PDA
View Full Version : 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15
  1. Callin' all BAY AREA 2nd gen owners!!!
  2. Hmmmmm
  3. 85 Maxima Oil Filter Location?
  4. Transmission rebuild book and/or #
  5. Halogen vs. Normal bulbs
  6. I need some 86 Max info
  7. Ebay 92 Max
  8. Pics!
  9. Speed Test
  10. ebay intake
  11. photoshop wheels
  12. 82 max with small block V8
  13. Anyone got extra headlights?
  14. what other transmissions will fit...
  15. Stupid Question Time...
  16. Door Handle Needs Repair
  17. Sacrilidge...
  18. Question for those who have dont the 300zx ECU swap
  19. Search function?
  20. grinding while movine
  21. AAV replaced...still high idle
  22. Voting for Maxima.org's calendar is taking place now!
  23. Working on the Cosmetics
  24. Need to change rear seal in 85 Max.
  25. big brakes
  26. air regulator/part number?
  27. fast idle control
  28. reading the ecu
  29. "whering" noise
  30. '87 Maxima, spark plug torque specs
  31. dieing at idle
  32. motor mounts
  33. gunmetal wheels
  34. adjustable suspension
  35. Dashlights
  36. sputtering/backfiring
  37. Check This Out
  38. speakers
  39. Stereo Question
  40. Maxima Compilation
  41. SE or GXE?
  42. Nicotene (?) Stained Paint
  43. stereo
  44. Couple Of Questions
  45. got 2 87's but there diffrent inside
  46. Maxima.org 2004 Calendar...Would you like your car to be featured in the calendar?
  47. Tranny swap complete
  48. Woot woot
  49. Washer/bolt from Heck
  50. Buying my 1st gen Maxima today!!!
  51. Where can i get this peice for my Max
  52. Temp Woes
  53. $600bux 87 Max?
  54. diesel engine swap
  55. Got a couple questions...
  56. antenna question
  57. Is this true?
  58. Another 1st Gen on the road
  59. 87 Max Specs.
  60. Cassette player won't release casette
  61. 1988 Maxima Interior smells like smoke
  62. Where is front pump located on transmission?
  63. finding/accessing the oil filter...
  64. 3 Problems Black smoke, voltmeter, lo power
  65. 3rd Gen 5spd Tranny
  66. performance camshafts
  67. fix one problem find another (orange fiber shake pics inside)
  68. Maxima Diesel Help!
  69. 88 auto to stick swap almost complete
  70. 2nd gen intake
  71. Door Locks won't lock!
  72. Got one but need the other
  73. reverse lights
  74. need info on the u11
  75. best spark plugs to use?
  76. which 2nd gen should i get?
  77. 85 vacuum system hosed pt. 2
  78. Control Arm Bushing Alternatives?
  79. air conditioner compressor clutch
  80. Wipers don't work - 1st Gen
  81. Rear bushing for front lower Control Arm
  82. Help - 1985 security system problem!!!
  83. Oil pressure woes. Help!
  84. timing belt question
  85. color
  86. What a nightmare!
  87. Suspension/Brakes
  88. Pricing/Ordering for 2nd gen CAI now available.
  89. pedal jam
  90. I need some help plz~
  91. Front End Suspension Noise on 88
  92. car inspection
  93. Injectors not functioning tho Ecu is fine
  94. i pulled my radio
  95. when i go to sell my max how much do you think i should ask, pics of it are inside
  96. mounts and PS lines
  97. guage lights...
  98. Finally, a true 2nd gen CAI running off the TB.
  99. WTF Accelerating and Braking
  100. 5 Speed Convos
  101. Oil Changes
  102. Friend with auto tranny problem 88
  103. Don't mean to brag...
  104. Still a really fast idle
  105. Possibly Parting Out 87 Max, Guaging Interest
  106. Lowered Suspension
  107. 85 max wagon trans prob.
  108. ACK! Rust?
  109. Stupid Teenage Girl 1, Maxima 0
  110. C.V. Boot solutions
  111. anyone want CAI?
  112. High beams
  113. Coolant recommedations?
  114. o2 sensor
  115. 87' Maxima running bad
  116. Detailing Questions?
  117. Electrical problem found...
  118. IT FINALLY DIED! (need a seccond opinion though)
  119. More Problems! Advice Needed
  120. "Check Engine" light never goes on except...
  121. Need them clear signals or numbers
  122. Rebuilt Engine/overhaul
  123. Question About Procarparts Guages and Fuel Capacity
  124. Throttle body mod?
  125. Electrical problems...
  126. Maxima SE 5spd?
  127. The Wagon Runs Again...???
  128. Can someone donate some web space for a few turbo max articles?
  129. buyin a 87, need your advice
  130. General Info
  131. Low beams don't work
  132. water useage
  133. thinking about buying the 2nd gen
  134. i need to make sure the battery is connected right
  135. I have a 1987 Maxima with GOOD parts
  136. which is better.
  137. Stalling in Portland Ore
  138. Wagon update...
  139. 88 max door lock question--please help!
  140. sensor light...
  141. Can I install the battery myself?
  142. What Rims Fit 87 Max?
  143. Ideas?
  144. alternator question
  145. Oil loss mystery?
  146. Ground effects
  147. driving a 5speed?
  148. EEK problems
  149. black/tan interior...
  150. Grrrrrrrrrrrrrr!
  151. timing belt question ???????
  152. Needs some leads
  153. Final Farewell
  154. swapping 3rd gen onto my 2nd
  155. Wheel Spacers
  156. Auto Trannies
  157. exhaust system noise advice
  158. Another update...
  159. 82 Diesel Max tranny Q's
  160. timing belt change
  161. I think I've found my muffler!
  162. Installed the SilverStars!
  163. lost my maxima =[
  164. Cheap way to replace struts on an 87
  165. 2nd gen Maxima was the best generation ever?
  166. Where can i Get a full exhaust kit
  167. Make a Bluebird???
  168. Anyonr have a modded wagon?
  169. ac idler pulley needed.
  170. Timing
  171. Super-HICAS?
  172. General Info
  173. 88 max se for sale for all you 2nd gen lovers
  174. Just letting you know, turbo intake for sale
  175. 89 diff in an 85-86 tranny???
  176. Maxima Sits
  177. Since the org is going to be down...
  178. wheres the trany fill plug on a pre 92 5spd
  179. Quick Stereo Question
  180. 82 Max Diesel
  181. 82 Maxima Diesel
  182. Rear ended and written off
  183. Motor Oil Question
  184. Cylinder Head Temperature Sensor
  185. Performance Exhaust
  186. Lights in Blue.
  187. Horn doesnt work
  188. Tires?
  189. I've recently noticed...
  190. acceleration noise
  191. 300ZX compared to Maxima
  192. EAS Front struts
  193. Compression on VG30E
  194. Knock Sensor
  195. Electronic suspension conversion -- confused!
  196. Replacing Positive Battery terminal junction
  197. 86 maxima 99 altima spec. challenge
  198. Allignment woes
  199. Window Regulators
  200. Need advice on replacing rear hub bearing
  201. Best Cost for Performance?
  202. Not be around much for a while...
  203. ok now i am confused...
  204. Help info onTRANS
  205. pricing
  206. decisions decisions
  207. Ohio?
  208. Off-set??
  209. I just bought a new ride
  210. cheap little improvements for the engine...
  211. leaking power steering fluid... again...
  212. 86 maxima to the test
  213. no spark from ignition coil
  214. 86 maxima or 90 accord
  215. My new Rims are on tell me what you think
  216. cruies control
  217. Stock Radio
  218. question about 9005 and 9006 bulbs
  219. 2nd/3rd Gen Comparison
  220. headlights...
  221. battery light...
  222. Shifter bushing replacement
  223. Stupid Question Time...
  224. my 87 max vs. mid 90s probeGT-- max victorious!
  225. exhaust
  226. Hesitation
  227. How can you tell what model Maxima you have if...
  228. JDM 33 Laurel body
  229. posting pics...
  230. Q about oil pressure...
  231. your exparences with airfilters (the good ones)
  232. new ride?
  233. Horn Doesnt work
  234. darkness ahead...
  235. radio problems
  236. Got the Tranny Out!
  237. Front Mount...
  238. Got MAF?
  239. August 23,2003
  240. finally got pics....
  241. Help!! Runs Very Rough
  242. Front Suspension Question
  243. Sluggish Engine Fixed (Possibly)!
  244. burnout
  245. need parts advice.....
  246. Front suspension is done
  247. my black 86 maxima
  248. Fuel Temperature Sensor
  249. whats the stock power?
  250. Inline 6 vs. V6
