- How To Disable Auto Steering Wheel/Tilt??
- Rear Camber Bolt???
- Got rid of the 02 and purchased a 08 SL
- fuel pump relay????
- Shorter Stick Shift
- My 2013 teaser with video
- Engine harness
- That Spoiler!
- Fog lights and night driving
- Cvt gone bad
- Garmin GPS
- occasional clutter noise when turning
- Front End Feels Loose/Tramlining/Pulls left and right
- In Dash install?
- wants to replace electronic locks of my car - requires a locksmith
- 2006 Maxima - ABS Actuator / Control Pump / Motor
- suspension
- longer o2 sensors??
- 2006 se
- 02 sensors.
- shift lock button problem
- Help needed please 06 fan with start up, when car engine is started
- 2008 Maxima - Need help
- Cmod grill fitment issue
- 2006 Clogged Cat big problem, help!!!!
- new here and in need of some help
- Anyone shortened their shifter?
- can a fluid change prevent trans problems with my 5spAT?
- Momentary loss of all electrical power
- Emergency Brake Question
- 04 Maxima no acceleration
- Cooling/heating problem
- Urgent: Changes for nissan maxima between the 2004-2006 model year
- Door Actuator part number
- Can you reset abs codes without the machine?
- Led turn signal fix
- 2004 Maxima - Timing Chain Issues
- Sudden MPG drop on my Max
- Rattling console/control center
- 07-08 oem grille wtb!!
- Heated and folding Mirrors
- Noise Under Hood
- Front left suspension shakes over bumps
- 04 engine removal withou trans can it be done
- 04 wont idle when warm
- 18x8 35 offset with 245/45/18
- Anyone tried g37 intake manifold and or g37 throttle bodies?
- 07 maxima startup noise
- Replacing rotors/pads on 04 Maxima (Any guides around?)
- Factory Fit Stereo recomendations with NAVI
- Rattle at 3000 rpm and won`t run nightmare
- hi newbie here...a.c making noise
- Stereo Stuck in Bluetooth Mode
- Safe mode????
- acceleration problem
- 2007 Timing Chain/Tensioner
- Buying a 2004 thru 2007 maxima
- 6th gen vs altima se-r
- 6speed conversion p0335 code
- Midnight Blue with wheels?
- 2008 maxima nav/radio issue
- First Time User-AC/heat Issue
- Engine Swap on 2004 Maxima
- some questions for you 6th gen-ers
- 2004 Maxima SE ABS issues
- 83,000 Miles finally running right!
- Rattle at 2500 rpm
- Transmission
- Which Haynes manual?
- 2004 Maxima running bad any ideas?? Any help please
- Does an 18" Wheel fit in the trunk
- Newbie need info on purchase
- Should I purchase a 06 max or 02 max?
- has anyone baked their headlights?
- Thinking about a 2005 maxima
- 2004 maxima w/bose wo/nav aux input?
- Ipod Integration Kit
- Noise help
- This Maxima Wreck is kinda funny...
- 07 SE Rear View Mirror Wiring Diagram
- Need some advice on p0300 problem
- 07 Max CVT Fluid Question
- Headlight 04
- Head light 04
- Head light
- Quick light question
- Power window problem
- Remove Console to remove 12V Outlet
- So what are 2004 Maximas going for?
- 04 nissan maxina
- Loosening Idler Pully Nut Tips?
- Intermittent No Acceleration from Stop
- New Tranny for my 2005 Maxima
- thinking of buying a 2008 Maxima
- 2005 maxima sl
- Is it me or is every other car on here look alike???
- I'm new here...
- 2007 Maxima dash light modification
- Dash cam!!
- 370z wheels on a 08 max?
- Valve body or tranny gone?
- Coil Pack Problems '06
- Question about electric motor mount in my '04 Maxima
- knocking sound when ac is on
- I am a Noob with an orange Max
- Fog light lens
- Bye Maxi
- Anti Freeze leak
- Speaker-Amp problem!
- NEED HELP! Car isn't Functioning well with Coilovers!
- Strange sound
- AC/Heat stopped working?
- Help with 22" staggered rims!!
- '04 headlights/foglight problem
- Knock Knock
- Unknown dash indicator light
- Weird belt squeal.
- Weird staining on leather seat
- Cyl 1 Misfire problems - 04 maxima 3.5l
- Help with Bulldog Security 1200b Remote starter.
- Intro - 2004 MAXIMA Ti-L
- Car violently gives of a jerk when stepping on gas pedal?
- How I modified my headlights with video
- My Max 04
- 2004 Maxima Transmission Leak
- Recent pics
- New 07 Maxima SL Owner
- Hey
- Cold air intake
- intake manifold spacers ?
- Head light housing
- lost power and wont drive past 40mph
- Does anybody have transmission problems with their Maxima?
- Blower Motor Resistor a.k.a. Module Assy-Power
- Good quality front rotors?
- VQ35de motor swap
- Racingline y pipe finally
- 2004 Maxima remote programming PROBLEM
- Im out.
- Not a Maxima but same 5AT VB problem
- Security button by drivers side air vent
- Park Light Not Working
- maxima wont start
- Cocaine Maxima w/a Twist!
- Hardwire iPod/iPhone
- Replacing struts and shocks! Recommendations?
- buh bye Maxima
- Frequent Fog Light Bulb Replacement
- Replaced spark plugs, intake leaking now?
- 2007 Bose Radio Won't Shut Off!
- Upstream o2 sensor
- How to remove ebrake boot.
- CVT Transmission Valve Body / CVT Extended Warrany
- Thermostat? Newbie Here BTW!!
- Transmission Control Valve / CSV Extended Warranty
- ABS Sensor removal??
- '04 Maxima Dies Instantly on Cold Start! Help!
- Headlight bulb holder/mount broken. Any replacement?
- Question about core support in 05 Maxima...
- ABS fuse location
- Rear Speaker Replacement Grills?
- thinking about getting a 6th gen
- FM audio
- Cattman headers and y-pipes ready to ship
- need help with wiring: swapping out seats
- timing chain replaced won't start
- Maxima 2008 mounts
- Left rear ABS sensor and ABS actuator. HELP!
- What else do I change beside Struts?
- Farewell Maxima friends!
- Car starts fine when cold but takes longer to start when warm
- 2008 Maxima HID replacement
- CV Axle issue
- 9006 Bulbs Fit 2004 Maxima
- New Owner!
- Aftermarket Stereo- AC/Heat Issues...
- Remote start question
- My picture thread
- Ebay Exhaust System
- Just bought first Maxima
- Just bought an 04 got a few questions
- 04 maxima stuck in limp mode help! !!!
- 6th gen Auto to manual swap
- 204 maxima 6spd conversion
- Steering Rack
- 06 Max throttle hesitation and rev after let off
- what r some of the best "coilover" kits maxima 2007
- Clutch?
- Is this my tranny going bad??
- CamShaft Sensor Maxima '08 6th Gen
- Brake & ABS light on
- no sales
- **nothing for SALE**
- Interesting power door lock question
- Trouble Code (P0420)
- Alarm stopped working after battery died
- Cattman 6th gen headers and y-pipes for sale, ready to ship!
- Dash kits??
- 07 maxima trans
- New memeber here
- 07 door lock question ..
- Trans fluid spurting out the fill tube
- bad cats no sticker
- Knocking/Flexing noise from Driver's Side
- Had my max for a few years, looking to add some performance mods
- 04 grill
- Aftermarket CD player wont fit in Metra Kit
- HELP all tranny gurus please
- 05 Alt 3.5SE-R intake on 08 Max SL?
- 05 Maxima...no heat no AC.
- hit Y pipe with a rock, exhaust sound, replacement?
- Step by step video on replacing front wheel bearing and hub
- Where is my OBD plug in port?
- 2004 Maxima Transmission Issues
- Left hand indicators not working
- Looking at a 2006 Maxima
- exhaust upgrade help!!
- 04 Max with codes, issues.....
- 2004 Nissan maxima 5at stuck in 5th gear
- Keep my 06 or trade it in?
- Should I or shouldn't I....
- P1283 code!!!!!!!!!!!!!!
- 05 maxima SE totaled with 97k miles, should I fix or get something else
- Wheel and tire upgrade
- 2004 maxima gears issue!
- Re5f22a valve body diagram
- 3m di-noc carbon fiber wrap...on the engine cover??
- Invitation to play
- Not sure why car wont start
- climate control harness ripped out when thieves stole my radio. SOMEONE PLEASE HELP!!
- high beam bulbs?
- 08 Maxima SE 3.5 Maintenance Help
- 2006 Max- brake job
- Switching maxima grill
- oil leak
- rough idle in park and drive
- Nissan maxima 2004 shuts off while driving
- maxima
- Maxima is starting all by itself!
- Tranny problems
- clunking sound
- 2004 Maximum not heat when in idle
- how do I test camshaft sensors
- Twentyeggs: Comparison of Corvette vs. Maxima
- 07 maxima questions
- Just applied Sea Foam and now have SES
- New ideas
- vibration issue
- I Have a 2008 nissan maxima. Service help
