PDA
View Full Version : 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15
  1. Where is the PCV Valve located?
  2. Valve lash adjustments L24e and LD28
  3. Oil Pressure Problem
  4. 86 Maxima Cooling System
  5. 1st Generation Mystique
  6. 87 Max timing belt successful
  7. Anyone have a 1st Gen without a Sunroof?
  8. end of the road?
  9. what lowering options...
  10. Codes 2,1 & 4,1
  11. Clutch question
  12. 1988 Maxima RPM Problem
  13. 86 maxima help ME!!
  14. Some help with an 82 diesel.....
  15. Alignment with S/T springs
  16. 1982 Maxima 5-speed for sale in WA....
  17. headlamp removal...
  18. wanted 84 or older maxima
  19. Oil Cooler conversion coming
  20. That rubber timing belt!
  21. stalling - part 2
  22. Servicing the LD28
  23. To warm up, or not to warm up?
  24. setting idle?
  25. 2nd gen intake manifolds.
  26. starting problem
  27. New to the moding cars
  28. need a pulley
  29. Exhaust question
  30. Brake Maintenance / Upgrade
  31. oil pressure?
  32. Vg33
  33. suspension
  34. Need help Please Read (Not Enough Power)
  35. Spark Plug Trouble
  36. 1988 Rack and Pinion and Pwr Steering Pump
  37. need opinion on non-maxima related dilemma
  38. body customization
  39. Tranny
  40. over-heating
  41. Drop it like its hot!
  42. My old Max
  43. new to the maxima world
  44. speedo gear
  45. Always something...
  46. pimp the max!
  47. fuel injectors
  48. 4 questions
  49. Brake switch location 1986
  50. intakes...
  51. To those with hot start issues:
  52. literature about VG20E engine
  53. one irritating problem, then another
  54. 83 Maxima in need of help
  55. 83 datsun/nissan 810 maxima
  56. much atf
  57. Complete Performance/Upgrade Parts Lits
  58. Converting gas to diesel
  59. How Many Diesels were sold?
  60. LD28 Diesel
  61. where does one find...
  62. intake manifold disassembly
  63. Bosch Oxygen Sensor
  64. Cool link on how to tell if you have a VG30 A/B block or VG30 W Block
  65. Stalling on highway
  66. 1987 maxima wheels
  67. anti theft
  68. Shifting Question
  69. Does anyone here actually have the
  70. 2nd Gen SS Braided Brake Lines Group Buy *Please Look & Post*
  71. 2nd Gen Stainless Steel Braided Lines
  72. 1986 maxima handmedown, i need alot of help!
  73. Anybody had to replace the speedometer cable
  74. question for those with S/T springs
  75. Does anyone have dyno results
  76. What the HE11 is wrong with my radio!!!!
  77. Anyone got an extra center hub cover for an '87 GXE?
  78. Power flush---good or bad? '87 GXE
  79. Electrical wire color (TPS and Air Flow meter)
  80. I can now drive my car, but
  81. Tinkering
  82. Two Simple Questions!
  83. power mirrors don't work...
  84. 240sx brake rotors
  85. Broken strut cartridge nut?
  86. Let's see some pics
  87. 81 Max... when all else fails, go back to the basics
  88. How Much is it Worth ? Mint Max.
  89. List your mods!
  90. dash help
  91. werid noise
  92. Some photos from today...
  93. A mod for you guys that dont kno for :calvin:members only!!!!:calvin:
  94. talking lady voice box
  95. Runs great when cold...
  96. where can I get a GOOD alternator?
  97. 88 max likes to be difficult
  98. Broke a timing belt....
  99. SR20DET motor?
  100. That Damn Box
  101. Chts Q
  102. vg20et?
  103. CHC Guys! Check it out!!
  104. Battery, alternator, or other
  105. A wierd noise from engine
  106. Very Strange Steering Problem
  107. F/S:New KYB GR-2s 4 Dirty Cheap
  108. Stalling...
  109. Looking for a 1983 Maxima 5 speed trans
  110. Keyless Entry
  111. moonroof help needed
  112. ATTN dslsmoke
  113. Parting Out: 86 black SE 5spd
  114. water in vent?
  115. 2nd gen OEM clear front turn signal lenses for sale... check the classifieds
  116. tranny?
  117. some *pix* of my ride
  118. Who has the part number for a CHTS?
  119. 86 Nissan Maxima Audio Help
  120. Headliner removal help needed
  121. I need a driver side fender!!
  122. fuel injection
  123. Need some advice....
  124. what size is a second gen axle nut?
  125. Some problems with my 87
  126. Insurance Bull****
  127. Front Suspension.
  128. changing the rear valve cover gasket
  129. 2nd gen setting timing?
  130. Timing belt is gone
  131. replacing the front brakes need help
  132. Rough day, car might be dead
  133. Starting problem, 88 Maxima GXE
  134. Headlight Swap
  135. Sunroof and Trunk -- Please help!
  136. anyone know where i can get a turn signal arm?
  137. brake suspension upgrade parts
  138. Just Run!!!!
  139. 87 Max Exhaust Question
  140. Tranny problems! Help!
  141. Kalifornia?
  142. F/S 1984 Maxima stock grill
  143. Pinpointed my problem.
  144. so where do i find the break booster line?
  145. Nice Rack!
  146. blower motor resistor
  147. My friend's 1st gen...
  148. fuse/fuseable link for parking lights?
  149. alternator not charging
  150. Window pain
  151. What is this mystery part?...
  152. Advice from the crew on 1987 Maxima gle
  153. Where do I find this part???
  154. Sarin... Did Ya Get The ECU?
  155. 88 max aod help
  156. AT filter
  157. 1988 door panel removal?
  158. Cure for plastic headlight hazing
  159. HID's for Sarin.....
  160. ebay auction
  161. Keyless Pad
  162. Audio Installation for 87 Maxima
  163. whos got an extra grand to play?
  164. Throttle Body Position Sensor
  165. o2 sensor install
  166. 86 Wagon Questions;Electrical;Power Steering
  167. 87 max help
  168. 88 Rear Strut removal/replacement
  169. some info for the jdm conversion guys..
  170. 81 with an idling problem
  171. 87 FSM and Haynes manuals for sale *Make offer*
  172. 910 bluebird nose on 1st gen max..
  173. Alternator pull on 87
  174. poor lighting from the headlights
  175. car won't run... where do i start?
  176. Aftermarket sound and OEM Warrenty
  177. 1981 Max got wacked....need a bumper
  178. headlights dim
  179. Trunk lock
  180. Did a little more troubleshooting today.
  181. can i get an intake for my 86?
  182. leaking fuel, need advice (Pic included)
  183. Complete turbo conversion items
  184. Will a doubledin stereo fit in a 2nd gen?
  185. can't decide
  186. Parting out my 1987 Maxima
  187. Moment Of Silence Please...
  188. Help 85 Wagon Wont Idle
  189. Exhaust size? First gen
  190. Torque-RPM chart
  191. New Nissan on the block
  192. Always something!
  193. Hook me up with some Munro Sensitracks
  194. Running WAAAY too rich.
  195. Old School Wagon
  196. 2nd gen front grille
  197. should i sell the 2nd gen?
  198. Some new pics ( engine and Rikens ) 56k - crash into a ditch!
  199. opening up exhaust?
  200. AC/Heater Control...
  201. Coolant temp sensor and CAS on GA16E
  202. aav question
  203. Opinion on a 1984 Maxima
  204. Someone buy this!
  205. Wipers gone wacky
  206. '82 Max getting parted
  207. The 22 freeway
  208. Need a Part Number? I can help!
  209. Stripped Spark Plug
  210. How difficult is it to...
  211. Perfect Maximas
  212. Nissan Maxima 87 clutch separated from air compressor
  213. Wylie stopped by (56k blows goats)
  214. checking codes with scanner?
  215. Squeaking around the front end on bumps
  216. probally the most obvious TPS Q
  217. Leakdown Test w/ broken timing belt
  218. car sputters and dies when "cold" outside
  219. 86 automatic axle, fit an 88 stick shift.
  220. Help needed (brakes)
  221. stupid question
  222. Replacing Ball Joints
  223. One eye willy!
  224. What are the KYB part # to change from electronic setup.
  225. Engine won't run...
  226. Speed-o...
  227. spyware issues on the org?
  228. ECU Trouble Codes
  229. Tune Up!
  230. Best Muffler 88 max
  231. $139.90....good deal springs
  232. Hey Sarin!
  233. how the h31! do I remove the dash board?!
  234. Found why my speedometer not working, might help others.
  235. What is this part, coming from the rear of the 5 spd trans
  236. Quick Q - AAV
  237. won't shift
  238. Motor mounts
  239. Checking for spark
  240. Purchase a 88 max and having issues
  241. How can you tell the diff. btw the 88's?
  242. Spinning 18" of love! (56K, go to hell)
  243. 2nd gear low..
  244. Heat Issues.
  245. Back to using NGKs
  246. how hard would it be...
  247. I'm missing at least 25whp and 25wtq.....crap.
  248. 87 Factory Service Manual for sale
  249. DigiDash-Standard
  250. busted max for sale
