PDA
View Full Version : 6th Generation Maxima (2004-2008)
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Service engine soon light
  2. ground cables ?
  3. Screeching Serpentine Belt
  4. Weird power seat issue and battery dies within days.
  5. 04 nissan maxima starter problem
  6. Quick Headlights Fix?
  7. Help someone!
  8. Looking for replacement projector module
  9. 07 maxima Drain plug location
  10. Noise from timing belt/pumps
  11. 2004 max crank sensor problem
  12. Clatter sound from 2006 Maxima
  13. Light growl rear wheel bearing replacement.
  14. 04 HLSD Identification / Door Tag
  15. 06 Maxima Struts
  16. 04 maxima I can't find the a.c. compresser wire clutch won't kick in plz help!!
  17. 2004 Max. Clutch & flywheel replacement write up.
  18. 2007 6th gen 6 speed MT & HR swap
  19. Where The Heck Is My Starter?!?!
  20. ac fuse keep blowing
  21. R.I.P Chernmax aka Chris Hernandez
  22. 2004 Clutch replacement ERGH
  23. PCV valve
  24. )4 Maxima Cranks but wont Start
  25. Slight Knock in Engine
  26. Starter rebuild/replacement question
  27. My trans struggles up a hill, but travels in reverse..06se, does anyone have any thin
  28. '08 Maxima Grey Smoke Trouble Shooting
  29. 2006 missing outer door handle
  30. Low idling
  31. 04 maxima not shifting to 2nd gear
  32. Passenger side vents have no air flow.
  33. need valve cover
  34. Maxima06(112k) - Jerks when putting in reverse only after driving 10-15 mins
  35. Help
  36. 06 6spd manual advice
  37. ECU reset
  38. Emanage Blue on a 6th gen?
  39. Ac compressor relay??
  40. CXJPerformance Thermal Intake Manifold Spacers
  41. Idle Air Control Valve
  42. 07 - Parking Sensor wont turn ON
  43. 2007 Maxima overheats with AC on (or when stressed)
  44. I have Maxima parts for sale, Free shipping also
  45. 07 maxima passenger side mirror
  46. radio/key & fob/brake switch/cluster change/remote start
  47. Custom speaker box for trunk.
  48. Please help I'm desperate!
  49. orignial or superseded valve cover gaskets
  50. 07 max probs with transmission
  51. Newb.. RE5F22A interchange question
  52. Upgrade stereo for 08 Maxima with navi
  53. I am looking for a Y Pipe (can you guys help with my search)
  54. Please Help! 2007 maxima overhead console removal
  55. tilt steering
  56. ChapChap 6-Speed Build
  57. 2005 maxima not letting locksmith program key
  58. Just bought an 08 maxima, any specifics to dig into?
  59. 6gen vs 6.5gen color code
  60. 05 Nissan Maxima fuel filter locator
  61. buzzing noise reverse
  62. P0340 with P0011 on my nissan
  63. Hi beam sutter question
  64. Roof Rack?
  65. Newb here 2004 Nissan Maxima help plz
  66. Ses blinking while car is off before starting car?
  67. Still think it's the timing chain ...
  68. Limp/Safe mode but no related codes.....
  69. Headlights faded
  70. Any suggestions? - Maxima 2008 SE
  71. Power cut
  72. Intermittent no crank so start
  73. After market or OEM braking
  74. New member
  75. Windows roll down on their own/ Doors locking and unlocking randomly (2005 Maxima)
  76. 05 Service Manual
  77. Putting the Timing Cover Back on
  78. Help with a missing 6 speed manual transmission stop bolt
  79. steering wheel heater is always on
  80. Weird noise when driving on wet roads / in the rain
  81. Engineer Control Module
  82. engine swap
  83. 06 Maxima Whining Sound
  84. Power Steering Problem
  85. Yet another Key Fob Mystery
  86. PO300 3.5L 05 maxima
  87. Serpentine belt
  88. Conversion problems
  89. Navigation install
  90. power window switch
  91. I would like advise on removing/reinstalling the manifold and valve covers
  92. it hesitates to go over 60mph.. loosing power..
  93. 2004 Nissan Maxima 3.5 no compression no spark
  94. Brake light on. Not alternator.
  95. 6speed maxima speedo not working
  96. 350Z exhaust on a maxi 2006
  97. Rattling noise
  98. 04 Brakes making noise with back pressure on pedal.
  99. Won’t shift out of park and key not coming out
  100. Rims for my maxima.
  101. Wanna lower my car.
  102. Looking for help with a body kit!
  103. EVAP tube warranty extended by nissan
  104. 2008 Maxima bucking and chugging some between 20-40 mph after it warms up?
  105. 07 Maxima 3.5 Engine Oil
  106. Not speeding/jumpy car
  107. Help please?
  108. Help Identifying Transmission
  109. Trunk Lid Bushing Rubber Bumper
  110. Cooling system
  111. What grille is this?!
  112. Headers 06 Max
  113. Haunted radio PLEASE HELP !
  114. 2008 headlight question
  115. Precombustion sound
  116. Car Overreving between 20-40mph
  117. '08 Maxima - Thoughts on rap noise from engine block. Anyone ?
  118. Engine upgrade 05
  119. Please help
  120. Alternator replacement - lessone learned
  121. Genuine alternator brand question
  122. Using 07-08 Maxima in 04-06
  123. Crank but NO start?!?!
  124. p0301 code. Cylinder 1 misfire
  125. 2007 Maxima CVT
  126. 2004 Maxima se ecu and ignition swap but car won't run
  127. 2004 Maxima ECU/ignition swap
  128. temp gauge not working // not sure if overheating
  129. Intermittent headlight
  130. Getting less gas mileage
  131. RPMs up, oil light now on
  132. It’s been a fun ride...
  133. Fuel filter location 04 Max 3.5 SE
  134. Replacing wheel speed sensor ?
  135. Toe Camber Adjustment Arm Part Confusion? Rear Suspension Parts 2005
  136. Toe Camber Adjustment Arm Part Confusion? Rear Suspension Parts 2005
  137. Eyelids for 07 Maxima
  138. 07 maxima fog lights
  139. Been thinking - Surprising the competition with a CVT?
  140. Intelligent key/ Key fob
  141. Driver side window problem
  142. 142K and need to replace Engine Mounts...
  143. Back in a Max :)
  144. Worried/Need help on my 04 Maxima
  145. 2005 Maxima does not start!
  146. Key fob
  147. Not blowing air nor heat.
  148. Noise from under dash (HVAC/heater), please help identify (video)
  149. Car seems faster after new alternator?
  150. Unexplained Power Loss to OEM Audio Control Head
  151. Worried about 06 Maxima
  152. Horn and radio controls
  153. HID's
  154. big 3 upgrade
  155. Intermittent front window switch & passenger power door lock
  156. 6th gen headlight
  157. 2004 maxima hesitation update
  158. New member with a misfire
  159. Do I need a new alternator?
  160. Car cranks, wont start, security light solid red, can't connect via odbII
  161. Black Friday/Cyber Monday 2017 - Deals Start Now!
  162. heater core hose ?
  163. starter location
  164. I have a 05 Nissan Maxima all light were on the dashboard
  165. Steering hard to turn when cold
  166. steering wheel lights
  167. 06 Maxima transmission troubles
  168. Need "Service Engine Soon" diagnosis (three codes)...related?
  169. hesitation
  170. Transmission troubles
  171. day time running lights
  172. Any recommendations for aftermarket plastic nuts that adjust the headlight projectors
  173. Who is the OEM for Nissan alternators?
  174. Maxima OEM Projectors
  175. Changing Heated Oxygen Sensor ( Bank 2 Sensor 2) Error P0057, P0158
  176. VIN options list
  177. New tires (tire pressure light still on)
  178. Buying an 05 maxima sl?
  179. 2008 one time bad coolant leak
  180. Rear pre-cat (bank 1) alternative sources
  181. 6gen headlight adjustment plastic nuts
  182. 08 Maxima
  183. 2006 Maxima Rear Subwoofer Rattling
  184. Transmission Valve Body Nightmare
  185. Still stuck in failsafe mode 04 max
  186. 04 max. Stuck in failsafe mode
  187. Does a front Sway Bar Exist?
  188. What is involved with replacing the piping from the y-pipe on?
  189. New Rims and tires fitment
  190. Aux port issue
  191. Driver front tire shakes
  192. 6 spd swap, stuck in gear
  193. Engine and tranny swap...
  194. Trip Computer Display with Aftermkt HU
  195. 07 Maxima SL Need help desperately!!!!
  196. New Owner Questions & Concerns 2006
  197. cranking issues
  198. Im in need of some help guys.have an 04 max
  199. Where to Start for "bouncyness"
  200. Steering Wheel and Spoiler Question
  201. Halogen headlight projector retrofit w/ evox r 2.0
  202. 2004 runs fine then overheats next time driving
  203. P1778
  204. Auto transmission slipped gears once while stopped for traffic light
  205. 2006 maxima all 3 brake lights stay on when car is off
  206. Is p0420 code always due to bad precat?
  207. Oil pressure warning light
  208. Heated seats wiring info
  209. 2007 Nissan maxima. SUSPENSION QUESTION
  210. Hey guys, I'm new! Please help?
  211. Getting code p0021
  212. 06 Nissan Maxima I really need some help!!!
  213. 2007 Maxima Clock Spring, Anyone know the Part?
  214. Charging issue
  215. Finding the Right Exhaust
  216. 2005 SE CamShaft Sensor
  217. Front Grill
  218. Horn is not working
  219. Help needed
  220. KYB Strut Plus
  221. wheel and tires fitment
  222. No Start issue
  223. Spark plug and coil packs.
  224. 06' Electrical issues - no power to ac, console, seats, etc. stuck in Park
  225. 2006 Nissan Maxima
  226. Strut/shock question
  227. Speedometer Problem Please Help
  228. 2007 Maxima, Faulty Alternator?
  229. 2005 Max. Help with "Tune-Up"
  230. Running ruff in the summer with A/C
  231. Should I buy a Gen 6?
  232. 6th Gen Maxima - Broken Timing Belt - Possible engine damage
  233. 2005 Max cranks but won't start
  234. i need help
  235. 2004 Nissan Maxima Climate Control Issue?
  236. Crankshaft Position Sensor Issue
  237. I have an 07 that keeps stalling while driving and idling.
  238. Brightest d2s
  239. Any ideas? New exhaust, not happy with sound
  240. Duraflex gtr front bumper
  241. Help me with MAF
  242. Power seat
  243. A/C compressor pulley bearing seized
  244. IACV bypass
  245. Alternator connector wire colors
  246. Wires to my alternator connector
  247. 2004 Maxima Pass Window switch
  248. 2005 engine rattle (Intake Manifold or tensioner)
  249. Rear toe in on the driver side
  250. need syncros, cant find them anywhere
