- better late than never (introduction)
- How to install Led Strips
- Do you think these wheels would fit my 04 nissan maxima
- Vibration Issue
- steering question (2004 se)
- OEM HIDS light intensity seems poor to me.
- transmission fluid drain and fill
- OEM XENON BALLAST
- 6th gen roof spoiler options
- Mods List
- Any interest in a group buy for roof strips?
- HID question
- Twins or singles
- 6th gen Max front end squeak
- 08 maxima key blade
- 2004-2008 Great Car or not
- CXJPERFORMANCE.COM
- Is it possible for a VQ35DE to consume a full 4.4liters of oil in less than a month?
- New wheels for my 07 M35
- My repairs at 110,000 miles 2004 se
- I POD help
- P1402 & P0420
- Tire slowly losing air
- 5th and 6th gear not engaging
- VDC on 2004's?
- 04 max with p0550 and p1284
- BOUT TO HIT 100K
- 6th vs 5th gen advice planing on buying advice!
- LOW TRANS FLUID HELP!!!
- HAS ANY 6THGEN MEMBERS INSTALLED OR CUSTOMED THE 04 ALTIMA HEADERS IN A 04 MAXIMA?
- 08 STOCK Tail Lights
- 6th gen pics needed
- Wheel Theft
- Open Loop Fault
- A/C Operation and Radiator Fan Speed
- 2006 Nissan Maxima common problems fixed
- Ezconcepts
- Do you have to remove the front bumper to install a Cold air intake?
- P1402 code n EGR Valve
- 2.5 years later :(
- Changing front corner lights
- altima short throw shifter
- Custom Grilles
- 05 SE Won't Start
- MY CHECK ENGINE LIGHT JUST CAME ON AND MY CAR WON'T ACCELERATE
- Safc
- WHERE CAN I FIND HALO RINGS FOR THE 04 MAXIMA'S?
- goodbye, 6gen people :(
- MY RADIO AND MY HEATER SUDDENLY STOP WORKING
- advice... recommendations
- 2004 - Short throw shifter?
- Motor Mount Hell
- Need a foglight con for a 6.5
- Fusible link
- Happy Holidays and Merry Christmas!
- Blower motor help
- Anyone having problems with their steering wheel tilt?
- 08 MAXI RIP
- Tail-light Bulbs.
- 120k Maintenance for 05 SE
- Replacing front turn signal bulbs
- suspension noises
- 2007 maxima Hard to accelerate
- Advice on changing PCV valve?
- 2004 Maxima Serious Shake at 40mph+
- I need help with servicing before the winter
- Drive belts for 07-08 Max
- 05 maxima struts. WHAT BRAND?!?!
- CLUNK- rear suspension
- Where to run a power wire for my 04?
- Help: ABS Sensor bolt details
- main wiring harnesses - differences?
- Problems with a remote start.
- Flywheel resurfacing...
- Need aux input for 2004 Maxima with sat radio and ipod interface installed
- VFiber fiberglass fenders - installed!!
- R33 GTR rims
- FULL exhaust options!
- Driver side mirror broke
- Passanger headlight stuck on highbeam
- How much whp does a stock 04 6spd maxima have?
- Replacing bose amp using PAC AOEM-NIS2. PLEASE HELP!
- Aux jack in the back of the nonnav 6th gen information center?
- What size are the torx on the flywheel
- Moving on?
- "HELP" headlight bulb question
- Help with radiator fan
- Transmission success rate
- Short ram intake, best buy
- 2006 Maxima Automatic NEED HELP!!!!!
- 07-08 Max Shifter Knob
- 07 headlight OEM wavelength/color?
- my6thgen.org
- New to forum, Help with low heat on an 08
- Cutting a fujita CAI. should I do it?
- Tune up
- Problem when replacing my camshaft position sensor, need help!
- A or B? Grille options. Please vote. Pictures inside.
- where to put the second RSB
- Which 6thgen Maxima has the fastest 1/4 time with just bolt on mods?
- CXJ Thermal Spacers Sound video
- VQ35DE clutches
- Does anyone know a place to install a Transgo kit around Chicago
- Altima tranny in maxima?
- Lug nut horror story
- Finally managed to program my Homelink!
- Thoughts On CVT..
- 5 spd trany. help
- Doors dont stay open
- Thread for CXJ customer reviews!
- What's the perfect RPM to launch in a 6thgen with street tires compared to slicks?
- Looking to pick up a 04 SE with 177k need some advice
- It's tire time!
- Help!
- Intake manifold...
- Has anyone ever removed the hot water lines for cooler temps?
- Advice Needed On Coilovers
- racingline FSTB review
- Idle relearn
- Getting dyno tuned/ecu flash
- Gutting pre-cats.
- Has anyone changed their clutch?
- FREE!! Install of CXJ Performance 3pc Thermal Spacers!!!
- CXJ PERFORMANCE 3pc Thermal Phenolic Spacers Results
- Reprograming the 07-08 Max Ecu
- When changing the clutch...
- NWP Engineering "Economy" Thermal Intake Spacer Kit - New material! Lower prices!
- Engine swap thread.
- Should I upgrade to a stage 1,2 or 3 clutch in my 04 Maxima
- Which fluid for the 6 speed M/T
- Service engine light on
- 02-06 3.5vq thermal spacers - 3pc kit Install
- Let's talk cold air intakes!!
- What's the average price to change a clutch on my 6thgen max
- Engine rattle...
- Those who are having ABS issues Look here
- Tranny Problem???
- 2007 Front bumper
- 350z fstb
- 6th Gen v. 6.5 Gen Similarities/Differences
- 2008 Maxima's is your idle irratic. Does the RPM needle move?
- Full catback MagnaFlo Exhuast
- MOOG stab bar links pwn stock and ebay
- suspension noise
- I thought the start was bad but it wasn't the caseReally quick....im in Florida and i
- (04-06) (07-08) comparison,differences,similarities
- Side mirror light signals for 04-08 maxima
- Need Help Locating Starter
- What bolt up mods are there for the 6thgen Maxima's
- FSTB
- Turbo Charger for the max
- 2008 Maxima Tail lights. Read inside need some advice.
- Vehicle Security Immobilizer Dash Light
- you guys seen these tails before?
- WHAT would you do with a thousand bucks?
- Need advice...
- 6th gen Cattman header set
- Aftermarket deck that works with dash? And Xenon lights.
- looking to add a new max
- Motor Mounts with sensors and Stealership price rants
- 07 front bumper on 04
- Hey hillstead...
- help 07 idle problem
- ***04-08 I'm new here, please HELP... ***
- FUEL INJECTION System by Nissan.
- poor radio reception!!
- Transmission fluid change on 2004 Manual. Which to buy and how to do it.
- Philips D2S 6000k 85122WX Ultinon vs. Phillips D2S 85122+ 4300k
- Radiator Leak
- best drilled slotted rotors for the 6th gen?
- 2004 Elite Package - Onyx | Burnt Orange
- Reset procedure
- 6th gen faster than wrx sti
- 6.5 Swap assistance / Airbag help
- SSIM MOD and REVIEW (long)(PICTURES)
- Sold The Maxima... And Got This
- 05 maxima problems?
- Keyfob
- severe tire wear (drivers side rear)
- Wheel Bearing Problem
- 6th generation ride quality
- Noise!?
- 2006 a5 trans vs 2007 cvt trans?
- STD Seats
- 04-08 thermal spacer design leak
- Flashbacks for sale 2008 maxima
- o2 sensor locations
- Passenger heated seat function not working
- can u do the g35 mods on these cars?
- Need Help With Steering Wheel Radio Controls
- How to replace catalytic converters on '05
- Resetting Ecu
- Alarm keeps arming by itself.
- Transgo Shift Kit for 5sp Auto 6th gen Maxima
- EGR VALVE
- iPod/iPhone interface kit for 2004 maxima?
- How to Replace 2004 Maxima Stock Spoiler Lip?
- 7th gen springs on a 6th gen?
- 04-08 hawk pads part #
- still in the box
- Air suspension
- Nissan/Infiniti quality
- DENSO Spark Plug Heat Range 16 vs 20.
- Power folding side mirror
- Why is there oil on my engine block? Detailed Pictures inside.
- Power steering fluid
- Getting black leather interior soon
- 06 Maxima power tilt/telescope steering wheel issues
- 300HP 6th Gen?
- how many air filters in our cars?
- Questions about wheels and tires
- 08 maxima se
- Phillips HID bulb killer deal @ Amazon
- what would cause the tranny to shift right into overdrive?
- Problem with cruise control and speedometer
- C-mod Nissan Maxima 04-06 Sport Grill (New Design)
- Best coilover SETTING??
- Transgo Kit End Caps
- CVT warranty
- Air Bags Duration
- TPS on 2004 Maxima
- Headlight trouble
- Outide top of door trim
- Tips on Replacing Cats
- motor mounts
- New Custom headers ...yay (pic inside)
- Ebay Rotor and Pad Set up? Yay? Nay?
- MAGNAFLOW 14805 MUFFLERS- MAGNAFLOW 12640 RESONATOR=FAILLLLL
- Link for headlight sealent?
- BEST SUSPENSION ?
- 2006 Maxima long life tips.
- Blacked out headlights - complete!!
- shimmy finally fixed!
- Rotten Egg Smell, Engine noise and P0420 code
- warm air underneath...
- 2007 Maxima Hypermiling CVT
- Just passed 80k, what should I be aware of?
- headlight:halogen to xenon??
- Headlight
- 07-08 6.5 Gen Blue Batmobile's Yellow Fogs Overlay
- Spark Plug question
- Possible bad Water Pump?
- Wanting opinions on LED Bermuda Black Tail Lights
- 07s Factory Rust Warranty
- Light Output of Aftermarket, OEM, and OEM With ZKW-R Lens HIDs
- Engine Swap questions
- SES light = $2880.00
- Left rear turn signal light not blinking
- Roof strip question
