PDA
View Full Version : 7th Generation Maxima (2009-2015)
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
  1. Rattling noise
  2. AC Relay location?
  3. Best head unit interior mod
  4. Replacement axle
  5. Tapping into front turn signals
  6. Big Brake Swap
  7. Coolant Reservoir
  8. 444,444 miles
  9. CVT Fluid Brands To Use in Canada?
  10. Watch a Nissan Maxima plow into a gas pump
  11. Head unit mod affecting door locks.
  12. Key fob not working properly after car battery disconnect.
  13. parts for 6 speed swap
  14. Trac cont. Lights coming on.
  15. Rear adjustable camber arms
  16. 2014 Maxima SV Dying while idle in Drive
  17. Replace all 02 sensors in 2009 Nissan maxima
  18. Headlight out. Need reaplacement help
  19. Almost stalled while driving
  20. Drivers door handle opens but with hack
  21. Key fob has new batteries and still does not lock doors
  22. Oil Pan Replacement & Removing Y Pipe
  23. 7th Gen Maxima Transmission
  24. Rough Idle during Long Trips
  25. P1778 Stepper Motor CVT Fail & Fix
  26. Coolant reservoir is bubbling and smoking.
  27. 09 having a idle issue
  28. Replacement parts painted to match suggestions
  29. 2014 — Water in passenger side footwell after rain
  30. rough idle
  31. A/C Lines Stuck on Compressor
  32. Rear lip aprons install.
  33. Small A/C Leak
  34. Help! Trying to diagnose this noise
  35. Q50 Red Sport wheels on a Max?
  36. Limp mode????
  37. Air Bag Control Module
  38. 2014 Maxima is locked
  39. 1st Time Coil Overs
  40. Mudflaps?
  41. Floating Roof Design on my 14' 7th gen.
  42. Hi want to ask where is transmission output speed sensor for cvt transmi maxima 2013
  43. All four O2 sensors all have odd readings
  44. Rpm’s not normal
  45. How many of us out there have had a failed cvt?
  46. Need help with alternator connector - wiring issue
  47. Where to buy proper CV axle shaft
  48. 2009 Rear Blinkers not working
  49. HID headlight replacement
  50. Shakes after mount replacement
  51. Bc coils vs true rear coil overs
  52. I finally wore it out
  53. Ran out of gas now engine won't crank
  54. Broken spring/coil in front passenger shock...
  55. Aftermarket Screen?
  56. Help 2009 Stalling no start issues
  57. Radio and Climate Control panel not working after fuse replaced
  58. Score!! Any advice/suggestions?
  59. P0175 & p0172
  60. Diagram of factory radio connections needed
  61. CVT drain plug washer?
  62. Car struggling to start
  63. 2013 Maxima - Android Auto Options?
  64. Transmission Swap Options
  65. 2021 5 dvd map pack question
  66. Col pack
  67. 2013 Nissan Maxima bluetooth streaming not working
  68. Issue with A/C wiring
  69. Climate control issues
  70. Coolent leak, please help!
  71. Convert 2011 headlights to LED?
  72. ECU reprogram is a "MUST" after OEM MAF replacement?
  73. 2012 maxima slip light on start up
  74. 9 speed zf
  75. HID Headlight problems
  76. lady in distress
  77. Weird chirp sound
  78. 2014 SV Replaced Front Struts With Carquest Brand
  79. 2014 SV 90K Miles Transmission Delay
  80. Leaking mystery part
  81. Bluetooth not working
  82. 2009 Maxima S suddenly hesitant to accelerate, please help!
  83. Looking for recommendations for deep sounding exhaust
  84. Tesla Style Android Auto Aftermarket Radio
  85. 7th Gen fuel door spring
  86. Navigation
  87. Stiff Power Steering
  88. Exhaust system
  89. Help, I hit something and now my Altima has shaking issues
  90. How to remove swirls in paint and bring the luster back?
  91. Rodents like rubber hoses made from soy
  92. 9.5 Rims & tires
  93. Belt keeps shredding
  94. 09 oil leak
  95. my Battery keeps dying on me
  96. Vacuum hose sizes
  97. Price quote for plugs?
  98. sporadic starting issues
  99. How much power steering fluid the system holds?
  100. Anyone use a trunk mounted bike rack? What kind
  101. Cooling problem
  102. 2014 Maximum S - Fog Light install
  103. 2009 Flooded rebuild
  104. cloth seats/interior for sale with armrest, headrest
  105. Looking for tuning suggestions
  106. Can somebody please tell me if it's possible to bypass the a/c compressor in a 2009 M
  107. Radio and air-conditioning
  108. Tranny fluid change
  109. Starting problems after driving more then an hour
  110. Left rear ABS sensor replacement
  111. 2010 maxima repair questions
  112. Goodbye To My 7thGen
  113. 2011 Nissan Maxima Radio and clock display not working
  114. Apple Music getting video won't play message
  115. Noise from Engine after stop and accelerate
  116. Thumping sound going over small bumps, 2012 Maxima
  117. Shocks & Struts 2012 SV
  118. Vibrant resonator
  119. Vibrations, engine noise and shudder when accelerating
  120. Rear deck speakers not working non bose system
  121. How to adjust 2014 SV headlights aim higher?
  122. Rear camber kit finally installed
  123. 2011 nissan maxima wire colors
  124. Possible bad alternator, but maybe not...need some help...
  125. Melted roof trim rubber (with pics)
  126. Whining when pushing gas in park and while accelerating
  127. Humming by th belt
  128. 09 maxima front door speakers
  129. Replacement Interior Trim
  130. Radio/HVAC Head Unit Has Gone Out
  131. Purchasing a 7th Gen...???
  132. Suspension
  133. Change radio bezel
  134. 2011 SV 130Kmiles, Downshiffting coming to a quick stop
  135. 2010 Maxima SV Issues
  136. Does your Max have a Daytime Running Light fuse?
  137. Driver lock
  138. I have several codes on my 2011 Maxima
  139. Installing an Interior Switch for DRLs
  140. Opinions on which way to go - CVT
  141. Exhaust tip question
  142. 2010 maxima random loss of power to gas pedal
  143. Best buy radio installation
  144. Interchangeable gauge clusters
  145. Slight shutters and vibrations on acceleration from low speed.
  146. What's the best setup for BC Racing coilovers?
  147. 2010, 7th gen SV -- AV system, HDD, Music box fail
  148. Serious rattle and miss on startup
  149. cel p0507?
  150. 2013 Coolant Service
  151. Center Console Rear Screws
  152. TDC MARK in VQ35DE 2009
  153. Raspberry Pi through the auxillary Maxima
  154. Drivers side mirror cover
  155. LED Third Brake Light Strip
  156. Cleaning the TB. Ideas?
  157. Power outlet not working 09 7th gen maxima
  158. Need a new Purge Valve Solenoid/ Canister?
  159. Airbag Light Blinking B1139
  160. new shoes on ride
  161. Master switch replacement
  162. Wanna significantly increase your Max's HP?
  163. Cost to replace two O2 sensors?
  164. Shaking at 70mph
  165. Replaced car battery, fob not working
  166. Dead Batter - Power Draw?
  167. Location of passenger OCS connector
  168. 09 Maxima Transmission Dipstick
  169. Have a fuel leak which when I start the car it's started once started car
  170. Airbag light flashing - OCS issue
  171. 2011 Maxima not turning on Battery Dead? Theft immobilizer?
  172. Maxima awd or rwd
  173. Low Tire Pressure Warning
  174. Temperature reading up and down
  175. Replace Struts Still Rides Hard
  176. Replaced battery. Lost seat and steering wheel settings. Need help with settings
  177. Switched the 2 Maximas to M1 European 0w40
  178. 12-14 tail lights on a 09 max
  179. Tire Maintenance Warning
  180. Idler pulley or tensioner making noise
  181. Antifreeze leak
  182. New to the club
  183. P0014, P0024, need help on 2014 maxima
  184. 9.3GB music storage
  185. Solved my front spring/strut conundrum
  186. Can you use 350z pulleys
  187. New rear shocks
  188. Seasucker for Panoramic sunroof
  189. How accurate is the mpg on the dashboard?
  190. Car just hiccups sometimes going down the road?
  191. Intake CEL
  192. First time Nissan owner
  193. Front strut oem or after market
  194. CVT Maintance Question
  195. Which 7th Gen Maxima Is The Best?
  196. O2 sensor
  197. Alternative CVT fluids
  198. groaning / whining noise - looking for ideas
  199. Question about crush washer for the oil drain plug
  200. Auto lock/unlock problem
  201. Tail light wires
  202. Mono to color screen 2010 maxima sv
  203. Brake and battery light
  204. Loss of power at 110 MPH
  205. White 7th gens
  206. light strip
  207. SV Tech and SV sport same struts?
  208. Antifreeze leak from bottom
  209. How to: Fixing a Sticky/Melting Dashboard (with pics)
  210. Loud rubbing noise while turning the steering wheel, steering column issue?
  211. Please Help Identifying This Part
  212. No throttle/acceleration response problem.
  213. Strange Vibration
  214. Fall River Ma area lowering springs instal
  215. Used 7gm owner should I get a cvt flush?
  216. Slip light
  217. Power steering line
  218. Rear Shocks
  219. 2012 Center Console Power Port
  220. 2014 Maxima sv w sport package
  221. 2010 Maxima SV starting problems
  222. Seats
  223. Shifter nob from 5th gen in the 7th gen
  224. Front-end noises: your input is appreciated
  225. Test pipes...
  226. UpRev tune with CVT ?
  227. 2012 digital info center
  228. P0725
  229. $1200 for P/S high pressure hose replacement?
  230. All of a sudden, about one degree of freeplay in steering wheel
  231. 2010 rear power shade replacement.
  232. Engine Knock
  233. Complete Front End Suspension Upgrade
  234. Coilover installation
  235. Shock and Strut Replacement
  236. VTC solenoid noise?
  237. 09 Maxima rear suspension
  238. car shut off
  239. Colour Screen VS Orange Dot Matrix Screen
  240. spare tire question
  241. 2013 Maxima Backup Camera
  242. 2013 Maxima SV a/c Repair (compressor)
  243. cvt vs hill
  244. Driver and Passenger front doors won’t stay open
  245. Brake Calipers
  246. Sticky situation
  247. Cxj throttle body spacer
  248. Squealing/ grinding noise when making turn
  249. Belt squeaking after hitting a deer.
  250. Error messages
