..
  87. Hard Starting...
  88. How much is she worth?
  89. 2000 I30 Holding 1st Gear on WOT
  90. 02 I35 ses light dose not work
  91. problem with Progress rear sway bar width
  92. Oh Geese, This is not my month AT ALL please help..
  93. shifter knob for 4th gen max or 1st gen i30 5 speed
  94. 4th gen steelies on 1st gen i30
  95. Car vibrates and becomes louder
  96. '04 Center Console fit an '01??
  97. Question about a 2000 I30t
  98. Fluctuating Oil Temperature
  99. Spare Keys
  100. NO START! URGENT HELP!
  101. Laser Shifter Install
  102. Close call
  103. Autech Kitted A32
  104. Need advice
  105. Where to buy I35 performance mods?
  106. jingling noise from under car
  107. 00-01 I30 DRIVERS SIDE HEADLIGHT
  108. Bad struts?
  109. Transmission issue? Sensor?
  110. Can someone guide me in the right direction.
  111. What do you make of these Ebay Cefiro headlights?
  112. Proud new I30 owner
  113. 6th Gen Maxima Rims on a I30
  114. GI: A32 Calendar
  115. Stance Nation I30
  116. SWEET RIDE! :)
  117. Mirror LED pics and video
  118. Navigation mod (need advice)
  119. In need of a front passenger seat..99 Infiniti I30t
  120. Installed AE Foglights A33 01 I30
  121. adjusting shift cable
  122. 98-99 Headlights in 96 I30
  123. No one can figure it out! Suspension issues. Please advise!
  124. Best corner light bulb
  125. SYCEFIRO!
  126. Looking for parts
  127. Planning next upgrade (sub)
  128. Please help quick!
  129. Transmission pan gasket
  130. Sunshade stuck in the up position
  131. AUTO power window not working on driver's side
  132. Transmission problem?
  133. Corner lights
  134. 97 i30 headlights
  135. 97 i30 tails for sale
  136. Cefiro owners..
  137. HID fog lights installation (sticky?)
  138. Question on drop springs
  139. Key fob window roll UP feature ???
  140. Reverse lights LED
  141. What is this radio connection?
  142. Thinking about my Gpas I35
  143. Teaser - BCR Coilovers and Ionic Dynamics Install
  144. What do I need to buy in order to give my i30 a tune up @ 175,000 miles
  145. Maxima Mirrors on an I30?
  146. Red Headed Step Child to the I30
  147. Hard Question (electrical)
  148. 2000 i30, SLIP and TCS lights, gas smell, cant drive pass 20 MPH
  149. SES p2135
  150. Battery Buffer
  151. front end project 1998 i30
  152. Mirror LED Mods?
  153. My I30 build
  154. Rear window trim
  155. What are the symptoms of a key that is not programmed to a car
  156. HID fogs
  157. Brake Problems
  158. A/C Cooling Intermittently
  159. I30 Fog Lights: Terrible Light Output
  160. front end pics...painted everything
  161. Gauging Interest for VIP Front Tables...A33
  162. quick leather repair
  163. Sound dampening
  164. 2000RPM whine has me stumped
  165. Feniex Flashers on I35 (Short Review and Video)
  166. Tokico HP + Eibach Pro Kit Review
  167. Best LED wedge bulbs?
  168. Anyone got aftermarket exhaust?
  169. Strange "springing" noise from transmission
  170. Oil leak
  171. Painted Engine Cover (Color Matched)
  172. I35 2003 question
  173. i30 shake on highway
  174. Quick Question!
  175. Brake Pads
  176. gen 1 illumination issue
  177. So i35 suck overall?
  178. Rear Ended on Saturday :(
  179. Need advice with sub
  180. Front Lip for I35
  181. Parking light issue
  182. Quick quick?
  183. SoCal Maxima is up and running
  184. 5th gen window vent shade
  185. How to remove the dash trim pieces...
  186. Bulb size interior spot/directional light
  187. Knock sensor replacement on i35
  188. Cefiro Headlights on I35
  189. Carpeted Floor Mats
  190. WTB: I30t BBS Centercaps
  191. Is looking for a Front Cover(bra)for my 2000 I30
  192. Type of oil to be used
  193. Tires and wheels....4 sale
  194. WTB I35 Wheels
  195. 02 I35 WONT CRANK :o(
  196. Noise in engine
  197. Interested in mod, need advice
  198. Faint burning plastic smell?
  199. Possible GD on CF I30 hoods.
  200. 2000 Infiniti I30 with rough idle . . stalling . .so confused.
  201. i30 wont start
  202. Yellow Foglight Capsules
  203. Really bad gas comsuption
  204. 2002-2003 I35 ECU compatible?
  205. 2002-2003 I35 compatible?
  206. I35 HID Fog Conversion
  207. H.I.D. Bulb Replacement
  208. Ignition Coils & Fuel System Issues
  209. Infiniti i35 / Nissan Maxima Vapor Canister Purge Valve Replacement
  210. Do the 96 I30 fog lights fit on 99 I30?
  211. Does 96-99 maxima fog lights fit on 99 infiniti I30?
  212. Fog Light Mod Help?
  213. I35 Dash/Cluster/Climate/Clock Lighting Help?
  214. I35 DRL Bulb Size?
  215. I35 Lowbeam bulb replacement help?
  216. Leather Kits for the I30 01-04
  217. Difficult to change I35 headlight ballast?
  218. Are these bulbs legal?
  219. I35 Foglight With Highbeams???
  220. Group Buy Discussion for 1st gen I30 Body Kit
  221. Will these headlights work effectively?
  222. Fog light and High Beam Headlight Help?
  223. Automatic Dome Light Problem !
  224. Headlight Help!
  225. Cattman Cold Air Intake
  226. Whine/Rumble noise at specific RPMs
  227. quick question glass pack
  228. I35 Heater/Blower Grinding
  229. Are the interior lights of an 02 I35 compatable with those of an 03 Maxima?
  230. hid seating in cefiro housing
  231. A32 I30 with R34's, not Cefiro's?
  232. I35 Straight Pipes Help?
  233. Random Misfires, Cam Pos Sensor, and Bad Ignition Coil - Please Help!
  234. Anyone down to help?
  235. Anyone know if these headlights will fit?
  236. O2 Sensor, Direct Fit-Color Coded or Not?
  237. test pipe vs cat..down pipe
  238. P0138 Code-ECM reprogram?
  239. Automatic Climate Control: How to "force" the AC on?
  240. Anyone know where to buy a splash gaurd?
  241. About to join the I35 club
  242. Transmission trouble
  243. Whirring noise before startup
  244. HOW-TO: Fixing the 98-99 center tail light bulge
  245. a32 on Coils: how low will it go?
  246. Anyone know whose i30T this is?
  247. Anyone know whose i30T this is?
  248. corner lights (96 i30)
  249. Maxima Forums listed as Attack Site by Google?
  250. 18" G35's, What size tire? 2k I30
