- interesting find with pocket logger
- Crazy Tach
- Need help ASAP before i make a Purchase!!!
- 96 with a 3.5 in it link inside
- 3.5 head on 3.0 bottom
- vi question
- need help with 3.5 swap
- help vafc to control 00vi
- Abs
- 3.5 Bottom And 3.0 Heads Finnaly Running
- 00VI install help
- any 4th gen ecu work with 5th?
- Adapter plate? I don't need no stinking adapter plate..
- Making adapter plate for '00VI help.
- '00 VI Cali or Fed Spec make a big diff.?
- Advantages of full 3.5 in 4th gen, as oppossed to 3.5 bottem with 3.0 heads?
- Its Alive!!!!
- Heads Q
- Question about headers?
- Nissan Engine Geometry & Connecting rod guide
- Who thinks i should go all motor
- 00VI produces 14.5 ft-lbs more tq than MEVI
- yes more VI questions
- Cylinder head and valve train miscellaneous information
- N E 1 here installed a Pathfinder
- Which would be better if you could do only one
- Another 00VI installed on a 4th gen.
- Are VQ manifolds symmetrical?
- Cam swap. Help!
- VQ35 engine pics after mods
- VQ35 valves in VQ30 heads
- REbuild Question...
- 3.5 tb on a 2000 max
- NeoVVl On VQ
- What activates the power valve on 00-01 IM.
- VQ35 cams in a VQ30
- Anyone know 4 gen rod length?
- Nismo cams
- Who wants too see a full 3.5 4th gen on 3.0 ecu
- 00VI questions
- potential and future planing
- anyone see a problem with doing this?
- tryin to get back in the groove
- ok I am now in the hunt
- What Would You Perfer??? Jwt Cams Or 3.5l Cams???
- VQ35 longblock + VQ30 Cam Gear = What?
- Whats up with using a 3.5 bottomend with 3.0 heads???
- Got another ques?
- Best ECU
- motor guys, need help with options
- spec and stillen combo!!!
- All this talk about VI's
- Used Engine Break In?
- Heads and cams by CrawfordZ
- new header, no egr connecter
- What has to be done to get 4th gen injectors to fit 00VI lower manifold?
- Two ECUs
- *****VQ30 Head Porting*****
- Change Final Drive ratio
- 00VI customized IM
- Hows the 3.5 working out in the 3.0 ?
- Crank???????
- Best ECU to get
- 00 VI finally got one
- GRRRRRRRR clutch slip
- Need socket size to do engine work...
- Revving Higher??
- HP Gains...All Motor Add Ons
- NA 1/4 list
- Heard JWT cams in a VQ35 last night...
- JWT GD great for all motor guys!!
- Engine Effiencey
- 3rd Generation Fuel Injectors for VG30E engine
- 3.5 internal parts
- ARP Rod bolts for the VQ35!!!
- engine rebuild???
- What the hell?
- Heads from a 2K3
- been viewing my car with auterra...?? about TPS
- altima/maxima 2002+ transmissions
- Vq30de
- Other Displacement Options
- 8000 - 9000 rpm VQ30DE valve train.
- SR20DET Bluebird on 2k Maxima?
- the 3.5 swaps future
- bore out or engine swap?
- Internals Upgrade Kit
- Exhaust?
- Should i get a SAFC-II (dyno inside with a/f plot)
- Links to threads with useful information
- A/F tuning?
- How does the JWT ecu change rpm limit?
- Who will be the one to be in the 12's ...
- Who here wants to see a all motor drag 4th gen
- Good place to have Rods ...?
- ****IMPORTANT**** Please read before posting!!
- Wut cold air intake should I get?
- Post your all motor setup:
- Thanks Sprint
- First Test Drive Finally
- 3.5 in a 4th gen
- VQ35 Secret Sauce manifold nearing completion.
- The Great Gearhead thread
- VQ35 internals in VQ30 makes VQ33 stroker, bolt on! PICS!
- Cattman VQ30 headers installed on my VQ35
- 3" PVC MAF Project. Works fine.
