PDA
View Full Version : 6th Generation Maxima (2004-2008)
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. HID to Halogen
  2. Power Steering Issues
  3. Connect Seat Nissan maxima 2004.
  4. Navigation screen does not come on all the time when I start the car
  5. Trip Info not showing and Climate control screen is black
  6. Bag idle
  7. Scored a 2007 Maxima SL for $500!
  8. 2006 Maxima P0174
  9. New motor, no remote start
  10. For sale 2005 nissan maxima 6 spd
  11. Wearing out CV axles too quickly cuz I'm lowered. Advice?
  12. 05 and 08 maxima A/t
  13. 2004 Nissan Maxima
  14. idle relearn wont take
  15. fuel needle
  16. First car a 2005 nissan maxima 3.5 se
  17. Timing Chain Mating Marks
  18. Timing change replacement
  19. Water pump leak, need help
  20. Fuel Level Sensor Circuit Low Input. P0452 code 2004 Max,
  21. Overhead console removal broken 08 Maxima
  22. Door handle is siezed/door wont close
  23. How to get blacked out headlight for 6th gen maxima with factory xenon headlights
  24. Need help my nissan maximum went start and the key wouldn't turn and wheel wouldn't
  25. 2007 Maxima CVT issues P1778 P0776 P0868
  26. What is causing the car to jerk?
  27. 2008 Maxima P0171 and P0507
  28. 2007 Maxima wont Rev past 2000 pms in reverse
  29. 2006 maxima Left muffler fell off
  30. Maxima 2004 6M/T p0335 X2 pending and stored
  31. Heater turns on automatically
  32. Rattling noise where axle goes into transmission
  33. Creeking cracking etc from front right wheel
  34. Starter from 2000 Max fit my 2004 Max?
  35. No Crank until key is cycled on/off 5 times
  36. 2006 maxima 3.5L won’t stay running
  37. 06 maxima cranks-no start
  38. Ported and polished heads for vq35de
  39. 08 tail lights
  40. 06 Maxima Wont Accel.
  41. After 12 years 3 months and 268,759 miles, CVT died. Bye my trusted Maxima!
  42. Hello
  43. Power steering
  44. Map Lamp Assembly Light Dome Upper Roof Console On Off Switch
  45. PLS HELP! Valve body Replacement
  46. ENGINE OIL leak, underneath passenger side
  47. Unstable fuel gauge
  48. Help Power Issue When First Placed in Gear
  49. Engine oil leak
  50. Starter problems (pictures)
  51. What Parts to Pull From an SE-R?
  52. What Parts to Pull From an SE-R?
  53. 08 Maxima A/C display not working after new radio install
  54. Transmission swap
  55. 04 maxima sl has no power/won't rev past 2500 rpm
  56. Low voltage while running.
  57. Limp mode when A/C is turned on.
  58. Brake light and Battery Light on when driving
  59. Exhaust Advice
  60. Hr upgrades
  61. Car overheats- Cooling Fan Won't turn on. Running out of @$#%! ideas why - Help!
  62. Air Bag Light
  63. 2005 Nissan Maxima - slip light during deceleration
  64. P0507 code and 2500 RPM startup
  65. 07 Maxima - Sudden Low Power Issue
  66. Electrical Help Please
  67. 2007 into autocrosser
  68. Diagnostic on 6 speed
  69. CVT “downshifting” on Highway
  70. engine swap///3 codes///limp mode
  71. Clutch Advice Needed: 04 Maxima 3.5SE 6spd
  72. Maxim-um Attraction...
  73. rattle at 40 mph
  74. 07 Maxima TPMS Error C1710
  75. Oil in cylinder 2 /// clogging up spark plug
  76. Any suggestions of why white smoke out of tailpipe, jerking issues
  77. Please HELP!!!
  78. IPDM question
  79. 2004 maxima 6 speed Y pipe CA emissions? For sale?
  80. Transmission/cv axle left side squeak
  81. Alarm...is killing me
  82. mufflers opinions
  83. Coilovers vs lowering springs
  84. P0406
  85. Tie rod
  86. 04 bogging down
  87. P0456 Help
  88. 04 Max won't start after tranny rebuild and clutch/flywheel replacement.
  89. cabin filters
  90. front control arm broken bolt
  91. how to reset ECM/ECU ?
  92. code p0037
  93. Sometimes horn
  94. P1335!!!!
  95. Can I do a facelift on my 2006 Nissan Maxima?
  96. static sound
  97. JDM Maxima vq23de to vq35de swap
  98. Just got 2007 auto with 188k
  99. Remove Upper oil pan to remove harmonic balancer?
  100. New member, 07 maxima 129,000 miles towing a seadoo
  101. ac cooling fixed
  102. New owner! Please help upgrade sound system to BOSE AND BEYOND
  103. Oil leak upper pan
  104. In search of aw55-50 sn parts
  105. Front Suspension Work
  106. where to find part number
  107. please help me locate the ac relay
  108. 04 Maxima A/C Recharge
  109. Seat wiring diagram?
  110. P0037
  111. p0301 code
  112. IPDM Housing Installation
  113. Power steering pump/ cv boot/ tie road end all soaked in engine oil. Thoughts?
  114. 05 Maxima intermittent battery light while driving
  115. Motor no good
  116. AC is no longer cold
  117. Clockspring
  118. 2005 grille replacement tutorial?
  119. 4" custom intake
  120. Sudden shutoff
  121. Strange noise...
  122. 2007 maxima se
  123. P0300 code
  124. Parking lights
  125. 2007 maxima a/c relay, fuse location
  126. Variable Valve timing solenoids
  127. Battery tie down
  128. Nwp spacers and throttle body
  129. 2018 maxima rims on a 05 maxima
  130. Ac - where is the expansion valve?
  131. '05 Max, having the issue with ABS activating while driving.
  132. 04 maxima laat continu lucht in het koelsysteem.
  133. Help!! Transmission part needed.
  134. 07 Maxima Sl abandoned
  135. Cv axles
  136. How do you remove high mount stop lamp in spoiler?
  137. Brunt orange elite driver seat
  138. Can i put a 350z LIM and UIM on the maxima?
  139. 2007 nissan maxima performance parts canada
  140. Water pump sprocket
  141. valve cover and intake plenum bolt torque specs
  142. 2008 altima with ctv
  143. Power Steering..
  144. 05 manual se clutch issues
  145. Headlight problem
  146. Headlight problem
  147. 05 Nissan Maxima automatic
  148. power window problem
  149. Coolant leak
  150. Brake lights stay on. Even though I replaced switch
  151. 2007 Maxima oil pump replacement
  152. Moog control arms, stabilizer links, inner/outer tie rod ends
  153. Crank no start
  154. Widest wheel that fit 05 maxima
  155. Looking for advice on aftermarket brands for motor/trans mount(s)
  156. 08 maxima base system ( clarion en1240 amplifier) bypass HELL!!
  157. help
  158. 2006 Maxima engine swap coolant line issue
  159. HID's not as bright as I think they should be?
  160. 2007 Maxmia brake light
  161. 6 Codes Scanned on 2005 Maxima SL
  162. Oil Leak
  163. Electrical issue with 2004 Maxima
  164. Car misfiring, codes P0300, P1110, and P0011
  165. Troubleshooting Codes
  166. 2004 Maxima camshaft sensor
  167. Weird power issues with my 08 3.5 Max
  168. Best ways to improve cornering performance?
  169. 06 nissan maxima, need help with transmission issues
  170. Clutch pedal a little soft not going into gear
  171. Transmission is making sounds, surges of power and revs
  172. only 8.7 mpg!!
  173. Where is the Vehicle Speed Sensor (VSS) located?
  174. Front suspension noise/clunking on 2008 3.5 Maxima, blown struts?
  175. telescoping steering column...
  176. Replace both camshaft sensors. Car still won't start.
  177. Looking for replacement intelligent key
  178. Looking to purchase 2004 Max. Insight appreciated.
  179. Temp and fuel light
  180. Where do I run power cable for aftermarket amp?
  181. 07 Maxima cruise control issue
  182. 2004 crank no start
  183. Help and advice needed please.
  184. 04 maxima no power need sensor and throttle acuator help!!
  185. brake light and charge warning light
  186. Trans leak pls help
  187. 04 w/ shifting issue after trans valve body replacement
  188. Fujita replacement filter
  189. P2135 Code, little to no acceleration
  190. Program a BCM
  191. In dire need of assistance
  192. Rough "clacky" idle, no codes
  193. Delayed shift, hard downshift
  194. Timing
  195. Help with codes p0174 and p0171
  196. Aackshun swaps a 07-08 to 6MT
  197. 04 Maxima - ABS+Brake light randomly comes on, gauges die, blinker doesn't blink, etc
  198. 2005 maxima steering rack removal
  199. Just bought a 07 se any tips
  200. Rear motor mount
  201. 04 Bose issues
  202. Remove and replce my rack and pinion
  203. Battery light keeps staying on, limp mode
  204. 05 maxima barely moves I have to push pedal to floor
  205. Trip Info Display Units
  206. whistle or whine after engine warmed up
  207. Halogen to Hid
  208. Trans cooler seal passenger side??
  209. what should i do to my 6th gen maxima?
  210. 06 wont start after longer drives until it cools off.
  211. Can slow crank no start mean bad timing chain ?
  212. Shift interlock module
  213. Auto A/C does not work
  214. Bose stereo making intermittent popping sound even when off
  215. Loose wire in door handle?
  216. Race line Motor mount inserts
  217. Knocking sound when accelerating
  218. Steering wandering
  219. Engine swap
  220. Desperately Searching For A Roof Rack
  221. Just bought a Maxima, questions about o2 sensors.
  222. 2007 starts in high gear but shifts manually ok
  223. Brake lights don't turn off, cruise control intermittent problem
  224. I want,to,steal my own own car.
  225. Maxima Car Title
  226. burping cooling system after radiator replacement
  227. Paraasitic Load Testing - Battery Keeps Draining
  228. Engine swap
  229. No acceleration
  230. 06 Max turns Over No Fire Please Help
  231. 2005 grille replacement tutorial?
  232. grill
  233. Error code P0113 IAT location?
  234. Pinging (detonation) anybody else experienced?
  235. Key Fob Programming
  236. 04 Maxima SE Brake and Battery Lights flash randomly, ABS light followed by no power
  237. New to site/ problem with my 2008 Max cutting off while driving
  238. Ac blower will not turn off
  239. Acceleration
  240. Looking at 08 Maxima - 145k miles
  241. Grinding noise coming from front right
  242. 2005 Maxima SE
  243. Double Din Install
  244. 06 maxima no crank new ecm bcm and ignition
  245. Passenger window sticking
  246. Oops. Broke side view mirror. What's this piece called?
  247. Will these Headlight Bulbs Fit
  248. 2006 maxima
  249. 2004 SL headlight question
  250. Looking to buy
