- Squealing/ grinding noise when making turn
- Belt squeaking after hitting a deer.
- Error messages
- Locked Out & Battery is Dead
- Battery terminal post
- Apple Carplay
- Just got a 2014 Maxima S what should I look for?
- 70k miles & completely immobile help appreciated
- It's been fun, but now I must go...
- Eibach vs rs-r lowering springs
- No-Screw Front Plate Mount Suggestions?
- Need help with AC diagnosis low and high pressure readings attached
- A/c Help
- Motor swap
- Want to replace Amber screen with touchscreen
- New to me 09 Maxima SV
- Bumper angle alignment with tail light
- 7th Gen Maxima Tuned Process
- Headlight Difference Help
- Rear window sun Shade not working
- Beck Arnley CVT fluid
- 2012 Maxima Knocking/Ticking
- Anyone Selling 3p Management or Airlift Parts
- HELP !!!! Whining after Drain and Fill CVT 2009 maxima
- Drain & Fill, Transmission fluid. Replacing External Filter
- time for lower control arm replacement?
- New struts making clunking noise when turning
- Help finding PN
- Nissan maxima 2011 Ac controls not working
- Lowering springs on aftermarket struts?
- Offsett question
- 2009 Maxima SV Passenger side Headlight issue?!??
- Castol Edge 5w40 update
- 2012 Spoiler Removal
- Weird sound coming from passenger side
- Coilover options
- 2009-2013 vs. 2014 front suspension
- Transmission funk
- Inifinit Q50S- Front Bumper Mash ups
- Sunroof deflector/visor recommendation
- Akebono brake swap for 2014 Nissan Maxima SV
- Key Slot Doesn't Recognize Key
- Key symbol on dash
- Need a suggestion for a good sun protector
- power steering pump replace
- Air compressor or serpentine belt? Help!
- Sounds like when shake a can of spray paint
- Engine knock and high idle
- Hook up the line out converter
- Po455
- What should I do for tires
- Bleeding the power steering system.
- Repairing climate controlled seat, DIY
- Window Grinding Noise
- Wheel bearings
- Can somebody tell me if this is my cv axle or not.
- Please help 2012 with Megan Racing OERS Catback Exhaust
- Question for Megan Racing Cat-Back Owners
- Grinding/Catching sound from Belt side area
- Help: Replace BOSE speakers, keep factory HU/Amp
- Where to find proper fitting 15mm Spacers?
- How to replace 3rd brake light?
- 2012 Maxima/ SV Engaged AC Fault Assist Request
- Wheel spacing
- Sachs the best replacement struts?
- Help Needed 09 Stereo Wiring
- Steering wheel shakes upon acceleration. Help please
- Choosing Dampening on coilovers
- Camber help with lowering springs
- Does your 7th gen engine burn oil?
- Alignment/camber issues
- Timing Chain Issue?? HELP!!
- Replacing exhaust gasket below Catylitic converter
- Best cold air intake
- A/c compressor
- A/C blower issue
- 2012 maxima cutting off
- MonoChrome screen to color
- Horsepower
- 2009 Nissan Maxima, not sure what this sound is.
- What catback exhaust do you recommend?
- Seat belt warning light not coming on. Help please
- 7th Gen Maxima with JUST the Motordyne Y-Pipe?
- Limp mode
- NS-2 vs NS-3
- 09 Nissan Maxima has the electronic steering wheel lock malfunction
- Transmission Dipstick
- Part no of lower clip for right splash guard (oil filter access)
- Engine Cover Standoff Part Number?
- Side mirror direction lights
- 2011 SV Emergency Brk Lght & Battry, Light
- DIY: Engine Torque Strut replacement.
- 09 Maxima AC Cannot Switch Mode, stucked at blowing air front
- how to remove rear seat.
- trunk does not open from inside the car i have to use the emergency pull to pop open
- Any issues with the 10-14 model years?
- Klunking noise
- Rear Shock Replacement
- Hood won't stay propped open
- 09 Maxima Lower Control Arms
- Air Suspension/Deeper Car Tone
- Blue Paint code??
- Tranny Fluid Issues
- Thumping noise as i drive !
- Strange sound when turning on the my 2010 Maxima HELP !
- Where to get tinted headlight covers?
- Car won’t start Help
- Does anyone have a 7th gen Maxima with the CVT and...like it?
- Do these lines go anywhere?
- Replaced rear shocks to KYB "Sport"
- Slowly but surely
- Fam battery
- New here! Having problem with my CVT, PLEASE HELP
- 2012 Touchscreen/Nav/Radio blank
- Convertible 7th Gen
- Spoke with a mechanic today about the CVT filter
- Car club in Minnesota?
- Wheel Question
- Your opinion or experiences, please.
- Running external LED to dome light
- Need Help: Can't find bluethooth option in my settings
- Fuel gauge problem
- Inside the CVT Filter, mystery solved?
- Car not starting/barely starting.
- Is there a 360° camera kit for the 2014 Maxima?
- 2012 maxima cvt transmission fill and drain?
- Remote Start
- Fluid Change
- I have Murano 20in rims what tires should I use
- Tinted the 7th gen max
- Help: There's a jerk when shifting the car into drive mode (2014)
- Nissan Maxima keyless entry button on driver side not working
- Running voltage @12.7V after about 2mins. Alternator change time?
- Help identifying a part
- What brake fluid should I use with my BBK upgrade?
- 2013 oil pan
- 2011 SV Maxima 120K, Broken Front Spring
- Opinion on rear suspension components to replace
- Running power to a trailer from the trunk
- nissan maxima vibrating
- Should I convert to LED or stick with HID?
- Anyone done eibachs w/monroe struts on a 7th gen?
- Needing Ideas for Exhaust (and other parts)
- Driver side CV Axle
- new monroe quick strut 272605
- Need white bumper and drivers side fender 2011 maxima NJ
- Headlight Bulbs recommendation
- Alternator vs Rack Pinion
- Factory HID Headlamp questions
- 7th gen Maxima suspension questions
- Anyone using Amsoil CVT fluid vs. Nissan
- Are radio units for 7th gen interchangeable?
- Need Help Location Cigarette Lighter Outlet
- shocks and strut front 2010 maxima
- Anyone using 245/45/19 instead of 245/40/19 tires on their 7th Gen?
- I got my car tinted and it has a bad glare in the rear glass. Is this normal?
- Shocks
- Driver's power seat stuck in recline position; moves back not forward
- Cup holder Maxima 2013
- Need Alternator wiring schematics
- Outside. Mirrors signals
- 2011 sv jatco jf010e cvt/ filter
- OBD not readying
- Front Driver Window
- 17" wheel on a 2014?
- Weird jerk when breaking under 20 miles
- 2011 Maxima Steering Wheel Play/Creaking when braking
- Front lip
- Replacing Low Pressure AC Hose
- Found the coolant leak... I need to find part number for the hose..
- 2010 maxima sport pkg reaches 5th gear hear a stranger noise on the left side
- Launching my 2011 Maxima
- Cleaning the throttle body
- Installing lower engine cover / splash guard
- Wagner Rotors, opinions?
- 2010 white sv maxima
- What's your engine oil and filter of choice?
- 2011 Maxima climate-controlled driver's seat
- Relocating push to start button
- Tire Maintenance light not resetting 2010
- Service Engine Soon
- Put on Conti DWS-06's What an improvement!
- OEM lug nuts keep going bad
- Rpm going low
- Rear Chrome Delete
- Monroe Struts
- How do I program my spare key fob?
- Wheel bearing brands.
- CVT whine or power steering whine?
- Head light cover
- Alternator keeps failing to charge
- Block heater
- Car door speakers and back speakers don't work but dashboard speakers do?
- 2013 Maxima Charging Issue
- Serpentine belt / tensioner bolt
- Engine Swap Questions
- Help cold morning
- Clunking noise in front end 2014 Maxima SV Sport Pkg
- coilover kit that doesn't lower too much ~ 1"
- AC Hissing/Wooshing from Underdash
- A question to those who have paddle shifters
- Speaker low volume
- Tightening up the suspension w/eibachs, gabriel's & stillen
- Brake pads/rotors and sway bar links?
- A/C Pulley Bypass - Already searched the forums
- Halogen vs HID headlight assembly (Replacement)
- Alternator issues
- How to replace tensioner on 09 Maxima?
- Coolant leak
- Hello! Need some experienced advice! MAF issues?
- Which bulb should I replace in my tail light? Is it The marker bulb?
- First Time Maxima Owner
- 2012 maxima has a minor slip/shutter sometimes at very slow starts
- First maxima. I have questions.
- Any idea what this wire is for?
- Can someone tell me what this is?
- LED nissan emblem
- New wheels and tires
- My first maxima. What do u think?
- Screen swap help
- Cold Air Intake
- Failing catalytic convertor
- Air conditioning controls do not come come on
- Just got my alternator replaced what could this noise be?
- Need her to sounds better
- 2012 Maxima S
- Grinding metal on metal sound when accelerating only
- Maxima clicking
- Winter tire size for the 7th gen Maxima?
- Swapping out stereo
- Need new AC compressor -2012
- Main battery fuse
- Popping/Clunking Noise Near Rear Driver’s Side
- 2009 Maxima Exhaust Work Approximate Cost & Difficulty
- Climate Controlled Seat switch not working
- Cvt upgrade
- Oil Pressure Test
- iPhone 11 compatibility?
- Lost acceleration all of a sudden
- Some good tire that will fit/ will rims fit
- Rough engine. 2000RPM
- Suspension Replacement / upgrade
- moonroof tilt not working & squeaky moonroof
- 2011 Max Dashboard Cracked all over!
- Back to a maxima...
- Blend door actuator(s) very loud, is this common?
