PDA
View Full Version : 6th Generation Maxima (2004-2008)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Fitting '04 HID Components To '04 Halogen Assembly... HELP!!!
  2. tranny
  3. headlight issue
  4. Switchback problems
  5. Need help, hit a Coyote...
  6. Catback with dual tips on each?
  7. racingline y pipe help!!
  8. Extreme Roof Spoiler Opinions
  9. Deep discounts on Cattman 6th gen mufflers!
  10. What does it mean?
  11. 07 altima transmission on 06 maxima se automatic?
  12. anyone have g35 Rays on a 6th gen ?
  13. Cvt oil change...
  14. Ebay Catback exhaust in Cabin clips
  15. SES On but No Codes
  16. Weight of the driver side power seat?
  17. Door Lock
  18. Cant Find Fuse for Cig Lighter... and Im no dummy.
  19. Would you rather m45 19 sport rims or 18 350z anniversary rims on a 6 6.5 gen maxima?
  20. Ram air intake on a 6th gen .. anyone ever done this ?
  21. new transmission
  22. Anyone have g35 Rays or 350z Anniversary rims on a 04-08 Maxima ?
  23. Projectors
  24. Symptoms of bad intake valve timing solenoids
  25. What's the Oem part number for this.
  26. new pics..let me kwn wht u think..!!
  27. How Do I get This?
  28. Updates to my maxima
  29. 5th gen 17" wheels on 6th gen?
  30. Slight shake when driving-more when braking
  31. Brake and Battery Light Problem
  32. Steering Rack Adjustment
  33. anyone have m45 rims on their 6 6.5 gen maxima ?
  34. First time at the Track
  35. Rear 3 spark plug removal....
  36. What spark plugs are you guys using?
  37. will dese fit an 08 max?
  38. If this is your car
  39. stillen exhaust & racingline y pipe
  40. thinking about buying a set of F/R rotors
  41. Closing on a 2004 max tomorrow, or should i not??
  42. AFTER 7.5 YEARS WITH THE MAX...
  43. pic of 6th gen on eibachs and 7th gen 19"s"?
  44. dstruc's custom scion tc lip
  45. Elegant Roof Spoiler
  46. Bulb, Ballast, or whole assembly?
  47. 2004 SE 6M
  48. 6.5 affiliates ride
  49. Ipod direct wire kit?
  50. Got Some New Shoes
  51. 3rd brake light removal
  52. Car won't start after replacing injectors
  53. Need plastic shroud for Street Scene grill
  54. Stock radio repair
  55. Noise from rear suspension
  56. Possible Starter Issue
  57. The BeSt 5 MoD EvEr
  58. Maxi
  59. CAR HEAT
  60. 07-08 Window regulator
  61. wobbling sound underneath. Any ideas?
  62. Iphone app..
  63. eBay Catback with RacingLine Y-Pipe (Video and Sound)
  64. are these tires okay
  65. Wind Noise (tweeter area)
  66. How to remove 04 Maxima speedometer/cluster
  67. Painting the emblem or burger
  68. Halos...Finally done.
  69. Progress spring install/pics
  70. Pic request--MAXs on 19's
  71. 21 max's ride
  72. manual grind
  73. 2005 S.E Clutch Fluid Flush
  74. Who's car is this?
  75. Will the Bose work in a non Bose equipped car....?
  76. Did I do it right?
  77. My6thgen.org won't open??
  78. P0202 code help!
  79. 2011 6thgen's United Video Teaser
  80. Ticking noise
  81. ?? For 6.5 conversion
  82. Throttle Body Cleaning
  83. lowering spring Eibach
  84. Ebay Catback installed with High quality sound and video
  85. timing advance help
  86. 2004 Maxima Noise need help!
  87. Rattling front end
  88. i need a advise!!
  89. Should I Buy a New Hood Or......
  90. utec 350 starting bid
  91. no racing threads!!
  92. Right Front Motor Mount- anyone done this before?
  93. Step on Gas with no RPM Change
  94. Top end issue : Fun run in mexico vid inside
  95. Lowering Springs ** Poll **
  96. Is this possible?
  97. Are these springs any good ?
  98. Nissan, Renault and Mercedes Make Major Announcment
  99. Car Shakes at Freeway Speeds?
  100. AVIC-Z120BT is in my 07 Max
  101. Window roll donw/back up, possible?
  102. Is there anything i need to know...
  103. Racingline Ypipe PROBLEM
  104. so nissan couldnt find the problem..
  105. Installing GTR Bumper need help!
  106. New Roof Spoiler comes Painted
  107. Trunk Button FAIL on my 6.5 plz help.
  108. Engine Mounts...
  109. Just a little FYI....
  110. manual issues
  111. Clearing a CEL
  112. Introducing new Racingline High flow Catalytic Converters
  113. two tone 6.5 gen help
  114. I'm thinking of selling if the MPG doesn't change
  115. Finally, my timing chain tensioners are done!
  116. Project "Blackout" continues!
  117. Fastest 6th gen ?
  118. Switchbacks installed
  119. Farewell 2004 Maxima
  120. P0455 cel on.. Please help!
  121. Mass air flow problems
  122. Opinion
  123. Trunk Problem
  124. What went wrong..What can be done now.
  125. p1402 wont go away!!!!
  126. Post pictures of max on 18s
  127. Looking for tran shop in Dallas for RE5F22A TRANSMISSION FIX
  128. Door actuator or body control module, or both?
  129. Cleaned and took some pics.
  130. Major Starting Problems
  131. Tierd of this dam wheel shimmy
  132. does the motor warranty ends at 35K?
  133. Installed new springs sagging rear
  134. 05 Maxima 6MT transmission flush
  135. for 2007-2008 years
  136. No more $%#*&# chrome roof strips!!!
  137. Shaking/Vibration issue
  138. Powered seat swap - Need Help
  139. HID bulb confusion...SOS
  140. Question regarding 6.5 Gen Conversion
  141. WILL IT RUB!!
  142. Need help with a relay
  143. 04 Nissan Maxima tranny problem, HELP
  144. misfire help
  145. Engine light on Code: P0797 Help needed!!!
  146. just installed fujita CAI- wierd noise
  147. Finally got some pics of my MAX
  148. One day Special Cattman Sale - Friday the 13th in GD forum
  149. Flywheels
  150. Tinted Headlights & Tinted Taillights
  151. Assistance please
  152. Ok Set me straight .. NDSS System ..??
  153. How to tell .. HID's or not?
  154. Need Your thouights 2007 Infiniti M35X AWD
  155. Help!!! 6 Gen Members
  156. NEW EXHAUST CAT-BACK!!
  157. need little help..
  158. Ok Let me get this straight ..(Upgrade?)
  159. Wanting to buy a 6th gen....
  160. fantastic Car DVD Player??
  161. pine sap
  162. EZKoncepts LED Tail Light Issue..
  163. RLM bumper mods
  164. Got a couple more car projects done over the past week!
  165. Painted Rims
  166. Replace 3.5 engine or Remanufactured?
  167. Are there any other nissan's that have the same size fogs as the 6.5?
  168. Wierd noise... please help!
  169. This is an odd maxima...
  170. Maxima of the month
  171. Anybody have a trailer hitch on their maxima?
  172. Need Opinions
  173. The Tale of my grille.
  174. Night Night Max
  175. 2008 Yellow Fog Lens Tinted
  176. time for some rims
  177. My New Taillight Overlays
  178. Finally dropped w/pics
  179. Want to Lower My Max.. Done a bit of research.
  180. powder coating
  181. nismo cold air intake or Fujita???
  182. what are the major differences between a 6th gen and 6.5 gen?
  183. bye bye my max </3 =(
  184. No Longer a Maxima Owner...
  185. Noise coming from front right wheel after lowering the car?
  186. dual alternator
  187. Had a bumper bender issue on my max :( no pics srry
  188. 'Stillen' Roof Lip group buy
  189. compass color
  190. Help w/ iPod Adapter!!
  191. any 6.5 gens having weird jerking CVT symptoms?
  192. Post your 6th gen with HID's!
  193. 05 Max Lowered worth it?
  194. Swapping out the projector lens
  195. spotted silver maxima on the 405 today....
  196. What are these supposed to be hooked up too?
  197. Would motor mounts make a squeaking sound?
  198. Help Me with my LED MOD!...Please
  199. suspension issues!
  200. Rotten Egg Smell W/ "Spirited" Driving
  201. It just crossed my mind...
  202. 04-06 Headlight halo option.Which one looks better?
  203. Lets see some maximas lowered!!
  204. are these good wheel spacers
  205. How can i make my headlight reflectors white
  206. im looking for a Rear shock replacement DIY
  207. Wheel Choice
  208. Any recommendations on Intake Systems and Lowering Springs?
  209. Power Wire
  210. Megan Cat-Back Exhaust W/Fujita CAI..
  211. Tires for SE
  212. HID and auto headlight question
  213. Windshield replacement
  214. lighting problem..Anyone else?
  215. RIM HELP 2
  216. 07 Bumper scratches
  217. whistle noise after headers, y, and intake port
  218. Engine Noise/Timing Belt question!
  219. ADR Sokudo on 04-08 Maxima!?
  220. RSX Rims on Maxima?!
  221. Memory seat and steering problems
  222. Caliper Covers
  223. What are you guys using for tires these days?
  224. Lets see some stock painted wheels on 6Gens only
  225. Which Rims Do You THink?
  226. A19's new suspension....finally
  227. i got some newspaper coverage
  228. Non-Bose Audio upgrade 07 max
  229. Pics of your 22's
  230. Post pics of your interior!
  231. Need Help with HID Please!!
  232. Body kit/Custom front bumper Discussion - ALL 04-06 & 07-08 Check-in.
  233. Anyone with 275/35/19's on their maxima?
  234. headunit installation
  235. photoshoot
  236. Coolant for a 6th Gen
  237. Free shipping on TireBuyer.com orders
  238. How do i replace 07 headlight cover?
  239. 07-08 First Mugen Lip Complete
  240. question about Y PIPE
  241. Replacing Engine pulleys belts.
  242. 07 max halogen to hid conversion help!!
  243. 07-08 lip teaser
  244. We liked the Nissan product so much that...
  245. Painting headlights for a 6.5
  246. Looking for Single Din Dash Kit in Aluminum Finish
  247. Introducing myself to the 6th Gen Boards...
  248. 04 Bose issue
  249. Tensioners replaced, still whining
  250. Daylight Running Lights
