- 07 Maxima smart key problem
- 2006 Maxima Gone - Parts for Sale
- Struts and Shocks
- '07 Maxima SE dead fuel gauge
- Upper Oil Pan or Rear Main Leak - 2004 Maxima
- 2004 maxima shifts, but no forward or reverse all of a sudden
- Need Help. 08 Maxima
- May have did damage to my engine due to ice in wheel well
- built in back seat usb charger
- Automatic driver positioner/Retracting steering wheel and Reverse mirrors not workin
- 2007 Maxima 3.5SE Air Conditioning/Noise at Startup
- 2005 VQ35DE Engine Year interchange?
- 2004 heated seat question
- install remote start
- Tranny Probs?
- Scratched Windshield
- Brake/ABS Light On
- 2004 Maxima power window issues
- Any way to hide rear exhaust and mufflers?
- 06 Maxima Transmission Upgrade
- Need Help with P0037 05 Maxima SE
- [Advice Needed] Wiring radio
- 2006 Maxima quick struts Front/Rear
- defogger
- 07, lowered, light bar, four 8's on 4k
- Rear Defroster
- MAF sensor and oxygen sensors
- Engine "shake" on throttle
- Thinking of Transgo Shift kit
- Left rear suspension??
- New to me 04 max.. Big problems with powerless
- Timing chain tensionor
- Trunk lid hydraulic assist
- car shutting off after clutch replacement
- Sixth gen Maxima headlight removal...?!
- Nissan Maxima 07 code P0171 O2 sensor
- NATS malfunction 04 maxima
- Heat doesnt work at idle..
- '06 Maxima P2A00 Intake/exhaust leak?
- wire colors under hood
- Is there supposed to be a hood seal?
- led light bar wiring
- Slight Oil Leak after replacing valve cover gaskets in 2004 nissan maxima, could it e
- air vent problems
- Creaking noise when turning the steering wheel, also clunk noise
- Headlight problem
- Looking For Bumper Covers 2008 SL (Dark Slate)
- Potential 2004 Maxima purchaser here!!
- Windshied wiper fuse location?
- 2005 turbine revolution sensor
- Climate Controls do not work at all
- 2004 Maxima SL - Low Volume -left spkr -CD & Tape Only
- Stability Control
- Exhaust Leak - Please Help!
- Engine Knocking on Startup...Timing Chain Tensioner?
- 2004 maxima transmission problem
- 04 nissan Maxima Mod.
- Keyless Remote Issues: 2005 Nissan Maxima
- Surge in rpm's!
- Timing chain replaced now this
- Idle Speed
- New Guy Hi & Intro
- smoke
- under hood fuse box
- Most miles on stock spark plugs?
- Manual 6th Gens
- 2004 Max - No heat at idle
- Help w ABS issue (running while motors off)!?!
- Need new Brake Pads and Rotors - Bad Experience last time with Alien Performance
- Slight Wobble/Grind
- Help reading a check engine code
- 17" wheel inside diameter?
- Occasional momentary loss of power on highway
- Cluster gauge removal
- How to Replace Alternator on 05 Max
- Throttle response: none, low normal
- Bye Bye My 2004 Maxima....:(
- 2008 Max suggestions?
- My back up lights won't turn on
- Fix for sagging rear? Fix for droopy sunvisor?
- Debris inside the projector lens?
- Fog Lamps
- 2004 Nissan Maxima. Please help
- 08 maxima thumping noise at idle
- 08 bi xenon turns pink when warms
- replaced catalytic converter and engine now have p0420, p0455, p0507
- Need Help finding parts
- please help... whole dash ripped out for my stolen stereo.
- Help New Trans Problems
- HELP!!! No power on dashboard
- 04 maxima poping noise
- 05' maxima stereo upgrade
- Hard time in snow
- 05 maxima auto in limp mode
- 04 Maxuma tough start when cold
- Leaking Power Steering Fluid Question
- electronic exhaust options
- Possible start of tranny problem..
- Funny sounds when i hit 1700-2000 rpm in every gear
- Can you remove the evap, and the engine still run?
- Crankshaft Position Sensor SEAL (not o-ring)
- Power window issues
- stuck in 5th gear
- Somebody hit my baby :(
- Jerks when shifting from Reverse to Drive
- strange ABS triggered.
- 2007 Nissan maxima acceleration problems
- Headers
- 07 Maxima Brake light and Battery light came on, and have no gas in drive
- VIAS not staying open
- 05 Maxima Stuck in 5th Gear
- TCS off & slip on 2005 maxima
- AC Bypass
- Door panel not working.
- 2006 Maxima VDC light
- p0507 and p1283 on a 04 maxima caused by MAF!?!?!
- 2004 maxima power steering location and replacement
- need abs sensor, where should i buy and what brands have people had luck with?
- 2007 Nissan Maxima
- Dashboard light replacement (single bulb behind speedometer)
- AUX input for 2004-2008 Nissan Maxima
- 05 SL ticking noise
- Mistake Four Oxygen Sensor in Maxima 2006r 6Th Generation.
- engine or clogged caty noise?
- Intake manifold runner control valve
- 4spd auto or 5 spd auto which is better?
- P0507 p1238 p1273
- Replace steering wheel controls
- Infiniti i35 vs Maxima---- Same Motor?
- 07 maxima excessive gas smell in cabin
- Camshaft/Crankshaft Position Sensor 2004 Max
- General Cost for Pro HID Headlight Installation
- Radiator Replacement 2005
- Tune up advice needed
- give me a hand
- 2007 maxima blowing cold air when idle?
- 04 Maxima Crank but no start!
- 2004 defroster/heated mirrors and blower motor dont work....
- leather seat upgrade electrical connections need help
- Nissan Maxima App
- Help!! My oil is watery!!
- O2 and Fuel Air Sensor OBDII Values
- 6th gen experts, need serious advice on purchase
- opinions needed
- Fuel smell
- bad timing or something wrost
- Help with P0171 and P0174 codes
- engine hesitates help
- Trouble with my Bose/Nav system
- Slip Light & TCS Lights on.. Help plz!!!
- How do you change ABS Module 6gen
- Help with part number
- 04 Maxima engine blown.....
- FS - 2004 to 2008 18" RIM (Maryland)
- got P0420 code
- 2007 maxima
- double din head unit..with boss system/bass box
- Ambient Temp Sensor reading 131°F Vents blowng cold air
- 07 radio install
- Throttle Body Replace??
- navigation fried
- Grinding noise that I cannot figure out
- Bose system - want to change headunit to play ipod
- abs, slip, vdc lights after new engine swap
- 06 Maxima no fire
- Engine Swap + Catyltic Converter problem
- Cam Sensor Bank2
- Remote Start on 6MT
- New transmission
- Need help deciphering an noise
- N/A motor build on Nissanclub
- Highbeam/Lowbeam Issue
- Was driving in D3
- Replacing speed sensor and Throttle body and looking for wheels.
- 04 Maxima radiator R&R
- 2004 Maxima SL: U1001 and P0462
- 08 Maxima SE Halogen to HID
- '04 max with bose system - looking for navi interface w/aux input and back up camera
- Motor Tapping when the engine starts
- Auto head lamp issue
- in need of floor mats
- Need help, 05 maxima acting up, now not starting
- 04 SE Catalytic and sensors
- Picture of under the trunk mat
- leaky power steering hoses
- 07 Max shut off while cruise control was set.
- Help finding right front axle for 2007 Nissan Maxima SL
- 2007 Nissan Maxima right passenger front axle part help
- Help p3431code
- Cars handling go mushy after work was done
- New to me, 6th Gen high miles
- car won't accept fuel
- Does fujita still sell cold air intakes?
- 2005 maxima 3.5 SE AC Compressor Clutch Pulley Bearing replacement
- Any common oil leak locations?
- I want to add Navigation to my 2007
- Passenger side window rolling down on its own
- 04 Headlight on SE
- Stereo Antenna on 2004 Maxima
- Stereo Line In on 2004 Maxima
- Valve cover gasket repair, 6 times now
- Wont start, clicks once, the end
- Picked up an 07 Maxima today
- Looking to buy a 2007 tomorrow
- need some Transmission advice please help
- Can't turn engine by hand -- help--
- Need help with overhead dome light switch
- unknown sound identification needed
- Picking up an 04 tomorrow… Advice?
- Need help on 07 maxima
- Is an 04 SE and 07 SL swap (trans) all plug and play?
- Oil cooler
- 2006 Nissan Maxima timing chain problem
- stereo system
- Weird Electrical Issues
- 07 120K miles check engine light
- Wiring diagrams
- Car will not accelerate, advise needed
- SES Codes
- Rear backup sonar
- Audio Fuse Problems
- How to disassemble dash cluster and ABS problems
- 2006 nissan max after rostra solenoid replace
- 04 Nismo Maxima project
- Vibration at 65-80
- Racingline HFPC
- Scary noise from my 2006 Maxima
- 06 with a mystery misfire..PLEASE HELP
- 07 Maxima AC Drops Off and Temp Goes up At Traffic Light
- Can I install Factory GPS screen
- Is Anyone running the K&N FIPK intake system
- Convert rear windows to auto up and down
- Need help fixing my car up please!!
- 2008 Maxima Bulb Chart
- spiral cable
- 06 maxima problems
- spark plugs
- airbag warning
- '04 Maxima with P1273 code...
- Shaking when I brake.
- 04 Max Navigation Screen Stuck
- Lower windshield molding
- Busted Trunk Latch
- O2 sensors
- Hydro Locked...
- a question no one has seemed to ask
- Calipers? How hard can it really be?
- Starting issues
- Climate ac heater control amplifier
- Replaced axles and now the transmisson doesn't work!
