PDA
View Full Version : 6th Generation Maxima (2004-2008)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Dash lights
  2. Suspension Upgrade
  3. (IOWA) 04 MAXIMA SE stock mufflers and stock springs
  4. Nissan Vehicle Recall Form - Transmission issue ...
  5. Oil leaks from underneath
  6. AC Temp Settings Issues
  7. No longer a 6th gen owner...
  8. My wheel offset pictures with 10 and 15mm spacers
  9. 6000k or 8000k HID replacement bulbs on 08 Maxima ?
  10. **Overhead console problem**
  11. Rattling Behind the Dash
  12. Pulling Code P1800 sigh.....
  13. Buying Magnaflows tonight on fleabay....have a couple questions first.
  14. Strut boot torn. Worth the hassle to replace boot only?
  15. exhaust help
  16. So I got the dreaded p0420 on friday...
  17. Where should I put my exhaust cutouts?
  18. Bluebat hood overlays
  19. 08 radio problem HELP!!
  20. Aluminum motor mounts for our cars ?
  21. ticking thumping humming noise not timing chain need help
  22. replacing struts, what all parts do i need?
  23. Transmission bearing needed
  24. memory seats/steering wheel issues...
  25. Anyone using Mobil 1 Synthetic ATF instead of matic K?
  26. got hit in the rear
  27. ITT, I get new wheels!
  28. Has anyone replaced fuel filter?
  29. Maxima Hesitation Issue Solved
  30. Opinion on Springs..
  31. Door Panel replacement
  32. Has anyone ever bought a 6thgen through E-Bay??
  33. Quick 07-08 Auto Tranny Shift Knob Q
  34. Ok....so I have an 05 Max and I do not want to change my front bumper, but...
  35. Where did you put your HID balasts?
  36. Maxima Drivers Seat Gives Me Extreme Back Pain
  37. 04-06(maybe 07-08) - TransMission Problem - Then Look here.
  38. Weird metallic whine before shift up
  39. Anyone have a pic of a Max with this grille on it?
  40. HIDS too dim?
  41. Difference in OEM Xenon Projectors vs. other E55 one's?
  42. Shifter bushings
  43. Factory Remote Start Sometimes Works
  44. Tail light replacement
  45. Console unit
  46. WILL THIS WORK
  47. My C-Mod grill is on its way. Question about painting it.
  48. Anyone know about NEX Type SS coilovers?
  49. Possible Group Buy...who's interested
  50. Yes or No
  51. Suspension Info
  52. Rear Shocks replacement useful info
  53. SES light on---Inspection due! How to Reset?
  54. moonroof problem
  55. Cutting stock springs...
  56. BlueBat Roof Stripe
  57. Drop Resistor tranny
  58. max not stable
  59. tire choices on stock rims
  60. HID Conversion
  61. Newb to the Forum with suspension questions
  62. Valve body R&R tips?
  63. Tranny Problems!
  64. These gas prices are crazy and my car has been drinking it....
  65. Getting ready to buy a 2004 Maxima, shall I run?
  66. Current Timing Chain/Tensioner Job Underway Help!
  67. Deus joins the Dub Club!!
  68. Aftemarket suspension and dealer warranty
  69. Squeak or Rub when Hitting Bumps
  70. Where did you get your ABS Module?
  71. 04-06 max 6speed or 03-06 g35 sedan 6speed
  72. viberation at idle plus tires coupped
  73. Progress Springs
  74. No more 6th Gen Maxima in my garage, I will miss her, will miss this forum as well.
  75. Whats the Difference with radiators for the 6th Gen??
  76. need a lil help
  77. Possible Alternator Replacement?
  78. Does anyone own this car?
  79. Timing Chains/Tensioners/Guides job
  80. RLM bumper - painted and installed, with Pics!!
  81. LED Tails - Need some help....
  82. Spark Plugs
  83. C-Mod vs JDM Grill for my 05 Max
  84. Electric Supercharger
  85. Just had to share...
  86. 04 maxima transmission transplant
  87. Possible solution to stuck/mushy clutch peddle!!!
  88. explanation on unworking radio head unit.
  89. Video clips of my Racinline ypipe + Greddy SP2
  90. 07 Stock Air Box
  91. Intermittent starting problems – I need your help…
  92. Possible 2006 purchase
  93. Cant get inspection to go through
  94. Manual Trans Swap
  95. Listen, I know Magnaflow topics are old, but I need an updated answer...
  96. Car is going bonkers! Help!
  97. REAR SHELF (deck) RATTLE
  98. satellite radio
  99. rattling sound when start up cold
  100. Help!!! Car will not accelerate.
  101. question about front strut mounts
  102. WTB Drivers side mirror
  103. new gtr bumper on my car!!!
  104. Which bolts hold on valve body on 06 maxima?
  105. 06 Maxima valve body removal
  106. 2005 Satellite radio
  107. Convenience light switch
  108. loose rearview mirror
  109. whatttttttttt
  110. Anyone Use Sprint Lowering Springs?
  111. This snow storm kicked my a$$...
  112. Effects of freezing weather
  113. 2004 Transmission slipping issues
  114. selling 5th gen, getting a 6th gen, what to look for?
  115. Are Megan Lowering Springs good?
  116. Nissan Maxima Spark Plug replacement DIY
  117. Where is the Racingline Christmas Sale?
  118. Lightweight rotors!?
  119. H&R Springs
  120. Make SURE you get what you want for Christmas, Hanukkah, etc. @ Cattman Performance
  121. Cattman December Discount Sale in Group Deal
  122. Amsoil tranny fluid
  123. Electrical Problems with windows??!? 04' SL
  124. H3 HID Fog Install
  125. NISSAN MAXIMA 04-06 HID XENON LIGHTS... QUESTION.
  126. Ebay Grille
  127. LED cornering lights resistor needed?
  128. Altima SER Wheel on 6 / 6.5 Gen Maxima on PIC???
  129. Grounding Kit help
  130. just picked up an 2004 maxima and im about to pick up some wheels
  131. Converting 05 Bumper to 07-08
  132. NON HID to HID Headlight Assembly Conversion
  133. 6th Gen Rotors: What to Buy?
  134. Anyone used an re4f04b in a '04 yet?
  135. Y-pipe for 6.5?
  136. My Shimmy is Solved..... I think/hope.
  137. Splash Guards 04
  138. Headlight just went out...cost to replace?
  139. So I just came from the nissan stealership...
  140. side marker lights on?
  141. NON HID to HID conversion
  142. Win a Sony Playstation 3 (PS3) or Gran Turismo 5
  143. smooth ride
  144. Auto up/down rear windows...
  145. Maxima Custom Fog Lights .. Question.
  146. Power steering pump removal help
  147. Aux Input Help
  148. AC Not working
  149. Nissan Maxima Replacement Concept
  150. Does Altima Springs Fit 6th Gen Maxima?
  151. coolant change - no heat
  152. How do I replace Ballasts? 2005 Maxima HIDs
  153. Resonator assistance please
  154. HID fog needs relay?
  155. Coolant fans
  156. sunroof issue again
  157. Where are teh females that drive the 6th gens??
  158. BW9 - Stealth Bomber
  159. Racingline Black Friday Specials
  160. TAIL LIGHT MOD
  161. Sunroof deflector and shock sensor question...
  162. FINAL WEEK
  163. timing issues....help me im desperate lol
  164. Were the mudflaps standard on the 6th gen?
  165. Wanna save some money when fixing you timing chain issues?
  166. XEON Flickers and Goes Out. Bad Ground? Where is it?
  167. coil packs
  168. timing marks
  169. foglights keep going out
  170. Got owned this morning....
  171. Oil Pipe Rotting?
  172. Happy 7th birthday to my 6th gen! (and some history)
  173. Leaking Bblue/greenish liquid after hit. Help asap plz!
  174. ANOTHER PLASTI DIP THREAD
  175. TSW Nardo Or TSW Vairano..?
  176. TPMS do i need them on new tires install?
  177. Another tranny problem?
  178. 04 maxima Transmission issue (Yupe me too now)
  179. Flashing air bag light after replacing passenger seat?
  180. Can i please get some help with replacing floor and glove compartent light (led)
  181. Headlight bulb replacement TIPS
  182. Ideas for HID fogs
  183. Need part numbers for timing chain tensioner fix
  184. No more Maxima
  185. Stock Muffler Dimensions for a 2004 Maxima?
  186. Speedo pinion gear
  187. 2007 Fog Light Help!
  188. Where can i get a performance chip for my 04?
  189. 6th Gen maxima Tranny swap
  190. Brand new transmission/clutch installed.....
  191. Borla muffler on my 04 Max?
  192. Anyone replaced their AC compressor?
  193. Nitto Tire on Facebook, LIKE to win tires
  194. Steering hard/tough to turn 6th Gen
  195. Catalytic converter question
  196. Just bought a 6.5 that had no owners manual
  197. questions on 07 maxima SE (please HELP) Thanks
  198. Timing Tensioners
  199. The difference in valve bodies
  200. Stock/custom mass air intake...feedback cuz it was to easy
  201. 04 maxima se need help with stock cd player please
  202. blend door actuator location
  203. E-Brake too soft
  204. Nitto Tire on Facebook, LIKE to win tires
  205. Code P1621?
  206. Front drivers side inner tie rod
  207. New wheels!! volks!
  208. Grounding kit install problems
  209. I want headers! WTF
  210. Advance your timing?
  211. Post pik'z of 20" and 22" Rims..
  212. PCV (Positive Crankcase Ventilation) Valve
  213. New suspension / Rims - What do you guys think?
  214. Steering creaks when sitting still
  215. Replacing front bumper cover...how-to?
  216. Car making popping when turnin left?
  217. Flat spot on exhaust center pipe
  218. Gas tank is full- needle reads EMPTY
  219. Mishimoto radiator
  220. Trade In Value= Lousy
  221. rim question
  222. 6speed transmission issues....2006 Maxima
  223. Transmission diagnosis and repair manual.
  224. Lets make nissan accountable for the crappy transmission.
  225. Nissan Maxima 2005 Shifting Problem
  226. XENON Bulb Replacement Advise....
  227. How to LED 3rd Roof Brake Light
  228. Tranny, cats, timing chain tensioners, etc. When did yours go bad?
  229. Traction help 07!
  230. Will these Altima wheels fit a maxima??
  231. Tail Light Assembly ( brake light replacement)
  232. Rumbling noise from the dash on warm starts
  233. Early Christmas for me (parts ordered)
  234. Sunroof stopped working!
  235. Transmission sometimes slips and in 5th gear: Please Help
  236. clear door lenses
  237. SES Help Plz!
  238. Radiator Hoses
  239. R.I.P. KC2010s 05 Max!
  240. Need some asistance! Tranny related
  241. Keyless entry keypad
  242. Transmission class action lawsuit
  243. Transgo kit ... successful stories?
  244. need help with radiator issue
  245. difference between 04/05 vq35
  246. Help!!! Rattle (fixed)
  247. 2006 transmission cooler
  248. 04 with 55K miles....dead ECM already?!
  249. 5spd auto transmission code of death :-(
  250. 04 SE Detailed!
