- 87 Max Tranny Question
- Thanx!!
- A/C not blowing cold
- Funny story, maybe...
- Instrument panel
- Wheel stud/nut Issue
- Putting Maxine back on the road
- Help!!! Car Won't Start!!!!
- Digital Instruments Good or not.
- My correction, sorry
- Fresh Update
- UDP and Unothordox timing mark misprint
- who has the talking lady ?
- What's holding the power steering pump in?
- My car's starting to make me mad!
- Turbo anyone?
- Sold the Honda
- So I finally hit the track for the first time
- Alternator question?
- Keyless entry Master code on 85 Wagon
- Please help w/87 maxima problem
- Progress report
- Ashtray light
- Studs!?
- Transmission...
- New Gen 2 Owner - Suspension Upgrade
- New Gen 2 Owner - Tranny Swap
- New Gen 2 Owner - Intro (bought it last night)
- air dam question
- Power Steering Leaks
- Cold-Air Intake
- computer question???
- bypass hose replacement
- Ouch! My to do list keeps growing!
- Idling problem
- 1985 Maxima
- Specifications for LD28 Diesel
- Happy NEW Owner of a Maxima 2nd GEN!
- ATF fluids...
- exhaust setup?
- Is Maxima.org Up And Running Fully?
- What does a Auto tranny weigh?
- help....yet another q' :)
- 30% off Nissan OEM list ends April 30 2004
- Front Motor Mount
- forum is dead...someone build me an intake
- Vapor lock????
- Problems removing seats and VSS question
- Hello, im new here
- 88 Maxima replacing rear brake pads
- EGR Valve?
- Radio swap on 85 1985 Wagon .. ?
- help! quick Q'
- what sensors and parts should I pick up?
- 1st Gen Audio Question...
- rear suspension install problems
- Rear shocks
- Finding Parts
- SE front bumper wanted
- Disc brakes....check it out
- getting there...
- ALMOST Hydro Locked
- Hot Start Woes
- Im Rich!!!
- Shocks???
- Need advice on vacuum lines and seat
- Keypad Beepy Going,going,gone..
- Pics of Stillen Exhaust (56k warning)
- Gen 1 door fatigue fix
- DYNO question to members of the org.
- Tips + tricks on pulling a second gen motor
- Need To Restore 1986 Maxima
- hope to be getting back into the maxima picture
- Swap!!!!
- Curing a Rough Idle Problem
- New 2 Board
- f/s: '85 maxima
- Gen 1 AT trans mount for diesel
- Anyone driven/ have both 1st and 2nd gen?
- Maxima meet in MAY please read!!!!!
- Very Good News!
- 5 speed wont go into reverse
- I need a 5-Speed Drive Shaft for 1st Gen
- replacement struts
- whats the demand for second gen parts?
- Questions from a Newbie-Swap, throttle body, shocks
- friend of mine just got a 2000 cavalier...
- doors wont open ...........Help!
- Where does the EGR hook up on 1st Gen?
- I need some help
- What happened here? Oil leak + no idle issues (pics inside).
- Headlight Problem seeking advice
- HELP PLEASE with manual transmission problems :(
- everyone here is gonna hate me.......
- H2O on the ground #*@&#$
- Need Help!!!!
- Brake bleeding
- help: squeaking noise
- Any Ideas ?? Help here***
- Stick shift problems (position?)
- plugs
- bolt on mods for HP
- fuel/emission problem
- Is 0-60 in 7 bad?
- VG30DET's for everyone!
- ignition
- Don't have new pics.....
- 87 maxima parts car, PRICE LOWERED, now $200
- Erratic fuel gauge
- Antenna woahs
- Boom!
- paint touch up
- Manual Swap a Success!
- transmission
- Parts
- Throttle body
- 300zx ecu
- Can anyone with a manual max help me?
- Does anybody has parts for an 81-84?
- Online used parts?
- A/C belt and others
- Nissan Master Tech for Hire Ohio area
- driver side wiper not working?
- Engine Cradle
- Digital Dash...
- losing power (87 maxima)
- Possible Down-grade...
- Power Windows problem..
- How much hp am I looking at?
- Auto Tranny Woes
- Exhaust issues...
- Installed a Stillen Exhaust on my car.
- I think I found my wheels...
- Resetting keyless entry code 1985 Maxi
- which struts?
- y-pipe...gutted?
- 9004 > 9007 headlight conversion
- Wheel Heigh Measurements on 1st Gens?
- Wheels, this question again...
- is it possible that.....
- Shifter/brand name question
- 87 Won't start
- My dilemma that some of you may know about
- what weight oil should i use on my 88 sedan
- I did a few things too...
- IM BACK (new pics)
- crazy idle
- Tires...
- P/S pump...
- Glad To See Ya Back MaxWgn
- "Spot Light" in 1st Gen Maximas?
- New clutch in now I need...
- If u need parts check this out, Maxima f/s $300.00
- general performance parts questions
- auxilary fan
- Need Exhaust
- turning steering wheel does not turn front wheels
- just wondering........
- Did a few things today.
- Larger MAF
- 200k club
- Woo Hoo!
- Wiper Question
- how strong is the '82 rear end
- Anybody with an '83 or '84 service manual?
- replaced thermostat...much better
- Havn't got my CAI yet
- Addco Swaybars for 1st Gen
- Where is flasher located on 87?
- Questions on my 86 Max: Help?
- back to maxima.org....
- vacuum hose kit?
- Got a ?
- FS: 87 SE stock tape deck and EQ
- how in gods name do I remove this pulley?
- tires and lowering
- 87, having crazy idle
- changing belts on 87 Max...
- High Beam's quit working!
- Takes forever to warm up in winter!!!
- Timing belt...
- Newbee with a question
- Manifold CRACK! HELP
- shift knob
- headlights
- squeaking engine
- 87 lower springs?
- Time to replace the starter...
- New wheels!
- Getting some studdering...
- What could cause hi readings of HC at idle?
- not exactly a L.E.D. taillight mod
- Just thought i would give u guys a heads up, I might be parting out the max
- Finally, a decent battery!
- Warm start problems.
- R31 Skyline - looks just like a Maxima!
- Lookin 4...87/88 Maxima parts
- Still experiencing starting problems...
- Looking for a wheel upgrade for my 1st gen
- output ?
- cold no starts
- FS: 87 Maxima
- Paging MaxWgn!
- anyone have a 88 factory service manual handy
- cork in hose?
- got a ?
- autolite??
- recall?
- can anyone tell me what trim i have
- how do i read codes?
- My car is stuck in reverse?
- Battery cable questions
- Timing belt parts
- meeting for the LA autoshow 1/10 sat....
- Horsepwr
- Diesel Maxima specs
- Problem on the horizon...
- running hot
- Newbie and a water pump question!
- Door handles
- struts for 87 Maxima
- why is?
- PIAA Xtreme White 9004 question
- 1st gen carpet set?
- Fuel Pump Hum -1987 Maxima (5 sp Manual)
- struts
- Got me a wee bit of a problem.....
- Got the new bumper on!
- fuel meter guage
- RIP my Maxima
- 87 maxima intake??
- BMW Headlights and heater question
- gas smell
- aftermarket deck instal
- brake problem
- The MaxPC
- engine problems
- 86-87 Maxima ANTI THEFT HELP??
- 1988 Maxima VG20ET
- 87 SE Maxima engine trouble...
- 87 Max on E-bay
- The worst night yet
- Starting Problems
- cup holder?
- idle adustment?
- Finally got some pics!
- Hey guys, got stuff for sale...
- idler pulley assembly
- 88 maxima stalls when put into gear
