- SERIOUS KNOCKING (SOUND)
- LED Halo MOD
- The 100,000 mile Club thread
- Coilover problem
- Cleaning filter from my CAI ( FUJITA)
- 05 SL Aux?
- Switchback LEDs.... resistor???
- Gas Mileage Question
- If your 6th gen has automatic transmission issues, please read and participate.
- Front Bumper Removal
- Chrome Body Strip discoloring
- Rims FINALLY
- Shift Lock Problem_Car will not shift out of Park
- Fit Pontiac G8 GT rims on my 04 nissan maxima?
- What do you think of these rims? Will they fit?
- nitto or goodyear
- Reppin" for Thealliance43!! Pics inside!!
- My power steering isn't there
- Magnaflow Mufflers vs. Cheap catback system. opinions?
- Blackout Roof
- wheel studs
- headlight assembly
- brake calipers and rotors
- Woo Hoo
- Woohoo! Transmission probs will soon be fixed!
- DIY guide for changing spark plugs?
- Belts are getting loud, easy fix?
- So, I've had my 04 SL for about a year and a half and...
- Can I upgrade To The CVT Transmission??
- whats in your trunk
- Need new brake pads!
- 09-10 Maxima Side Mirror on 6th-6.5 Gen Maxima..?
- It Might Not Be Your Tranny!!!
- Yup. Traded in the '04...
- Quick Pics of my ride.
- Driver Mirror on 05 - Non-heated work on heated
- aftermarket HIDs
- Crank position Sensor - different offset for AT block?
- Need a replacement Pass. side Fender.. Black
- tie rod end
- Best transmission fluid...
- '04 or '05 HLSD six speed?
- Brake Pads
- Having some problems with my car!
- Check engine light on
- Nav Update
- 04 maxima Head Liner
- New headlight Paint Scheme
- 08 Hood
- Will OEM Nissan HID ballasts light aftermarket 9006 HID bulbs?
- swapping new engine. questions!
- HELP! 07 trying to use OEM 06 Mufflers
- Deus solos with an orchestra
- hollowed out cat
- Dropped on Teins
- Need to change tires... which is the best??
- Got some G wheels
- Hissing Brakes.. 07 Max
- Sensor for expired registration
- Wheel Bearing
- Well there goes my boot...
- Eibach lowering springs
- Factory Warranty???
- 19" Rays from a 370z..need help!
- Has anyone used progress auto's front alignment kit?
- Spare Tire
- Having drama with my Max!lol
- i need a part number for an A/C line
- Does tranny cooler kit really help?
- Whoa, 04 SE Manual Tranny is GONE!
- Sunroof Wind Deflector
- eBay Intelli key
- Just fu*king Great A/C Fan Stuck on HI!
- Interior Lights/Memory seat not working?
- Steering Wheel Feels Like Its Sticking!
- Underbody Panel
- Got 19" Enkei rotas for my max
- r2c intake is wayyy better than the jita
- Led Modd Special Promotion (3.16.10 - 4.16.10)
- Break Noise
- 2006 Maxima CarPC
- 08 max se
- HID Issue - Both will not turn on
- Installed New C-Mod Grille
- Replacement CAT
- LCD tire pressure check, wheel order
- max2damax 6.5 gen lip
- Modified my C-Mod grille....again
- 2008 rear bumper on 07
- Ordered some new suspension parts for the maxima!
- Radiator fan replacement
- Llumar ATR 20 Tint
- Engine issues
- LOOK! NEW WHEELS AND TIRES!
- ANOTHER FIRST / HYBRID INTAKE
- Got a new Grille. Let me know what you all think
- HID Auto feature
- p0171 / Turbine Revolution Sensor / TCM
- Any 04 6mt hlsd owners in here?
- Suspension questions
- Need help with rims (g37s)
- Loose Hand Brake Rattling
- Motor Mounts and Walbro 255lph
- 04 HSLD firewall vin plate picture request.
- Tire Size
- Transmission problems never end!
- How do you take off the side-pillar piece that surrounds the top seatbelt piece?
- Door Side Molding removal
- Bi-Xenon AIMING ISSUE
- A lil' help in installing my Hella Supertone please
- Headlight mod need Directions
- Air Intake Foam Strip
- Navi and Bluetooth
- LED's what you think?
- Fujita CAI Filter Size?
- Wheel Spacers what size?
- Replacement Nismo Intake Filter
- o2 extension harness
- Led Strip Mod
- Need some Maintence V-belt and Auto fluid
- switchblade key question
- New Car some Problems
- 10000K HID's just installed
- led side markers and hids
- Anyone successfully install o2 sim on the 6th Gen?
- Amp question
- Thermostat Assistance
- seatbelts locked due to accident, can they be released?
- 2007 Auto transmission
- Reverse Cam!
- Finally replacing my balding RSA'a (42k miles)...I just ordered some Eagle GT's!
- 08 Max gauge
- Throttle Body
- Radio Antenna
- 07 Max backup cam?
- Hello new owner and some questions
- How much boost??
- Just put 370z 19inch wheels on my Max
- 5 spd auto tranny is stuck
- manual flood
- How hard is to install cams in 6th gen?
- 07-08 6.5 Front Lip.
- How to replace 2006 Maxima driver side mirror
- Vortech Super charger on 6th gen max?
- ebay headlights?
- My Canadian Bruthas
- Trans number three going in today
- how the cams are installed onto the heads
- ATL Rotors ( better than Rotor Pros )
- Infrared Blind Spot Detection System For Maximas
- How rare is the 6 speed in the Maxima?
- New Prototype LED MODD PT.3
- lowering my car
- Amp question, Bose vs non-Bose
- Pinout diagram for Apexi SAFC-II install.
- I NEED GOOD IDEAS
- 6th gear popout
- Please Need Help Radio Not Working
- Aluminum radiator INSTALLED!!!! With pics!!
- endlinks are they really needed?
- So much for the new ride ... SAD pictures ahead
- Will these rims clear everything?
- failed cat
- Engine light
- will new tires rub?
- 04 Maxima Se Transmission issue (whats goimg on)
- P0420......again
- SATELITE RADIO...??
- car vinyl wrap....
- Monster Cable Grounding Kit....Because I Was Bored
- any ball joint option for 6th gen??
- Lowering Springs on the 6th Gen Comparison
- Why will technosquare not help me???
- drag radials
- Weirdest thing happened with my max today
- motor sides
- what bank is what
- *Part 2* Pioneer unveils NEW products at 2010 CES [Video Coverage]
- Next mods, thoughts?
- 2010 18" Wheels
- 04-06 vs 07-08 Seats
- Unable to avoid a deep pothole = fail. Dented Greddy...
- Locking problem
- Ringing type noise under hood when car is not running.
- 60,000 service?
- wiper Motor help
- Time 4 a new headunit? Need advice
- PUDDLE LIGHT MOD
- 07 swap progress
- cloggged catalytic converter!!!!
- Which version of the GTR front bumper can be found on ebay?
- Hissing during acc/deceleration, under dash
- Hot Shot headers sound clip
- Finally gave in and bought some wheels and tires for the max
- Wagner ThermoQuiet or Akebono ProAct Ceramics?
- Swapping H&R Springs for Eibach
- TPMS questions...
- Alternator draining battery?
- Rear Tail light cover broken - how to replace
- Manual Transmission/Running Gear
- How To Do The 07-08 Swap & What's Needed For Install
- Car Fax
- for those with aftermarket headers..
- Help with diagnostic issue....
- 6th gen Keep my exhaust quiet but increase flow? prob a stupid question I did search
- Adjustable shocks?
- 04 SE Manual Trans Problems
- New shoes, new look
- Racing Seats - How can I make these fit?
- Cluster gauge change? Need small gauges.
- rules vs noob
- GTR wheels
- Thought I would like to share some of my winter shots
- Finally, let me introduce myself
- What's a good windshield wiper?
- interior swap
- Does the 6th Gen Maxima use G35 ECU?
- AUTO DIMMING MIRROR
- Buying 6th Gen... which transmission.....
- Strut Noise
- My odometer not working?
- Got new tranny for my 04 Maxima from Nissan of Manhattan under extended warranty
- LED Mod Trouble
- Thinking about buying a y-pipe...I need more info.
- Need help with my 2005 SE Maxima ( No Sound )
- Control Arms/ Ball Joint
- 2007 SL Hid issue
- Which Ebay Spoiler
- 07 rear bumper cover
- horn not working
- What happen to 6thgenmaxima.org site?
- Performance Adds vs Cost
- new shoes!
- 6thGen Total'd In LI Accident-2TheMax05 Old Car
- Pioneer unveils NEW products at 2010 CES [Video Coverage]
- Transmission Issues....I think
- Tenzo R type black rims on white
- trunk wont open from inside or keyfob
- Trans issues... kinda...
- Royal purple oil filter
- popping noise when cvt trans shifts
- Cattman 6th gen b-pipes and mufflers available again (finally!)
- The Kid Does It Again (Led Modd New Color Scheme)
- Question about rotors...
- Finally got time for a few mods!
- MAXIMA617 Minor Colision and totaled by insurance...
- Ralco Pulley Belt Size
- So thinking about moving to a 04 sl have some questions?????????
