PDA
View Full Version : 6th Generation Maxima (2004-2008)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Goodbye summer show mode and hello pre-winter mode
  2. Intro
  3. So confused regarding 07 Maxima Headlights!
  4. Ever try this on your trunk?
  5. GPS update
  6. Cattman Performance 6th gen headers and y-pipes going into production, time to order!
  7. Question on 08
  8. 6 speed swap in my 04
  9. Shifter cable Maxima 2004
  10. fey fob lock/unlock issue
  11. Winter Wheels
  12. 04 lips n 08 wing diference
  13. Shifter problem any ideas
  14. Blown two engines in 6 months
  15. 05 maxima transgo shift kit
  16. Got in a big wreck...
  17. Transmission advice
  18. Does the 2008 stereo have aux ports default?
  19. EZ Koncepts Zk1+2 Hybrid Front Bumper LIP Combo
  20. What happens if you DONT fix the timing guide and/or tensioner?
  21. rough idle after timing chain tensioner repair
  22. HID Color Change - HELP!
  23. hid problems... in fogs
  24. hello all
  25. 2005 Maxima SAT Sirius reception problems.
  26. Will it fit?
  27. Kinetix?
  28. Looking to buy, need some pointers?
  29. 2004 nissan maxima lower engine cover replacement?
  30. 2004 nissan maxima front bumper underneath part?
  31. Which mods to make
  32. Headlight problem
  33. In need of some advice, would be greatly appreciated
  34. Front end trouble, looking for advice/mechanic in NY/NJ area that knows 6 Gen
  35. side mirror problems please help
  36. Front grill
  37. Opinions On This Ebay Product?
  38. HELP with Sunroof misalignment and Dome lights
  39. help wireing issue
  40. New wheels, G37 look-a-likes
  41. Put on 20mm f 25mm r ichiba bolt on spacers look
  42. flex plate?
  43. Upper Intake Question
  44. FYI- Theres a Cattman Exhaust Group Buy going on
  45. Aftermarket head unit on 2008 maxima?
  46. remove front side carpet instructions?
  47. Back in the game
  48. 04' Maxima SRS Airbag Module LOCATION?!?
  49. Thinking about buying a Maxima
  50. Radiator Fan Installation and Wiring - Need Assistance
  51. K sport springs on 6 gen
  52. 160k+ miles to much ??
  53. Changed Headlights, Car wont start now
  54. MAF and IAT connector
  55. I'd like everyones feedback on this 2004 Maxima SE...
  56. Ignition Coil Pack dilemma: New aftermarket or salvaged OEM?
  57. Need some help with a fuse box diagram(A34)
  58. You've just taken delivery of your 6th gen...what's the first mod you do?
  59. What is wrong with these wipers?
  60. Electric Turbocharger ????
  61. Headers and other mods
  62. Car is sluggish when its hot out?
  63. Intro awaiting shipment
  64. which harness did I break...? (passenger side near oil pan)
  65. Muffler/exhaust sounds GOOD?
  66. Threw on a few decals
  67. Front sway bar links
  68. what kind of cars have u "left in the wind"
  69. Can i drop my 07 max with the stock wheel and tire
  70. 05 maxima Sl paint issue
  71. First time, long time. Mod advice?
  72. Maxima is awesome
  73. Moisture in my HID Headlight.... HELP!
  74. CVT Jerk
  75. Help please: Is there a bolt-on list for 6th gens?
  76. Handbrake + vdc off sign, weird motor sound.
  77. new (to me) 2007 nissan maxima
  78. Passenger Door Window/Locks Problem
  79. Sudden shake about 40mph
  80. 22's on my 6th gen
  81. Where to buy parts for Nissan Maxima 2004
  82. Putting in navigation
  83. Power Window Switch
  84. New to the forums!
  85. 2004 Maxima takes a few tries to start in morning
  86. Cigarette Lighter in Console
  87. Floor pan rust anyone?
  88. Help!!!! ALARM WON'T GO OFF!?!
  89. [for sale]
  90. Any comments on 2004 Maxima SE
  91. Door lock actuator
  92. Car cranks, revs, then dies??!!
  93. Cams
  94. New 2009+ Maxima Roof Spoiler on Ebay
  95. Cattman
  96. incorrect fuel gauge readings issue!!
  97. blower motor resistor
  98. Lowered on Racingline springs
  99. 2004 maxima se transmission drain/flush
  100. Cabin blower not working
  101. >> Nissan Maxima Vent Visors <<
  102. 2007 Maxima 3.5 SE L
  103. Wheel hub and bearing
  104. Both radiator fans stopped working at same time
  105. New 2007 SE Owner
  106. 05 SE shifts hard, transmission does some random shifting at times, etc....
  107. Sprint booster
  108. Has my transmission gone bad? 2004 Maxima (Automatic)
  109. Full-Throttle Hesitation
  110. New wheels!!!!
  111. 04 SL whining noise
  112. 2007 SL owner
  113. HELP!! Hard Start after camshaft/crankshaft sensor replacement.
  114. Timing chain repair.... Coolant leak??
  115. Black Vinyl Trim Overlay
  116. Looking to sell Infinity Kappas 639i 3-way speakers
  117. Looking to sell Infinity Kappas 609cs component speakers
  118. Thermostat change
  119. ABS Sensor Help
  120. will the '07-08 GRILL fit on a 04-06 bumper?
  121. AC weak, stopped working, started again?
  122. Nismo exhaust? where to purchase?
  123. '04 Lifter noise
  124. 2004 SL... what's it worth?
  125. Been thinking of selling my 5.5gen, what about this one?
  126. Thinking about selling my Dad's 06 Maxima need advise
  127. Passenger Headlight won't work
  128. Smittybizzle build
  129. Intakes that can be converted to short?
  130. Tranny Problem 05 Max
  131. ECU location
  132. 2005 Maxima won't start after valve control replaced
  133. Camshaft Position Sensor Replaced
  134. 04 maxima 116km Just purchased!
  135. 2006 SL, bad knock at startup, now won't start
  136. Side-scanning radar collision warning
  137. Custom Sub-Enclosure.
  138. Australian J31 Maxima - Power steering high pressure hose dramas!
  139. Totaled 05 SL.
  140. My new 05 Maxima SE
  141. What would you do ? After-purchase maintenance.
  142. anyone was able to repair door lock assembly?
  143. SES light, bad tranny shift & "P78" code?
  144. Side curtain and seat airbag replacement?
  145. Driving CVT in "Manual" Mode
  146. Need help identifying my new max.
  147. 6th Generation Forum Guidlines
  148. What's up everybody!
  149. Thinking of buying one...
  150. First Forum post; rear deck Rattle
  151. Blown brake light fuse
  152. Curious Computer Issue
  153. Oil cooler leak
  154. P1284
  155. Exhaust question
  156. Buying 05 Maxima - Reliable Trans Stories?
  157. brake and battery light on??
  158. Stereo install in my 2004 SE
  159. New maxima for me, what to do first?
  160. 07 max blows smoke on startup
  161. upgrade for hedlight xinon system
  162. 2004 maxima orange display to color????
  163. U1000 error code 2004 maxima
  164. NEED HELP - PLEASE -- Climate Control Problem
  165. Brake and cruise control switches
  166. Looking for engine...what will work?
  167. Stucked park-brake interlock solenoid
  168. o2 sensors
  169. Bigger Rims and Engine and trans upgrades
  170. Problem with brakes... no power... all lights turn on...
  171. Transmission
  172. fujita
  173. Trying to diagnose a sound
  174. Grinding & vibration when pressing brakes.
  175. ZEX wet kit questions
  176. KYB Shocks/Struts.. Do I need anything else?
  177. Rim compatibility
  178. 2002 Maxima GLE vs. 2005 Maxima SE?!
  179. Lsd and non-lsd axles
  180. 2004-2006 Bumper covers VS 2007-2008 Bumper covers
  181. help!
  182. Exhaust parts
  183. Controlling uphifts
  184. Pot hole = strut
  185. Front Bumper License Plate Holder
  186. How many of you deleted EGR?
  187. Need answers to my questions of a 04 elite maxima
  188. '08 SE Remote Start suggestions?
  189. help?
  190. I'm still here, by accident
  191. AC cycling issue
  192. Loud Air Compressor Sound?
  193. 07 passenger side mirror
  194. Spiral Cable
  195. Is it me or??
  196. 2007 Maxima SE issues
  197. 06 fan problem?
  198. 2005 Nissan maxima radio adapters
  199. 06 maxima SE headlight replacement
  200. '04 Maxima Rattles on start up????
  201. 04 Maxima Overheating
  202. Got my hands on some G37 wheels
  203. 2006 Nissan Maxima Problems Please Help
  204. check engine light codes help
  205. 2012 Detailing
  206. Coilover Spring Rate for 6th gen
  207. Engine light on
  208. 6th Gen Alternator Replacement thread?
  209. Mesh Grille Recommendations (C-Mod)
  210. Annoying noise
  211. 2005 Maxima P0455 code after gutting cats and replacing Alternator
  212. splash guard
  213. Passenger side rearview mirror swap
  214. 2004 sl issues
  215. metra dash kit wrong color
  216. Speedometer and odometer not working...help
  217. new engine or just fix timing chain
  218. PICS! From 91' to 98' and now 08'
  219. Center display doesn't dim when headlights come on automatically. Is this normal?
  220. need help on this problem i had any Suggestion
  221. rings or seals?
  222. Cost to replace CVT - 2007 Maxima?
  223. Damn, 6.5 GEN W/ TRANNY LEAK!!!
  224. AC Compressor!!!!!!!!!!!!!!!!!!
  225. Engine/Trans Question
  226. 2004 5spd A/T driver side axle
  227. Rough Idle them SES light
  228. Lowered on Canuck Motorsports springs
  229. Dreaded Transmission Problems :(
  230. New 2005 Owner
  231. Rough Ride?
  232. lowering springs which one is the best?
  233. Key Fob
  234. 6th generation transmission 5sp at $1500
  235. Vacuum Leak/O2?
  236. HEADERS!!!! tell me what chu think
  237. 2004 Maxima Air Vents Are Stuck Closed
  238. Airbag light flashing
  239. emblem
  240. Tired of trying!!!
  241. Unique door locks situation
  242. 04 Max overhead sunglass console broke - need help
  243. 2006 Maxima Help?
  244. 04 maxima headlight condensation
  245. i need help i have few questions
  246. Need motor I have questions
  247. Sunglass holder "slow" gear not working
  248. Faithfull Maxima owner
  249. Headlight problem!!
  250. Transmission question
