PDA
View Full Version : All Motor
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15
  1. Stock valve springs + aftermarket cams
  2. VAFC removal question?
  3. FS: PLX R-500 wideband AFR datalogging computer kit
  4. breaking up after 6speed swap
  5. Removed the butterfly on my vq35 today
  6. 350z TOB in Maxima 6spd?
  7. (3") Big Bore MAF Housing (General Discussion)
  8. Air Temp & Humidity: Effects on performance
  9. Cant get Autotune to work on my EU....
  10. Complete Port/Polish VQ35DE Intake Manifold + Spacers
  11. for those with a n AEM FPR
  12. Stock MAF Housing VS Big Bore MAF Housing (76.2mm ~ 3") Technical Discussion
  13. Timing Advance - Definitive Proof
  14. Yet another 300+ WHP build....
  15. Where to get....
  16. 3.5 swap getting me angry now
  17. Air Filter Restriction %s
  18. Datalog sheets
  19. TQ convertor removal???
  20. Tis the season for Oil Pumps
  21. Brian Crower Camshafts?
  22. quick 3.5 question
  23. Stupid question regarding chain guides (3.5 swap)
  24. Fidanza Doesnt Fit
  25. 3.5 swap on a 4th gen central Florida?
  26. XJinCT's VQ35DE swap/progess thread
  27. **Read-me** VQ35 and 00VI swap info
  28. Anyone with Stillen Camshafts, please step in!
  29. VQ37VHR Tech Data
  30. Opinions need on recent mods...
  31. Exhaust theory on x/y-pipe placement
  32. Quick question
  33. How much horse can 6 sp. and 3.5 Handle?
  34. 3.5 swap with 3.5 pans
  35. Another 6speed 4th gen up and running
  36. AFR 1st gear vs 3rd
  37. What are these wires coming out of my JWT ECU?
  38. 35 swap on the cheap.
  39. SMT-7 Basemaps
  40. 00VI on Supercharged 4th gen rough idle and then dieing
  41. quick question on 3.5 timing
  42. 3.5 swap no start...
  43. TB with 3.5 swap
  44. TB Restrictor plate?
  45. techno squares ECU
  46. Finally!! Emanage Ultimate installed in a ’99
  47. VAFC2 Tune
  48. WOT - heavy miss, intake backfire, stock VQ30/ECU (lengthy)
  49. Question: 300zx in a Maxima?
  50. 3.5 timing question
  51. RPM signal for mevi on 99 max
  52. Problem after swap....
  53. Its official. The 3.5 swap kicked my butt
  54. 00VI idle problem
  55. strange timing position of 3.5 cams
  56. how to prime a timing chain tensioner?
  57. Can't remember. Anyone use Split Second products?
  58. PF TB adapter plate trouble...
  59. FP gauge and fuel tee
  60. TB cable bracket...
  61. Enlarged MAF...
  62. question
  63. Chain Tensionor ASAP
  64. another 3.5 timing question
  65. SOOOO mad right now
  66. Pathfinder TB w/ 00VI, does not fit?
  67. Taller 5th gear?
  68. 3.5 upper oil pan dust cover plate?
  69. i cracked a damn cam so i need one, and some 3.5 swap questions
  70. Wideband o2 Hookup.
  71. E-Gas what exactly is it?
  72. Has anybody done a true dual exhaust on a 4th gen?
  73. E-manage Ultimate Rev limiter
  74. ECU Swap vs timing gear swap
  75. high idle after eu install
  76. 6 Speed Starting Problem
  77. Pulled 3.5 oil pan, found a metal chunk
  78. anyone with a 5speed swap figure out how to get rid of code 1003
  79. eu install and tuning questions
  80. hesistation and hick ups between 2k-4k rpm...
  81. Where do I wire VAFC to NX window switch.....??????
  82. VK45 Throttle body.
  83. dek hard start
  84. Quaife Differentials V. 3.5 Swap
  85. Lean when braking
  86. Is a UDP worth it?
  87. Pcv Question
  88. First AFR/Timing Map, Opinions Please!
  89. Weird hesitation/stalling with 3.5 5 speed swap
  90. injectors
  91. Typically how many rpms can the 3.0 handle before something breaks?
  92. radiator/fan assembly
  93. 3.5 swap cam question
  94. tranny gurus please step in(3.5 swap)
  95. question about 3.5 swap
  96. Crank Shaft?
  97. Stroker motor build ?
  98. Tuning settings for DEK and VAFC II HELP>>>>>>
  99. 4th gen radiator after VQ35 swap, help please!
  100. Stock pump to walbro... problem? help..
  101. 1/4 Mile Time in a 3.5 Swap
  102. Flywheel rust?
  103. 04+ Max EGR into Gen 4 Swap Q?
  104. Need Help Asap!
  105. Exedy Stage 1, is it enough for 3.5?
  106. Fuel injector question
  107. 3.5 swap question
  108. vq35 and vq30 water pumps
  109. 3.5 exhaust cam gears
  110. Pathfinder TB
  111. Upper Oil Pan Removal
  112. 3.5 swap slowly but surely
  113. Knocking and Ready
  114. '07 Altima IM
  115. 3.5 help...fuel is driving me insane...
  116. 6 spd in a 4th gen swap procedure & faq
  117. EVAP code 0111 since doing 00vi swap
  118. Nissan WONT touch it! WTF!
  119. VQ 37 HR dyno!!!!!!!!
  120. 3rd gear vs Axles, Raxles, and rotational mass
  121. Well it was the oil pump...
  122. 30 Valve covers on 35 head Q's
  123. ECU code and stored info....
  124. Vq35de(350z) cams in a Vq30de
  125. DEK jumpy Idle
  126. Tilley Still Sell Preped 3.5's?
  127. 3.5 from which cars
  128. starting problem after 6spd swap
  129. Air/fuel ratio Guess
  130. What parts needed for LSD trans swap?
  131. 5 speed swap stalling issue
  132. 3.5 with 3.0 Valve covers, possible?
  133. What am I missing from this motor in order to complete this swap?
  134. Switch Panel Finished
  135. HKS Pistons and Connecting Rods... can they work our swaps?
  136. 3.5 swap, Cam drilling
  137. Technosquare or E-Ultimate for 3.5 swap?
  138. DEK Swap - Vacuum Problems
  139. q45 tb on vq35?
  140. EU/car difficulties
  141. Engines out and apart... what can we do while i have it open?
  142. 4th gen 3.5 swap compression
  143. fidanza flywheel install problem
  144. Throttle Stop Canister
  145. Datalogging/Tuning?/Motor IssuesSo
  146. How much did you spend on your 3.5 swap?
  147. Napa vacuum canister part number please? (MEVI install)
  148. issues with neo and 00vi
  149. List of members who have done the VQ35 Swap
  150. 3.5 swap cold start problem
  151. Who has the Cleanest VQ35 Swap?
  152. OK! Whats going on with my car?
  153. Installing Flywheel Tomorrow - need advice
  154. Let's see your mallfinder throttle bodies.
  155. Where else to get Crank POS Harness?
  156. Installed VAFC2
  157. Clutch recommendations
  158. Power loss after 80 - 90mph
  159. 00VI/VIAS help
  160. 3.5 short block
  161. which air fuel system to use for 3.5 swap
  162. 4th Gen TCU Wiring
  163. 3.5 swap SOOO worth it
  164. 3.5 swap help???
  165. 3.5 Swap, EGR, and Pilot Bearing?
  166. Walbro 255 + Stock FPR + E-manage Ultimate
  167. flywheel break-in?
  168. DEK swap
  169. 3.5 swap good for a Daily driver?
  170. Fan Control Mod
  171. Some 3.5 info Needed
  172. 00vi swap
  173. 3.5 horsepower
  174. 95-99 VAFC II Writeup Complete.
  175. VQ Valve Spring spec. charts
  176. 5-speed transmission rebuild/overhaul
  177. Mevi Swap Questions
  178. What would I need for a 6 speed swap?
  179. Those with 3.5 swap....
  180. Fellow 3.5 swappers-- question
  181. 00VI EGR Problems
  182. How much is a 4.5 gen worth?
  183. VQ35 in a 2k1.
  184. fuel pump wiring question
  185. Drop in RPMs to 200....
  186. apexi neo tuning
  187. 2nd Guessing Cam Install due to difficulty
  188. oo vi reliabillity feedback
  189. Returnless question
  190. 00-01 injector plugs
  191. need help with 4th gen vq35 swap
  192. 305 WHP all-motor 350Z!!
  193. Congrats, new All Motor moderator!
  194. just wanted your opinions on my 3.5 swap video
  195. 00vi cup position....driving me CRAZY
  196. Finished the swap.... but one more problem...
  197. Verify my timing...
  198. Anyone know about resonators/mufflers and sound?
  199. SFC-VTEC controller
  200. Where to set the 00VI switch over point?
  201. need help with 3.5...
  202. Vq30 sleeves?
  203. techno square ecu for 02' 3.5
  204. Fuel fittings - 00vi
  205. Car Wont Stop Running - Help!
  206. VAFCII question
  207. Bad fuel pump?
  208. Aftermarket Ring and/or Piston Question
  209. MEVI installed, now getting 0205
  210. Just want to make sure this is normal...
  211. Wbo2?
  212. vias info
  213. help
  214. Summit RPM Switch - MEVI
  215. Looking for a Thread about a 3.5 w/Nitrous getting 350whp!
  216. Boost + High Revs?
  217. Field sfc-hyper r
  218. 00VI swap running rough
  219. Double-checking on VAFC install
  220. IT'S ALIVE.....Well sort of
  221. 00VI Throttle Bracket
  222. 3.5 non-floating T.C. guide?
  223. Are the secondary (downstream) O2 sensors really by-passable?
  224. Emissions in VA, ECU not ready.
  225. 3.5 swap car wont start...please help
  226. Differences between stock MEVI equipped VQ30 ECU and USDM?
  227. 00VI brain teaser (unexplained cold start issue)
  228. 3.0 removal
  229. 3.5 in a 3rd gen?
  230. Larger MAF, fuel and timing mod
  231. TPS Caliberation & external Ground please advice
  232. Fuel pump wiring Q
  233. Okay... needing last minute opinions
  234. camshafts
  235. need some help
  236. 3.5 swap fuel and napa injector harness connections
  237. Supercharge vs 3.5 swap
  238. DEK Swap
  239. UDP Problem.
  240. 3.5 swap flexplate pin hole....
  241. VQ35 + 01 PF TB = 3000rpm idle
  242. DEK timing cover different?
  243. Emanag Ultimate Update 2.11
  244. Help with my 3.5 swap....
  245. ecu upgrade reccomendations
  246. Finally it's done - my EU writeup inside
  247. 3.5 cam swap, which gaskets should I replace?
  248. Preparing for a 3.5 swap
  249. EVAP, EGR & Emissions
  250. VQ37HR VVEL discussion..
