- From throttle lag to complete unresponsiveness
- Need to replace sway bar and links 2010
- Service the CVT? 2009 w/ 59k miles
- How do I access the Top Mount on Rear Coilovers?
- I've a question
- 09 Radiator Replacement
- Driver and passenger footwells wet
- How should I tackle restoring a 2011 Maxima Clusterfawk
- Gen 7 CarPlay
- Driveshafts
- Need help
- 2014 Nissan Maxima Rear Window Defroster Not Working
- Oxygen Sensor Voltage going crazy
- 2011 Nissan Maxima SV with sport problems
- Bad CVT Fluid Change
- Oil leaking
- 2014 Maxima 3.5L Startup diagnosis.
- 7GM has no power during acceleration
- Battery/Alternator issues 2010
- Need advice on aftermarket system installation please!
- Battery and Brake light extravaganza
- 09 maxima p0430
- Can I fit 350z/g35 cams in a 7th gen maxima vq?
- My car won’t start
- My won’t turn on
- Under engine splash shield
- Aftermarket Screen Upgrade
- Which O2 sensor is between radiator and engine?
- 5th gen to 7th gen transmission swap
- Should I buy 2010 Maxima?
- Drive belt clicking noise
- what is this item, washer?
- Old and new problems with my max
- New strut time
- Black December
- ECM fuse keeps blowing
- Downsizing from Upsized tires.
- Clunking noise
- 2010 Maxima S Audio Fuses - Which Fuse is for What?
- Racing Seats that fit 7th gen
- Anyone selling a MotorDyne exhaust set up ?
- 2014 Nissan Maxima SV iPod problem.
- Cold Start Noise from under hood just changed transmission twice. Out of Money$!$!
- Another Electrical Issues Thread...
- Electrical Gremlins.. SOS
- Electrical issue with My maxima
- Swapping side mirror blinkers to sequential on 14 sv
- Swapping options from 2010 SV to 2013 S?
- Stall at red lights or traffic
- Noise when slowing down/start
- Where is the resitor on a maxima 2009
- Can I use Halogen light's instead of HiD if the car came with HID lights
- Help!! Trouble with power locks on doors.
- 17 inch rims
- Need Trunk Wire harness rubber boot
- 17 Inch rims for 2012 Maxima s
- Wondering about rim size
- 2012 Maxima driver seat switch not working
- Just bought a 2012 Nissan Maxima
- VDC problem
- 6spd Swapped 7th gen help/thoughts?
- Steering Rack Change
- P0500 & P1778 Code on 2014 Maxima S
- Short causing problems
- Heavier brake dust on rear wheels?
- 2013 Maxima Belt tensioner noise
- What are my options for headers?
- SUSPENSION: 2013 Max S
- 2009 Maxima Wont Start
- '14 Maxima overheated; Now won't start
- Fog lights
- 2014 nissan maxima
- CVT Rebuild
- White background dash lights not working
- tire wear after allignment
- Flashing dash lights/car losing power (2013 Maxima)
- ecm
- Need your help
- Fog Light Installation Help Needed
- what should I service with a CPO 2014 ( 47k )
- Vibrant Resonator options?
- 25k short!
- What do you think a Nissan Maxima is worth today?
- 2014 Nissan maxima sv
- P0455 sequence of diagnosis?
- Need help with p0746
- No spark to plugs
- 2013 Maxima SV Stalling in Idle
- No Start
- Water inside the car. Carpet is soaked.
- Changing fuel injectors
- cd player in maxima 2012
- Engine Temp Gauge showing hot but Not??
- Scammed? Need some Suggestions/Insight!
- Headlamp not working, moisture in hl housing and ballast
- Correct P/N for Rear Seat Belt - 2012
- 2011 Maxima - Issues?
- Front Doors Not Locking issue?
- 2013 maxima sv
- 2013 maxima sv
- need alarm system recommendation
- 2010 maxima rough idle
- New battery and altonator still wont hold charge
- Squealing Belt
- Cylinder Firing Order Diagram #3?
- From a 2011 to 2017 (Rayyyy)
- Nissan Maxima 2012 door issue
- Timing chain
- 0-60
- 💡 put some led fogs and highs, ready to start adding some cosmetics
- What are these wires? (White/black)
- Key Fob Beeping
- Running good and then died all the sudden, cranks, but won’t start back up
- Ignition Coil Compatibility of Different Engines
- Suggestions for fuel cleaner, fuel??
- VTC solenoid connector STUCK
- SV Sport Premium
- Wants to quit after idling for a while
- Do I need a new transmission
- 2013 Maxima S - slight jerking issue
- Oil Catch Can step by step
- Got a CEL for Transmission
- transmission replacement or?
- Backup Camera Lines
- 2009 Nissan Maxima S 3.5l
- HELP!! Aftermarket LEDs
- CarPlay - Maxima 2014?
- 2009 Maxima Loss off acceleration/running
- 2013 Nissan Maxima won't start
- Parts illustration catalog source
- Battery drains down if not used for thee days
- 2014 maxima locked out.
- 2011 maxima transmission service
- Help, one headlight doesn't work after being replaced
- 2009 MAXIMA Stalls at idle after 30 minutes of driving.
- Tail lights, license plate lights, shifter lights are out.
- OBDII port not working, brake and gas light on. Need help.
- New headlights and fog lights
- Bad new alternator? Problem with ground wire?
- 2014 Intermittent vibration
- Camshaft position sensor
- Weird noise from under hood, near the driver side wheel
- No start?
- Quality of TYC tail lamp assembly
- P0746
- 2014 maxima, jerks at low speed and RPM. Ideas?
- Head Gasket is Blown
- Weird vibrations
- Dashboard display blank
- engine "da da da..." noise when pressing the gas pedal
- what's leaking?
- Engine mount
- RHD workshop manual
- Suggestions for an upgraded radiator?
- Dual Climate Control
- A/c not working, blows ambient air temperature
- U1000 Heater & air conditioning code
- Flush coolant system
- CVT Filter 2009 350Ti
- Pano roof rattling
- Head gasket?
- Tires fit my 2012 Maxima
- Accessory power question.
- 2014 Maxima Transmission Valve body Replacement
- Acanni DRL Headlights: Any one find Good LED's that Fit
- Hood bumper dissolving
- head units
- Another ABS/Traction Control Issue
- 2012 HVAC control/display
- MONROE 272604 / 272605 Question
- Screen dimming and clicking noise
- 19 in wheels help
- Camshaft Position Sensor
- CVT Failure at 72k
- Where does this plug go
- Power steering pump serpatine belt issues
- Fuel door actuator
- Camshaft Position Sensor Location?
- Need help with PN for Throttle Body hoses
- Another post about charging - interesting issue...
- Problems with charging
- Bluetooth control unit
- Rpm moving on it's own after driving car for a while
- Cheers to Rock Auto and Monroe Jeers to the Lt.
- Power Stop KC6075 Z23 Evolution
- Newbie aftermarket Projector housing help pls?
- What do you guys think about this
- 2010 Nissan Maxima
- Bird like Chirping Inside the Cabin
- Megan OE-RS Exhaust
- 2012 with 98k help!
- Vibration when given throttle
- Radiator Hoses
- 2014 nissan maxima transmission fluid change Interval
- Went over a puddle and my engine shutoff
- Panoramic Sunroof Drains
- Alternative start options
- 2014 SV Non Sport Rear Shock Recommendations
- Transmission oil cooler
- Aftermarket Bluetooth Module Questions
- Installing Heated Seats
- 2010 Maxima S Radio Questions
- Adding a brake light
- Borla or Stillen exhaust
- Serpentine belt jumps only when cold.
- Effing battery+brake light came on... (with pics)
- Radio issuse
- 2014 Maxima: New battery no radio for 1 hr??
- New to the forum and to Maxima’s
- Transmission leakage
- 2011 Maxima Widow regulator repair
- Install trunk lid with spoiler where there was no spoiler?
- 2009 Maxima SV-Panoramic sunroof leak
- sun visor replacements
- Does anyone have any obx headers for a 7th gen maxima?
- 09 maxima 350z heads
- Repair manual for 7th gen. Maxima
- Driver’s Door Won’t Open
- aftermarket stereo
- 2014 power steering not working
- Rear Lip Spoiler no 3rd Brake light / permanent
- What is the drive cycle of 2010 nissan maxima?
- Cold weather high rpms
- Rattling noise while idling or low rpms.
- Help. Please crazy oil in intake. Field of smoke
- 2012 Maxima 100k miles - engine knocking LOUDLY
- Vdc,slip,brake,abs,key lights all on
- Motor Mount part number confusion
- 2010 Maxima Navigation System Question
- Code 0024- Vvt solenoid
- Windshield washer nozzle aim - 7th generation
- 2010 Maxima - Evap Leak
- 2010 Maxima - Key Fob / Driver Door
- engine area high pitch ringing w engine turned off
- Weird Noise
- Offset and spacer...
- Engine making a sound when stopped
- 2010 maxima
- Intermittent idling and headlights going dim to bright
- Does a 2011 have a fuel filter?
- Power Steering Pump Failed. Replace on my own or pay someone?
- CVT Transmission Pan Gasket
- PROBLEM SOLVED with no start after gas
- 2012 Maxima SV - speed sensitive steering quesrion
- 2014 maxima won't start after getting gas
- Not starting
- 8th gen to 7th gen motor swap
