PDA
View Full Version : 6th Generation Maxima (2004-2008)
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. P0340 and Wiring/Battery issues?
  2. 2004 max 6 speed
  3. can my Maxima have a sporty ride?
  4. Transmission Issues
  5. Sick Maxima
  6. Should I keep my used Maxima 2005 (Seems like infinite problems: Transmission/CatC)?
  7. 04 maxima 3.5 timing chain inside replacement
  8. Heated seats question
  9. 06 maxima (no crank, no start)
  10. HELP with headlight cover
  11. P0726 Check Engine Light
  12. Floor pan rust Question
  13. Ignition will not move into lock position
  14. Intelligent key issue
  15. Parking Lights Stay On Even When The Car Is Locked
  16. 05 SE thoughts on these filters / oil / air / Purolator PureONE
  17. Anyone down to help me out with factory to aftermarket double din install on 05?
  18. engine mounts
  19. Mounts & Strut
  20. Pulling Codes P1278 and P1279
  21. Sunroof cover
  22. Aftermarket Headunit Problems
  23. engine shuts off, hard shifting aotomatic tranny
  24. car overheating
  25. 08 SE with bad FM reception
  26. steering wheel vibration
  27. What is the belt size To bypass AC compressor
  28. Error Code P0456 & P0406
  29. 2004 Nissan Maxima SE (Your Opinion?)
  30. 2006 Double Din Install / Toronto / Scosche or Metra?
  31. Plug Change 2006
  32. 370z rims
  33. ABS front wheel speed sensor
  34. 2004 Max door locks intermitent
  35. A/c climate control
  36. 6th and 7th gen differences
  37. Goodby
  38. re starting issues
  39. Charging System Problem
  40. Not a Maxima...but
  41. fuse keeps blowing
  42. ECU compatibility
  43. Tranny safe mode / Grounding issue / cable replacement
  44. 6th Gen. Struts - Any opinion on KYB Strut Plus?
  45. radio turns off randomally
  46. New to me 05'. Looking for recommendations.
  47. 02 sensors
  48. Will these headers fit a 2006?
  49. 2004 maxima se after market exhaust??
  50. What is this called?
  51. TSB NTB07-016b...ABS issues
  52. 2004 J31 Australian Maxima Ti - Audio Upgrade
  53. Head lights
  54. Someone please help! No radio!
  55. 2006 shift takes about 3 seconds to kick in.
  56. 2007 Nissan Maxima CVT Indicator Light
  57. Abs fuse under hood keeps blowing
  58. TPS Sensors
  59. Front Lower Control Arms w/ Ball Joints
  60. Codes P1800 and P0340
  61. 2006 automatic trans: cv axle nut size?
  62. engine and trans swap?
  63. 2007 Nissan Maxima Stereo Steering Wheel Control works only with wheel turned left
  64. Engine rattling noise over 30mph
  65. Cardone Select vs Napa Maxdrive cv axles.
  66. Replacement Power Steering Fluid
  67. Selling my 04 Maxima. How much??
  68. 98 and 05 maxima
  69. Performance
  70. Advice needed to replace bulbs
  71. 2006 Nissan Maxima Tranny problems?
  72. VA, Part out 2005 max SE auto 160k miles
  73. 2006 Nissan Maxima 3.5 SE Transmission problems
  74. Best place to get coil packs?
  75. knocking on a 2006 max automatic
  76. Braking system..
  77. Crankshaft position sensor
  78. Are the 04-05 Max's really as bad as the reviews I'm reading?
  79. Help
  80. Contemplating purchasing a creampuff need opinions.
  81. cylinder misfire p301??
  82. 2006 max "fuel econ" button
  83. Driver side window problem
  84. 2004 Maxima Convertible w/Suicide Doors
  85. 2004 maxima won't start after engines warm
  86. 2004 maxima
  87. Dashboard lights turn off when headligts turn on
  88. 6th gen wont idle after reconnecting the battery
  89. Found this ridiculious Max on web
  90. Exhaust for a 06 SL??
  91. New TSW Wheels
  92. 08 Maxima A/C problem
  93. parts for sale
  94. ABS Pump on while car is off
  95. 04 Maxima Owner
  96. Questions about the VIAS Solenoid. Please Help!
  97. 06 center dash screen
  98. ABS Pump for MT
  99. rockauto.com discount code
  100. engine swaps?
  101. Going Straight Pipe... Which Exhaust Tips?
  102. New guy to Maxima forum
  103. bose cd changer
  104. Fog lights fuse...WTH
  105. Fix for Some Issues
  106. 2004 Maxima not shifting in 2nd or 4th gear
  107. Should I Buy: 04 6Speed Manual
  108. Question - Shaking Steering wheel & console
  109. Maxima Catching oil and a question.
  110. Fuel pump lock ring removal tool
  111. Broken rear shock stud
  112. 04 Maxima Floor Panel issues
  113. 6.7 swap help
  114. Instrument Cluster Issues
  115. Front Quarter Panel Removal
  116. need help on buying exhaust system!
  117. Drove 300 miles a half court of oil low; damage?
  118. 2004 Power windows
  119. Short term fuel trims
  120. 2004 Maxima SE
  121. Front tire vibrate bad PLEASE HELP
  122. Intake manifold VQ 35 spark plugs
  123. Front shocks
  124. 2006 Max Advice
  125. Nissan maxima si
  126. K & N vs Fram Extra Guard
  127. VQ35HR Plenum
  128. Abs unit caught fire, 04 max totaled. Nissan liable?
  129. Doesn't shift down after reaching 5th gear
  130. rear defroster affecting radio signal
  131. B1049 Driver Air Bag Module (Open) on 2007
  132. Difference in automatic/manual Engine
  133. Any vendors sell electrical connectors?
  134. 06 maxima strut/shock replacement
  135. keep lowering springs or get coilovers?
  136. Rant: Racingline Performance
  137. Code P1284 / 2004 Maxima
  138. 06 max se tire feathering
  139. 08 Altima vq35de in to 04 maxima
  140. 2004 Nissan Maxima SE Transmission fluid Change
  141. 06 died starts for 5 secs then dies again?
  142. Power steering pump belt cause ?
  143. 2006 maxima se Fog Light
  144. 04 mesh grill
  145. how much R134a needed
  146. 2004 Engine Light Anomaly
  147. New - looking at 04 3.5SL
  148. my 07 max 3.5
  149. Trouble Finding The Correct Transmission Filter & Gasket
  150. tune up advice
  151. hard power steering ?
  152. decarbonise with water ?
  153. Starter Issue. what to check ?
  154. what is the best oil to get for my maxima?
  155. Looking to buy a 2004-2006 maxima
  156. 05 SL ECM/ECU question ......
  157. Manual
  158. Bad rotors
  159. 2005 Shift Solenoid
  160. 04 maxima power steering filter ?
  161. clunk noise when i hit any bump
  162. rattle / ping solved from engine bay
  163. Oxygen Sensor
  164. Anyone else with TERRIBLE gas mileage ??
  165. break wheel turn left side
  166. Engine won't start, no security light at all.
  167. Rear passenger brakes drag after replacement
  168. how to detech air leak ?
  169. Cabin filter ?
  170. Motor mounts
  171. New Member here, just got a 08 SE, exhaust & cold air kit?
  172. sensor cleaning spray
  173. ac not blowing enough cold air
  174. Some advice? 04 vs 06 at different prices, future aspect, etc,.
  175. Body Clips Under The Hood
  176. Help! 05 Maxima stalled --> SLIP, TCS, Hard shift, long start
  177. 2004 - Steering Wheel Stuck Locked
  178. turn noise
  179. eBay exhaust require welding?
  180. Vibration
  181. Engine question
  182. 04 maxima ABS problem
  183. Ambient Temperature reads -22
  184. 06 maxima wont start after crash?
  185. 2006 nissan maxima se wiring
  186. 3000+rpm problems
  187. Where is knock sensor located ?
  188. 08 maxima entry/exit W/o nav
  189. Advice for potential 2006 SL owner
  190. Timing Chain Lawsuit - 2004 - 08 Maximas
  191. Low rev rattle from engine bay on 2004 Maxima
  192. Change Horn on 6.5 Gen Max
  193. Nissan bulletin board ?
  194. Leaking Power Steering Fluid Quote
  195. how to rest throttle body ?
  196. Help A Newbie Out ?!
  197. Have to say goodbye to the Max fam
  198. Instrument Cluster
  199. lateral shift/hop in rear end
  200. Coil Pack and Spark plugs
  201. another moonroof problem
  202. 2006 maxima hard shift
  203. how to replace throttle body
  204. Key fob question
  205. Throttle Body dont open
  206. How to open map light bulb compartment
  207. Should I keep my HID's or switch to LED?
  208. 2004 maxima grille
  209. Style and Performance
  210. Brake Issues After Upgrading
  211. 2004 headlamp replacement
  212. 5th gen trans in 6th gen
  213. gear shift bang
  214. Maxima SL 2005 problem
  215. Maxima 2004
  216. adjust headlight
  217. Performance exhaust
  218. 04 se smoking
  219. new here. i dont know where to post
  220. Help with 2004 se clutch remove/install
  221. HELP with info on homelink button program
  222. Grinding noise from front wheels/brakes area
  223. Help! ABS, TCS Off & SLIP lights all lit
  224. P1402 EGR Valve
  225. Roof strip clips
  226. CD player stuck on Eject for 2004 Maxima
  227. What did you do to your 6th gen today?
  228. 2004 Maxima SL Transmission issues
  229. Old timers: What does your car look like now?
  230. Seat height
  231. electrical
  232. 'Mood' lighting in overhead console replaced with LED
  233. Timing Chain Repair
  234. Tire sizing and brand
  235. Question
  236. 06 Maxima throwing a few codes
  237. Help with lowering car
  238. 2004 Nissian Maxima transmission slipping and slamming
  239. ISO 2004 17" Wheel - Question?
  240. Cleanest 2007 maxima
  241. Whizzing on da Max
  242. 04 Maxima SL engine quits
  243. 2004 Maxima SL tranny/camshaft problems
  244. Help, please? New Owner
  245. Replacing Bulbs in Map light and high brake light
  246. Maxima 2005, heat comes with full force
  247. Supplemental Air Bag System
  248. Speedometer needle fuse?
  249. 2005 Power Steering Pump Replacement
  250. Auto 3.5 into a manual maxima????
