- 2004 Maxima transmission issue
- car won't start with new battery
- Side mirrors
- Seat Upgrade infinity or newer Max??
- Alternator Part Number Confusion 🤷
- Help Oil light comes on at low rpm/idle once warm
- Transmission not shifting at all after filter and fluid Change.
- Advice please
- 2004 valve body / frame in the way
- 2007 maxima please help . New ignition problems
- VIAS Emissions tank hose connector broke
- Ecu disconnected? Why
- Hello ECU......please help
- Positive battery connection problem
- Oil in the coolant
- Transmission Leak!!!
- 2006 maxima cranking with loud noise and not starting
- Help!! Leaking trans cooler line
- Suggestion for Wheel bearing
- Heat only at idle
- Should I part it out
- Please please please help me
- 05 infinity G35 Alternator, can it fit in my 6th Gen Max?
- p430 and p1283
- Ignition fuse blows everytime i turn the key to acc
- Ignition fuse blow everytime i turn key to acc
- The most reliable 2007 maxima putt putted on me!!!! WTF
- 07 max electrical problems
- 04 to 07 complete front end
- Headlamp Restoration
- Are the springs in 230/350 j31's the same?
- 06 SE 3.5 Auto no acceleration when warm
- 2005 stock rear end hangs low and scraps easily.
- Good CVT Advice
- Loose battery
- 2005 maxima will not start HELP!!!!!!!!!!
- 08 maxima Scraping or grinding coming from maybe transmission
- Driving issues 06 maxima
- Intermittent Misfire After Spark Plug Replacement
- 2004 Nissan Maxima Engine Swap
- ECU LOCATION ? Need the part number
- my Maxima's endless issues, persistent P0303
- Info hard to find
- 06 maxima stuck in limp mode
- AC Problem in the Texas heat
- Chrome Roof Strips
- Bouncing rpms
- My Batmobile 2005 6 Speed Manual 😍
- Speedo issues.
- Solid security light
- 06 maxima won’t stay running unless foot is in the gas
- Replacing positive battery cable?
- Trans up shifting while racing
- cigarette lighters
- No throttle then warp factor 3.
- Resonated test pipes
- I love this car but now it's dead and I don't know what to do I definitely need help
- My Max is still overheating after new radiator, thermostat and water pump. Thoughts?
- Newbie Here! Help Please!
- My 2004 maxima having issues
- Fair price or scam ?
- OBD2 scanner
- 2008 p0021 code
- I NEED HEADERS WHAT COULD I FIT IN MY 04 maxima
- 2006 Nissan Maxima/ clueless
- Driving automatic with the manual shift
- Need advice on 2007 Maxima SL Transmission problem?
- 2007 SL 120k miles ABS system Failure
- CVT Transmission Leak Help
- Yea rotten egg s!! I have 251,000 on mine
- 06 Maxima Timing Valve Cover Gaskets
- Transmission Fitment by Year 04-08 maxima
- 2006 Maxima
- Lowering Springs
- 2007 No start, tries to crank
- Power window fuse
- 07 Maxima Se, Abs issues
- Vacuum routing/MAF P0113 hard shifts/no transmission fluid hoses to radiator
- Engine trouble
- Help required to find out radiator transmission tube size
- 2007 3.5 hot start issue
- Brake light on
- 07 Maxima Crank/No start
- 2007 wheel fitment issue
- Variable Intake timing issues 04 Maxima
- Halogen to HID?
- 04 MAXIMA STUCK IN 5th gear and wont get out
- 2005 Max TRANNY FLUID/COOLANT MIXED UP
- how expensive is a DIY auto manual swap?
- 2004 SL maxima fail safe mode
- 2007 maxima SL start issue
- 04-06 Elite package rear seats
- help asap car will not attepmt to start now
- Gasoline question
- Won’t rev past 1800
- A/f sensor too short
- Wiring issue?
- OEM wheel paint code?
- changed stereo...help with display
- Part out 2006 Maxima SL?
- Will 2003 350Z stock rims fit my 2007 maxima
- While driving loosing power, won't accelerate and then dies.
- Need ABS help
- 2004 Maxima SE BCM part number
- Sputters and dies
- Ball joint change or whole arm?
- 2007 AC vents dont seem to be blowing as hard in middle as outside
- Security indicator lamp solid red
- Engine Noise
- Please Please HELP ME,...
- Car wobble...can't figure this out and it's about to go in a river.
- Auto Tilt side mirror and climate control issue
- Transmission type ????
- Replace gage cluster lamps
- Help me find aftermarket 2007 headers
- Some guidance would be appreciated
- Need help with flashing check engine light
- 2004 Nissan Maxima No tail Lights!!
- How you turn on fog lights?
- Help needed. Car went into limp mode after driving through dirt & sand
- 2007 Nissan Maxima
- How to make the VQ35DE live up to its potential.
- 6th Generation Side Mirrors
- 04-08 Maxima Side Mirrors
- Mysterious heater
- Overheating / Cooling fan questions
- 2007 Maxima Speedometer Not Working
- NO CRANK NO START 2008 Maxima 3.5 CVT
- 2004 Max - stereo problems
- Instrument Cluster Went Out
- Help!!!!
- Need transmission seals/orings. RE5F22A.
- New battery being drained.
- '05 - Multiple Codes
- Shaking when letting off gas
- Maxima Transmission Issues
- K20swap6gmaxima
- I can't be the only one who has noticed
- engine swap options
- 2007 Nissan Maxima intermittent hesitation in acceleration
- C MOD Grill
- Need Y pipe
- Please help me find this part!
- Rear roof trim clip replacement. HELP w/ part number!
- Water pump install. Possible timing jump
- Noisy valves
- Transmission compatibility for 2007 Maxima
- Maxima Radio Not Working
- Where to sell catback exhaust??
- Transmission problems
- Somebody please help I’m lost asf
- X Pipe
- Overheating when Hot outside
- 2008 Maxima gets stuck on 3rd/4th gear / limp mode no codes!
- 6th gen Maxima vq35de fwd automatic
- 07 Maxima phantom battery drain
- CV axle
- Looking for Catback Exhaust recommendations
- Driver side rear view mirror foggy -what happened
- Sputters and backfires
- Same 04 max
- Random unattached hose & Air box connection
- Drain plug?
- PCR? Any thoughts?
- What a mess
- NATS has NOTHING to do with cranking.
- plastic body part between trunk and tail light
- AC not holding a charge.
- P0726 error code
- Need help. New here
- Retune 2004 VQ35DE
- Can I remove the passenger vent, without removing the dashboard?
- Upgrading exhaust question(s)
- Key doesn't unlock door, with a disconnected battery.
- Ambient temperature sensor
- No start
- Hearer core flush
- Big brake
- Minimum rear ride height
- Need to confirm what solenoid is what
- AC replacement
- Aux Input
- 06 SL (lemon/valve body) situation
- 04 Maxima 3.5L SE randomly refused to accelerate, grinding
- Engine starts but runs rough and idles high to low
- Anyone interested in a real carbon fiber steering wheel?
- Cranks but no starts p1610
- New here please help
- 6th gen maxima tune. 3.5se
- 2005 engine swap with 2007 engine
- Bomb in my brake pedal
- poor cooling
- Changed spark plugs, boots now multiple codes and misfire - any ideas?
- '08 Spiral Cable Part #
- Bumper Bar Chrome parts J31
- Transmission cooler
- Transmission Filter
- ABS sensor TSB problem
- fuel filter
- All lights on and gauge cluster not working, help
- Need help with camshaft wiring
- 05 Maxima stereo w/w Nav. Swap to 06 Maxima
- U1000 u1001
- 2006 Maxima License Plate Camera
- Am I forgetting to replace anything else?
- Weird Noise Coming Out Of Suspension
- Looking for part numbers for Catalytic converter system and exhaust system
- No acceleration after changing plugs
- 08 Maxima won't accelerate
- Oil galley gaskets.
- Lights behind climate control and radio ?
- 2007 maxima cvt relearn procedure
- How did this occur and solution??
- Cam cap bearing question.
- 2004 nissan maxima sl wont start
- 05 Maxima, no power to ECM
- Will not start after driving for about 15minutes or so
- Code P1800
- 02 sensors
- 6 speed swap
- Not sure how to proceed - advice needed?
- 2007 maxima temperature gauge doesnt ever move
- 04 maxima se no throttle response
- Impossible to hold RPM when in neutral to 3000. Have P0420.
- Reset 06 Nissan Maxima Radio
- Radiators
- 2007 maxima ecm
- Relearn procedure for Throttle Body
- Sport Mode?
- How do I take this banjo bolt off?
- 06 maxima sl automatic
- 2005 Nissan maxima SE Transmission repair for $2200
- Does this ground wire look ok? And, what's this little thing?
- OEM gas cap part number lookup
- Exhaust Upgrade
- Need help with codes p0726, p0128, p1800, p0420
- Burning oil
- VAIS Low circuit
- Failed emissions
- interior lacking need upgrades help
- 6th gen gear ratio
- Remove / lower the rear subframe - 05 SL
- Loss of power - Engine bogs & stalls under load
- Oil leak, Possible oil filter housing ring. PICS INCLUDED
- Need help determining proper motor mounts
- Tire and wheel questions can I view mount a 245 40 R20 wheel on a stock height 2006 N
- 08 shaking on acceleration
- Car won’t move
- Slip tcs and abs light on
- 04 maxima engine trouble
