- World's first turbocharged 7th gen Maxima
- need help with changing 2010 maxima sv lights.. need help
- converting to HIDs
- 2014 maxima windshield creak
- Undecided on painting Sport Grille- Photoshop?
- Should I Paint my 22`s or not
- 2015 Maxima Available Fall 2014
- Odd engine noises?
- Lost Smart Key & FOB 2011 Maxima
- Why buy a Stillen when you can grow one
- lexani wheels
- Has the Org been Ad Pimped Out or What???
- VDC/Brake light, misfire??
- Whats on your 7th ten maxmima?
- Camber kit for Eibach Springs - 11 Maxima
- V motion grille a sure thing for the next gen maxima
- Interior leds question
- LED turn signals only flash
- Grill mod for a 2011 Maxima
- Idle Re-Learn
- trunk sub floor organizer - molded plastic thing...
- Car fax
- Newbie to Maxima 2011
- LED bar in foglight area?
- Going SMALL ?!
- Where Is the vacuum hose located on the 7th gen maxima?
- 350z camber arms with eibach springs
- Replaced battery, alarm goes off!
- Engine Knocking Noise Problems
- Never wash my rims again?
- Buying 19's.. Will These Specs fit?
- Need OEM Part # for 2012 Dark Gray Grille
- can we talk grilles, in particular the cut out ones for the nissan logo
- why do u need wheel spacers
- Will these fit flush?
- Replaced Head Gaskets
- Arabian 2 Toned Maxima on Bentley Shoes
- 2009 maxima running terrible
- How hard can you push our spacers?
- Newb Question
- Borla Exhaust and Racingline Ypipe available
- Nexus 7 In-Dash + On-Face Custom Mount
- Want lip on wheels..
- rocking seat for 2013
- New member, new maxima, need mods
- Where are the annoying sounds youve found?
- (22's) Why Not?? 20 vs 22 rivalry
- Sub woofer line-level wiring and remote line
- Main Bearing Problem 09 Maxima
- Passenger rear door actuator
- Hankook Ventus R-S3 tires
- cvt problem
- Vehicle Information Display below speedo
- Step By Step or Guide to Double Din Install?
- Nissan Factory Spark Plug?
- Driver's Seat 2010 Maxima
- Door lock actuator replacement
- NY NJ Conn Max owners.....
- Am I getting the dealership service run around?
- Pic Request: Eibach Pro Kit on 20" and 22" wheels.
- hmm I wonder if this front lip can be modded to fit the max
- AVS window vent visors, which ones do I get?
- Cluster gauage removal
- Eibach Springs - Rear Toe Issue
- Cilajet and sway bars
- Eibachs + Struts?
- Help!!! Identifying the part the engine cover screws into!
- $$ to install Eibachs
- 2009 maxima with bad doors
- Nice Pic Of Maxine
- 2010 Maxima losing power on Interstate
- 2013 370Z Wheels Problem
- Racingline help please!
- Rough idle in drive?
- Jerking upon slow acceleration
- Rear deck speakers
- A/C Issue; possibly compressor?
- Changed up my Thump in the Trunk
- HELP on Subwoofer wiring
- OK, I've got one for you.
- Newbie, New Max, First Time Mods
- tint on tail lights
- Lights by your feet bulb size?
- Can someone point me in the right direction...
- door handle beep?
- Old Max gets younger brother
- Curbed my rim
- Power steering fluid question
- What's your average mpg?
- Brakes an Rotors suggestion
- Feedback Requested
- New to 7th gen old
- Best way to wash tinted windows?
- Double Din Dash kit for 7in touchscreen radio
- Fog light installation help
- New Update Pics (Roof Spoiler/Eibachs/Wheel Spacers/New Wheel Plasti Dip)
- New '10 owner! Bearing and other noises
- 2010 and 2012 lug nut size
- New member - spring booster?
- Need help to find this part
- PO101 code
- Sequential front turn signals
- Whistle
- Nissan Teana
- Stereo back light is blinding at night
- 13 maxima door speakers
- got locked out the other day
- Noise behind instrument cluster
- New Platform
- Replacing stock fog lights... Not the bulbs
- I iz confused about Offsets
- 2009 Maxima radio issue
- Grinding/Vibration in gas pedal when accelerating
- Sunroof problems
- At what point do you...
- You want HOW much?
- Will Stillen front lip spoiler reduce front ground clearance
- MP3's and Music Server
- TPMS questions
- Annoying noise harm on rest
- 1/4 mile time? Post it here. Seems nobody has raced the 7th gen
- New Owner :)
- Plasti-dip
- Heated seat fix
- Hello Everyone!!
- Best wiper blades
- What is the best Cold Air Intake for my 2010 SV?
- RoadForce Tire Balance ( Video)
- 2010 maxima color change
- Power steering going out?
- headlight nd fog light help
- Pics of Eibachs with stock 19" sport wheels
- Loud bang from rear
- Heated passenger seats
- TPMS question
- 370z rays wheels on maxima????
- 2011 tail light removal
- Muffler recommendations
- Auto Dim and tinting
- LED Load Resistor
- A sticky situation
- TSB's
- Hopefully an easy fix/solution
- Parts i'm looking at getting
- Has Anybody Tried This?
- My Traction Control, and airbag sure don't like the cold.
- Front Struts
- New to the Club
- Steering Wheel easy exit tilt
- 19" rim
- Selling My Bully Dog
- K&N Replacement Air Filter
- Smallest Rims that will fit
- Running Light Replacement Question
- Badge or no badge on the trunk?
- all data hookup??? anyone??
- Almost leased a '14 yesterday
- Question for anyone with the ebay spoiler
- Any suspension mods beneficial without doing a drop
- Need some information
- Removing Engine Cover
- Interior paint
- Is this it?!?!?!?!?!?!
- How do I take off Stock Ballast?
- Slip Indicator Light
- Mod's for More Leg Room ???
- 2014 SV Sport driver seat
- Range accuracy...
- Has anyone installed the 2J Racing pulley?
- Air bag warning stickers
- Let me see your Grille!
- 2011+ Exhaust tips compatible with 2010?
- Megan Racing OE-RS Exhaust vs. AAM Competition
- OT question
- Just a newbie intro....
- Stillen cold air intake????
- Opt for the '14 Maxima premium or keep '09 Maxima
- Auto tilt reverse mirrors
- Replacing brake light bulb
- Battery died out of nowhere today, could relay harness have anything to do with it?
- Help with double din install/ ground wire?
- Heated Seat Question
- Nice day=Car Wash and Pics with wheel spacers
- reverse wire for pioneer in dash
- 2009 Maxima Prototype?
- Redbone still here lol
- Car shakes when braking?
- BRAKE light randomly turns on while driving
- 18in OEM Rim 2013
- First Time Ever Done
- Nissan maxima cold air intake system
- anyone use LED bulbs for their lowbeam projector ?
- Maxima Model Car
- Nissan Rubber mats or Weathertech??
- Seat heaters
- trunk will not open!!!! HELP
- PlastiDip Question....
- Best place to order tail light?
- Leather Seats
- Hi, Im new! Is this a good deal?
- A few Pics.
- Pix as promised
- Removal of coolant
- license plate led bulb flicker !
- Need help with clip to fasten wheel hub moulding
- HID question for the hid gurus...
- Best way to black out my grille...
- All Maxima Owners
- BT Audio Streaming Question
- Rear brake pad and rotor DIY?
- Who has the most miles on their 7th generations?
- Paddle shifters
- Philips Daylight 4 Daytime Running Lights (DRL) with Auto-Dim module Instructions!
- Subs and Amp
- blown head gasket?
- Finally... Officially part of the Org!
- Intermittent bad Seat Switch
- New Owner
- Does this spoiler seem legit?
- Un lock button
- Possibly a bent wheel?
- 93k mile service, is a fuel injector service necessary ?
- My experience at Nissan service.
- Finally I now belong here!
- Hesitation.
- Information Center Blank
- Heat and Air question
- remote and or cell phone jammer pouch
- Cold starting
- factory headlight harness adapter
- Has anyone softened up the ride.
- 2009 Spoiler and Nav/Interface Questions
- First Oil change/Tune up
- 09/10 SV Purchase
- Tire Suggestions
- "Traded" an '11 for a '14
- Turn signal mirror help
- CVT question
- THK Ball Joints
- how to adjust idle rpms?
- 09 Max with SE-R Rims
- New business - Ghozt Lighting
- Eyelids installed on Maxine
- Door Locks Freezing
- Bluetooth and ipod dock
- Help me decide wheel color...
- How many Maximas are sold in Canada???
- Double take?
- Drop First or Wheel Spacers First?
- obd port not working
