PDA
View Full Version : 6th Generation Maxima (2004-2008)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. idler pulley lock nut thread size
  2. Redlinemax
  3. Fog light led diodedynamics
  4. Bumper
  5. Change front bumper
  6. 2004 nissan maxima ticking noise
  7. CV joint Output shaft leak
  8. Questions about performance bolt ons and tuning
  9. I need urgent rebuild help please
  10. Tilt steering wheel and druver power seat not working
  11. Almost at 200,000 miles for my 06!
  12. Spark problem
  13. How many Elite Package 6MTs have you seen?
  14. My CVT Adventures
  15. 04 Maxima LH axle seal
  16. Does anyone know if mileage is stored in the gauge cluster?
  17. Nissan murano /maxima question
  18. Power loss and gas mileage
  19. How to Replace Interior Windshield Pillar Trim?
  20. Suspension lift on 04 SE?
  21. Advice needed on purchasing 2006 Maxima.
  22. Super Sexy Custom Headlight Upgrade Build Log
  23. Question regarding front bumper cover replacement
  24. Won't start but only when it is above 80 deg outside
  25. Tried searching head hurts Noob :( Audio Question
  26. Need help with resetting new timing chain
  27. Do i need am idle relearn?
  28. Transfer won't do 3rd gear
  29. 04 6spd swap pass axle problem
  30. New Issue
  31. 2007 Maxima: Replaced battery today, and now engine cranks but won't start!!
  32. 05 Max SL running very sluggish after warm up
  33. Power window problem on 06 max? Rolls up but bounces back?
  34. Extending o2 sensors
  35. 05 Maxima Tranny Help
  36. Getting p1273 and exhaust smell inside!
  37. The 5 spd AT fluid drain plug location
  38. Need advice for injectors for 05 Maxima
  39. windows /memory seats/ and sideview mirrors.... help me please....!
  40. Where is the FM antenna?
  41. Pigtail for Camshaft position sensor
  42. 2006 Nissan Maxima Fuel Smell
  43. No codes but abs acting up?
  44. looking to purchase 2005 nissan max SE
  45. Sunroof motor
  46. Selling damaged car for parts
  47. Dreaded p0300
  48. Please help!
  49. map lights
  50. Non memory harness on memory seat
  51. Clicking, ticking noise coming from engine
  52. 06 Maxima Transmission Issues
  53. Crank sensor location after 6speed swap
  54. Skyview Window Rust
  55. 2006 maxima catalytic coverter problem
  56. Having a hard time connecting Scanmaster software to VQ35DE ECU
  57. Rattling from transmission - Maxima 2004 J31
  58. Where is the starter relay and how is it labeled.
  59. How to price loaded 6MT with ABS actuator issue?
  60. 6sp popping out of 2nd
  61. Issue with battery drain (security light?)
  62. Motor mount labor cost
  63. Sunroof not opening
  64. 2007 Maxima (6.5 gen) fog light bulbs
  65. Click noise
  66. New fuel pump making noise?
  67. Revving sound when in park
  68. Bench test ABS actuator?
  69. 2006 Maxima SE: Transmission Issue
  70. Is something happening with Racingline?
  71. Oxygen O2 Fuel/Air Ratio Sensor Locations 2005 SE Auto Trans
  72. Tip for: Oil light sporadically coming on and or Rough Idle
  73. Transmission issues
  74. 2008 maxima stalling, help!!!
  75. CV axles with Tein springs
  76. 2006 Maxima SE: Suspension Help!
  77. Blowing brake lamp fuse
  78. grinding(?) noise from driver front
  79. 6th gen Movie scene
  80. Offset Help
  81. How do you remove the halogen metal housing/projector?2006
  82. Are all the 04 to 06 manual transmissions interchangeable??
  83. Electrical Issues/ Dash Lights
  84. 2004 VQ35de waterpump stuck
  85. About the Pre-Cat and Y-pipe options!?!
  86. Can you Change Out Just the Feul Level Gauge?
  87. fuel needle slowly moves up and down
  88. How to Remove Instrument Panel
  89. 6th gen Maxima 3.5 engine swap
  90. 2006
  91. 2005 Maxima left side cv axle replacement
  92. Suspension upgrades, surprising results
  93. Car Dies while idling (some) and hard to start (Some)
  94. Car wont move after reaching operating temp
  95. Abs problem
  96. Car shakes at about 1500RPMS- 07 SE Auto
  97. Will 04 5AT interchange with 05-06?
  98. EVAP codes
  99. clockspring
  100. 6th Gen Nu-Jak
  101. 04 Maxima with some tranny issues?
  102. 08 transmission
  103. Bluetooth problem
  104. 2007 Maxima Springs and shocks
  105. 2004 maxima transmission issues
  106. Car Goes BLACK when trying to start with powered sub hooked up!?!
  107. 2005 nissan maxima no acceleration
  108. Big 3 Upgrade. pls advice
  109. Car starter messing up heat controls?? Anyone??
  110. Oil grease smell inside cabin
  111. 2005 Maxima Cranks but wont start.
  112. O6 6MT Transmission Codes
  113. Radiator without transmission cooling
  114. Jack and safety stand points 2007 Maxima
  115. A/C compressor clutch bearing seized
  116. Window regulator/motor help
  117. Stripped oil cap
  118. Monroe Struts
  119. gas needle
  120. 04 Maxima VQ35DE Rear Upper Engine Noise Help??
  121. Heat & A/C but no air
  122. 6th gen body kits available?
  123. Need help finding PNP switch on 05
  124. Are altima parts interchangeable?
  125. Maxi won't crank
  126. Are these repairs critical and necessary?
  127. p0744
  128. Hard starting, won't rev, and slams into gear
  129. I'm back! engine options
  130. Current opinions on doing an 05 manual swap??
  131. HID ballast advise.
  132. Swapping a 07 stereo unit into a 04
  133. Limp Mode after alternator change
  134. Rough start Rpms are low and it does. Help
  135. oil on spark plug
  136. Timing chains & tensioners DIY job
  137. New here suspension fix front Monster truck stance & Rear Super Sag
  138. Ac hose Replacement
  139. Can I change to a switch blade key?
  140. 2006 maxima 5speed auto 3.5 trans question
  141. Something is running when car is off
  142. Leaking ac hose
  143. Parasitic Drain and Code P1065
  144. Hood Struts
  145. heater core flush
  146. Speedometer light
  147. 07 Maxima Key Fob
  148. 07 Maxima Muffler
  149. 07 Maxima Hyper Flash Signal
  150. 2004 Maxima P0011, P1110 - Limp Mode
  151. Trunk lift struts
  152. 05 maxima power steering issues
  153. timing chain replacement
  154. 2005 SE - Mobil 1 5W30 Being Burned Like Crazy?
  155. 2008 Transmission Failed
  156. 2006 fuel pump assembly concerns
  157. 08 key fob problem
  158. 07 Maxima Maintenace
  159. Driver Seat, Side View Mirror (Driver/Passenger)
  160. (Australian) 04 Maxima TI Door Panel Removal
  161. Front seat wiring
  162. Crazy issue-need a maxima detective lol
  163. transmission
  164. Exit limp mode ?
  165. Ground cables ?
  166. P0303
  167. Tuner for 06 maxima
  168. j31 2008 help
  169. cannot locate 2004 nissan maxima tail light fuse
  170. 2006 with rough warm start, rough idle, previous P0420s
  171. Convert manual pass seat to power?
  172. 07 Maxima won't accelerate in drive ..
  173. 2004 maxima sl
  174. 06 max, no start,fans on, no ac control's
  175. bad weekend ending in p0744
  176. Bought a 2004 Maxima about a year ago.. question about alarm
  177. Tail Light Shortage?
  178. Steering Wheel Vibration Issue $1300 later
  179. Key wont turn
  180. how much more life in my 04?
  181. Instrument panel illumination issue
  182. I have screwed something up
  183. Stabilizer Link Bar Removal
  184. Bose Stereo Head Unit swap, whine when engines on
  185. 2005 Maxima SE Upgrades
  186. oem radio swap for Factory Navi
  187. 2004 Transmission will not engage
  188. LED Headlight Conversion Kit
  189. Opinions on purchase?
  190. 2007 maxima in limp or safe mode
  191. 2009+ maxima throttle body
  192. How to find the correct ECM part number from the VIN
  193. where to buy timing chain kit?
  194. Lit up like a Christmas tree, every light, limp mode, high idle, OBD2 not connecting
  195. O2 sensor issues
  196. 2004 maxima ses light blinking
  197. Intake Camshaft Advance/Angle
  198. Parasitic draw
  199. Wiring issue
  200. Dash "BRAKE" light on
  201. New owner
  202. Help please
  203. Loud humming noise 40 - 70 mph
  204. Loud humming noise 40 - 70 mph
  205. Downstream Oxygen Sensor Help Please
  206. SLIP Light Blinking/Grinding Noise
  207. 2006 window motor fix
  208. Rack and Pinion Installation
  209. Need some help please
  210. VQ35HR in my '08 Maxima
  211. door lock/unlock
  212. Plz help me
  213. Muffler delete and resonator swap?
  214. Anybody running these wheels? HELP ME PICK!!
  215. Aftermarket Radio Questions
  216. Transmission/shifting problems. HELP
  217. Help! so many codes, so little time.
  218. RE5F22A Valve Body Cover Part Number?
  219. Advice needed please.
  220. starting/starter problems?
  221. New '04 Maxima Sl owner with some questions!
  222. Sunroof stuck open
  223. Reverse, back-up lights not working, need help.
  224. EGR tube in upper collector cleanout question?
  225. Jumpy Bouncey Idle and No Acceleration - Limp Mode Soon As Engine Is Hot
  226. Few Questions..
  227. Rattle. Pls advise
  228. timing chain repair cost ?
  229. Strut Top Mount
  230. Front brake pad questions
  231. HID issues: Can I use aftermarket kit in my car with FACTORY HID?
  232. 2004 driver side front and rear speakers cutting out
  233. Question on ses light
  234. Should I replace the transaxle seal when:
  235. Headlight Xenon
  236. New here and need some help
  237. Saying farewell after 15 years...
  238. Help with the rear seat assy
  239. Fwiw
  240. Sway bar link
  241. Exedy OEM clutch replacements suck!
  242. New Maxima Owner - AC/Heater Blower Problem
  243. Jet performance Sensor
  244. Throttle body spacer
  245. 2005 Max bottoms out
  246. Motor mount job
  247. 2004 Nissan Maxima: Can't Locate Valet Button to Reset Viper Car Alarm
  248. 6 Speed manual popping out of 5&6 gears
  249. Rattle on 1st start
  250. OBX 02-06 3.5L catback
