PDA
View Full Version : 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15
  1. 1987 Nissan maxima Rear Exterior Handle Search!
  2. learned something about P/S pump and Rack failure
  3. Power Steering Fluid Overflow and Noise
  4. Rack and Pinion Rebuild
  5. LED swap 87 maxima SE
  6. Nissan Dealership Service Manual PDF
  7. Any 81-84 Maximas for sale? Texas or surrounding states
  8. 1987 Maxima Wagon
  9. Anyone Rebuild Your Master Cylinder
  10. Conversion: 1157 LED Tail light bulbs
  11. High Parasitic Current Draining Battery
  12. Looking for a control arm bracket
  13. best way to drain the tank?
  14. Driver side door locked and will not unlock
  15. 1986 Nissan Maxima Resources
  16. Searching for a 1982 Wagon Fuel Tank
  17. '84 Maxima: To sell, to part off, or to Garbage
  18. E-Brake snapped
  19. 1988 Shiro Mega MAX Value
  20. 86 maxima hard cold start and stalls when up to temperature
  21. Help finding parts - 84 Maxima SE
  22. Recommended Brands For Brake Master Cylinder
  23. 1984 interior parts - gray
  24. struts
  25. oil pump
  26. rb20DET swap
  27. Distributor Pickup Coil
  28. Need Headlight Rubber Trim
  29. Need Headlight Rubber Trim
  30. Engine Miss No Power When Warm
  31. back glass Weatherstrip
  32. Water Leak in Trunk
  33. any thing on 1981-84 Fuel sending unit?
  34. 1985 Nissan Maxima parts
  35. All windows work, except drivers door.
  36. Pictures for how the cassette player is mounted?
  37. Help with fixing 88' Digital display.
  38. 2 Gen maxima vibes
  39. Exhaust
  40. Key wont turn on driver side door
  41. Dashboard Brake Warning Light Stays On
  42. 2nd gen production/US sales figures
  43. AC High Side Fitting Adapter for AC Gauge Set for '87
  44. '88 Headrests
  45. Who lent their Maxima to Doug DeMuro?
  46. Probably a longshot but i need help fixing after some idiocy
  47. Just got a MINT 87 gxe
  48. Just bough an 87 Maxima GXE
  49. Parts
  50. Passenger side headlight
  51. 88 max survivor
  52. Fuel Check Valve
  53. new Rear Strut
  54. 1983 L24E Motor and trans for sell
  55. Fuel Pump installation
  56. Ugh...
  57. Trans fluid change/ recommended trans oil 1988 Maxima
  58. Fuel pump relay location for an 87!!!!
  59. Engines runs then shuts off
  60. My steering suddenly hard to steer
  61. 2nd gen ecu location
  62. 87 maxima no crank no start
  63. Injector help!!
  64. does anyone have OEM radio
  65. Car missing after it warms up??
  66. ISO: 1988 Maxima Engine V6 SOHC
  67. Looking for belt diagrams for 87 3.0 v6
  68. 87 automatic EGR valve
  69. Difference between EGR valves for '87 gxe
  70. 1985 nissan maxima coilovers
  71. Rebuild engine
  72. Alternator relocation
  73. Upper intake manifold for sale
  74. Injector issues, and cleaning contacts?
  75. New owner of an '82 Diesel!
  76. Heater core
  77. Coilover struts for '87 Maxima wagon GXE.
  78. 1983 Glove box
  79. replacement of clarion stereo and now no sound
  80. 1987 Maxima cold start!!!
  81. Need a lil insight to an electrical issue 84 maxima
  82. What do you guys use for Window Visors?
  83. Anyone have a good ac compressor for a 1987?
  84. 88maxima throttle goes wide open when put in gear
  85. 88 Maxima throttles goes to wide open as soon as I put it in gear , drive, reverse,
  86. Rod fork 1-2nd gear avail?
  87. Lots of things not working on my 87
  88. Going to local junk yard for an 87 Maxima SE; Parts Request?
  89. Desperate for wheel hub assembly
  90. Heater hose diagra
  91. If i cant use key to deactivate my anti theft system what else can i do to get car st
  92. Fuel injector
  93. Air regulator
  94. 88 nissan maxima throttle valve switch curcuit
  95. Fuel regulator temp sensor
  96. 2nd Gen Maxima Headers?
  97. Stalling issue
  98. How to remove Headlight Assemblies?
  99. Reference Pictures
  100. Need help finding driver side rear caliper 86-87 Maxima for my Triumph project
  101. 86SE Door Locks / Speaker
  102. Manual flywheel
  103. Voltage issues
  104. 2nd Generation Maxima Flywheel Bolts
  105. 1986 Maxima GL | 56k
  106. Please help us
  107. 1987 Nissan Maxima Wagons meet after 31 years
  108. Pilot Bushing
  109. 1987 Maxima Wagon available for parts
  110. Rear Stabilizer Links
  111. Fuel pump access
  112. What Windscreen washer pump will fit 88 maxima?
  113. 1988 LED Headlights upgrade?
  114. Idler pulley part
  115. '87 Headlight Low Beam Issue
  116. found a digital dash, is it an easy swap?
  117. The brochure from 1988
  118. 88 SE hesitation problems
  119. 1987 Maxima
  120. R180 to R200 diff swap help?
  121. Motorized seat belt
  122. Belt issues
  123. 87 Maxima SE 5 spd for auction
  124. Rear End Super Stiff - 88 Maxima Wagon
  125. My 88 GXE Wagon
  126. '88 Maxima GXE
  127. More 2nd Gen Parts Available
  128. New Member: Hello!
  129. Oil Pan
  130. Seat Belt conversion?
  131. So your window switchs are not working......
  132. Here my newly acquired 87 SE
  133. Anyone have a fog light switch for 87-88
  134. question about the 87 SE Trim
  135. Hi there! Im Patrick! looking for a maxima!
  136. For when your ECCS dies
  137. 88 se questions
  138. High Side AC hose fitting adapter for Gauge Set
  139. 1985 Nissan Maxima Wagon Parts Available
  140. 1985 Maxima Parts Available
  141. Starter solenoid repair?
  142. Advice on removing Cat 88" SE
  143. Need a 1st gen hub!
  144. NISformance 1983 RWD Maxima dyno testing!
  145. Passenger seat with the track,
  146. 1987 Nissan Maxima Wagon for sale
  147. Idle stutter / low idle when warming up
  148. Temp Fluctuates in stop and go traffic unless A/C is on
  149. 2nd Gen Transmissions and other parts available
  150. Looking for door weather stripping for an 88 GXE
  151. Manual trans mounts PICS
  152. 1988 Maxima Wagon for sale $300
  153. 1988 fuel pump sending unit wireing?
  154. Favorite plugs
  155. Fix for Failing ICMs ?
  156. Denver Area Mechanic
  157. 2nd gen maxima with electronics package
  158. coilovers! (2gen)
  159. 2nd gen Parts near West Coast
  160. Second Call for 2nd Generation Maxima parts
  161. New kid on the block
  162. 1987 Maxima GXE Sedan - Things I am learning along the way (with some good links)
  163. '87 Heater Core...
  164. Datsun 810/Maxima ka24de
  165. Turbo'd first gen wagon on eBay...
  166. 1988 GXE Security System issue
  167. 1987 maxima se 5 speed for sale southern CA only
  168. Anyone Convert the Air Con to R134a ?
  169. 2ns Gen brake lights always on
  170. heat/ac blower can it be upgraded?
  171. 2nd Gen not starting, error code 23 + 45
  172. Passenger seat lower track frame
  173. Intake options for 2nd Gen.
  174. Actually compression
  175. 5 speed transmission questions
  176. Hammers
  177. CV axle on manual transmission
  178. In serch of 2nd Gen 5 speed
  179. Possible Facebook Group?
  180. Ill just leave this here......
  181. dat smoking datsun
  182. Removing the Intake Plenum
  183. Transmission mount
  184. Bringing the MAX BACK!!! TRACK CAR
  185. Transmission upgrades?
  186. 87 TCM for automatic
  187. Ignition Control Modules Failing
  188. Leaking Windshield Washer Pump ?
  189. Alignment on 87's.
  190. Engine needed
  191. Car Idle is high about 1600 rpm's
  192. 1st gen with z32 rear subframes
  193. Interchangeability of parts
  194. Engine rotates but wont start
  195. looking for 87 maxima wagon parts?
  196. HELP 1987 5sp tranny swap questions
  197. HELP 1987 5sp tranny swap questions
  198. Found a 1987 MT maxima
  199. 82 datsun maxima 810 drive shaft
  200. Power steering pump pulley is worn out and shaft is worn out.
  201. Corner light
  202. Sunroof
  203. 1984 Maxima - Hazards and Turn Signals not working!
  204. Throttle body help
  205. Help with power steering lower banjo bolt driving me nuts.
  206. For AW11PRW...help with cai.
  207. Front door compatibility between wagon and sedan...
  208. Help pick my 88' 100k birthday color...HaloEFX
  209. I still have not seen a cool looking 1st gen maxima
  210. 1985 nissan maxima sedan
  211. 87 5spd conversion with 89 exhaust manifolds
  212. led bulbs
  213. Wanted--1985 nissan maxima
  214. 2nd gen art! look what I found!
  215. fuel pressure regulator
  216. L24E Notched Bores
  217. 1984 maxima
  218. 1985 Nissan Maxima with only 40K miles
  219. AW11Power build thread for my 88 SE
  220. maxima 1988 need new front struts
  221. Thought I'd make a short vid...
  222. Is this forum still alive?
  223. Haunting electrical issues with proof - the Truth is out there
  224. Has anyone done a turn signal mod?
  225. digital cluster....
  226. Just Revived My 2nd Gen Maxima Website!!
  227. someone snatch this up 85 for sale
  228. 1987 Maxima: Need help please!!!
  229. 87-88 SE Question
  230. Really crappy cold start.
  231. Considering a Maxima
  232. A/C Compressor clutch lock up
  233. glove box light help
  234. Added another Maxima '84
  235. A/C Control Unit
  236. 1st gen Wagon sunroof leaking
  237. Headlight Projector Retrofit DIY
  238. What is this wire?
  239. How to remove rear seat 82 maxima sedan?
  240. Car will barely start and it stalls when i give it gas
  241. intro? 1983 maxima
  242. head gasket replacement assistance
  243. Mini Maximas
  244. Please Help Need Wiring Diagrams
  245. Cardana24's first gen
  246. rough idle only in drive
  247. Wagon rear seat headrests...
  248. Cold start valve help
  249. Help needed to open trunk of '87 Maxima
  250. What can I replace the front seats with?
