- Rough Idle no CEL
- On the edge of being a new Maxima owner
- Well guys it's been fun...
- Trouble Codes P0171 & P0174
- 250a battery fuse keeps blowing
- Chirp/Rattle/Passenger Side Engine
- Maxima SE throttle control motor problems
- CVT issue, please help
- Can a Maxima 2010 CVT work on a Murano 2010 (not AWD)?
- Warning sound not working
- Took my 09 Max to get alternator replaced
- 2011 Maxima S options
- armrest console lid
- 2011 Nissan Maxima shifting issue
- Help please. Losing power while driving
- Kumho Ecsta LX Platinum?
- 2010 Maxima Alternator harness
- Where to hide the OBDII adapter?
- Passenger cv axle removal help
- 2009 Replacement Hood
- Blower motor replacement
- Front signal pigtail
- Our cars take ages to warm up?
- Car wont start?
- Is it worth calling Insurance over this?/Where can I buy replacement parts
- Trouble finding a replacement side mirror
- 2009 Nissan Maxima SV Air Conditioning Mode Question
- Front Sway Bar Bushings
- Who still has their 7th gen....?
- Air tube from catalytic converter
- It this CVTF deterioration value possible?
- Nissan Maxima sv 2011
- Still getting P2101 Code After Throttle Body Change
- Steering Column Play
- Smoke coming from Glove Box
- What's causing my tranny to slam into gear?
- CVT whir
- 3rd Brake Light
- Rear deck speakers not working
- Motor and Tranny Mounts Shot
- Advice on rim size, thanks
- accidentally put in 30% ethanol fuel...
- New 2013 Maxima Owner
- Power steering noise
- Where can I buy a demon eye kit?
- Exhaust fumes from tailpipe after engine turned off
- My 2012 maxima build thread
- new shoes for the Max
- Fuel gauge misreading - car won't start
- Single exit?
- Our cars are getting old...is anyone actually still using premium gas?
- CVT fluid stinking in and around car after dealer fluid flush
- 350z or g37 exhaust on a 7 gen?
- Warranty Policy Enhancment from Nissan
- Cleaning tan leather seats 2009 max
- Audio options
- Steering issue
- Phone Mounting
- Sun roof drain
- 2010 maxima starting problem
- Have anyone asked the Nissan Dealer to set engine braking to OFF in Maxima 2009?
- Adjustable rear swaybar
- Nissan 2010 maxima S CVT
- Running without TPM sensors?
- 18" wheels with 35 offset?
- Bluetooth Streaming Audio Solution (Ask)
- 2010 maxima front passenger door will not open
- CVT: Issue or normal operation
- Ticking after mass air flow sensor 2010
- No heat to floor vents
- Noob question, checking fluids.
- Looking for brakes upgrade
- 0-60 and top speed
- Help pls!!!
- Wheel bearing brands
- Key fob range
- TIRES-245/45R18 to 225/45R18
- Automatic Door Locks
- 09 Max * WATER LEAK * HELPPPPP
- Help diagnosing a humminmg noise
- Car stops accelerating with no warning or reason
- p0430 on 7th Gen
- Metallic clanking sound at start up
- 2011 "Safe Mode" - what is suggested Diagnostic work flow?
- 2012 Radio install with Tech Package
- Any difference in 09 and 2012+ Grills?
- Clicking noise
- Any one deal with Rims from xxr -559
- Replacing my 2010's cvt filter, who knew....
- Coilover max2014
- Race line or motordyne Y-pipe
- Anyone have experience with Weapon R throttle body commander?
- Using battery tender all the time?
- Wheels that fit the 2010?
- No sound from stock Bose system 2012
- Rear suspension issues 2011 nissan maxima
- Climate control issue
- Belt tensioner pulley replacement help
- A/C and all other Climate Controls suddenly shut down
- How do I replace the fog light bulb?
- Satellite radio issue
- 2010 maxima brake fluid flush
- Drain and refill cvt transmission or just add
- MusicBox Problem
- Wheel Bearings Replaced
- Engine mount parts Maxima 2009
- plz help !!dark purple fluid leaking in the front left side of maxima 2010
- Is 136k miles high on a 2011? avoid?
- questions regarding no start issues, searched
- 7th gen: Paddle shifters: useful? fun? necessary? gimmick?
- Tow hitch for our cars?
- Timing chain and service eng light
- In the market
- Central Jack points for front and rear
- Cv axle
- longer studs/spacers
- Anyone tried changing tpms batteries?
- Fog lights and pass headlight issue
- 7th Gen Maxima Power Steering
- 2008 shutdown
- Problem with my factory HID headlights.
- Still having issues...
- USA Spec BT45-NIS
- An open intake tube?
- removing the dash/radio
- Cvt
- 2011, 70k miles, charcoal cloth, 1 owner for 10k?
- Rattle from low acceleration
- 2012 CVT issue?
- How long do replacement tensioner last?
- Vern
- Bluetooth Control
- Tire Pressure Gauge and Aftermarket Wheels
- Fuel Door wont lock.
- Wheel hub and suspension
- Wiper problems
- A/c relay location 2014 maxima sv
- Rattling noise in cabin (ground wires?)
- front under body plastic engine guard
- Buyer question
- Subwoofers aka rear speakers not working
- Need help removing Tension pulley
- Megan exhaust
- Common timing chain issues?
- Key fob not working
- Electrical issues
- What to look for this 2013?
- Power steering
- Best summer tires?
- Help!!
- 7th gen (2011) maxima AC Compressor bypass belt size
- fogs getting more voltage when car is on vs. off?
- Alarm/Electrical Issues - 2013 Maxima S
- how to make ride comparable to an Infiniti Q50?
- Help! After Strut replacement Smooth ride on normal roads but bottoms out unusual
- Megan Racing
- Replacing a Power Mirror Turn Signal LED
- HID Conversion *NOOB*
- Changing fuses
- Clicking
- Top speed and warranty question?
- 2013 Maxima. Installed Magnaflows and less power/better mileage than stock?
- Flat tire! Missing lug nut key
- Melting tail lights
- Removing glove box
- 2011 Maxima CVT Bucking at Highway Speeds
- Front headligt side marker
- Repair of Nissan information display in center of gauge cluster.
- Replace Inner Tie Rods
- BC racing or D2
- Water in maxima
- Removing rear seats on 7th gen
- 2010 bought today...a few Qs
- Battery charging issues, Reman alternator on 2010 Max
- How much for lip kit painting?
- 2014 Maxima fog light question .
- Elephant Grey Vinyl with ESR BBS Reps.
- Floor jack placement
- 2014 SV loosing power/trans slipping?
- Need a new Rack and Pinion - EVO??
- installing switchback led resistors tip
- Emergency Brake Light is Always On
- Looking to swap out head unit (2011 SV)
- Brake upgrades
- Sensor/thermostat Help
- 09 Maxima VDC,ABS,TRACTION CONTROL:LIGHTS ON HELP
- Car shop saying this kind of damage totals the car
- 2014 Maxima S, 58K miles - how to make ride smoother?
- Voice Recognition
- Poorer-than-you-think fuel economy
- Nissan Maxima 2011 Problem!
- Can/will dealership program an aftermarket key fob?
- Camber Kit
- Overheating
- Rear brake question
- Full body kit question and average cost for paint/ install
- How many miles
- Black screen
- Black screen
- '14 Navigation - how to stop auto start?
- CVT concern 2012 Max
- Fender Flares
- Paint 2010 Nissan Maxima
- Halo headlights?
- Brake Hub covers
- 7th Gen “spider” rims
- Better tires
- Brake booster replaced, new “problem”
- Which ATF to Use for 7th Gen
- Oil Burning Again?
- Question about Eibach Pro Kit Springs New Member!
- Paint oxidation
- Maxima 2013 Headlights
- More power
- interchangable grill
- Radio reception is super fuzzy
- whining while turning steering wheel (stationary) and driving and also idling
- 09 Maxima trunk won’t open!!!
- I really need help!!
- Carbon Fiber in 09 Maxima SV
- Random dash lights while driving
- Wheel Adapters for 09?
- Thinner tires than stock?
- Doors unlock in "Park" position?
- 2012 S cloth seat swap for leather
- Softer ride possible?
- What HID or Xenon headlight or foglight should I buy?
- Car makes noiseW
- Can't Get Trunk to Open
- 2010 Maxima Issues
- Consult 3 Info
- Flowmaster
- 09' Maxima Tow Hook Access
- Can I see the internal temperature?
- Bumper Replacement
- New wheels, speedo, warning lights issue
- Knocking noise front end (not strut)
- How to remove plastic around 2014 gear shifter
- Can You Name That Maxima? need help :D
- FULLY optioned 2010 - good price?
- New Member
- 2014 Maxima Intelligent Key reset
- Hid replacement bulbs
- Spacers
- Magnaflow or Y-pipe?
- 2014 Sport suspension question
- What to do with top screen when using aftermarket receiver?
- Clicking/Loose feeling in steering wheel after repair
- Replace Struts when lowering w/ Eibach Springs?
