PDA
View Full Version : 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15
  1. Hot day...looking for ECU and MAF upgrades...
  2. Steering loss in curves.....
  3. '88 Shiro on CL...
  4. Ecu
  5. Could an improper alignment cause this?
  6. I'm moving on.....and I have parts to sell!
  7. Help with Power Steering rebuild...
  8. 1986 Wagon Runners Project
  9. Couple of engine issues....
  10. Headlights For 85-86?
  11. How to remove trunk carpet liners?
  12. Can we get "stickies" out of the way??
  13. Aftermarket ignition coil code 21 ?
  14. 1986 on ebay pristine condition
  15. 1988 Maxima GXE...ECU mode I one... & EGR, MAF and O2 sensors?
  16. Horns...security system...keyless entry...
  17. Air Box Delete Parts List
  18. Fuel sending unit & Fuel pump part#
  19. About to buy 1988 SE limited
  20. 1st gen engine troubles
  21. 1987 max wont rev pass 2500 rpms
  22. 87 Maxima no injector pulse---Help Please
  23. Intermittent Start 1987
  24. My MAXIPAD DONE FINALLY.
  25. Horns gone bad???
  26. Help - 1987 Maxima Ignition / digital dash issues
  27. No Start with No Codes - No Spark
  28. OEM vs Aftermarket Radiator and Heater Hose Fitment/Quality
  29. Great to see this forum waking up!!!
  30. New user with a 1985 Maxima Wagon
  31. 85-86 Digital Dash Cluster
  32. Production Numbers
  33. Rear sticker badge
  34. Left "A" Pillar
  35. 2nd Gen with Factory Fogs question
  36. Jccs 2013
  37. Engine mounts on a 2nd Gen?
  38. ayudenme con la restauracion de una maxima 1981
  39. My 1st Gen. 84 Maxima (New to Forum)
  40. New 1987 Nissan Maxima SE 5 speed
  41. rough idle, little to no power
  42. 88 model on ebay..
  43. 1987 Maxima wiring
  44. Weekly Check-ins
  45. cd player install
  46. Transmission Removal
  47. new door handle/lock garnish.
  48. Which keys fit our cars?
  49. 1987 Maxima fors sale Houston area
  50. High beams acting weird...
  51. Vacuum Diagram 1987 Maxima V6 3000 (E)
  52. Need a Heater core?
  53. 87 Maxima crankshaft sensor question,need some help,pease!!
  54. What is my 1988 Max worth?
  55. Pic Request: 2nd Gen OEM Floor Mats
  56. Aftermarket CD player Install
  57. Fuel pump wiring?
  58. Fuel Temperaure Sensor / Fuel Pump Regulator
  59. 2 1986 SE Maximas For Sale
  60. z31 axles on 1st gen maxima
  61. My new maxima
  62. Headlight assbly
  63. Finally putting my hands on the Max!!
  64. Online Brochures
  65. left A pillar
  66. Rack and pinion bushings
  67. 1982 Nissan/Datsun maxima 810 Hardtop SSS
  68. '87 SE failing CA smog
  69. My Maxima
  70. pillar
  71. 2nd Gen crash tests
  72. The Dashboard Voltmeter fluctuates*
  73. 87 Max no turn or hazard lights
  74. Engine noise
  75. 5 speed rebuild kit for a 84 rwd
  76. Heater Core Replacement...
  77. Ignition switch problem
  78. bmw seats
  79. VERY Cool Gen1 for Sale
  80. Carb manifold upgrade
  81. Auto Trans rpm bounce
  82. 1st gen spuddering and shooting off black smoke
  83. "Driver Inattention"
  84. 1st gen Oil Pan Gasket replacement
  85. 1st Gen Strut Rod Bushing - TC kit
  86. Just purchased 1st Gen Maxima
  87. No start/Electrical issues and a free fix...
  88. 1st Gen Maxima Sedan fuel economy
  89. Super Rare 1982 maxima diesel Sedan
  90. Manufacturer of Custom Coil Springs
  91. Lowered 2nd Gen camber adjustment
  92. 2nd Gen Lowering Springs no longer available
  93. Driver Shoulder Harness Wont' Go Backward
  94. Vacuum problem
  95. Drivers door problem
  96. Fuel pump dead? '87 GXE Wagon
  97. Link to the build thread
  98. 86 Maxima Wagon intermitent run then dies
  99. my pics
  100. Idler Pulley Bearing Replacement - Bench Vise Size
  101. Small Coolant Leak after Cool Down - Freeze Plug?
  102. Rear Caliper Guide Pins
  103. Goodbye 2nd gen!
  104. 1986 Max Build Thread!
  105. Timing Belt - How To -
  106. Last minute timing belt change questions...
  107. YALL BETTER HAVE A SMART ANSWER!!!!!!!!!
  108. Performance Parts (Most Wanted)
  109. 87 Max wagon for sale on Ebay
  110. 2nd Generation for Sale in Dallas/Ft. Worth Texas
  111. Replace Ignition Coil as Preventative Maintenance?
  112. budget max restomod, first build thread ever
  113. rb26tt awd swap on 85' Maxima
  114. Suspension Q's and a couple other odd bits...
  115. VG30E broke crank?
  116. 86 Maxima Trying to start for the first time in 15 years
  117. Scan/info needed of the timing chain setup for the L28
  118. Looks like I may be back to a Maxima...
  119. 85 died while driving, no spark from coil, throwing two codes
  120. "totaled" my 2nd gen
  121. No Start
  122. 1986 maxima heater core replacement?
  123. help! Just did my timing belt, waterpump t stat and now wont start
  124. Shiro edition 2nd gen?
  125. anyone know where i can locate interior parts for 1st gen maxima?
  126. anyone out there!?!?!
  127. 1987 Nissan maxima hvac blower motor replacement
  128. Sunroof from 1983
  129. '81 Maxima must go.... $350
  130. clear blinker covers and clear door panel covers
  131. Disaster! Cracked Dash!
  132. s12 n/a axles work in first gen!
  133. Had to jumpstart the other day and now the radio doesn't work!
  134. Removing rear windshield?
  135. First gen L24 manual to automatic swap trouble
  136. need wiring diagram for 84 maxima
  137. 2nd Gen Louver
  138. Cutting stock rear springs
  139. Sunroof Seal?
  140. T-belt Tension and Tensioner Clock Position
  141. Water Pump bolt length?
  142. 2nd Gen headlight restoration!
  143. Location of Water Pump and Block Coolant Drain Bolts ?
  144. 83 Diesel Max Wagon on Ebay
  145. Torquing Right (Firewall ) Cam Gear Bolt
  146. Thermostat By-Pass Hose and Fitting
  147. 84 Max, 82 Max, 86 Cressida FSM [For Sale]
  148. went to the junkyard
  149. Good find....
  150. TransAmBandit's 1988 Maxima SE
  151. What Brand Coolant Hoses?
  152. T-belt Tensioner Stud Replacement
  153. best option for exhaust manifold gasket sealing?
  154. seat belt fuse
  155. Anyone Running an Aftermarket Waterpump?
  156. 1985 Maxima pricing?
  157. seats or seat skins
  158. SoCal Maxima is up and running
  159. Look at what i found in my neighborhood!
  160. 84 maxima engine and transmission
  161. rain deflectors
  162. Question for those that did a 1st gen L28 efi swap
  163. short shifter for second gen.???
  164. Need a scan from 1st gen FSM
  165. CHECK THIS OUTTT!!!
  166. 1st gen L28 swap thread!
  167. Should I or shouldn't I?
  168. Can you name this part?!
  169. Manual steering rack?
  170. looking at an '84 wagon, got some Q's
  171. RWD 2nd gen Maxima..
  172. 2nd gen. question
  173. 1st gen Extended lug studs
  174. v8 1st gen
  175. Looking for a factory wheel center cap for a 1982 Sedan...
  176. Anyone have any inside info on the first generation ECU
  177. Head Coolant Plug Reseal
  178. Brake Guide Pin Rubber Grease ?
  179. ECU swap
  180. Model series or vin
  181. A couple of issues with my '88 Maxima
  182. New OE Replacement Catback Pipe
  183. ECU Pinout for an 87 Maxima Auto
  184. Rebuild kit?
  185. clutch issues
  186. Another Developing Problem
  187. My '87!!!!
  188. Looking to revamp the 1st and 2nd gen stickies
  189. '87 AC Compressor
  190. 84 maxima wagon
  191. The Challenge and repair log
  192. Split Boot Replacement for Outer CV Boot
  193. Anyone Know if 2nd and 3rd Gen Idler Pulleys the Same?
  194. 1st annual Jassic car show! {May 29th,Tampa Fl}
  195. Anyone Replace the Bearing in the Power Steering Idler Pulley in 2nd Gen?
  196. where in the hell can I find this
  197. Starter and Solenoid Wiring Pic
  198. 2nd Gen Maxima Getting Huge air VID INSIDE!
  199. Another no start thread!
  200. RB20det swap into first gen
  201. 1st Gens for Sale (ongoing)
  202. thinking about buying a 88 Max
  203. anyone have link to download 1st gen diesel owners manual?
  204. 300zx ecu swap
  205. '82 Maxima FS with 5speed
  206. '81 Maxima front strut assembly
  207. Learn me on an '83 wagon...
  208. wtf
  209. 1st & 2nd Gen Photo Request
  210. 1987 Questions
  211. WTB- SECOND GEN PARTS
  212. Intake setup for 87
  213. best suspension
  214. clean 2nd gen
  215. '87 MAX Heater control panel lighting (manual A/C)
  216. Project Museum VIP - 87 Maxima
  217. 1987 Max runs rough only when in gear
  218. 86 Max and Error code 21
  219. slammed 1st gen sedan
  220. Anyone need any 85 Wagon parts?
  221. on with the old
  222. Is it possible to convert an automatic to a manual??
  223. 87 wagon on Ebay
  224. Clear Blinkers!
  225. '82 Maxima Diesel Wagon on ebay (nice!)
  226. Headlight trouble
  227. 2nd gen help
  228. 87 Transmission Swap - LSD?
  229. lets boost the second gen tlkk
  230. any NYC second gens
  231. some progress
  232. WTB 2nd gen
  233. suspention
  234. CHTS help/info needed
  235. Wheel sizing info needed from the gurus
  236. New member here with an 87 Maxima
  237. 0 gen l24e 810 datsun
  238. Any interest in an '87 Max...?
  239. 1985 maxima find...dirt cheap, $400
  240. '81 Strut Assembly
  241. reppin' for all the 1st gens
  242. amazing what a little maintence will do....
  243. Breakout Box (BOB) for 88' Maxima
  244. Clutch pedal for a 1st gen
  245. SUPER EASY fix for overheating / heatsoak
  246. 1982 ac compressor
  247. 81-84 maxima tokico springs pictures?
  248. '84 Maxim with 45K miles
  249. 1984 Maxima sedan on Ebay
  250. Anyone Install Front Stabilizer Links - Length?
