PDA
View Full Version : 6th Generation Maxima (2004-2008)
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. 07 maxima Headers?
  2. Loose wire, any idea?
  3. Broken Dome Light Switch Caused Fuse to Blow?
  4. Got these wheels with my maxima. Are they worth anything?
  5. Issue: Delayed Automatic Shift from Drive-to-reverse (or vice versa) Max SE 2004...
  6. Y-Pipe
  7. 07 Max start up issues
  8. what do u think about this grill
  9. whats everyones age
  10. Styling of the 6th gen
  11. 06' Altima SE-R Satellite Radio ?
  12. 06 codes
  13. Is Wal-mart or Kroger fuel safe for a 2004 maxima?
  14. Headlights shutting off 04 Maxima
  15. C-MOD Grill ??
  16. Custom intake
  17. Rattling noise in 2004 maxima
  18. 6th gen maintenance how much i've spent: get ready to do your math!!!!
  19. Exhaust drone
  20. 6 Speed Clutch Pedal Sticking
  21. Hid or Halogen
  22. ebay exhaust question
  23. Stock tires 06 SL?
  24. Headlights
  25. Trans failˇˇ help mee pleaseˇˇ
  26. p0021 and p1135 codes
  27. No start after swap
  28. Exhaust
  29. installing sun visor
  30. Help me unlock steering wheel
  31. Mounting a new audio head unit...
  32. Timing chain replacement
  33. Weird engine noises 07 max
  34. Failed Emissions?
  35. I am new here
  36. New wheels for the maxi
  37. 02' altima seats in a 04' maxima?
  38. 08 Driver side Front window issues?
  39. Transmission Repair/Rebuild/Replacement
  40. bose stock subwoofers cut in and out..HELP!!
  41. Ebay cat back?
  42. A Few Issues / Need Help
  43. sun visor
  44. 04 maxima bad noise
  45. 370z exhaust on 08 Max????
  46. 2004 maxima heater problem
  47. 08 Engine in 07 maxima
  48. Headers and Cats
  49. Bigger Tires
  50. best exhaust for maxima SL
  51. MPG changes
  52. 2004 Maxima Noise
  53. After Market Grille Options
  54. 04' SL setup pics
  55. headlight beam
  56. Aftermarket Grille Options 2013
  57. Ebay catalytic converter any good?
  58. automatic door lock issue
  59. Dash Board Light on Auto
  60. Can't figure this one out!
  61. Maxima 06 steering wheel controls not working
  62. Intellegent Key Fob replacement
  63. 04' Maxima Cooling probblem?
  64. Fog Lights Off With High Beams
  65. both power steering and heater not working
  66. 2004 Nissan Maxima Timing chain issue
  67. Heating/Cooling Problems
  68. Rohanna 05 Maxima
  69. Engine Swap !!
  70. help with 02 sensor code p2a00
  71. engine knock/rattle
  72. NEW Transmission, still not fixed
  73. Replacing motor mounts on 04 maxima
  74. gears locking
  75. Car wont start.
  76. going crazy with this maxima!!
  77. Fog light aiming
  78. Replaced battery and still won't start
  79. Remote Entry
  80. 6 speed transmission problems and questions
  81. Will 2013 Altima 18" wheels fit on '08 Maxima SE?
  82. Burn Off
  83. short ram or cold air intake!!??? which would you prefer?
  84. My 06 is leaning on 1 side
  85. one perfect fit
  86. Tell Me What You Guys Think. !!!
  87. '04 Maxima camshaft sensor/bad ignition coil?
  88. 04 maxima thermostst problem!!
  89. 07 Front end on a 04
  90. Squeaking Noise at 2000 rpm
  91. 06 Maxima Tranny
  92. Idler pulley threaded adjuster broke - options for replacement?
  93. Spark plug R&R 6th gen Maxima
  94. 07 fog lights sizes
  95. When my Maxima grows up...
  96. what do u guys think? 05 70k miles for $500
  97. 2005 maxima
  98. ABS Actuator
  99. Friend's Rear brake parking lights don't work after radio install
  100. Maxima/Altima confusing annoying
  101. Transmission Issues help!
  102. Modest upgrades?
  103. free at last.....
  104. a Jenny in my car (sunroof problem)
  105. fix dangling side mirror?
  106. where to get the fog light bulb holding pin
  107. 6th gen overhead console
  108. 2005 maxima slip light
  109. Front and rear tires are not the same size
  110. Display screen has an Icon with a car and 'B' embeded within it
  111. Bose stereo..no sound
  112. The G35 and the Maxima
  113. CDs will not eject
  114. Allow myself to introduce...my self
  115. Transmission Fluid exchange
  116. I am looking for information on the RE5F22A Transmission
  117. Tire sizes
  118. Best aftermarket air system
  119. rough idle, no power, NO DTC, HELP!
  120. tranny failed
  121. Acceleration while towing 3,000lbs...vid
  122. rear deck rattle in 04 maxima
  123. No brake lights or diming interior
  124. Key programming
  125. Power Windows, Seats stopped working
  126. 6.5 center console swap
  127. Bought friend's 05 maxima 3.5L SE
  128. GRRRR Got in a wreck, Wondering if they will total it or not.
  129. Friend bought a 2005 Maxima. What is the sickest black grill that is afordible?
  130. Fog light question
  131. Thumping noise on front end
  132. Problem with power locks & windows
  133. 2004 maxima 3.5 oil capacity
  134. 07 3.5 SL CVT Problems?
  135. Radio help
  136. 2006 Nissan maxima
  137. A/C Delete on 06 Maxima
  138. amplifier installation
  139. Selling: front suspension items
  140. Air vent fix 2004 SE
  141. My First Nissan - 2008 Maxima SE
  142. What Octane Gas Do You Put In Your Maxima?
  143. The horrible P0744...
  144. Upgrading AUX/SAT to play iPhone 5
  145. Recommend 3rd party headlight assembly
  146. Grille Oxidation Issue
  147. HELP: Cant get the Intelligent Key to work
  148. 5-sp Auto worth modding
  149. ABS Sensor issue
  150. strong vibration starting from 50mph
  151. Pinch nut on tensioner pulley
  152. Level 10 myths busted!!
  153. The dreaded "Service Engine Soon" Light
  154. Interested Buyer
  155. is HID to Halogen conversion possible 07 SE
  156. Should I fix it or get rid of it?
  157. evaporator cleaning?
  158. Clicking Sounds.
  159. Sunroof
  160. Spongy brake pedal
  161. Buying a 2004 Maxima.. Suggestions?
  162. 6 gen tranny issues ? sos
  163. Time
  164. Abs actuator issue
  165. 04 maxima air intake
  166. Trouble Shifting 04 Maxima Please Help!!!
  167. Need advice on 6spd slave cylinder replacement
  168. Tuning program
  169. can someone measure for me real quick?
  170. Steering rack is bad
  171. Y pipe
  172. flushing coolant
  173. Performance parts and fluids ???
  174. help servicing transmission
  175. 2 cylinder misfire
  176. Tighten sequence and torque specs
  177. Clutch Problems...
  178. New to the forum
  179. Electronics Turn Off, Then On
  180. Stuck on 4th gear, camshaft position sensor
  181. Sway in the rear end?
  182. Rear Defuser
  183. Just sayin' Hello
  184. 05 maxima trans. flush
  185. Eibach and Camber Kits
  186. What Octane Gas Should I Run In My 04 Maxima 3.5
  187. Maxima 2004 getting 8 MPG !!!
  188. Resetting Radio
  189. Gen 6: rear door won't open/unlock
  190. Got my calipers painted today tell me what you guys think?
  191. Engine Restorer
  192. Driver Seat Frame Broken
  193. Problem after replacing window regulator/motor
  194. Strange problem VQ35 !!
  195. Headlights dont turn off on auto
  196. Timing Chain or Oil Pump?
  197. Level Ten Complaints
  198. Rim Opinions 08 Maxima SL
  199. new member. 2006 nissan maxima
  200. Lost your lights after led bulb install?
  201. new 05 se owner with TONS of issues, help needed
  202. Flex pipes blown
  203. no spark after water pump install. Help!!!
  204. wats good maxima forums
  205. New member 04 Max P0500 probs
  206. 2008 maxima se need some kind of performance parts!!
  207. Sky-view roof
  208. New media player that has steering wheel remote wire
  209. xenon + halogen headlights
  210. Nismo Intake and Tein S-Tech Springs for sale
  211. 2005 Nissan Maxima with 125K miles for $6000...yay or nay?
  212. 2008 Nissan Maxima, Remote start possible?
  213. P0420 Will not turn offf
  214. 2005 Nissan Maxima SWC Axxess
  215. Push fasteners/clips
  216. 06 Maxima ABS TC dash light
  217. 06 maxima Shift lock fuse keeps blowing
  218. 07 Weird sound during acceleration
  219. No power after timing chain replacement. Ignition?
  220. Just saying Hi
  221. Weak Mileage? 2007 Maxima SL
  222. Engine over-revs when cruise control on
  223. rose_bud
  224. 04 Maxima Trans: rebuilt, remanufactured or just ditch it?
  225. G37 calipers
  226. Akebono G37 calipers
  227. 06 maxima stock stereo question
  228. Car wont crank
  229. 2004 Maxima, how to jump AC Compressor
  230. Sunroof won't open
  231. Major ABS problem
  232. Taking trip in 04 Max SE
  233. Any Thoughts on this Maxima, pics inside ...
  234. 03-05 350z headlamp conversion for 04 maxima?
  235. 19 Years Old, New 04 Max SE, Looking to add on, please help!!!
  236. 6th gen question, why all the problems?
  237. Transmission Well Hex Bolt
  238. Your Maxima
  239. 07-08 Hood Panel
  240. 04 Maxima SE alarm keeps going off
  241. My 2006 Maxima
  242. 07 Maxima cvt problem
  243. P1706 Park/neutral switch maxima 2004
  244. Gearbox
  245. Stock 6-spoke wheels
  246. 2004 Nissan maxima se making a weird noise at startup
  247. 06 maxima need exhaust system?
  248. Need advice on lug nut color
  249. New maxi owner need some serious help.
  250. 2006 Maxima Service Manual
