PDA
View Full Version : 7th Generation Maxima (2009-2015)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
  1. Transmission Slips when using Ds or shifting mode
  2. Bluetooth Control Module location
  3. HELP! Long High RPM Idle times on cold startup, is it normal or something is wrong?
  4. Led low beams
  5. Are leather seats compatible with all maximas of 7th gen
  6. Radio problems
  7. 2011 Maxima SV Suspension Issue?
  8. 3rd Brake Light Replacement
  9. Sport oem suspension differences?
  10. ABS/VDC lights on; will not shift out of Park HELP!!!
  11. New strut recommendations
  12. Big breaks with oem wheels
  13. Suspension
  14. 2015 Pathfinder
  15. Performance Chips
  16. Mas air flow
  17. 2012 Nissan Maxima S belt size to bypass ac compressor
  18. Heating issue
  19. 2011 maxima 115K miles
  20. shake and ps wine (not involved with shake)
  21. Another Brake Issue. Pass Frt squeak, squeak, squeaks!
  22. 2009 Maxima with brake, abs and tcl on after front wheel bearings replaced
  23. Rear brake issue
  24. 350Z Z33 wheels
  25. Maxima 2009 battery? 35 or 24f?
  26. 2014 Stalling on Start
  27. 7th gen manual swap
  28. 6spd swap
  29. Speed sensor
  30. Instrument lights(vdc, brake, Tpms, traction control and heater and AC are stuck on.
  31. Key not recognized in key port
  32. Most recent map update to Nav (2009)
  33. A/C Pulley Bypass — belt size
  34. Limp mode?
  35. OBDII Bluetooth adapter & scanning app for 7th gen maintenance?
  36. Camshaft position sensor location
  37. Considering a Chilton's subscription($30/yr)
  38. Oil pan gasket
  39. Interlock relay wiring issues
  40. Gauge Cluster LED Backlight Not Working
  41. Replacing Amber display screen with colored display
  42. Anyone have an idea where the ambient sensor is in the front bumper
  43. 02 sensor. Where is bank 1 sensor 1?
  44. Should I give up on my 2009 Maxima?
  45. 2009 Maxima Exhaust Replacement
  46. Air condition
  47. Shifter Stuck In Park
  48. Dead car battery and keb fob also locked inside
  49. Wiring fog lights
  50. Rear window fails to roll up and down
  51. Clicking when shifting
  52. 2010 Check engine light
  53. 2012 tail lights swapped on a 2011?
  54. Blend door actuator
  55. Humming sound on the Rear Tire
  56. Engine noise just started, not quite sure what it is
  57. Help!!! - Weird Growling Noise when Turning Left
  58. Overpaid for strut replacement 2011 Maxima
  59. Buying a 7th Gen in 2019 - what to look for? CVT?
  60. 2009 maxima idle issue
  61. Help me find out the name of this part plz
  62. Rear shock absorbers for 2013 Max?
  63. Foggy LH Mirror
  64. Shocks and struct replacement 2009 maxima
  65. Fan is blowing hot air and its stuck on high speed.
  66. Ac Climate control module
  67. 7th gen daytime running lights (2nd pair of foglights)
  68. 2010 maxima orange screen relocated kit with new pioneer dhm-c2550nex modular screen
  69. Window fuses??
  70. Rear brakes are @#%$^$ help on 370z brakes
  71. Strut Replacement Gone Bad
  72. Transmission Problem
  73. cvtz50 compatible bluetooth OBD2 adapter
  74. Permanent fault (shifter locked) HELPPPP
  75. headlight help
  76. new cvt or rebuild cvt?
  77. 7th Gen Oil Cooler O-Ring
  78. Instrument panel/push start issues
  79. Valve Covers
  80. Akebono BBK on 7th gen
  81. Can you make a 7th gen AWD
  82. Ac only works at idle? Stops with engine rev?
  83. Akebono caliper upgrade
  84. Headlight help
  85. Having a stillen front lip in nyc on a daily driver
  86. Will this work?
  87. Cvt flush
  88. Power steering pump replacement
  89. Tire Leaking Slowly - Replace TPMS Valve Stem?
  90. SV Premium with SV Sport suspension?
  91. Power steering high pressure hose
  92. Right control arm
  93. 2010 max Front Sway Bar Bushings
  94. Remote start
  95. Powered USB port
  96. Projectors Lens in headlights are foggy
  97. Display changing by itself
  98. Blinking SES
  99. Need a backup camera in an S
  100. Hids in factory projector housings
  101. Help with car lights?
  102. Hi. im a new member with a question about the HIDs
  103. Hey! New Nissan Maxima owner, and I need some help!
  104. 370Z Nismo rims on 7th gen Maxima
  105. Suspension / Spring Recommendation(s)
  106. Does it damage CVT to shift from N to D on a slow roll forward?
  107. Trade in for Infiniti in Knoxville?
  108. CV Axel Replacement
  109. Looking for a good tire size for 20s
  110. Best battery
  111. Key stuck in ignition
  112. Rear tail light assembly not working
  113. Ipdm 7th gen
  114. Mass air flow sensor
  115. Why Nissan wants front to back same side tire rotation rather than X pattern?
  116. Hard brake pedal after car sits overnight
  117. What goes into a "Tune up"
  118. A/c
  119. Weird electrical problems
  120. Need 1 Oem rim for 2011 maxima
  121. White smoke?
  122. What is the 2009 stock factory glass tiny percentage?
  123. Pictures of the engine (what do you think?)
  124. Need help with tapping noise when start the car in the morning.
  125. CVT Fluid
  126. A little upgrade
  127. Dash light on
  128. Interior lights stay on when doors are closed
  129. Cold startup smoke (bad valve seal)
  130. Aftermarket stereo upgrade NOTHING COMPATIBLE
  131. My trunk suddenly won’t open!!!
  132. 2010 Maxima SV exhaust issue
  133. Oem Rear spoiler dealer installed wires spitted and not soldered $%$&%??
  134. Chrome window trim to Black?
  135. K&N Air Filter
  136. Tint
  137. HOT HOT HOT...engine
  138. Removal of center console!
  139. 09 Issue with Maxima Rear Sunshade
  140. USB/Music
  141. High mileage Maximas
  142. Not sure if this is a heat sheild or exhaust leak or something else.
  143. Door Lock Issues
  144. Key Fob
  145. 2010 Max
  146. A/c
  147. window trim removal
  148. 2009 Through 2014 Seat Dimensions: Need a Measurement
  149. Dash lights wont come on car wont excelerate 09 max
  150. Check Engine Light (P0014/P0024)
  151. Should i attempt gaskets & Spark plugs on my day off?
  152. Air condition problems on my 2010 maxima
  153. Air filter and cabin air filter
  154. Rim staggering? 4th gen to 7th gen.
  155. Wheels or aftermarket Exhaust
  156. Need help pinpointing the rear clunk, click or knock is coming from. Pic inside
  157. Folks with Monroe quick strut
  158. 09 Check Engine Codes. What they mean?
  159. Static/hissing through RCA audio inputs
  160. Spark plug question
  161. Clicking sounds
  162. Looking to get into a Maxima
  163. Wheel Bearing
  164. Inner tie rod lock washer
  165. Has anyone replaced there Thermostat ?
  166. Which shocks/struts do you recommend I pair with Eibach springs?
  167. 7th gen HID headlights...
  168. Wheel Spacers long term issues?
  169. A/C Compressor Not Coming On/Gauge Shows In The Red
  170. CVT Fluid dark
  171. Plastic black pipe that connects to bottom of intake hose
  172. 2010 Maxima with Knock ! After AC went out.
  173. Mirror tilt reverse memory
  174. Latest Blackstone Oil Report
  175. HVAC wiring schematic
  176. What are my rear struts options?
  177. Had the TCM and ECM update yesterday. Impressions.
  178. Ecu reflash
  179. 2 issues one post (some of you may get the title)
  180. Drl
  181. Air intake resonator location
  182. TBI vase gasket - can’t find
  183. Can I do radiator coolant drain on ground (no ramps)?
  184. Engine moves when turning steering wheel.
  185. Phantom clunk!!
  186. Loose Power Steering Pump Pulley 2014
  187. Connecticut dealers for basic Maxima CVT maintenance?
  188. Help with P2A00 code
  189. Looking to get a Maxima Again
  190. 09 maxima tail light
  191. Alternator replacement
  192. My new 2012 "orphan" 7th gen Maxima.
  193. my max was in the shop for two months
  194. Car shudders under slow acceleration
  195. Has anyone cleaned their throttle body?
  196. Transmission doesn't want to "let go" on hard braking
  197. Running amp and sub to stock radio
  198. Is this a power steering leak?
  199. Rear End Clunking
  200. Who has a manual 7th gen maxima
  201. Coils!
  202. 2009 Maxima won’t start.
  203. incredible tires
  204. Does tire rotation throw TPMS system off?
  205. 2009 Nissan Maxima won’t start
  206. 2009 Sway bar bushing part numbers help please!
  207. Jerking or lack of power
  208. Power Lock question
  209. How do I wash the engine bay?
  210. What is a UpRev ROM editor
  211. 7th gen maxima check engine light does anyone know
  212. Low rough idle
  213. Oxygen sensor location
  214. Just bought a 7th gen for $2500!
  215. Coilovers or lowing springs
  216. HID to Halogen
  217. 7th gen maxima New headlights
  218. Low RPM NO GEARS WORK
  219. CVT fliter change - 1st time
  220. 7th generation 2014 Nissan Maxima S "Line output converter help" (no Bose)
  221. Big Power Steering Leak... What is this component?
  222. 2014 Maxima SV Stereo Issue
  223. Hunting down tcs light problem
  224. Front signal fast blink
  225. AC is blowing hot air when the AC On
  226. In Dash Stereo / GPS in an S
  227. Maxima sounds just before crank.
  228. My car drove me crazy Help me !!TC indicator is on and rpm jumping on 2500 rpm
  229. Air pressure light flashing when car turns on
  230. 2012 ac only works at 61 or below
  231. Converting from HID to LED
  232. AC blowing hot even after compressor replaced...
  233. Any app that can connect to OBD and read and reset TPMS data?
  234. How Common is the Main Bearing #1 Knock
  235. How urgent is a P0051 code?
  236. Sticky Dash Panel
  237. 2011 Nissan Maxima A/c going off and on
  238. BOP's
  239. Power Steering Pump
  240. Speaker wire colors at Bose amp
  241. Tire Recommendations
  242. HELP! So Many Questions: Need Work on My Maxima
  243. Volunteer needed: VIAS solenoid identification
  244. Maxima Fuel Economy
  245. Lowering my 2014 Max
  246. ABS sensor issue
  247. Noob question: Will a K&N Cold Air Intake add performance?
  248. HELP!! Lights on dash coming on
  249. cvt running hot
  250. why am i not not getting 19 miles a hour in the city?
