- Remove harness protector from engine room harness.
- 1997 Infiniti i30t - CODE P1447 - Purge Evap Control Selenoid - HELP?
- IACV hose
- More Transmission Questions - P0740 TCC Circuit
- Coilovers and suspension
- Cold start issue
- New I30 owner
- 2003-04 i35 heated seat wiring differences
- 2000 infiniti I30 door check
- 2002 I35 possible fries ecm
- Startup issues
- Alternator
- Alternator
- 1998 Infiniti i30- no ground at a/c relay, clutch won’t engage.
- Paint on console
- My i35 is a Beast.
- I35 hard shift into 2nd gear only
- Key fob
- 2000 infiniti I30 coil packs
- annoying rattle from rear
- Band-aide fix for knocking?
- Infiniti i30 motor swap possibilities
- Coilovers and aluminum radiator
- How to fix factory stereo I35
- 2002 I35 Steering Wheel
- MAF Sensor 2002 I35
- 2001 I30 Strange MAF issue
- Is it worth a new motor
- 2004 I35 burning oil ridiculously
- Rays on an I30t?
- Abs and tcs light on
- 2004 I35 hard shifting
- Looking for headers and exhaust
- Clarion head unit
- 2004 I35 cylinder 2 misfire
- 2003 I35 on BC Coilovers and 350z wheels
- Disconnecting electronic motor mounts 2001 I30
- I35 won’t start
- Navi disc for North East
- Help with Aftermarket Wiring?
- Failing PNP Switch?
- Picked up a 2003 I35
- BOSE radio was draining the battery
- 2001 I30 Carpet
- 2001 Infiniti i30 intermittent issue that is somewhat stumping me
- Parting out 2004 I35
- Can’t get car to run right after tb gasket and manifold gasket replacement
- Lower control arm pin the same as maxima of same year ?
- Air intake help!
- 99 130 coolant leak
- 2004 I35 Engine Knock??
- 1999/2000 Infiniti i30 Climate Control/Blower Motor Not Working
- Lower Control Arms - Touring vs Non Touring
- 2001 I30: Buzzing / Motor sound from trunk area.
- 2001 Infiniti I30T 75K Miles For Sale (Clean Florida Title)
- Found: Infiniti I30 Combination Meter Backlight Bulb
- Factory Service Manuals I30 '96 - '01
- I35 - Timing Chain Concern?
- Rear suspension bracket bushings
- Infinity 130 1320 code 505 code car want start
- Bringing a 2001 i30 back to life
- 1998 infiniti i30 t coolant leak from around oil pan
- Buzzing Grill
- Opinions on the 99 Limited Alloy wheels
- New 1999 Infiniti I30 owner need help
- i30 sunroof compatibiltiy?
- P0130 and P0325 codes on 96 I30 AT
- Recently purchased Infinity I35 looking to restore and upgrade
- 02 infiniti i35
- My 2002 Infiniti I35 isn't accelerating and shifts hard. TCS and Slip light is on.
- 2001 I30 Electrical Problem
- I30 wheel replacement
- What headlights are compatible with my 99 Infiniti I30?
- I30t Radio Wiring diagram
- 02 Infiniti i35
- I picked up a 2001 I30T!
- Problem with nissan gloria y33 VQ30DE
- steering mounting bushings
- wheel spacers has "Brake Active Cooling" function?
- Replacement Radiator Fan Motor
- Trip Odometer Keeps Resetting On Its Own
- I30 hood on i35
- Dead Inst Pnl Lights
- The only Idle Relearn Procedure that worked for me
- 1998 Infiniti I30t
- 2000 Infiniti I30 ECU Electronic Schematic
- My 1997 Infiniti I30 Starter/Beginner Car
- Rear wheels are out if alignment
- Fuse block-Junction Box (J/B) HELP!!!!
- Airbag connector
- 2001 Infiniti i30 engine: Grinding noise as I shut car off?
- Looking for sun visors
- Complete I30/I35 Specs and package options
- Starting problem
- Axle but size
- 2003 Infiniti i35 where can I find the tec sheets with info about all the wiring
- A33 Maxima Cefiro (I35) Ultra Racing Parts
- The 1997 I30 restoration thread
- Wheels
- So long i30t...
- Electrical Issues
- 2003 i35
- Complete audio set up
- Brake and Battery light
- My 1997 I30 is back on the road but I need help
- 2003 I35 fuse location for sunshade
- Key Fob protective cover for 98 I-30T???
- Looking for a part name and more on this
- 2000 I30! I finally got a Fancy car!
- What is this and how do I clean it?
- Weird smog test fail
- Check engine light on and doesnt shift when driving?
- Door Lock Actuator Gone Bad?
- Proud new i30 owner
- Bad alternator or neutral safety switch?
- Recently purchased 2001 I30
- Customize/restoring interior
- I30 vs the 4th Gen
- Suggestions on a Transmission repair
- 1999 Infiniti I30 electrical problems
- cargo net
- Rear noise and vibration
- 98 i30 beige cupholder
- I30 and Maxima Gauge cluster interchangeable? 2000-2001 GLE
- About to replace front struts... need torque specs
- Why is there hardly any discussion in the Infiniti forum?
- Motor Oil 5W-30 Synthetic Blend
- Leaking hose to oil filter
- My new (to me) 2002 Infniti I35
- My I-35 rides rough and bounces the wrong way
- New Car and Issues Already...
- European Maxima **GLASS** headlights for 96-99 4th gen I30
- WTB: 96 I30 fog lamp brackets
- P1456 04 Infiniti I35
- Infiniti i35 randomly not starting in park
- Need Help 2001 Infiniti I30: Have to press the gas pedal to get it to start
- I left my low beam headlights on for 7 hours ..
- Issue with car window i don't know how to start fixing (video included).
- Does my oil need changing? Topping off? (Pictures included)
- 2000 I30 totaled today!
- Power loss after Cai install
- 1999 infiniti i30
- A32 Restoration and Build Journal
- Overheating issue
- Just got my i30 a few days ago
- Security light solid red car won't start
- 96' I30 wheels cleaned
- Are the front turn signal bulbs supposed to be clear or amber in the 96 I30?
- Best I35 replacement Starter
- Abs light on
- Canbus / Databus
- 1999 Infiniti i30 Climate control
- Alternator help!
- My brake light and battery light flicker
- Black housing headlights
- Code P01448, Valve Control valve cleaning
- Moment of victory for my i30 radio repair
- 2000 i30t sunroof and map light
- How many miles have you put on you Infiniti i30/Maxima?
- What harness to use to connect steering wheel volume control to Infiniti 98 q45
- Cornering Light bulb replacement 1997 i30
- Ist Gen i30
- Bad Head Gasket, Water Pump, or Thermostat?
- Rare i30 limited door sills (black)
- Tranny questions
- Let’s see those rides!! Post pictures please!!
- 2004 I35 Multi-Point Inspection
- 99 Maxima SE gauge cluster in 96 i30
- Giving some life to this forum!
- Need help solving this one
- 2002 I35 - Orphaned hose after replacing starter
- Recently purchased a 98 i30 t 5spd
- LED clock lights................
- Car Seats for 98 Infiniti i30
- ABS light VDC and SLIP
- 1999 I30 engine swap into a 1999 I30 california version with a swirl valve?
- A/C Not Blowing Cold
- 2004 infiniti i35 help!!!!
- Looking at Buying a high mileage 2001 i30t
- Hi, everyone, need help please
- P0420 code
- Did they make the 5th gen I30 in pearl white with black interior?
- Help?!? Quick Question
- Infinity I30 most common electrical problems
- 98 I30 randomly not starting.
- Limp Mode / Fail Safe No CEL
- I35 interior wood trim fit on 2001 I30?
- Wreck of the I 35 by ignorant texter
- Crankshaft position sensor
- Airbag question
- A/c cooler pipe repair
- Part Identification
- New Here & Considering Infiniti I35
- Breaking in New Catalytic converter
- 2001 Infiniti I30t newbie here!
- 19" M45 sport wheels for i35
- Project I35
- 01 i30 stalls / hesitates when fuel is low
- Rubber and grey Infiniti mats
- Is there a built-in mic? 2002 I35
- Please Help 1997 Infinity I30 engine code
- 1998 I30 Spun rod
- AC Climate Control Motor
- 2002 I35 Electric Seat Question
- Need help... Please!
- Y pipe installation
- Selling/Parting Out 2003 Infiniti I35
- 02 Sensor P0140
- Tire Pressure
- I30 catalytic converter
- Anyone know somebody that is parting way with their I30/I35?
- *** 03 I35 bogging at 2500 rpm **Video**
- New Key Fob/This one?
- High Operating Temp
- Steering Wheel Insert '02 I35
- Garage Door Opener Button
- One issue or two? You decide
- Bought BC coilovers
- Just bought an '02 Infiniti I35, may need timing chain?
- Removing dash vents: how?
- color of Infiniti lettering on 4th Gen trunk lid garnish
- Sunroof issue
- Reliability
- Now have working trunk lid lights
- 96 i30 broken radio antenna. Car wash damn
- Bumper scratch
- Infiniti i30t 2000
- New Ride-1999 i30
- 96 İnfiniti İ30 Transmission Slipping Back ...
- Hello everyone new to forum need some help
- Transmission Problem
- 2000 infiniti i30t wont start
- 99 I30 Seat swap question (airbag)
- Power steering pump bolt
- 2001 Maxima - Are the car seats interchangeable with a 2002 Infiniti i35?
- 04 I35 @ 123K miles == Thrown Rod???
- How do I fix this?
- 02 tranny work with the 01 motor in my I30?
- 1998 i30 has code P0325 P0440 P0400 P1448
- Engine noise
- foglights and headlights
- How do you remove the connector near Starter
- I30 clicks when starting
- Door Trim Panel Maxima & I30
- tail light differences 96-99
- Center Stack upgrade Done
- power antenna woes - down, then up, then down
- how to remove 4thGen I30 front leather "seatback finisher"
- Alternator broke again
- gas smell in car
