- After the engine work and car sitting for a long time, started, shut off and no start
- 2004 5AT - Car Pulls When Trans Shifts Into 4th or 5th
- Install New Timing Chain
- Pull back when off the throttle
- Skyview Removal?
- My 2004 Maxima stearing wheel is shaking (vibrating) when driving at 80 - 100
- Help with Power steering fluid leak location?
- 2008 maxima still having problems!!!
- my car sometimes won't shift past Neutral
- 2005 Maxima Hard Shifting
- 06 Maxima Weird Problems
- My cassette player.
- Can I put a smaller belt on my 2005 maxima to bypass ac?
- Cooling fan not running
- Rostra solenoid. Trans issue. Please help!
- Please spoonfeed me, how much to replace a 2005 waterpump?
- AC compressor always engaged
- Transmission Thud/Kick
- OBDII Code P0075 ?
- Like DTC report printing and google search
- Speedometer doesn't work
- Engine occasionally stalls when taking foot off accelerator.
- 2004 maxima parts with 2007 maxima?
- shifter issue
- Other reasons for power steering leak
- Which is left/right sway bar link?
- 04 Hesitation When Applying Full Throttle at Idle
- Oil from my tie rod boot?
- 2004 Maxima 4 speed transmission replacement
- New axle now abs slip tcip warning
- 4 speed auto to 5 speed auto
- Camshaft position sensor replaced, now won’t start
- I think something is missing from my battery cable!
- 2008 Throwing Camshaft Position Codes P0011 / P0022
- Sputter
- Buying 6th Gen - Pointers / Look-fors?
- EZ Koncepts LED Tail Light Fix
- fuel pressure regulator
- Gauges and ac not working
- Wiring harness for VQ35DE in 2004 Maxima
- Weird humming noise that comes only when the engine is hot
- 07-08 Gauge Cluster in 04 - Removing TCS OFF/SLIP Lights
- 06 maxima 5 speed automatic MAF
- 2004 Maxima - ABS, Speedometer and Odometer Problem
- Potential New 6th Gen Owner
- a/c Freon Question
- 2008 Maxima CVT Fluid Change?
- My 2006 maxima
- 2004 ECU Flashing Tool
- New Maxima Owner, having issues please help
- catalytic converter
- 2008 Max - AC Automatically Turns On / AC Controls Wont Do Anything
- 2008 Max Knock
- 07 Maxima won’t go over 20 mph, no DTC
- fuel pressure hose i guess ?
- OBD Won't Connect?
- 06 Maxima fail safe mode please help
- Self programming of key fob?
- Please Help Diagnose Front Driver Side Noise
- A/C not blowing cold air
- Engine Hum
- Hey I'm new 08 Nissan maxima 3.5
- Some mount snapped on 05 maxima SE
- High outside temp?
- Car dying
- Diagnosing Starter Trouble
- Many codes please help - O2 Sensor related possibly
- 04 maxima
- Exhaust rattling on crossmember
- 2007 scraping/squeaking from left side
- sway bar link remoal
- Compression Specs?
- 2008 maxima. Car won't always start
- Headlight Issues
- 2004 Maxima Timing Chain Rattle
- Can someone identify this wiring harness hanging in my front bumper?
- Belt squeal... can I fix it myself?
- Rear Shock Absorber Complete Assy
- Can someone tell me everything I need to know about the stock HID on my 6th gen?
- p0507 normal idle
- P0340 with 10V at both bank 1 and 2 CPS
- The 200,000 Mile Club Thread...
- Question about Downstream Sensors & EGR NOT READY
- 05 Maxima Shifter stuck intermittently
- PreCat Delete?
- 08 maxima motor swap need help.
- No acceleration, RPM won't go above 2,500
- Slippery Trans
- Headers
- engine died while driving
- Aftermarket parts
- speed / transmission / sensor issues
- Camshaft Position Sensor Issues
- 2006 Maxima ABS fuse replacement
- Magnaflow Y-pipe has a smaller cat than stock
- 2004 Maxima Aux
- 07 to 08 cvt transmission repair
- P0302
- Ebay Front Lip
- 06 maxima radio
- Which transmission do I have?
- 2004 6th Gen climate control modular
- Delayed start after engine swap
- Evap crap
- P0507 code Help
- Engine wiring diagram v6 6spd
- oil change info
- 04 to 07 engine swap
- BC coilovers "2004 Maxims"
- New hubs and abs sensors..Help please 05 maxima
- HID assembly replacements
- idle relearn procedure
- CV boot
- Cylinder 2 misfire p0302
- nats question
- Bad catalytic converter
- After jumping my 07 maxima off it want shift into 5th or 6th gear
- Abs tcs brake and slip lights still on
- Slow crank
- Trying to get the right parts
- window issue
- just out of curiousity
- [Maxima A34 05] the oil level in the gearbox is increasing
- throttle body
- Weird noise I can’t figure out
- Transmission killing engine?
- power issue
- 07 Nissan Maxima driver window won't roll up
- random miss at idle
- Engine surges to 8k on tach as soon as 5k is reached in gear or in neutral NEEDINPUT
- 04 coolant bubbling out of reservoir ????
- No shift past 3rd gear .
- 04 Max 3.5 crank no start.. No fuel or Spark
- 2006 nissan maxima v6
- Nissan is Junk compared to Land Rover
- 2007 6AT surging issue
- Power Steering Fluid
- What are these parts?
- front fuel pressure damper
- Where to get hood struts with ball?
- New Maxima Owner and member
- Clock spring replacement
- coolant hose bypass
- 2004 Maxima SE throttle control motor problems
- rack and pinion bushings??
- No Brakes!!!
- Clicking noise when steering wheel adjust
- Engine Swap
- lights on bumber cover
- 05 Maxima Steering Wheel Vibration, knocking noise from front end.
- I have a 07 and I got a engine from dismantler 03
- Pulled abs fuse
- Having starting problem.
- rpo build codes
- Loud Break squeal when brake rotors/pads warm up
- How do you remove b1 s1 Oxygen Sensor?
- Xenon replacement bulbs for '06 Maxima
- Slipping issues pulled codes P0826 and P1800
- oxygen sensor
- Crank angle sensor
- worst headlights ever!
- Oil in the intake
- Repetitive Cloggin PCV Valve
- What relay triggers alternator output?
- 2008 Evap Recall
- Random Front End Vibration - 2005 Maxima
- Idler pulley
- Ram Air?
- Oil dipstick smells like exhaust
- 2007 Max...P0507 issue..need some guidance
- 2006 maxima shift solenoid
- Timing chain class action lawsuit settlement
- new leather seat bottom
- low down on 06 RS5F51A?
- Battery brake light is on
- Timing Chain Tensioner Replacement
- p0420 bank 1
- '06 Maxima SE - New touchscreen stereo = Disabled factory features?
- Sticky steering
- Totally lost on 05 belt/ps/alt issue ANY ADVICE APPRECIATED
- 2006 Auto to 6 speed man
- 2005 Halogen upgrade to LED question
- Ignition switch replacement
- Hid to halogen lights
- Engine oil leak on Power Steering Pump
- Tunes!?
- Timing chain questions
- 2004 maxima is in safe mode
- 2005 Maxima starts, revs & dies
- Timing problem
- Newbie
- 2007 Max: VIAS Solenoid issue
- Turbo?
- Ball joint to steering knuckle nut size
- Misfire At Idle?
- Need pin sheet for 2004 ECU
- 2008 Factory HIDs
- Eastern vs Walker Y-Pipe
- 06 Maxima headlight
- 2006 máxima
- Driver's door power lock problems
- Shaking my head
- 06 Nissan Maxima won't start
- 2005 Maxima - What's this hose?
- No heat in cabin
- Fuel Pump Relay Location
- 2004 engine wiring harness
- 06 Max temp gauge going up at idle?
- Parts list
- Parts list
- 2004 Blower motor intermediately working
- People say the 6th gen is when the max really went downhill...please educate me!
- Where is the transmission filter?
- Oil and Transmission fluid everywhere.
- all kinds of misfires
- Tie Rod Ends on 2005 Maxima
- POS car now "no sat" message
- Valve knock
- A/C electrical problems
- Car seat problems
- 2006 maxima normal idle?
- air/pressure sound on passenger floor area help!!
- Ipdm e/r
- Multiple Ground
- Flaming Undercarriage
- Rim size question!
- 2006 Maxima Seat Swap
- Headers
- Where do I find Bug deflector Hood protector for 2007 Maxima
- Power Window Pinch Safety Feature
- 6 Speed manual loosing 2nd gear after a couple of shifts
- Interior question
- Another AC thread...
- 06 maxima jerks when changing to D
- Starter ground nut
- Headlights dilemma
- Fuse able link
- Caliper install, no fluid
- Transmission acts like it's in 5th gear consistently
- 2007 does not accelerate?
- Stalled and won't start
- Can i put 7th gen maxima coilovers on a 6th gen?
- 2004 Maxima SL Whining Noise.
- Can't adjust belt idle nut
- Steering Wheels Shakes at 80mph
- Slightly Slow and Sluggish Starting?
- Service engine soon light
- ground cables ?
- Screeching Serpentine Belt
