- Codes 1148, 1031, 1148P 1031P
- What's the best alternative to Cattman headers for 04 Auto 5spd
- Show me YOUR rims!
- 2004 nissan maxima vdc light comes on and the car stalls
- Limp Mode. Transmission Issues
- 2007 SE No Power to OBDII Port
- 2005 Maxima Instrument Cluster
- slight howl from right front
- Any Good Mufflers For A 04 SL
- 05 maxima won't start
- Looking for good Coilsovers on a daily driven!!
- Replacing Struts/shocks on 04 Maxima
- Cheap source for OEM 07-08 rear spoilers
- 08 Maxima
- Knocking sound after a cold start
- High Idle at start lasts too long
- vacuum leaks
- A/C Controls Unresponsive, Car Turns Off During Hard Turns
- Wheel for full size spare tire
- Vaccum help
- 07-08 removing aftermarket unit and reinstalling factory radio
- Speed sensor replacement
- Location of Air fuel Sensor Bank 1
- Flood & Cornering Lights Don't work
- Relay Box Diagram
- '05 Maxima fuse/relay box diagram
- Anniversary edition uses different fog lights?
- One lower tire is lower than the other side, cause?
- Battery Change, and Car Settings
- Catalytic Converter Replacement
- Tires that fit
- Interesting ABS problem, AGAIN
- Outer tie rod bushing
- Looking at a 04 Max.
- 06 Maxima hard to start
- side power mirror "downgrade" ?
- New Member Here, 2007 Maxima SE
- Is this worth it for an 04 Maxima??
- Cup holder lid sticks
- HID KIT, need help!! plz
- how to disarm car alarm on 2004 Maxima without remote.
- P0138 p0304 p1273
- Current load on power socket?
- Just Detailed the Engine Bay!
- Suspension Question
- Camshaft position sensors
- Parts store?
- tranny switched to neutral while driving
- timing chain
- Knock sound
- 04 motor replacement options?
- Just got my transmission rebuilt
- Cluster and interior Lights Not Working Car Won't Shift
- Gear shift and bang noise
- looking at 04 SL tomorrow
- Selling the max
- Replacing a single tire
- 5.5 gen vs. 6th gen FINALLY tested
- Which engines are interchangeable?
- Aggressive tail lights for Nissan Maxima
- Mini Maximas
- Issue when turning to the right
- Service Engine Soon light after Gas Cap mishap
- Whistling Noise and Rough Idle
- Hello, I just pulled in here...
- Safe mode ?
- Maxima Stopping all of a sudden
- SELLING: 2004 Nissan Maxima Power Steering Rack & Pinion Assembly
- Replacement for Front Exhaust Tube
- 2008 Maxima Speakers
- Coolant Leaking
- I don't know if it me or not I just saw 5th gen spoiler
- Speedo & Odometer not working
- need obscure information, please
- Looking for a roof rail system.
- Maxima SES + Overheat Question!
- 2007 Nissan Maxima SL repairs question
- 2004 maxima ac compressor
- Car battery keeps dying, is it battery or alternator?
- 2004 maxima 3.5 se
- 08 Exhaust system advice
- Valve covers and gaskets leaking oil
- 2006 6peed Catalyic Converter Questions and Answers
- 07 maxima overheats with AC on
- Where can i buy rebuilt transmission
- New Maxima Owner... Q's...
- 2006 maxima
- Brake light switch
- Leaking coolant heater core
- Maxima rattling/pinging noise when at idle
- im tryin to figure out if my ecu ecm pcm w.e u wanna call it is bad
- What are the stock front and rear disc sizes
- trans fluid
- Is there any issue with driving on a P0302 code
- Handles get stuck and I have to manually close them
- unknown stereo plug in.
- P0138 Code
- replacing low pressure ac hose
- Help! Thanks in advance
- Shocks and struts
- Any one in So-Cal OC able to fix my tension guide?
- Tune Up for my 04 Maxima SE
- 2004 maxima power loss at specific rpm range
- So I bought my first car today :p
- Goodbye all..
- Idiot lights
- fuel additives
- Trans
- Releasing/pressing throttle causes car to jerk abrutly
- Time to say good bye ...
- Torque for Valve cover Screws
- Chrome protective film never removed?
- 2005 Nissan Maxima SE is showing "Service Engine Soon" P0780
- Passenger side mirror
- LED! Conversion, Replacement, Pics & Pointerrs
- Camshaft Sensors
- Wheel question
- Replacing clutch pedal fluid
- 2006 Wont start (just clicks) new starter put in
- Nismo Catback
- Key for driverside door, wont open w/dead battery
- 04 door locks. Help if you can please
- factory alarm preventing car start up.
- transmission noise
- 2007 SE - Doors Won't Unlock - Immediately Lock Themselves
- Replace Rim '08 Maxima
- Enter button on 2007 Maxima SL w/ Nav
- 2004 Maxima ST wireless remote programming issue
- car is still jerking please help
- VIAS solenoid another name?
- Oil Change
- Replacing Linear Solenoids in 5spd. NYC shop recommendations?
- stock spring rate on 6th gen
- Has anyone tinted headlights w film?
- Transmission issues
- New Member requesting input on repair quotes
- break fluids ?
- Arming the stock Security system
- 2005 SL Running Sluggish
- Passenger door mirror
- Exhaust HELP
- 04 Maxima Camshaft Position Bank 1 Help
- Obnoxious clicking noise
- Gas gauge
- 05 Steering Concern
- Rim Repair
- Driverside Door Window/Lock controls
- What Total Fuel Range / MI/KM per tank do you usually get?
- How to find a Intake leak / P2a00
- Where is the Engine ground?
- My temp gauge
- help with maxima shut off
- 2004 Tensioner Guide Problem
- 6th gen repair list get ready!
- a good spring rate recommendation
- Help!!! Another p0340,p0345 thread.
- pulling my engine question
- Car Shut Off
- Factory service manual
- Opinion on Transmission Fitting.!!!!!
- How to install an oil cooler on a 6thgen Maxima with video
- abs, slip, tcs, brake light on
- Center bore
- New battery, still no power...
- Q45/6th gen hybrid brakes?
- Wheel fit
- 2004 Nissan Maxima 6 speed p0300 trouble
- My Maxima heating up
- Drivers power window/regulator/motor/switch?
- car feels like it slows down when I release the gas.....
- How do I spin my engine manually!?
- 3nails4life
- New to Maximas
- Trip info and fuel economy and climate LCD not working
- ABS light on
- Going low
- Speedo and mile Counter not working
- Moon Roof Leaking
- DIY - Replacing the Valve Cover Gasket
- A/T infiniti problem
- 6th gen correct tire size 22inch wheel
- in-dash rattle
- Good Bye Maxima
- Transmission Oil Change
- Timing Assistance
- can you install a 6.5 gen spoiler on a 6th gen?!
- Low rpm, less power, Hard start, rattling sound
- tail light fuse blown working dome light.
- u1000 04 Nissan maxims help help
- car jerking
- Vias hiss
- Need any helpful information with my problems!!!!
- trouble with key fob
- Clutch Master Fitting thread size
- Speaker System
- cold start issues
- Weird electrical issue, possibly with speed sensor?
- Wtb front grill for 07 max black color?
- How I tinted my tail lights
- Brakes - Shop v.s. DIY?
- My custom front lip
- Is it my wheel bearings?
- Headers
- Rear Brakes Replacement
- 04 Idle Dips And Almost Stalls
- Trans Question
- How do you price a _fully_ loaded '05 6MT?
- Crap I let a pad get totally worn and ruined a rotor.
- TPMS fuse
- '04 Maxima Bose amp/sub help!
- 04 maxima elite package conversion
- Lowing your car and CV joint axle problems
- Right Rear ABS Sensor C1105
- advise for lowering shocks and struts
- How Much Should I Pay
- 08 "limp" mode issue? no throttle, no rpms, no go! please help!
- Maximas with D2 coilovers
- Salvage Title Question
- Abs light is still on after i replaced the actuator
- 2004 Maxima Power Seat Moves on its Own while Driving!
- Bypass AC compressor ?
- 5 LED tail light bulbs not lighting up
- electrical dissastor
- p0744 and p0420
- Twin turbo?
- Shimmy is back!
- 6th generation zenon headlights problems
- 04maxima and 08maxima performance parts
- brake light
- help with p0507
- 07 maxima hid problem
- Unresponsive throttle...
- Left view mirror with auto dim
- Any aftermarket aluminum oil pans?
- Anyone paint their rims?
- 4th gen owner looking to upgrade to 6th gen soon...
- First time customizing Car
- Shifter Not Returning To Center
- 4at to 5at swap
- How much money does a new transmission valve body cost for a 2004 Maxima?
- Bad Coil Pack maybe
- 20's + Drop Springs
- PLEASE HELP: 2007 Exhaust System
- Help with check engine code p0420
- Rough Idle After Changing Front and Rear Engine Mounts
- Nissan Maxima noisy ABS
- Timing Chains and Tensioners 2006
- Transmission questions
