PDA
View Full Version : 6th Generation Maxima (2004-2008)
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. 2005 Maxima Cooling Fans Not Working
  2. 2006 SE Pre cats.
  3. 2005 Maxima SE 6speed tranny noise.
  4. Vibration just after take off??
  5. How I dealt with the infamous 'shimmy'
  6. Tranny problems???
  7. racingline highflow precats in CA question
  8. ODBII port
  9. OBX Headers
  10. Alternator from eBay
  11. Power Steering hi pressure hose leaks
  12. Looking at a 2005 Maxima LS
  13. Rack & Pinion Replacement in 2007 Maxima
  14. unknown plugs on vq35de wiring harness that go over each cam cover
  15. Sound controls & reverse sensors not working
  16. P0300 woes
  17. 2008 gives me trouble when its raining outside.
  18. 2005 manual transmission o2 sensors different part number?
  19. Long cranking start
  20. 2006 Nissan Maxima
  21. Tranny shifts hard when cold fix for 2004 SE?
  22. Power steering issues?
  23. Stereos for J31?
  24. Part find - Driver Cowl side panel
  25. Corner/Fog lamps
  26. Newbie advice
  27. Need help : tach/rmp drops by 500 rmp while at low speeds
  28. Owners Manuals Online?
  29. Opinion/thoughts on 2007 Nissan Maxima 3.5 SE
  30. Tachometer needle dropping split second
  31. Mechanic says I need a new A/C compressor hose and a new condenser hose for my 2008
  32. Fuel Pressure Damper Rattle
  33. 2005 Maxima limp mode, no obd connect, electrical problems
  34. Help misfire cyl 3 P0303, tried everything!
  35. Stuck in fifth gear with no codes
  36. 2006 maxima 6spd almost stalls out a couple of time while driving
  37. Did The Dealership Cause A New Problem After $5,000 Worth Of Repairs?
  38. Turbo / Superchargers for 6th gen?
  39. 2005 maxima rough idle and strange random knocking
  40. HID Headlight Not Working
  41. NWP 75mm big bore throttle body review
  42. What hose/part is this?
  43. Will 04 350z rims fit on 06 Maxima
  44. Building my engine
  45. Anyone running an aftermarket radiator?
  46. ecm fusebox #10 fuse keep blowing is that an electrical problem
  47. Radio/climate control screen
  48. Led light bar
  49. Flex Pipe or Entire Piece? & Idle Issues
  50. LH SiIDE TRANNY MOUNT
  51. Tire size?
  52. Air intake system?
  53. Driver side fan not working.
  54. Radiator advice
  55. Lowering my car
  56. Knocking by right tire
  57. Starting problems
  58. Catalytic Converter
  59. Need to remove steering wheel controls
  60. New here, bought new rims that don't fit need help
  61. Need advice
  62. Need help
  63. Questions about performance parts
  64. Fed up because of P1273 code- maxima 05
  65. Lowering
  66. Illustrated timing chain replacement
  67. Battery Troubles
  68. Exhaust
  69. 05 maxima trans issue
  70. Coil Pack failure on 07 SE with 78k miles?
  71. Front turn signal mode
  72. Front o2 Sensor Location / limp mode in 1st gear after being on highway
  73. P03030 Engine code
  74. HELP PLEASE - Pioneer AVH4100NEX install question.
  75. 04 maxima headlights/fog light switch
  76. HELP! ACC Lights, No Acceleration + ABS SLIP VDC Come On At Low Speeds ++
  77. Difference in the 04-06 and 07/08 engines?
  78. 04 6spd SE
  79. Air condition problems
  80. Cam code.
  81. 2007 Maxima SL Memory Seat/Smart Key Problems
  82. Help! Crank No Start....Tried all I can. Now What?
  83. Fuse don't work
  84. 2008 Maxima exhaust kit
  85. Questions regarding the 6th gen.
  86. ballast
  87. New guy here need help find this add on rear lip
  88. wheel issuesss
  89. 2004 maxima with stuck A/C vent
  90. Am I just in denial.. Or is my trans shot?..
  91. Need help new driver just got a Nissan maxima 2007
  92. Need help new driver just got a Nissan maxima 2007
  93. Bat 10a fuse blown
  94. Factory HID question
  95. Got a code for a part my 07' dosent even have.
  96. Need a engine tuner
  97. Please help diagnose transmission (?) problem on 2007 Maxima
  98. Rear Deck 6x9 speaker removal/installation
  99. I have a question about body kits for 6th gen...
  100. trany rebuilt and issue
  101. What is this part/leak?
  102. Leds for the dash
  103. trans fluid
  104. 06 Maxima SE - Many issues
  105. Turning radius 07-08
  106. Opinions
  107. NAPA Ignition Coil
  108. Illluminated Steering wheel controls/OEM navi
  109. Floor Dimensions (Driver side, passenger sides)
  110. Car wont go past 1500 rpm
  111. Radio not working. Help***
  112. ABS needing replacement
  113. Rear Bumper Removal
  114. Looking at a 6-gen
  115. 2006 Maxima engine noise
  116. How Many Mounts 2004 ?
  117. 04 Maxima wont run. PLEASE HELP!!
  118. No sound from aftermarket radio
  119. Timing chain adjuster
  120. Replacement key
  121. '07 Max purchase ,,, a world of hurt???
  122. bose sound system - Cd player issue
  123. Engine swap on a 2005 Maxima
  124. 06 3.5 cranks no start multiple dtcs
  125. 2004 Maxima Crankshaft Sensor Location
  126. front left door open
  127. Altima springs
  128. Hot Engine
  129. 05 Maxima hard shifting after Valve body reinstall
  130. maxima 2004 LED corner light
  131. Replaced factory rear 6x9's with new aftermarket ones and they sound like CRAP! Help!
  132. Missfire at idle
  133. Problem - Horn goes off when I open door
  134. 2007 headlight problem
  135. Start/Electrical issue
  136. Code 744 after valve body relacement
  137. 5 Quart Full Syn oil - $12
  138. 02 sensor help
  139. 06 water pump replacement cost
  140. Inner joint apart when installing struts
  141. Bose system rear speakers too quiet
  142. OBD No Power
  143. 06 SE slow to start
  144. 07 Maxima oil leak
  145. Noise while turning.
  146. 04 Maxima will not move when accelerating.
  147. Front struts
  148. Replacing cam chains?
  149. Cooling fan
  150. 04 maxima will not turn ova and start
  151. Clutch Pedal Low Pressure and engagement point
  152. Coolant reservoir boiling
  153. Help with coolant leak?
  154. 07 nissan maxima
  155. Slip. Tcs off. Issues
  156. Rear Brake Slider Pin Issues (HELP!!)
  157. Evergreen TK3034WP Timing Chain Kit
  158. ABS Sensor issues....
  159. Looking to buy 2007 SE/SL 55K $9400
  160. Issues Opening Door
  161. Replace Full Wheel Hub assembly or just berring.
  162. tranny slip. ols advice
  163. 2004 Maxima - water under the car (not in the car)
  164. Heater blowing out a gas smell
  165. 19 inch wheels
  166. 2007 3.5 losing power
  167. Are 17'' rims too small for my 07 maxima?
  168. P1800 Code 2004 maxima
  169. Tranny flush vs drain
  170. Revamping the Deus Ex Maxima
  171. 2007 Nissan Maxima ABS, Slip and TCS off lights on
  172. 2007 Maxima - Airbag light on
  173. *PLEASE HELP* 2004 Maxima Engine Issues
  174. TCS Control System
  175. stuck shifter
  176. Seat swap - airbag light issues
  177. Trashed a stop sign in the snow
  178. radio replacement with bose
  179. Dynomax VT variable muffler
  180. Please help before I burn my car to the ground.
  181. cleared p0455 now have p0300
  182. P1800 with P0420 codes
  183. Keyless Remote Starter
  184. 06 Maxima Question About Tranny
  185. Maxima Motor Mounts and Delay in Transmission Shifting
  186. Best Affordable Seat Covers
  187. P0305 service engine code
  188. emanage ultimate harness help
  189. Reliability of 2006 SE w/ Manual Transmission
  190. help please......
  191. Can anyone run a carfax for me?
  192. Sunroof Assistance.
  193. Power Window Issue
  194. 05-06 Maxima Transmission "Stand" Needed..
  195. 04 Maxima Nismo Grille
  196. Get your Clusters Custom Color Modded
  197. 06 maxima performance
  198. Battery Issues
  199. 2004 Maxima vs 1992 Accord
  200. Car warm up takes time
  201. CEL..throwing codes 1800, 1564, 1283, 1031, 1148
  202. Replacing the Horn.
  203. Reverse/backup lights not working!!
  204. 04 Maxima - Just Plasti Dipped Hood/Roof LMK
  205. ABS Problem?
  206. Window won't go up
  207. heater core
  208. radiator flush ?
  209. coolant type ?
  210. 06 Maxima Trans Mount Question
  211. underdrive pulleys difference Maxima vs 350Z???
  212. Heater not working on idel
  213. easier o2 sim install
  214. 2004 Max cranked but didn't start
  215. 2004 nissan maxima ti-j31
  216. Another no Crank no Start
  217. stock stereo upgrade and interior lighting
  218. Altenator symptoms ???
  219. 04 Max Rad without Tranny Cooler?
  220. Transmission?
  221. Horn Problems - 6th Generation (2007)
  222. 06 Coils & Plugs Replacement
  223. Radiator Replacement HELP!
  224. Changing wipers on my 07 Max
  225. Information: Nissan Maxima NavTool Navigation Video Interface
  226. 04 Maxima SE cranks but won't start
  227. a/c not working
  228. headunit
  229. SE and SL Rear Doors the Same
  230. Performance chip/ AIR Flow Sensors and plenum spacers, oh and coilovers????
  231. Rattling noise while engine cold for 15 min
  232. Rattle on certain RPM
  233. 06 maxima performance
  234. 6th Gen OBX V2 Header Install
  235. Help
  236. Timing chain or Alternator?
  237. recommended mfr(s) for tie rods, LCA, end links?
  238. Keep or Upgrade?
  239. 2007 Maxima Acceleration Problems
  240. 2004 maxima trouble starting
  241. maxima 2007,batterie dead
  242. Hows this brake setup
  243. 04 No Heat on driver side
  244. 2004 Max Elite Front seats heat - Not working but the rear does
  245. In cabin squeel noise. 05. When using heat on high only. Plus heated seat question
  246. 2007 max overhead console
  247. 2004 Nissan Maxima Battery Size Question
  248. 06 Maxima trans issue. Stops working @ oper temp.
  249. OBD2 code questions, answers not found.
  250. 2004 maxima Stereo Needed
