PDA
View Full Version : 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15
  1. Found Engine Number
  2. changing the timing belt
  3. power mirrors
  4. strange squeal
  5. Auto tranny drain plug... of spooky doom!
  6. Now what???
  7. Turbo Selection
  8. SENSOR light on dash bar
  9. Brake light comes on...
  10. engine number
  11. Transmission wont shift past 2nd gear...
  12. "new" 88
  13. Factory Radio Setup Anyone?
  14. Help with air filters
  15. 87 maxima cold start
  16. 87 Max Tran slipping!
  17. No more indecision...
  18. Help
  19. Rear spoiler
  20. Temp Gauge Creeping Up
  21. Its been along time since ive posted so hears an update
  22. Smoking. Smoking. Smoking
  23. I am sadly leaving the .ORG
  24. light stays on even when lights are off?
  25. Power Steering Problem
  26. Clutch issues in Sentra
  27. Where there's smoke.....
  28. 84 temp sensor wire
  29. 87 Max No Start - Distributor?
  30. looking for rear upper strut mounts for '88 Max
  31. How do I use mode II on ECU?
  32. "Crying fuel pump" Good brand for fuel filter?
  33. a quick Q
  34. fuel injectors
  35. Best cleaners/wax etc. for a white '87 GXE Sedan
  36. instrument cluster part 2
  37. fix lights or exhaust?
  38. 1987 Factory repair manual for sale
  39. RL4F02A trans...need diagram....
  40. Checked ECU today and got 'ignition signal' code
  41. Auto seatbelts, revisited....
  42. What N/A mod adds the most power?
  43. 88' Maxima SE 5sp Transmission Question
  44. Intermitent electrical issues.
  45. I need to replace my 'In vehicle temp. sensor' Auto Climate
  46. AHH Dash Crack!
  47. How to check ECU without removing seat??
  48. Replacing front & rear suspensions...Any tips?
  49. stalling after running out of gas
  50. Canadian Engine Mounties
  51. tranny fluid change...
  52. picked up an '88 today
  53. Leaking exhaust manifold
  54. Is my car REALLY that UGLY?
  55. Auto Seatbelts, Airbags. When did they start?
  56. Auto Tranny Swap---Remove Engine?
  57. Gone for 3 days, look what happens!
  58. Taking soooo long to warm up as weather gets colder...
  59. foglight question
  60. Seafoam lots of smoke under front..
  61. Air filter question.
  62. Throttle Body?
  63. Anybody ever use Lucas?
  64. Aftermarket stereo advice
  65. ATF / Filter recommendations
  66. A/c recharge in a 85
  67. 85 Maxima steering pump
  68. Contemplating O2 sensor replacement
  69. Auto Climate Control Woes**Need Help**
  70. Tach conversion
  71. how do you guys like these wheels?
  72. updated pics
  73. 1983 Maxima Limo E-bay
  74. Finding KYB-GR2s in NY area
  75. Intake pictures
  76. power window motors
  77. Mass Airflow Sensor (MAF) removal...
  78. More pics for the masses....
  79. how do I install a remote for door locks
  80. Various tune-up questions
  81. Urgent question: Fuel cutoff in case of accident? Override?
  82. Back on the road, new problem.
  83. RL4F02A Rebuild
  84. engine removal...
  85. Rear Brakes
  86. Does anyone want my spare midpipe?
  87. Alternator/generator upgrade
  88. 87 maxima axle
  89. found on e-bay(I do this alot..lol)
  90. Brake Pad Squeal
  91. nissan v8's
  92. suspension rattle
  93. Sticky the 5-speed conversion
  94. interesting little blurb
  95. Keyless Entry
  96. alternator belt
  97. how do I redo the boots on the rear end of a 83
  98. Floor mats
  99. Cylinder 3 not firing and there is oil on the spark plug
  100. problems with my 88
  101. Auto Transmission Woes
  102. Need help picking a NTK O2 sensor for 87 Max
  103. Not the right thread, I know.
  104. Windex on your headliner!
  105. Front bumper concept image
  106. Unorthodox Underdrive Pulley for sale
  107. Decisions
  108. Found some new rims for my car!
  109. parts that dont fit or dont ship
  110. Wrecked my 97, bought an 86
  111. Hi all, new to site. how to read ecu codes??
  112. any1 feel like measuring their rear rotors diameter?
  113. How to fix a leaking sunroof
  114. The 5 lug conversion is now worth it!
  115. Engine Swap
  116. Pimp My Ride - Maxima
  117. Instrumentation from gas to Diesel
  118. i need a front exhaust manifold
  119. newbie
  120. Axles are fun?
  121. Exhaust question
  122. engine bulid sticky isnt working
  123. Maintanence at 80,000mi
  124. I have no idea what's wrong with my Maxima.
  125. Future Modding Plans
  126. torqe converter
  127. Seat Covers
  128. Cold Start Idle Problem
  129. Help, 1988 rh inner door trim piece needed!
  130. Speaker Setup for 1st Gen (For Sale)
  131. Signature Picture Guidelines. Read before posting signature pics!
  132. 88 Maxima auto transmission problem
  133. muffler idea
  134. '85 Maxima Sounding like a Diesel!
  135. 1985 Maxima FSM
  136. replacing the EGR?
  137. AC Question
  138. 86 300zx engine in a 90 Maxima?
  139. 86 300zx engine in a 90 Maxima?
  140. one of those really bad things
  141. message for DR J
  142. Fuel octane and 2nd Gen Maximas
  143. turbo anyone??
  144. She Speaks!
  145. Which had the better TB?
  146. auto tranny problems...
  147. wagon guys
  148. help.. overdrive went
  149. Diesel max 5 speed
  150. '87 Maxima V6 Turbo
  151. Mixture Ratio?
  152. Looking at some paint options...
  153. GL-4 or GL5 tranny oil for the Maximas?
  154. Shocks n' Struts
  155. AC problems
  156. Upgraded ECUs for 87-88 2nd gen
  157. Power Window...
  158. Air Condition Problem
  159. Starter motor is grinding every morning
  160. Emission Fixes
  161. LOL! A snip @ $18,000!
  162. Good To Be Back!
  163. 1985 wagon transmission slip into 3rd gear..
  164. random questions.....
  165. transmission cooler lines
  166. back with a vengence
  167. Starter Questions
  168. Top Speeds
  169. Realistic price for 1st gen
  170. Cleaning Intake Manifold
  171. Custom Intake!
  172. Lower control Arm for 88' Maxima SE
  173. wish I was around NJ
  174. P/s Leak!
  175. How can i tell what kind of Maxima I got?
  176. LD28 Longevity Maintenance
  177. size of hoses around the gas tank
  178. help car is runnin like ****!!!
  179. Eibach's Own.
  180. Still have one midpipe for sale
  181. Stero System for '87 Maxima
  182. My wagon tranny swap pic
  183. Help!!!!
  184. oil pressure erratic
  185. So this is odd...
  186. 17 Gallons
  187. where is the fast idle control?
  188. Total Engine Management
  189. electrical problems... yay
  190. Oil Filter Location....
  191. Selling Unorthodox Underdrive pulley
  192. guy selling lowering springs?
  193. Anyone?
  194. SE limited question
  195. KA24e throttle body and 5 spoke rims
  196. new here
  197. motor question
  198. ST springs on 85
  199. Got quite a few parts, need to sell.
  200. Handbrake Light
  201. help with oxygen sensor
  202. help with engine issue
  203. Brake Lights Don't Work
  204. 87 sedan electrical problems??
  205. Nissan Maxima 87 sedan engine wont start
  206. my poor car
  207. MAXIMA '85 station wagon FS
  208. Speaking of Body Kits .......
  209. Help the NewB's
  210. Gauging interested, ST Springs
  211. Idler Pulley help
  212. 1994 Sentra XE
  213. Air Flow Meter unplugged
  214. just got a 300zx ecu.
  215. body kit?
  216. security system
  217. 87 Y-Pipe needed
  218. Cleaning and Detailing
  219. She locked me out! '87 Max SE in NY
  220. tornado, fuel magnet K&N filter Gas savers?
  221. Diesel owners
  222. Fast Max!
  223. Fast idle
  224. 1 and 2 gen information
  225. %$#@!&$%^%
  226. 85' headlights wanted
  227. 5 lug conversion is nearing....
  228. Vacuum hose diagram
  229. Aaahhhh!!!
  230. Sun roof window
  231. Pics Coming soon!
  232. Just posting cause nothing ever happens here
  233. !chts!
  234. Painted Intake Manifold Cover
  235. Bearing Noise
  236. Air Intake
  237. Udp
  238. sunroof seal
  239. pimp my ride
  240. cylinder head temp sensor?
  241. 1st Gen on Pimp My Ride tonight
  242. Time for another Engine
  243. carpet kit/speakers
  244. Battery
  245. Foreign Object In Combustion Chamber
  246. Simple 1st Gen Question
  247. 94 Sentra XE
  248. Clean bill
  249. Need Manual Speedo Gear
  250. Pimp My Ride!
