- 8th gen motor swap to 7th gen
- 2012 Max
- Hose on back of intake box
- 2009 maxima - help with loose exhaust brackets
- Front Bumper (and parts) self repair and Paint-A-Part (experience)
- Engine won't shut off.
- Please Help :) Maxima SV will not start, periodically.
- 2013 nissan maxima v6
- Front speed sensor wrong part or bigger issue?
- P0196, 2011 Maxima SV
- 2013 Nissan Maxima noises
- Limp mode after abs, traction, brake, tire, and key lights come on only highway speed
- Four "BEEPS" when starting the engine, anybody?
- 2012 Nissan Maxima Oil Pan replacement
- Wheel bearing or something else?
- Tensioner making noise
- Engine (?) noise that sounds like a fast heartbeat? Speakers/audio are off.
- Parasitic Draw?
- 2013 Maxima Low Beam bulb
- Aftermarket Performance Sway bars
- 2011 maxima shows “fade” when I start it
- Help! 2010 maxima engine moving
- Suspension Overhaul
- 2010 in limp mode and then won’t start at all
- 2009 Maxima CV axle boot diameter
- Best Serpentine Belt
- Need help with beeping noise
- Thoughts on this aftermarket exhaust?
- Sept 2022 CVT fluid and filter change
- Who'd have Thunk'd Cruise control
- The oil stick... oh, the oil stick
- 2014 back up camera not working
- TPMS programming question
- Limp Mode 2011
- Houston dependable Nissan mechanic
- AC high pressure side spikes
- Replace Head Unit
- Rockauto Code
- Power loss
- Loosing power on hot weather
- Source of Supply for Display
- 2009 Maxima with code P0507 RPM going up and Down at Idle and hesitating at take off
- CNA Service Contract for CVT but what else?
- Apple Carplay
- Rattling under acceleration or load!
- Brake Caliper covers
- Putting on some Infiniti wheels, need new TPMS?
- Annoying Chirping AFTER Belt Replacement
- Locksmith screwed up my key fob
- Trunk Switch Not Working
- Rear Motor Mount
- AC Started blowing hot after new Alternator install.
- Trans swap.
- having to manually unlock doors after shifting into Park & turning off the car.
- Questions about PCV valve replacement in my 09
- 2014 Nissan Maxima S - Transmission issues?
- comfort settings have disappeared from menu
- catalytic converter got so hot caught fire
- Battery replacment
- Shocks and Struts Replacement - What parts are needed
- Spark plugs - a must do maintenance item?
- 2010 w/Sport Package, risks?
- Changed battery now have no ac, radio and information screen blank
- Ralay for fuel door actuator
- Hit the jackpot on a 2014 Maxima SV
- Oil in Port
- Dude, Where is my HEAT
- How to clean your throttle body -DIY
- A/C Issues
- Issues streaming music on gen 7 2013 Maxima
- P0420 and P0430 plus Tran
- Coolant leak leads to other problems.
- 2012 Maxima P0302 Replaced Coil & Spark Plug now P0300
- Refrigerant leaking from ac compressor o-ring and high pressure release valve
- Strut assemblies
- CVT noise or what?
- Rumbling, humming, vibration
- Camshaft sensor bank 1 location
- Creeps slow from a stop till 7mph then works absolutely normal
- Engine suddenly dies
- Big problem??
- A/C Repair (Switchport)??
- New member… multiple codes, need HELP
- 2012 Maxima SV Transmission fluid change
- Ambient Temperature Sensor calibration
- Need to replace Rack & Pinion
- Maxima Loss of Power
- 2014 Maxima SV Locked out
- Coolant leak
- CO leaking?
- CO leaking?
- Power steering pump
- 2012 Maxima still smoking
- Pressure sensor on rack and pinion HELLLPPPPP!! 2012 Nissan Maxima
- Upgrading halogen tail lights to LED
- Climate control seat Issues. 7th Generation Maxima
- 2010 Nissan Maxima Transmission No Gear Works
- Climate Control Problem
- 2009 Nissan Maxima Stalling
- Head unit ground
- Brakes and lugnuts
- Nissan Maxima 2015 - Video not showing
- Looking for Custom Tail Lights
- main power window switch
- Ipdm location
- Video not working in Maxima 2015
- Video won’t show up in 2015 Maxima
- Maxima 2011 3.5SV, Vibration in the Front Side
- Video won’t play in 2015 Maxima
- Video not working! Not DVD or RCA
- Transmission appears to stay in low gear (RPM stays between 4k-5.5k) when hot
- Polyurethane bushings for my ride?
- 2014 Maxima Suspension 103,000
- More rubber seal implants
- Ipdm voltage variable control system wire
- Bypassing the voltage variable control system
- Coolant reservoir removal
- Harness Adapters to Add Subwoofer, DSP, Amp, etc. Plug-N-Play
- 2012 Maxima S P0171 code.. please help
- 2010 nissan maxima shuts off while driving
- 2009-2015 Transmission
- What Color Coolant in your 7th Gen and how often do you change it?t
- 2011 Maxima lost acceleration and electrical power while driving
- Maxima 2012 steering button are not working only lights are there
- 390 amp Js alternator grounding method
- Anyone with tuning experience wanna give a beginner some advice?
- Factory Halogen Upgrade Options
- Mystery oil leak
- Speaker issues in the dashboard
- 2014 Maximum S - Rouch Idle when A/C is on
- Front upper strut tower bar for 7th gen maxima
- Lights fluttering after Alternator
- Horrible gas mileage and seemingly high idle...
- 7th gen alternator
- Blower not working
- LCA replacement and what else
- Leaking strut ?
- I cant find my intelligent key inside my Maxima
- 2012 Maxima Ignition Issues
- Navigation info frozen on half of screen.
- Bad Motor Mounts
- Suspension
- 2011 SV w/ Navigation Bose stereo speakers
- 2010 Maxima won't start
- Under rated, best seats in the game
- HELP with diag
- Something draining battery
- Clear Tail Lights
- Front Nissan grill emblem on 7th Gen. What other ones fit?
- Fog lights not working
- Slp loudmouth resonator
- Car shuts off while driving. Help needed.
- Subwoofer levels
- Any 7th Gen guys have Nismo 370z wheels?
- 2014 Maxima Rear Windows don't work
- 2014 Maxima shut off while driving
- Reset AV
- Grinding noise after installing coilovers
- 09 Maxima SV sport package 19 inch rim tire question
- High output alternator
- Driveline whine or howl from 35 to 75 mph
- Desperately Seeking Answers
- Sway bar bushing
- Traction Control
- Battery isolator ground.
- Fuse for battery isolator
- Pics of My Max Before Refresh
- Help help help
- Alternator issues
- Rusted subframe. Worth fixing? Anyone swapped a subframe?
- Maxima Losing Power and Battery Dying
- My max wont start
- 2009 maxima No dash illumination
- CVT Cooler lines
- Halo headlight purchase
- Sunroof edge weatherstrip
- Just bought 7th gen Maxima
- 245/45r19. Anyone actually done it and have pics?
- MotorDyne Exhaust
- Timing Chain
- Oxygen Sensor Bank 1 Sensor 1 Removal
- 2010 maxima weird issues
- [Help] Coolant gauge stuck at C, does not change
- Fitment Help Please
- [Help] 2014 Maxima stalled while driving/ in motion.
- Headlight upgrades?
- Suggestions for new Xenon headlights
- Wiring three 12s in a triple 12 sub box
- Popping/clunking from accelerating
- high idle RPM? (1500~)
- Engine shutdown while driving 2010
- I need to replace my lost key fob. I do have the other.
- Brake and battery light flickering
- Has anyone tried the "VLine NIS9VL2" Apple CarPlay/Android Auto Infotainment Update?
- Anyone using this code reader from Walmart
- Replacing Bose speakers
- Premium gas necessary?
- Alternator short
- Need more help
- po335 po725 ecm bad?
- Radio not working
- Backup Camera for 2012 Maxima
- Trunk lid switch rubber deterioration
- 2011 maxima , cvt issue
- Secondary battery
- Secondary battery size?
- Unknown tube after installing k&n filter
- iPhone adapter to play music
- Paddle Shifters Non-Sport 2014 SV
- Fuel pump replacement
- 2011Maxima Noise in Front Area when weight goes forward
- TPMS error
- Blew fuse now car won't start
- S mode (Sport Mode) Bad Relay or Fuse
- Key Fob remote engine starter not working
- 2011 Nissan Maxima S Mode Issues
- Engine ground
- Burning smell from engine bay and vents
- Fuel Issue? Computer/security issue? Please help.
- Bluetooth via USB port?
- HVAC/Radio Controls won't work on startup
- Need advice for changing '09 Maxima HID Ballast/Igniter Driver's Side
- Custom 2014 Front and Rear Emblems
- TE37s
- 2009 Maxima Bose Radio Code
- 2009 Maxima SV Cooled Seats Not Working
- Won’t start after fuel pump replacement
- A/C idle issues
- 2014 maxima sv shifting from park
- Boom! Here to report a CVT failure
- Frozen fuel and needle RPM when the car switch off
- 2010 Maxima SV Shocks/ struts
- Big 3 upgrade
- 2012 Nissan Maxima sv ran out of gas now will not start.
- 2009 Maxima power steering failure
- 1st cvt drain and fill at 140K
- Hubcap/Wheel Covers for 18-inch Rims
- CVTz50 App and Engine Brake Level
- Headlight and blinker trouble
- No power options after motor swap
- I have a leak on my 09 maxima
- whistle from engine
- radio trouble
- Removing Rear Crossmember
- Turbo??
- Rear passenger windows
- Temperature gage
