PDA
View Full Version : 6th Generation Maxima (2004-2008)
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Just Used VHT Nightshade to black out Tailights.. Thoughts?
  2. Transmission oil change
  3. Nissan Maxima Transmission Problem - Northern Virginia
  4. Can anyone do a Led conversion in Sacramento or know a place?
  5. 2007 SL, Idle seems a little high
  6. Dual tip catback systems?
  7. '04 Maxima RR sub not working...
  8. Right rear speaker not working
  9. Service manuel 2004 maxima
  10. Odometer Jackpot - What do I win?
  11. OEM HID retrofit with exoX-R , awesome
  12. To sell or not to sell
  13. 2006 Maxima transmision PROBLEMS
  14. New here need help with a cel
  15. New Buyer
  16. remote starter help??????????? PLEASE
  17. Doors Lock & All Windows go down... By themselves!
  18. MIL - SES Light On 158k Miles 2004 v6 3.5
  19. Need Transmission Help - 06
  20. TCS & ABS Problems '05 Maxima
  21. Headlight polishing trick to get long lasting effect
  22. 06 SE Sound system steering wheel switches
  23. 05 U.S. Maxima. Does it have DTRL?
  24. lights stay on
  25. 20s with Coilover help
  26. Fog Light 2008 SE
  27. Thought i would create a thread just because
  28. Engine Mounts DIY - Need Help!!!
  29. Driver HID headlight not working. Help please
  30. N1 Dual Catback Exhaust
  31. Help with codes P1402 & P1800
  32. Injectors and mods
  33. performance chips
  34. Uhhh??!! Anybody seen my AT oil cooler??
  35. Timing chain won't start up
  36. Who had code P1283? What was a problem?
  37. Good video tutorial on wheel bearing replacement!
  38. Motor mount sensors... can they be left off?
  39. Which scanner reads live data? I use Actron, it doesn't work well.
  40. Help on Coilovers
  41. Problem with my Maxima 04
  42. Can 16 inch wheels clear the 6th gen calipers?
  43. What paint is the silver trim?
  44. Help identifying year and trim model
  45. I forget, crank or cam sensor failure.
  46. Cold temps and brake failure
  47. Alignment specs for lowered Maxima.
  48. After 5.5 years with my Maxima... I'm fed up.
  49. Starting problems
  50. under engine shield
  51. 05 Maxima HID headlights to halogen?
  52. 07 Transmission problems
  53. I wanna go faster
  54. In-Dash GPS
  55. Wide band sensors have .3V and .8V. Any ideas?
  56. How do I access the ECM?? t/s P2A00
  57. 04 max nav display
  58. Help I messed up!
  59. Help?!! 05 Maxima trans/shift problems.
  60. Spoiler options for an 07 3.5SL?
  61. Maxima rims
  62. 2004 maxima SE troubles
  63. Replaced belts still get squeal from ps.
  64. Help...strange noise when the car is cold.
  65. P0037 and P0057
  66. Drunk Thread
  67. HID!! high or low beam?
  68. 2007 Maxima
  69. 04 Maxima - slow/no acceleration problem
  70. ABS kicking in constantly, need TSB done on 2004. Anyone in rockland recommended
  71. 6th engine swap
  72. PO744... Torque convertor clutch solenoid intermission
  73. spoiler from another car
  74. Cvt tranny fluid
  75. Nissan Maxima Modz
  76. stock bore size?
  77. Tranny fluid
  78. Rack and pinion loose after transmission change
  79. rim size matters
  80. cams
  81. need help!!! thanks in advance
  82. CVT gear got stuck...
  83. 4th Gen 99 cranks but don't start
  84. P1283
  85. washer fuse
  86. 05 Maxima Cut Off Back On While Driving
  87. 2007 Lumbar Support Problems
  88. Auto to Manual
  89. Passenger heated seat does not work
  90. Heater Auto Mode remains with AC on
  91. 6th gen owners
  92. Clockspring
  93. Retrofited headlights
  94. Trying to buy a 6th gen - Need input
  95. 05 maxima motor swap?
  96. From manual to standard mode
  97. Timing
  98. Replace sunglass holder in overhead console
  99. cornering light fuse?
  100. metal noise
  101. Need help
  102. 2007 Maxima question
  103. Tensioner and guide has me out of timing
  104. Trans Problems?
  105. I smell a RAT!!!
  106. Want a spoiler
  107. ABS System Malfunction
  108. Abs/slip/tcs
  109. Phone volume issues
  110. Need to accelerate to heat car
  111. Max is down for a bit
  112. New paint job
  113. hid headlights
  114. This Sucks
  115. Need Lowering Spring Suggestions!
  116. Headlight problem
  117. 2004 transmission problems
  118. Catalytic converter problem
  119. Front Lip Help!! (2008 Max)
  120. Glove Compartment Part
  121. Ebay front lip for my 08 Maxima
  122. 04 skyview leaking
  123. Spark Plug and Oil Change question
  124. 04 Max rear brake issues
  125. Transmission fluid change or not
  126. P0444 code
  127. Diagnostics Reading
  128. 2004 Maxima V6 -Noise -Ping Need Help
  129. Satellite radio removed & radio reception is bad
  130. Ticking noise on idel
  131. Top Roof Trim
  132. Abs question////brakes
  133. driver side axle
  134. Axle Splines & Motor Mounts
  135. 2007 stalls on start up randomly, please advise
  136. HID replacements?
  137. sick of this car
  138. Quick Help!!!
  139. Cylinder 1 missfire
  140. Remote Start concerns
  141. Bad Gas millage
  142. help me please
  143. P1800 code, need advice
  144. Vibration from transmission
  145. OBD2 says it can not connect to car "HELP"
  146. Module airbag
  147. catalytic converter
  148. console lighter
  149. Reminder: Check your battery ground to frame/transmission cable
  150. transmission pan placement
  151. Want more HP!!!!
  152. 2005 3.5 SE Fuse block
  153. camshaft position sensor
  154. after market parts
  155. tranny help
  156. Burning Oil, Whats your Remedy
  157. Trans Cooler on radiator?
  158. Lighting questions
  159. fog lights
  160. Blue and Red Shinjiduo Grounding kits $24.95 until 12/31/2013"
  161. 2004 Auto Trans Problem
  162. No pedal response, TCS and SLIP light are on
  163. Manual Closing Window - Help!!
  164. P0420 and O2 Sensor readings
  165. 2006 Nissan Maxima Cranks but not start.. NEED HELP
  166. CAI for 08 maxima
  167. Grounding wire at muffler?
  168. 2008 MAX CVT manual shift issue
  169. Newbie w basics
  170. 2005 Nissan Maxima SL Jerking
  171. New to the group
  172. 6th Gen Engine Replacement
  173. '04 Maxima factory alarm
  174. Anyone swapped the 7Gen VQ35s into the 6th Gens?
  175. help
  176. Smaller Magnaflow Resonator?
  177. Front Right Upper Motor Mount Doesn't Fit - Solution?
  178. 2006 Maxima Timing Chain & Tranny
  179. Turbo/Supercharge 08 CVT?
  180. Tail light
  181. Tail light
  182. Need help finding Ambient temp sensor harness
  183. did I make a mistake buying a Maxima
  184. Tap noise coming from engine / possible lifter problem?
  185. opinions on some good exhausts?
  186. Replacement Vent 05 Maxima
  187. no int lights or memory seats
  188. 9012 hid conversion
  189. Launch Control for 2004 Maxima?
  190. 2006 Transmission Question
  191. 06 domelight fuse location
  192. New Here...My First Nissan!
  193. 6th gen upkeep costs
  194. Replace resonator w/ straight pipe OR smaller resonator?
  195. short?
  196. introducing myself
  197. Brakes
  198. Big brakes
  199. 2007 maxima washer pump fuse
  200. Is it better to get a 2004 with less miles or a 2007 with more?
  201. 2006 Maxima Extended Warranty Question
  202. 2006 Maxima Motor Mount questions
  203. How to use Seafoam
  204. Module number?
  205. Coil Springs and Ground Clearance
  206. Unknow Maxima - needs more info
  207. 2013 rims
  208. Loud Squeal When Turning Steering Wheel
  209. Opinions please
  210. 2004 Transmission
  211. 2007 Maxima
  212. reset 2004 maxima service engine soon light
  213. (new to the fourm)Nissan maxima 2004 Does not acclerate passed 2000 rpm
  214. 04 maxima pining noise.
  215. gearbox/transmission problem nissan maxima 2004
  216. 2007 Maxima SL CVT Problems!
  217. False check engine light/iac sensor
  218. Nissan Maxima SE 2004 Headlight problem
  219. 05 maxima running rough..
  220. Installing Navigation System on 2007 Maxima
  221. back up camera
  222. Custom intake 07MaxSe
  223. HELPP!! Heated seat on driver side wobt work!?!????
  224. Engine noise on deceleration
  225. Switchback fitment
  226. Transmission Swap
  227. Speedometer Spun Around - Not Working
  228. Happy Thanksgiving.
  229. Battery size
  230. 2004 max heated seat on driver side not working
  231. Tranny Ground Strap & ECU/TCM Reprogramming
  232. filter gone bad or coil?
  233. 07 max se bulb question
  234. 07 SE Headlights Extremely Dim
  235. Oil Capacity vs Dipstick length
  236. Newbie with questions about newly acquired 04 maxima
  237. New headlights...GARBAGE!
  238. 2005 Maxima Purchase
  239. Correct Replacement Bulb for '07 SE
  240. Headlight Replacement Issue
  241. Timing Chain Question
  242. Bad MPG on interstate?
  243. How to identify type if headlight
  244. 06 maxima
  245. Question on a 06 max
  246. She just hit 100,000
  247. Tuning ?
  248. Replace Hid Bulb 06 Maxima?
  249. Engine shut off?
  250. 2004 Maxima SE power seat problem
