PDA
View Full Version : 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15
  1. Inline 6 vs. V6
  2. Fuel pump going out...
  3. Pics of some of the new stuff for SE 86
  4. Pulling out the transmission...
  5. Gas smell after running
  6. Power antenna whip replacement
  7. Transmission Whine and Engagement Problem
  8. Compressor tensioner pulley loosens itself...
  9. max88q, could we...
  10. Parts car in Los Angeles area
  11. PCV Valve (part II) and hose
  12. New fog bulbs
  13. Does It Matter?
  14. short circuit/battery draining
  15. Power Transistor
  16. PCV Valve
  17. Test Pipe
  18. A/C Compressor pully and oil?
  19. Power seat belt diagnosis mode
  20. More new stuff for SE86!
  21. Post your pix , My pics inside
  22. yet another t-belt q...
  23. a pic of the new wheels i just bought
  24. trunk switches
  25. Timing belt installed, Max runs fine.....
  26. Loud Noise Got Need Help
  27. Is this anyone's maxima?
  28. Any easy way of replacing the rear engine mount?
  29. finally something good happend with my car...
  30. Need Bolt Pattern
  31. overheating problem!
  32. FS: 83 sunroof panel
  33. History of the Timing Belt part I
  34. exhaust manifold
  35. EAS shock/strut question
  36. Need purchasing advise
  37. I get my Maxima back
  38. newbie replacing t-belt on 86
  39. throttle problem....
  40. Laptop in car?
  41. Can anyone help me?
  42. 2nd gen injector plug mismatch
  43. Rotor comes off distributor shaft
  44. 87-88 spolier. please make offer!
  45. foglight suggestion
  46. engine problem...MAF ?
  47. blew out my exhaust pipe.. replacements?
  48. coolant boil-over tank
  49. uhh any suggestions?
  50. Finally! Dyno!
  51. Whizzeeels and Sprizzings
  52. Radiator Fans not turning
  53. Head Unit Installation In 2nd Gen
  54. headlight bulb
  55. Gas Mileage
  56. How do I get to the fuel injectors!
  57. ok...probally another stupid question
  58. Where can i find.....
  59. Auto tranny shifting problem.
  60. Timing Belt Question of all Timing Belt Questions
  61. Clutch, springs, struts and shocks and bushings
  62. Couple of problems with my 2nd gen
  63. tail and stop sensor
  64. A/c recharge
  65. Remember the problems of the vaccum leak
  66. Power Steering
  67. Power Steering
  68. Antenna Button
  69. New Pics.............
  70. Stupid Question Time...
  71. Hella Supertones!
  72. 91 motor in a 86
  73. Rear wing on 87 Max?
  74. When it rains...
  75. Another idea bust...
  76. Ridin' On Rails!!!!
  77. Auto Trannies
  78. My pa wants to know..
  79. A/C R12 drop-in-replacement
  80. Engine dies sporadically!!
  81. Looking for sales sticker for 88 SE
  82. I'm back!
  83. those stupid little irritating problems
  84. I know i am new but i already got a Q
  85. Suspension Problem
  86. Wheel Size?
  87. 90 Max vs. 86 Max
  88. Bought a new toy!
  89. Need a driveshaft and radiator cooling fan
  90. Cruise Control Inoperative
  91. High Idle Problem
  92. Speedometer Problem
  93. Glove Box
  94. Ebrake?
  95. heater fan
  96. Algae problems in a 82 Diesel Max
  97. '88 Sunroof rattle...
  98. wiring harness available at best buy/circuit city?
  99. R&P Install Problem...
  100. Computers and Auto Trannies
  101. Anyone ever race there Maximas
  102. Question about A/C
  103. How to get coffee out of a rocker switch?
  104. where is the aux air valve at on a 1985 max
  105. Rattling noise during acceleration...
  106. help,digital dash 88' speedo intermittant, code 14 - speed sensor
  107. Battery Drain
  108. No shift into O/D
  109. pictures of wagon with tinted windows?
  110. Should I fight this ticket?
  111. man...
  112. I should have bought the Commodore
  113. My max goes in the shop today
  114. Rough Idle and then clears up once warm?
  115. Cylinder Head Temp Sensor
  116. which of these two dash kits should i buy?
  117. Coincidence? re: new o2 sensor..
  118. Diesel 82 Max... on the Mend
  119. Rebadged my trunk today
  120. common problems wiht second gen gxe wagons
  121. All alone?
  122. 88 Maxima SE vs. 89 Olds Cutlass Supreme SL - Part 2
  123. No More Water Leakage...
  124. Got some stuff for my car :D
  125. need new suspension
  126. Shake, Rattle, And Roll
  127. It's official - The Maxima's Back!
  128. Looking into possibly getting an Short Throw Shifter
  129. 87 Maxima - A/C debris-goes where?
  130. 87 MAXIMA A/C recharge
  131. Possible Opportunity...
  132. Ultimate 1st Gen Max------a limo!
  133. Looking for an 86,87,88 SE
  134. Wtb front lip for my 87
  135. Poll.... need help.
  136. Lil Nismo.... RIP?
  137. the maxima's back
  138. 300zx ECU swap questions
  139. finding an L-series
  140. Another power steering update...
  141. Help car won't run right
  142. 87 maxima with VG30DETT?
  143. NWMaxima meet was today...
  144. Cup Holders For 87' max's
  145. Why cant I search?
  146. Hello
  147. ASCD what is it?
  148. broken head bolt
  149. hello all
  150. Attn: 86wagon
  151. I got me an Unorthodox UDP
  152. Hook Battery reverse car die
  153. 1st gen head gasket
  154. cressidas are better than us?
  155. Spindle / Hub...
  156. Cone Filter Installation
  157. is this possible?
  158. Need Cheap Performance Parts
  159. Sealing Headlights
  160. New Pix
  161. 86 Max for Sale
  162. For Sale!!!!!!!!!!!!
  163. Installing a CD player
  164. top Speed of an 87 maxima?
  165. As soon as I fix one thing....guess what?
  166. Where Can i find a Nice Exhaust
  167. Help me find mfg. date for my new motor
  168. Rear passenger brake caliper stuck
  169. Car Repairs
  170. Fuse for mirrors
  171. Can't Find Sh.it!!!!
  172. sway bars
  173. I Hate Monroe Struts!
  174. Pulling Codes
  175. Opinions On which wheels i should get
  176. My First Time pix of my car
  177. bleeding clutch system 87 max???
  178. Posted new pics.
  179. Replacing waterpump myself any suggestions?
  180. 1st Leg Complete!
  181. 2nd gen motor mounts
  182. Engine Temps
  183. '88 Legran
  184. Lubricating throttle cable tensioner springs (or whatever they're called)?
  185. Stuff like this makes me laugh!
  186. A/C Recharge
  187. More problems with my exhaust then I though
  188. Motor Mounts?
  189. Chilton Manual
  190. P/S work update...
  191. Automatic stalling?!?
  192. Sleepers?
  193. 86 Max Ignition Mods
  194. Problems with my Maxima
  195. Hey Sarin!
  196. Z Car Injector Swap
  197. Z Car ECU Swap
  198. Thanks
  199. Suspension Mods
  200. 86 Maxima Engine Mods
  201. needs maf
  202. Last Day on My Computer............
  203. Had an accident, totaled?
  204. Need Air Filter Info
  205. 87 throttle position switch
  206. 85 Automatic wiggin out
  207. Wiring for remote-start/keyless entry.
  208. Water on the driver side front
  209. Looking for
  210. Seattle Streets: 5 Sarin:0
  211. Did the states get a factory turbo 2nd gen?
  212. I know it's been asked but,...How do i check my ecu on an 88?
  213. tranny part number?
  214. NITTO NT 555s...............
  215. MAF Upgrade question...
  216. Cone filter replacing stock filter
  217. Final Installations.......
  218. Northwest Maxima Meet
  219. Went Profile Hunting
  220. Maf
  221. 86 keyless entry
  222. running trouble
  223. Finally!
  224. dash board lights
  225. 87 maximas with rims?
  226. 87 Maxima - model difference
  227. tranny slip
  228. will a 87 transmission work on a 92?
  229. Introducing myself
  230. I want more power
  231. 87 maxima bad egr valve?????
  232. H.I.D.s That is, if you really want them........
  233. Tricky Hood
  234. sunroof problem on 1st gen...
  235. some new parts and my max feels like new!
  236. Trunk pop and spring probs?
  237. 87 Maxima - sluggish power
  238. 87 Bogs At 2000-2500k
  239. Come in from the cold...
  240. Exhaust gas sensor...error code 33....
  241. Idle Problem(s) with my 84
  242. Need Center Console For 84 AT
  243. Nissan Bluebird SSS
  244. Audis, Bemmers, and Opels........Oh My!!!!
  245. Engine Mount
  246. These coming weeks
  247. fuel gauge problems.
  248. JDM intake manifold arrived
  249. 87 Maxima PARTING OUT
  250. Turbo 88 comin
