PDA
View Full Version : Infiniti I30/I35
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. Air Bag Lite Flashing ! ! ! ! ! ! ! ! !
  2. Has anyone done an A33 6MT HLSD swap? (I am the mod. If repost- sorry)
  3. Installing I35 grill on I30
  4. Semi-Detailing Pics
  5. rear end q's?
  6. Help me mod my A33 I30
  7. double pop-out draw modification
  8. Rear Turn Signal Bulbs?
  9. Trunk not opening
  10. feedback on wheels
  11. 5 Spd. Swap DONE!!!
  12. dOES ANYONE KNOW WHERE I CAN BUY CHROME DOOR PILLARS FOR AN 03 INFINITI I35
  13. Shaking @ high speeds
  14. Replacing Stock Velour Seats with Leather Seats
  15. I35 stock HID Kelvin rating??
  16. Changing Navigation on '01 I30
  17. a/c & heat fan noise
  18. Infiniti I30 Armrest has cracked *pics*
  19. 5zigen wheels, are they any good?
  20. Coils and Knock Sensor???
  21. Stilloking for a32 cefiro parts
  22. Car keeps turning off while driving : HELP
  23. Looking for a32 cefiro parts
  24. SES light code #P0420 on 01 I30
  25. Auto headlights....anyway to stop them from working???
  26. 2000 aftermarket dash kit. still available?
  27. HID headlight problem
  28. Burned Light Sockets
  29. If you want A33 side skirts come in for cheaper than retail
  30. I35 led tail
  31. Interesting lighting tidbits (for those who care)
  32. Has anyone taken apart an A33 fog light?
  33. Wheel spacers
  34. Need some help identifying this
  35. what i really want.
  36. Vibration on acceleration
  37. Problem with my '96 A32
  38. wheel replacement - technical question
  39. another body kit
  40. I35 ?
  41. I'm Back
  42. A33 alternator installation question
  43. I've Never Seen This Before!
  44. I35 Rear Sway-Bar Installed
  45. one mint i30
  46. is this true?
  47. Soundgate ALNS1V2 question.
  48. Just found something thought i'd share
  49. Whats the rec. mileage for a water pump
  50. F/s gas door switch
  51. Door lights Not on?????
  52. Installed Yellow Foglight Capsules...and LED license plate light pics
  53. Infinti steering wheel??
  54. 96 I30 with 18" 2004 SE wheels
  55. Slip/abs/TCS off?
  56. Is this the correct fog bulb?
  57. Condensation in Tails
  58. I30 leather seats
  59. Exhaust diagram/layout?
  60. 1996 I30 with rough idle at cold start but smooth when warmed up?????
  61. 2k1 max and I30 ECM swapable?
  62. Snow Day Pics
  63. I'm part of the I30 family!
  64. How many miles do you plan on getting from your I30/35?
  65. SES galore
  66. Alternative to in-dash NAV
  67. re-attach rear view mirror?
  68. Brake Pad/Rotor Install Problems
  69. Low Mileage on 2000 i30t
  70. How do you remove the power antenna mast?
  71. dont yell
  72. Whine sound, car shuts off, and SES light??
  73. 01 i30t $12k for me sister
  74. 2000 I30 Gauge/Instrument/Speedometer/Cluster LED
  75. Question about Auto's
  76. Anybody know of any A33 aftermarket hoods?
  77. Pics of the front and rear dropped finally...
  78. Would you trade I30 for 3.2 TL?
  79. Throttle body cleaning
  80. 2000 I30t Died Again During Cold Start
  81. Finally got my I 30 lowered. and new lights *pics*
  82. Aftermarket or OEM Fog Light
  83. OEM Satellite for 2002 I35? Aftermarket NAV?
  84. BBK Suggestion
  85. Factory Navigation CD
  86. I30/I35 compass mirror ?
  87. Rough drive after coil / plugs replacement
  88. What size bulb
  89. Need help with chrome gauge rings.
  90. plugs/wires
  91. Problem With Y-pipe??
  92. I35... factory spare size?
  93. Battery Recomendation
  94. 1999 vs 2001 suspension differences
  95. 1999 I30..my backdoor won't unlock with remote, help...
  96. MAF Part#
  97. Service Engine Soon Light
  98. Belts
  99. Chrome Trim
  100. A sad example.
  101. ks, o2, and coil replacement question and advice with problems
  102. Yellow Fogs
  103. n3985's Lighting Evolution Worklog Begins....
  104. Infiniti i35 side skirts
  105. Help w/buzzing pls.
  106. Picture Request
  107. Brake light will not turn off?
  108. little quote here please!
  109. Anybody want to sell anything?
  110. Almost wrecked my car then.... CRASH
  111. Garage Door
  112. Think I found out why my gas mileage sux.
  113. Cefiro Wagon!!
  114. WTB 00-03 clear side markers.
  115. problem with gauges
  116. HID in 2001 I30
  117. 02 I35: New rattle at 1700 rpms until tranny shifts
  118. Any advice for coils?
  119. Woops, how do I buff THIS out?
  120. Sweet A33 Body Kit
  121. Does anyone know what this means?
  122. 2003 I35 parting out
  123. 00-01 carbod fiber hood?
  124. Finally found the best city light bulb!
  125. Installing I35 Overhead Console
  126. Newest Pics of said Debadge and more!!
  127. Exhaust and Suspenion
  128. Has anybody purchased...
  129. Debadged
  130. drop resistor mod installed
  131. wind noise
  132. Will This Buff Out???
  133. What To Do
  134. Does anyone know how?
  135. What Bulbs Will Match The OEM HIDs?
  136. Search Before You Post (Instructions Inside)
  137. I cant beleive what has happened!! What should I do?
  138. spliff this...
  139. Engine throwing P0138...
  140. Short Ram vs pop-charger on 5th gen
  141. picked up a 96 for 1k
  142. Cefiros wiring harness question
  143. Rattle Making Me Go Insane!!! Advice Needed
  144. Started And Then Died... Bad Battery?
  145. Authentic Cefiro A32 OEM parts?
  146. I30--side skirts, grille, spoiler
  147. Bad gas mileage???
  148. Burnout pics.......
  149. Coil replacement
  150. Projector Headlights
  151. what percent tint is this?
  152. LED guages
  153. wald kit
  154. gauge pod
  155. 2 Requests
  156. Discovered a Leak
  157. jet recal. chip
  158. 2000 I30 parts the same as in a 5th gen?
  159. Rear lights
  160. I35 mod list
  161. can a 2001 i30 headlight fit a 2002 i35
  162. Weird Dome Light- Map light Problem
  163. fuel filter replacement on I30
  164. dropping the front suspension only!
  165. I35 Grille
  166. 50K Milestone!!!
  167. Changing Rear Ignition Coils
  168. 5 or 6 speed swap???
  169. LED Tails
  170. Headlight Mod Question
  171. Tint from 2 different places
  172. are these ebay headlights any good?
  173. gotta serious sunroof issue
  174. Clear or Black?
  175. vb mod on an infiniti 2001 automatic
  176. Changing LED/Bulbs of Infiniti Clock
  177. What rims are these?
  178. Need some advice
  179. who has 2002-2003 infiniti i35 projector halos from ebay
  180. OEM spoiler project
  181. Hearing Some Sort Of Metal Part Swing?!
  182. 2000 I30 with steering wheel radio controls
  183. how to clean headlights?
  184. Box of Boost Goodies ***PICS***
  185. 05 Pathfinder Bose w/ in Dash 6-Disk CD Changer and MP3 Install ***PICS***
  186. Getting Ready For Paint
  187. Heated Rear Seat LED
  188. I30 Limited steering wheel
  189. Can You Say Rice???
  190. "Pebble Bleech" Gold. Are there other equivalents?
  191. Ouch...i hit something!!!
  192. tail lights
  193. High Mileage
  194. how to change i35 headlight len
  195. Plan on selling OEM alloy wheels from I30. What do they run?
  196. jl subs + jl e2150 + OEM Bose = SUCKS!
  197. Considering Carrloson rims
  198. Crunked Teardown of a 200k VQ30DE
  199. Fog Lights
  200. question about i35 BOSE stereo
  201. i35 painted sideskirts for sale on ebay
  202. headlight electronical question
  203. FS. Builder 2004 I35 with 16K miles
  204. Can't go over 2.5 K
  205. Better Brake Pads I35
  206. DIY Exhaust Modification question
  207. Springs and Struts
  208. Please Help...tried Everything
  209. Alarm Systems
  210. I30 (2000+) and I35 available Cold Air Intakes
  211. How to let others know you're done modifying your car
  212. bose sub cutout?
  213. ? On Rotors
  214. Which Air Bag Kit To get
  215. Yellow Capsule Foglights
  216. Does anybody know the official name of this color?
  217. DIY Diagram for HID foglight into A33
  218. How much would YOU pay for this engine +...
  219. O2 sensor advice for 1998 I30
  220. Tire inflation on Max vs. I30
  221. ?????????Engine light on??????????
  222. Infiniti Logo Plate
  223. Like my new wheels? (Photochop)
  224. Cefiro Head Light Aiming
  225. Alternator Question for 00 i30t
  226. Vibration/noise when braking....
  227. license plate bulbs stopped working
  228. New lip kit available for the I30-I35 (A33) infinity, we need some support.
  229. side skirts for i30
  230. Anyone got these!
  231. radio removal
  232. hood release problems
  233. Coloer Matched
  234. Infiniti auto service
  235. Know your paint code???
  236. Phillips VisionPlus
  237. A32 Cefiro Japen model center oplique
  238. VIP mesh grill?
  239. 98 I30 clear corner question?
  240. Replacing all exterior stock bulbs
  241. We Need our own For Sale Forum
  242. Who else is a fan of the Australian ST-R lip kit?
  243. 00+ I30t owners what size tires do you have ?
  244. Alignment from Midas
  245. Is there anywhere I can
  246. I may make some aftermarket HU kits, who is interested??
  247. How to replace cornering bulbs?
  248. A/C question
  249. A33 Dual Projector/Angel Eye Headlights
  250. Aftermarket HU install, No sound to speakers
