PDA
View Full Version : 6th Generation Maxima (2004-2008)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Seats seem high - options?
  2. Car died and will not go again!?
  3. million dollar question for 6 gen owners
  4. IB setup in our cars
  5. New headlights?
  6. Tapping 12V central current
  7. Fstb request
  8. Gauges and AC not working on my 2006 Maxima. Car won't start!!
  9. 2004 Maxima - 135,000 km - worth putting money on it?
  10. Camshaft sensor/s go bad W/O light coming on
  11. Does the timing chain wear issue only happen on badly maintained card?
  12. A/C leak inside the car
  13. AC barely keeps up with hot summer
  14. 2007 Nissan Maxima Engine Swap
  15. temp rises when a/c is on full blast
  16. Transmission dead :(
  17. Car Sold
  18. 2006 Maxima alternator noise on start up
  19. 2004 Brakes
  20. lowered help
  21. High pressure hose for power steering...
  22. Speedometer issue
  23. Adjust your timing from your phone
  24. Door Step Lights 2005 Maxima
  25. Slam Shift ---> level 10!!!
  26. Car wont crank. Help needed ASAP!
  27. Possibly Buying an 06 Maxima
  28. screen flip
  29. Steering Wheel Controls not working properly
  30. Installing big 3 alternator wire.
  31. Eggs
  32. Just bought 04 Maxima. Interior light issues.
  33. Connecting Custom AMP and Subs to factory Headunit..
  34. Should i Plastidip my rims?
  35. 6 Speed Question
  36. Extended warranty for subframe corrosion?
  37. modified nissan interior
  38. Jump started car, fuel gauge messed up. Help
  39. 2008 Mods?
  40. Rim Suggestions for New Owner?
  41. hissing sound from engine
  42. Intelligent Key Not working
  43. Trunk Lift supports - Buy a set of StrongArm 4087
  44. What would you pay for this?..
  45. Installing AMP and SUB??
  46. Noob (female) needing power outlet/ a/c help!!!
  47. Official newbie intro.
  48. No longer a Maxima owner...but...
  49. another gutting cats
  50. steerng wheel buttons on left side stopped working!
  51. MPG Reading
  52. Ambient Air Temperature Sensor
  53. Disconnected battery leadsto check engine light ?
  54. BCM needs to be programmed?
  55. Looking to purchase 2007 Maxima SE
  56. 2004 Air Conditioner
  57. Saggy look after installing Progress springs.
  58. Maxima/Altima Mixup
  59. Crap? Or Legit? Hahah
  60. 08 maxima leaning to the driver side
  61. G-Force Chip
  62. Maxima is hard to start sometimes, takes 3 tries
  63. 2004 maxima se skyview roof leaking
  64. 04 Max dash buttons wont work
  65. Best Satellite radio aux/usb adapter?
  66. 06 Maxima SE 6 speeds
  67. Lowered on new rims
  68. CD player issue.
  69. Power Door Lock and Power Windows intermittent problem
  70. Sexy beast done :) slammed
  71. Honk on Lock - Hold Lock and Unlock Won't Work
  72. Interior lights out on navi panel.
  73. Bigger tires on OEM SE Wheels
  74. New here I have just one question
  75. 2006 Engine rattle-need help (with video)
  76. 04 maxima alternator issues
  77. Exhaust Sulfur smell
  78. AC Help
  79. Worn seat gear?
  80. issues with my 05 Maxi
  81. 04 maxima alternator issues
  82. 04 maxima alternator issues
  83. Best LED's for headlights
  84. cam swaps
  85. Any advice on brakes?
  86. New guy
  87. Urgent please help 2004 nissan maxima se 3.5
  88. AC fan stuck on and no cold air
  89. Best Cold air Intake for an 06 Maxima
  90. High Speed Braking
  91. Air intake question
  92. ANy BUFFALO NissAN lovers???
  93. 08 Steering Wheel Controls not working
  94. Changing the chrome trim color??
  95. Program key
  96. Fan motor blowing hardly any coming out vents.
  97. KYB AGX Custom Rear Mod
  98. Decent summer tire with good tread life?
  99. Clutch Pedal issue
  100. steering feels a little bit harder lately
  101. 2006 Maxima overheating
  102. Transmission flush
  103. BOSE System issue
  104. taking a pole on what shocks and stuts to go with
  105. 2007 maxima temperature conversion?
  106. Maintenance Q
  107. SRS light blinking
  108. Opinions wanted on K & N air filter for 04 Maxima
  109. real slow acceleration
  110. Stillen
  111. Starting issue
  112. Cooling fans not working and hot A/C
  113. 2006 Nissan Maxima p0345 code?
  114. Motor Install Help
  115. Which Spark Plugs
  116. Rotors and brakes
  117. 2007 Maxima Driver Side Mirror
  118. puff of white smoke on startup -- ocassionally after warmup - when reving up
  119. alternator needs replacing? instructions?
  120. Engine Cut off all the sudden
  121. No bright lights!
  122. Valve Body Replaced
  123. PA15-NIS iPod to Nissan Interface
  124. aftermarket gauges, where do you put them?
  125. 04 tranny problem
  126. New OEM Valve Body Issues!!!
  127. Backup Sensor Buzzer Location
  128. Aftermarket in-cabin microfilter
  129. Flywheel
  130. Auto entry/exit - new battery
  131. Flickering Speedo
  132. Am I the first person to do this?
  133. Is it worth to buy '04 maxima?
  134. Gaskets
  135. Keep an eye on your aftermarket sway bar end links
  136. Led install..need help
  137. remove egr valve?
  138. Tire Question
  139. Help power Window seats and locks stop working
  140. 2004 transmission jerking 1st gear. Help please!
  141. 6th gen maxima need to take a look at this!!!!!!
  142. Average speed
  143. 2007 Hood
  144. Assess the value of my car (blown motor,5th/6th gear dont engage)
  145. LED's on Maxima
  146. weeeeell I got rear ended -_-
  147. 2004 maxima need help.
  148. Issues with battery or car not starting? Check this
  149. mystery part in 2007 maxima
  150. fuse box replaced
  151. Radio static while phone charger plugged in
  152. Pressure tank
  153. Transmission question..
  154. info on where i can find a front lip
  155. 2005 Nissan Maxima SE Finally Sold
  156. Just got em!!!
  157. information on mud flaps
  158. Need help with this strange problem
  159. My key is stuck in the ignition???
  160. Help
  161. Used valve body ideas
  162. 20 inch rims
  163. I'm love my maxima so much. She passed emissions with Ebay performance headers
  164. CamShaft/Cranksensor Question.
  165. ecu location
  166. TPMS issue in 2008 Maxima
  167. Firestone Oil Change
  168. How to install Kinetix IM & EGR
  169. Trip Info. strange reading
  170. Replacement Dash Trim for Center part only
  171. Best and easiest to install HID Xenon Headlights for 04 maxima
  172. 2008 Maxima Armrest
  173. Valve Body change finally!!
  174. Headlight Adjustment!!
  175. 2004 Maxima SL Headlight Issue *Pic Inside*
  176. 06 motor mounts, please help.
  177. need help on finding the right spacer
  178. Broken dome lights
  179. Clicking noise
  180. exhaust search
  181. Strut bars
  182. Y pipe
  183. the beast's new look
  184. New headers
  185. Cattman headers
  186. Cattman
  187. feedback
  188. need help removing 06 alternator long bolt.
  189. 2007 maxima alternator and battery help!!!
  190. New 6th gen owner.
  191. HID fog light replacement - fitting issues
  192. 6 Gen Climate Control FSM Manual section?
  193. Horrible vibration/humm. Puzzled!!!!!!
  194. need help on service engine light
  195. Help finding A/C leak
  196. Obx
  197. Engine screeching!!!
  198. A34 vs J31 differences
  199. Need help
  200. Obx
  201. Remove Film on Chrome?
  202. Rear Driver side door
  203. Help finding trunk part?
  204. TPS needs replacing
  205. Twice labor for timing chain!?!
  206. Rear rotor is very loose and tire sits at slight angle
  207. question
  208. pic question
  209. 04 MAXIMA brake griding??
  210. head light issue
  211. Accuair E-level installed
  212. 05blkmax
  213. Long life highway tire???
  214. hid question
  215. Need Help
  216. General stuff
  217. Driver Side Power Window Issues
  218. #piece of **** nissan
  219. Headlight bulbs
  220. 2007 Nissan Maxima wont start on first try
  221. Hid
  222. Popping sound from rear end
  223. 05 maxima Valve body ?s
  224. 05 Maxima-valve body replacement help!
  225. coolant leak cant tell were its coming from
  226. Paint touch-up help
  227. Leaking coolant please help!!
  228. General stuff
  229. 2005 Maxima wont accelerate.. Please i need help
  230. Catalyst
  231. Billet Grilles
  232. hid
  233. Driver Power Window Fix
  234. Battery Light On
  235. This is definitely worth watching
  236. can my fuel pump be going bad?
  237. Post pics of your HID Foglights output
  238. Maybe buying an 05...cpl questions.
  239. Wire
  240. 2005 Nissan Maxima question
  241. $$$maxima 2004?
  242. 2013 annual eastcoast maxima event
  243. P1168, P0051 codes...
  244. Help with timing issue!!!
  245. Now taking orders for 04-08 Cattman Headers and Y-pipes
  246. Can my car give me 24.3mpg without a tune and mods?
  247. was told trans issue. Won't start when hot?
  248. 2004 Maxima Problems
  249. 6th Gen AC Expansion Valve Replacement
  250. How To Disable Auto Steering Wheel/Tilt??
