PDA
View Full Version : Advanced Suspension, Chassis, and Braking
Pages : [1] 2 3 4 5
  1. CNC machined bracket to bolt 370z Akebono Calipers to 95 thru 08
  2. Tokico Illumina
  3. polyurethane bushings 7th gen
  4. 8th gen Coilovers
  5. Basics of Camber, Caster, Toe
  6. What is a conservative suspension upgrade for my 2012?
  7. 2012 Maxima - Hard Suspension System Problem
  8. Aftermarket steering wheel fitment
  9. Please advise on next step for suspenson redo.
  10. Cupro-nickel brake lines
  11. Are double flare unions all that short?
  12. Owners/users of stainless braided brake lines
  13. 4th Gen - Aluminum Sub-frame Spacer Modification
  14. Lowering Causing Axle to Bottom Out
  15. secret weapon
  16. Heavy Duty Suspension
  17. 300zx brakes and Cobra Motor on Maxima 1999
  18. Replace Full Wheel Hub assembly or just berring.
  19. Building Custom-Fit 2006-2008 350Z/G35 Front Calipers
  20. 6gen rotor and pads
  21. Has anyone modified K-sport coilovers to be more street friendly/comfortable?
  22. 13" cobra rotors + hub rings, need clarification
  23. sensen struts w/ ksport lowering springs bumb stops
  24. Fastbrakes rear brake upgrade fitment issues?
  25. s14 coilovers on 2000 maxima
  26. 6gen Brakes swap into 4gen that fits 16s
  27. 240sx z32 calipers brackets fit
  28. Cheap wheel spacer broke in 6 mo - er well the hub centering ring did.
  29. A33 - Rear Lower Tie Bar / Cross Member Brace - Opinions?
  30. Any way to upgrade the rack/pinion 6th gen....
  31. Vibrations when braking on the highway
  32. 3rd gen Tokico adjustable shocks
  33. rake
  34. seized adjustment ring on ksport coilovers
  35. Quick Question Tokico Illumina's
  36. Does 4th Gen use same Z32 relocation kit as 5th gen?
  37. 6th Gen Brakes Vs Z32 TT brakes?
  38. Koni Yellow w/ GC, top hats?
  39. suspension
  40. Different types of BC coils?
  41. Brake caliper swap
  42. jclaw traction control bar set
  43. Road course suspension set up recommendations
  44. Suspension issue
  45. 4 wheel drift
  46. Ebay rotor warning!!!
  47. Chassis stiffening/reinforcement
  48. brembo rotors
  49. how much wight can i eliminate ?
  50. Blemco Brackets w/ 12.75" 350z Rotors?
  51. Racingline
  52. maxima brake line fitting
  53. Rear Sway Bar
  54. shortening cv axles
  55. Put an other car 4 brakes?
  56. AP Racing rotor
  57. 300zx calipers/cobra 13" rotors
  58. Akebono BBK fitment on maxima
  59. Best route to go without BBK?
  60. 20" M310 - Hyper Silver question??
  61. Coilover Rebuild
  62. airbag suspension
  63. New, and searched, but...
  64. for those running coilovers
  65. 300zx Relocation Brackets
  66. Upgrading Calipers, Need Help on Brake Rotor Choice
  67. Powder Coated Altima SER Calipers
  68. coilovers vs spring combo?
  69. megan coilovers popping sound when turning left and right
  70. Rear suspension help for a 2006 Maxima
  71. Top mount question
  72. Top mounts on Megan coilovers
  73. Y33 brakes 13.6" rotor
  74. Question on Tein spring options
  75. BC Racing owners step inside.....
  76. 2004+ Maxima rotor hat ebrake for Z32 rear conversion?
  77. Firestone Alignment Printout - post shock inner outer tie rod rep.
  78. hit curb and the opposite wheel has camber now. WTF?
  79. Whiteline Caster Correction Bushings
  80. Stock Brakes Interchangable?
  81. Need help
  82. what should i get to lower my car?
  83. Issues switching between street and track pads on same set of rotors?
  84. rear calipers seized?
  85. trying to adjust BC coilovers preload
  86. What car will this Stillen Strut Bar fit?
  87. Brackets to Use Z32 Calipers
  88. Megan coilovers ride question
  89. Spring rate Q
  90. Help with setting up JIC Coilovers
  91. When replacing suspension??
  92. riding on air
  93. good spring/shock combo
  94. Fender braces installed!
  95. 2002 Maxima SE brake rotors help!!!
  96. 4th gen stock wheels with wilwood superlights
  97. Launch Control using ABS?
  98. Murano brakes in a Maxima? YES, itīs possible!
  99. Help! Problems installing used Wilwood/2-piece rotors setup
  100. blueprints for Q45 dogbones
  101. '94-03 Rear Brake Upgrade option...
  102. Sway bar diameters for 3G Maximas
  103. How To: 350z/G35 Dual Piston Brakes
  104. A thought on centering cobra rotors
  105. KYB GR-2
  106. Tein Street Advance
  107. 5th gen maxima struts on 3Gen Altima
  108. Making It Stick by Mike Kojima - All Installments from Modified Mag
  109. Stuck JICs
  110. Modding for the Road course
  111. r33 calipers and cobra rotors?
  112. Ways to battle CV axles failures
  113. What to "redrill" on the cobras?
  114. Can someone tell me which calipers these are?
  115. Need a chassis guru!
  116. 300zx rear Calipers on 4th gen
  117. Wilwood Master Cylinders?
  118. stitch welding????
  119. Question about top hats
  120. Anyone able to get ahold of MattBlehm? Or anyone for Caliper Adapters?
  121. Drivers Side More Flush Than Passenger Side
  122. sway bar endlinks
  123. My Official Truax SFC impressions after install. Along with basic how to.
  124. Diameter of Ball Joint Hole in LCA
  125. Rear trailing arms made more rigid
  126. Panhard Rod Install on a 4th Gen
  127. Setting the Preload on your BC Coilovers (or other brands)
  128. QT Adjustable links for A32/33 Dose anyone have experience with these ?
  129. Toyota 4 piston?
  130. q45 caliper relocation bracket
  131. custom maxima lowering springs?
  132. TRUAX SFC
  133. 350z brembos....
  134. Wilwood caliper question
  135. Camber adjustment due to uneven tire wear?
  136. FTSB and RTSB
  137. The end all thread of why Drilled/Slotted do not work.
  138. FAVOUR: Measurements for 4th Gen Stock Rear Mounts
  139. Coilover Reviews - Step in Please
  140. A32 Adjustable Lower Control Arms
  141. Tech can't get alignment right
  142. Brake Lines recommendations
  143. WP Pro Brakes Front & Rear BBK
  144. HELP*********Compatibility question********
  145. Racingline V2 Endlinks - Torque questions
  146. Rear Negative Camber
  147. "Can't Miss!" sale on Progress rear swaybars
  148. ES bushing for Axle beam ?
  149. squeeking? with whiteline/superpro bushings?
  150. 5.5 gen ES question
  151. Alignment on a [severely] lowered car.
  152. Anybody have any experience with Vogtland lowering springs on a 6/6.5 Gen?
  153. Could jacking on the rear beam alter the rear toe?
  154. 4th gen brake upgrade?
  155. Front LH ABS sensor
  156. How to make a good Koni/GC coilover setup
  157. 4th Gen Adjustable Front Sway Bar End Links
  158. Tein Rear Mounts Modified to Fit 2.5" Coilover Springs
  159. Mission Improbable: Making the Maxima stick with better suspension parts
  160. D2 Coilovers 4 7th Gen. Maxima
  161. New rotor option for Z32, J30 calipers.
  162. Aluminum steering column bushing?
  163. 5.5 gen LCA bushings how to
  164. reverse sound
  165. Difference between 300zx calipers
  166. 2003 maxima lowering questions
  167. 2k OEM SE Springs vs. 2k2
  168. Anybody know which moog Grease filled items work on the front of 4thgen?
  169. Anyone have pictures of Ksport coilover spring bushing area?
  170. Which caliper grease does everyone use?
  171. What coilovers to replace my D2 racing?
  172. 2002 Maxima caster/camber adjustment
  173. Custom CNC'd Camber/Caster plates 4th gen who wants em!
  174. Bc racing coilover?
  175. 00-01 front pads interchange with 95-99 front pads
  176. Brake Caliper Spacer?!?!
  177. A very interesting/informative read on shocks...
  178. Rear BBk for Maxima Take a look
  179. Before I get an Alignment, should I get anything else for my lowered suspension
  180. can someone explain linear and progressive spring rates
  181. 4th Gen:Koni questions (adjustments, plastic rings)
  182. any one ever replace pillow ball mounts?
  183. 5.0 Gen Front Brake Replacement
  184. Extra Parts After Adding Spacers
  185. rear brake kit options
  186. Help! Changed Rear Pads: Pedal Goes to Floor Now.
  187. Best setup for coilovers
  188. Progress with 03 Strut/Shocks Upgrade
  189. Triangular fstb
  190. Koni Yellows on sale at Tire Rack
  191. questions about spring rates...and really suspension in general
  192. Can 5th gen coilovers work on 4th gen
  193. Alignment experts...SAI and Included angle off...points to?
  194. Need Some Advice
  195. Ground Control: Different strut versions?
  196. drop zone suspensions
  197. Cutting down on oversteer
  198. D2 coilovers - Installation Prep
  199. Brake line fitting thread - 3rd vs 4th gen
  200. Clearing ABS codes help please
  201. Problems with 300zx calipers
  202. Can 370z calipers fit on a 4th gen? Prove me wrong
  203. What would cause my rear to feel like its moving side to side over bad roads?
  204. Strange axle noise
  205. Between Axxis Deluxe and Ultimates
  206. Need some expertise !!!!
  207. New Motor mounts;issue with safety
  208. Coilover spring rates - 7/5s to soft?
  209. 5th Gen 300zx brake upgrade horrible brake squeal
  210. 16" wheel options for A34 rotors
  211. Tokico Illuminas - Recently changed adjustable settings and...
  212. Does anyone bleed with the car running?
  213. What is the best 5th gen full coiloever setup for under 1k?
  214. suspension bushings
  215. Strut mount confort?
  216. Z32 brake proportioning valve
  217. stress on the car from lowering COG
  218. Non Brembo Calipers on a 5th gen?
  219. "How to make the maxima light" Website now gone, anyone have the info?
  220. Suspension swap feasability
  221. 4th gen suspension on a 5th gen
  222. Camber Kits for 4 th gen
  223. Abs Sensors (write ups?)
  224. Making some traction rods, who wants some?
  225. questions about suspension geometry 101
  226. Let the rebuilding begin...
  227. questions about KYBs - 99- 03? Fit?
  228. Beam bending party for 4th/5th gens in the works with B14 guys.....
  229. Has anyone ever tried 5.5G calipers or torque members on a 4th gen?
  230. Rogue rotors are same diameter, larger thickness than 5.5G rotors
  231. Nissan Quest front brakes are 11.4" diameter
  232. Megan racing coilovers
  233. Help Please!! 4TH GEN SUSPENSION PROBLEM
  234. For all the 12.6" rotor users. OEM bbk, 6th gen, Altima, oem G/Z users etc.
  235. Any reviews/comparison on BC racing coilovers?
  236. Need some advice on lowing a 2003 maxima
  237. 5.5 Gen rotors
  238. Im looking at bagging the beast
  239. BBK Options - Clarifications
  240. Coilover Wrench
  241. Just a note on Q45 rotors and control arm clearance and other issues (A32)
  242. 350Z pads are interchangeable with maxima pads
  243. Worn out suspension?
  244. Eibach align. kit
  245. Suspension Clunk on Sharp Bumps
  246. Raybestos Quiet Stops are no more?
  247. (MAx in ny) Best struts??
  248. 350z Brembro Calipers on 6th gen. HELP
  249. Stillen camber plate install
  250. Where can I get my Boss Chen Dampers rebuilt?
