PDA
View Full Version : Infiniti I30/I35
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. Engine swap
  2. Relay box
  3. Oil pressure sensor torque?
  4. i30 and i35 Cluster Modding service
  5. OEM relay question
  6. 04 I35 - inside headlight bulb
  7. Check engine light won't light
  8. Headlight issues
  9. 03 I35 low beam brightness
  10. 2000 i30 P0171 code
  11. 02 I-35 traction control on or off??
  12. I30 Parts that break often
  13. AC Compressor Kit
  14. 00-04 Owners: Let's Discuss Catbacks
  15. Parking brake and battery lights on
  16. Steering wheel interchangeablility
  17. Service Engine Soon indicator - 2002 I35
  18. Stereo Issues
  19. shock absorber fixing bolt and nut (to hoodledge)
  20. Graphite Interior Spray Paint?
  21. 2002 I35 NEW KEY Made?
  22. Seat Covers?
  23. My 2000 I30
  24. Glove compartment creaking noise
  25. long crank no speedo no rpm
  26. 2002 i35 part-out
  27. 01 I30 STARTS AND STALL!! Help please
  28. Starting problem with 2000 I30
  29. Cv axle replacement
  30. about to purchase an 02 I35
  31. Can I do Gen 5.5 MT Swap on a I35?
  32. bleeder location
  33. my i35
  34. 1998 İnfiniti i30 İnstrument Cluster Bulb ?
  35. Questions about A33 I30 fog light bulbs
  36. New motor
  37. Mirror Wire Cover
  38. I need help! - Should I use a thread repair kit?
  39. Scraping noise
  40. HID Ballast
  41. HELP!!!! No Compression on #5
  42. Radiator Fan
  43. i30 which spark plugs???
  44. Advice on replacing I35 transmission
  45. 2001 i30 Lights dimming
  46. 2000 I30 Front Brakes Sticking
  47. Vinyl Wrap vs Plasti-Dip
  48. 2003 i35 Great Fuel Mileage
  49. Performance Chips
  50. Stock Intake 03 i35
  51. Map light bulb replacement
  52. Driver's seat issue; seat stuck
  53. Radiator Leak - 2002 I35
  54. 2004 I35 p2135 and p1800 code after cross country ship and weird clicking noise
  55. Dead Sunroof - 02 I35
  56. Random Car Issue
  57. Aftermarket Subwoofer
  58. Stock G37 Rims on I30t
  59. I30 strange rumbling noise
  60. Nano energizer
  61. Unlocking passenger door with key fob
  62. 2003 I35 Cam sensor
  63. Trans Slipping
  64. i need help please !!!!!
  65. Is this a good deal? 2002 I35 109k
  66. Infiniti I30 w. 18" 09 M35 wheels
  67. WTB 2000 I30 Key fob
  68. What Do You Think It's Worth
  69. Ideas for mods '02 i35
  70. Rear trim for driver seat of 2001 Infiniti I30
  71. 2000 I30 - Did I get a good deal?
  72. Infiniti I30 Seat belt warranty
  73. Squeaking noises from all over
  74. Front End Issue
  75. Wheel Bearing replacement
  76. Sentra B14 headlights fit my I30?
  77. hi my name is Maxim, I from Russia
  78. Vlsd
  79. key flip out
  80. Thermostat open - what does this mean
  81. 00 I30 steering issue
  82. Hard to turn steering wheel, but new power steering fluid?
  83. 3003 I35 Po174 code issue
  84. 2000 I30 fits what year maximas?
  85. Just bought a used I30t
  86. 2002 Infiniti I35 Radio issues
  87. Lowering a 2000 I30 on 18's
  88. Leaking valve covers and replacing valve gaskets
  89. 2000 I30 fuel filter is where?
  90. I30 Parts for Sale
  91. Ac Compressor???
  92. Can I make a 02 I35 starter fit my 00 infiniti I30
  93. Rear Taillight Issue
  94. 2002 I35 - Oxygen Sensor Monitor stuck on INCOMPLETE
  95. Max tire sizes
  96. Freon fully charged but no cold air?
  97. New Group on Instagram for us!
  98. Power Steering Pump Replacement
  99. Drivers Side Window ?
  100. Anyone know where to get a replacement leather seat cover for a fair price?
  101. Knock Sensor replacement
  102. P01800 code ----Testing the SOLENOID Valve Circuit?
  103. 2000 i30t overheating/no heat issue
  104. terribly rough start
  105. Adding OEM heated seat to a non-heated i35
  106. Energy suspension 7.7108g
  107. i30 front fender fitment on i35
  108. My modded I35 (PICS)
  109. i35 revving noise problem. Anyone know what causes this?
  110. FS: I35 wood grain cupholder
  111. vibration and oil leak
  112. got some problems...suspecting fuel filter???
  113. My new ride
  114. i30 i35 parts fit
  115. Loud Growling Sound Exhaust?
  116. I35 cluster
  117. Infiniti i35 upgrading
  118. Bought my second I35
  119. Windshield washer reservior 02 I35
  120. Steering Wheel Buttons
  121. Any way to reset mpg readout on 2003 i35
  122. Transmission - who made it/what model is it
  123. 2004 infiniti i35 knock sensor problems
  124. Mark thread solved
  125. 2003 i35 vallet lockout . . . how
  126. Bypass Factory Radio With Navi
  127. FS: Pioneer DVH 345ub
  128. 2003 i35 trunk lid - something loose inside
  129. Trunk liner clips and hitch install
  130. LCA (I30 vs I30t)
  131. 2003 i35 splash guard
  132. just replaced throttle body and now more issues
  133. White Smoke
  134. 02 i35 stalls at idle..
  135. Memory seat function comes/goes
  136. Vibrations when braking on the highway
  137. What should I do to my trunk?
  138. At the dragstrip
  139. Any suggestions to a good loud exhaust for 01' i30?
  140. i35 interior clock light bulb question.
  141. Ash tray door removal?
  142. Sunroof seal is like rock!
  143. Odometer Fraud?
  144. I35 oil dipstick
  145. Winterizing '01 i30
  146. i30 LCA and CV Joints
  147. Muffler delete
  148. Need help with my i30 (Mass A/F)
  149. Oil Pressure Light Question I35
  150. 2000 i30 transmission slipping and dropping resistor
  151. Hard to start when warm
  152. 1997 i30 rough idle and flashing CEL
  153. CA WTB 2000-2001 I30T wheels!
  154. Exhaust pics
  155. Tinted headlight and tailights. PICS (Film)
  156. Best license plate LED lights for 01' i30
  157. Serpentine belt replacement question on 2000 I30
  158. Power steering hose.....
  159. What is this noise?
  160. Lower rad core support rust, need advice
  161. F/S Extra I30 Parts
  162. Transmission Issues
  163. Steering wheel swap
  164. Side Skirts Installed
  165. Low Voltage
  166. Any A/C problems?
  167. Found leeli35s i35 for sale!
  168. new fog light pics!
  169. bypass bose sub
  170. Headlight/Cruise Control Correlation?
  171. new pics! all cleaned up leds
  172. leds keep blowing tail light fuse
  173. rear struts gone
  174. Need help with installing a air intake for 2001 infiniti i30
  175. Weatherstripping
  176. Replacing third brake light bulbs - I30 with Sunshade
  177. 95-99 I30 Touring floormats (Tan)
  178. HELP!Going to buy i35.Are there diff. models diff. in years etc.?
  179. Help Me Pick Wheels
  180. Bose stereo receiver/ cd deck replacement
  181. infiniti i30 door sills
  182. SAI angle for 03 i35
  183. clacking noise when accelerating.
  184. Rear coils on 2000 I-30
  185. How to remove the center console
  186. Infiniti I30 remote problem
  187. Infiniti lightining door sills with infiniti logo
  188. did 00vi swap now high idle
  189. hid bulbs
  190. Transmission Mount Recommendation and Vibration at Idle
  191. air bag light
  192. New home 99 I30 limited
  193. does I35 driver door harness are the same as I30?
  194. Coil Packs
  195. 2002 I35 Squeaking Noise on Freeway Front Driver Side (Video Link)
  196. What do you guys think about the 97-01 model Q45?
  197. Replacing rear panel trim on driver seat
  198. P0011 and P0021 codes
  199. Roof Spoiler Installation (PICS)
  200. 2004 I35 cornering lights
  201. Car hesitating
  202. 02 I35 AC Issues. Ambient thermometer?
  203. Infiniti i35 body kits?
  204. Here she is! paid $1k last year came with chromes!
  205. I Keep Blowing A Fuse When Installing LED's
  206. Helpppp
  207. 98 I30 - R&R clear red plastic trunk-wide "Infiniti" bezel
  208. Getting it running
  209. heated seats
  210. Time to replace?
  211. Axle Seal?
  212. Fog Light Went Out - What to Replace it With?
  213. Maintenance time!
  214. cold engine sputter and power steering issue
  215. Somebody Please Help!!!!
  216. How to instructions..need help
  217. Different location for limit switch?
  218. Engine mount 2003 i35
  219. Ordered all new parts for my I30T
  220. High mileage - tune up question
  221. Need opinions
  222. Halogen bulb locations ? Going to LED
  223. Automatic Door Locks
  224. Infiniti i30t for 1700
  225. Anyone Get A Fender Replaced Recently?
  226. Oil changes
  227. Now I have an i30
  228. suspension creak/squeak after pothole
  229. Vibrations over 70
  230. Lug Nuts
  231. 2000 Infiniti I30 splash/mud guards
  232. Just got my first car! A 2003 infiniti i35
  233. cd changer in 2k doesn't work
  234. 2000 i30 jerk while shifting
  235. Replacing brake light bulb
  236. When cold transmission shifts hard. Warmed up it is fine
  237. I30/I35 OEM Sideskirts
  238. Wiper Linkage rod/arm popped off..'99 i-30
  239. Grille
  240. Replacing Factory HID ballast
  241. ABS Working but no TCS
  242. Looking at a 03 I35
  243. Replaced Spark Plugs Today. Have a few questions regarding hoses and clips
  244. Rear shade switch
  245. Just bought a 04 I35. Headlights seem very very dim
  246. Will g35 sedan seats fit an i30?????
  247. 1997 I30 hesitates around 40MPH after new brakes?
  248. 1996 Cefiro/I30 Transmission or Cluster issues?
  249. HID Headlight Life
  250. Is this the Ionic Dynamics lip kit?
