PDA
View Full Version : 6th Generation Maxima (2004-2008)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Cigarette Lighter
  2. Alternator
  3. 3 years after joining... I'm finally an owner!
  4. Steering wheel audio controls
  5. I need help on tire size on my 2004 nissan maxima!!
  6. anyone tried
  7. need advice from maxima experts
  8. Possessed Sunroof
  9. 07' Spoiler in a 04' Maxima??
  10. After market headlight
  11. New Nissan Owner
  12. G35 Coupe sport steering wheel compatibility
  13. Matte black (photos)
  14. Map light switch
  15. HELP! Lowering springs problem
  16. Aftermarket head unit in an '05 maxima. Not sure if it's possible?
  17. should i buy
  18. Need BRIGHTER Headlights and High Beams
  19. LED Daytime Headlight Mod (Audi-style)
  20. New 6th gen owner questions
  21. 4th gen rims on 6th gen maxima.
  22. Throttle lag.
  23. Abrupt Downshifting?
  24. Daytime Running Light Rewire
  25. New 6th gen Max owner very stressed!
  26. 07-08 Gauge Cluster Removal
  27. 2004 max cold air intake.
  28. JF506E Transmission?
  29. AC Compressor cost - this sound right?
  30. Lip & headlights
  31. diagnosing transmission problems
  32. 6th gen exhaust
  33. How can I get the pivot bolt loose on the power steering pump?
  34. P0021 and Flywheel questions.
  35. maxima stuck in 5th gear resolution
  36. Transmission problem
  37. 2007 nisssan maxima wont turn on passenger light and foglighs.
  38. Has anyone done better than this??
  39. 2007 frost color floor mats
  40. Bank 1 catalytic converter removal?
  41. wiring help
  42. Questions on some required maintenance (door locks, window, trunk..)
  43. 03 hid ballast for 04 maxima fog lamps can i do this???
  44. Problem with Bose left side speakers
  45. Its been long.. So here's some updates on the ride.
  46. 05 Maxima Rims opinions needed!!
  47. Another newbie here
  48. replacing tensioner 04 max
  49. 2004 Max won't turn over....electrical issues
  50. My customized grill
  51. New 04-06 C-mod Sport Grille...
  52. Timing Chain Guide
  53. hitch '06
  54. How many miles is too many??
  55. 2004 Maxima bumper cover attachment part?
  56. Premature tire wear on '08 SL
  57. Newbie (actually, premie) Buy an '07 Maxima SL??
  58. New to Maxima.org
  59. Caliper Torque Bolt Size?
  60. Fog lights help
  61. Engine mount
  62. Car won't start need help
  63. Looking to buy an 04 maxima..is this a bad idea?
  64. Will 3.5 altima headers fit on my 6.5 gen???
  65. best headlight/fog light package to buy for 08 maxima
  66. Rotor fitment
  67. Odom issue
  68. Best All Season Tires for a @2007
  69. brembo's ?
  70. Looking to buy Progress springs, where to buy?
  71. Looking at 2006 Maixima should I steer clear?
  72. bumper ?
  73. Factory alarm issue
  74. 2004 Maxima - Bose System not working. Popping Noise and Interference
  75. I need a EXHAUST TEMP SENSOR?
  76. 2008 3.5 SE Max steering wheel shake
  77. Need Part numbers please..
  78. fog light issues?
  79. Dont know sh$@ about Nissan and need a little help
  80. 05 Maxima transmission fluid
  81. Maxima 2005 Chrome Roof bars
  82. 2004
  83. lower control arm
  84. Good basic, cheap springs.
  85. A/C display not working
  86. Just bought an 08, a few questions!
  87. In Need of some serious help.
  88. 06 Maxima Ignition Problem
  89. Headlight Lenses?
  90. New Max Owner
  91. check engine light from hell???
  92. 08 Door handle request switch
  93. Malfunctioning dome and map lights
  94. BC coilover noise
  95. Checking which maxima gen 6 speed belongs to.
  96. Snapped up some Nismo Rays
  97. New Max Owner
  98. RPMs jump at 70+ mph
  99. 2004 SE p0340 camshaft sensor error...not quite
  100. 2006 Maxima Transmission Replacement
  101. 22 inch wheels
  102. Racingline HFPC's 1 Year Later
  103. Manual conversion
  104. Buying used motor
  105. part number help for engine guards
  106. Goodbye 6th Gen Max
  107. HID color recommendation .2008 maxima..
  108. 05 maxima 6speed
  109. 120K Later, want suspension Mods :-)
  110. New Owner, quick questions.
  111. I don't want to install my rear springs now
  112. Rust :(
  113. Clutch pedal pop
  114. tranny locked up..upgrading flywheel questions!!
  115. Clunking - front right
  116. Lighting Issue
  117. Runs great for about 10 minutes then dies
  118. How important is the Power Steering Pressure Switch for my 2004 Maxima
  119. Back from the dead. New mods added to the list
  120. Rough idle and sometimes hard to start
  121. Need advice
  122. Just sold my Max :(
  123. p0011 code
  124. new engine installed,CES and ABS lights are on !!
  125. '06 sunroof stopped working
  126. How many people tow with their Maxima?
  127. 2004 Maxima SL slipping tranny
  128. increased performance
  129. Where to buy 2 piece front rotor?
  130. Major hick up in my engine swap
  131. 07 SE Maxima Tires Verenti R6
  132. 2007 motor in 2004 maxima
  133. 2007 Maxima SL Intake Suggestions
  134. Need a Brake And Rotor Recomendation
  135. Stripping and polishing stock wheels>>?
  136. 2007 Maxima - ideas for projector fog lights
  137. So I Traded the Maxima
  138. permanently disabling TCS/VDC
  139. My 6thgen maxima made me proud today
  140. Just bought EBC USR Sport Slotted Rotors + EBC Redstuff
  141. intake snorkle
  142. 05 max, SE-14 Wheels
  143. Starting to Modd =)
  144. I used wrong coolant
  145. 2004 maxima bose system issue
  146. Torn Boot (Axle)
  147. QUESTION TO THOSE MEMBERS HERE THAT ARE LOWERED
  148. Throttle Body Install - Reprogram Computer?
  149. MORE ABS related questions
  150. 04 maxima aftermarket cd question
  151. SSIM...who does them?
  152. What brake pads and rotors?
  153. how to check fuel pressure 04 max.
  154. What's up 6th genneis
  155. 6th Gen Greddy SP Elite
  156. rear cat removal
  157. Air Conditioner problem help!
  158. CVT Transmission problem?
  159. needs help 04 maxima missing
  160. 04 max cant open trunk w/o key farb???
  161. Lookin' to purchase one of these, but what year
  162. Stock intake
  163. headlight
  164. Valve train noise on cold start
  165. Need info on brake site and product!!!
  166. Altima headers on 6thgen maxima pt 2
  167. Adjust Clutch Engagement?
  168. Revved Up Starting
  169. My 1st Max (6th Gen) how bitter sweet..
  170. Unlock rear seat
  171. Picking up an 04 6spd got some?s
  172. Ecu upgrade
  173. Skyview issue.. cant find anything.
  174. Will Rolling the fenders fix my problem?
  175. 6th gen cai
  176. Purchasing new tires
  177. Passenger Fog Lamp Keeps Blowing
  178. I♥MyA34 decal
  179. 2004 Maxima Has Tranny Issues, Anyone In Minnesota Have a Good Mechanic?
  180. 2004 Maxima has a random very slight misfire at idle. I'm out of ideas.
  181. Custom Grille **opinions wanted
  182. Replace Air Conditioning Suction Hose
  183. PLEASE ADVISE in transmission fluid color porblem
  184. 04 Maxima 6spd with 04 Altima header and Catback with Magnaflow 14816 muffler
  185. Bought a salvage 08' maxima unseen in person
  186. has anyone else experienced ALL the common problems on thier 04 max
  187. this car is gonna drive me crazy!!!! rattle at 2500rpms while driving
  188. Throttle Body
  189. Reverse light troubles
  190. RUST ISSUE
  191. Tune up Question
  192. DDM possible relay, bulb or ballast issue??
  193. Leak on 07 maxima
  194. HID Kit question
  195. Spark Plug Defouler Question?
  196. 6th gen maxima k4 coilovers
  197. Headlights we dread the yellow discoloration and fogging!
  198. what size exhaust?
  199. Solution to steering wheel Shimmy.
  200. 2007 maxima 3.5l engine
  201. 6th gen header install.
  202. 04 maxima rattle... Info please
  203. Precat compatibility question?
  204. 05 MAxima wont turn on cranks bad ECU?
  205. P0021?
  206. 04Blackmaxx farewell...
  207. Transmissions for 04-06 and 07-08
  208. VQ 40 Thermal Spacers
  209. Nissan Maxima 2005 running on 5 Cylinders
  210. inline alternator fuse
  211. Whirring/Groaning Noise on Left Turn
  212. New owner question - MUST do upgrades..
  213. 2004 Maxima SE battery type/size
  214. I need you guy's advice.
  215. bank 1 cat converter location?
  216. DDM HID Kit 55W
  217. '04 transmission flush question
  218. Someone asked me a question but I need expert advice to give them
  219. Battery issue! Troubleshooting advice needed!
  220. New owner !
  221. Brake Disc & Pad Recommendations
  222. Please HELP if you've had p1402, p1800, etc etc
  223. Need help with possible crankshaft sensor problem.
  224. tranny fluid for 4-speed auto
  225. Aluminum Engine Splash Shield
  226. Need some guidance
  227. I do miss her a little.
  228. >>>>06Maxima fog lights
  229. Interior Paint
  230. Stuck in 2nd Gear Issue/Help
  231. Help:Front Mount
  232. New 2006 3.5L Maxima Engine for sale
  233. loss of power while accelarating
  234. Drive Belt fix leaves me with no AC
  235. What maintenance should I do?
  236. Level 10 Valve body or oem Nissan??Help
  237. Transmission Problems??
  238. My new ride :-)
  239. new guy here (Boulder, CO members please look)
  240. oil around knock sensor?
  241. Rear view mirror question...
  242. AC compressor bypass
  243. Changing headlight turn signal bulb
  244. Air Bag Module location 2004 Maxima
  245. Climate control module not working at all
  246. Sad to see it end but I'm out....
  247. INFO : Cattman Y- Pipe
  248. Gutted stock headers?
  249. Radio Compatibility
  250. Winter tire options?
