View Full Version : All Motor
Pages :
2]
- 470cc Fuel Injectors on stock fuel pump?
- DEK swap completed, minor drivability issues...
- DEK sensor compatibility
- ghetto building the 3.0
- tranny swap
- z32 maf
- vq35 bad valve???
- My racecar!! lol
- The reason for a full ecu/wiring harness/Engine swap vs. 3.0 timing
- VQ35HR, running with a VQ30 ECU (swap)
- the swap once again
- anyone ever heard of zfever.com?
- Need help with VQ35 swap
- Looking for 4th gen base maps
- Crank Balanced
- SAFCII and MAF issues (linking thread)
- 2001-2003 NATS Immobilizer (NVIS) Tip
- Bigger MAF help
- How much tuning is needed with an SSIM?
- DEK Swap - Need throttle body & other info!
- 87mm Throttle Body Install
- 97 maxima no spark to cylinders 1,2, and 3
- VQ35 w/vtc+00vi on 30 ECU?
- Cool custom IM for VQ35DE in a 280zx
- In and Out settings for 3.0 SAFC w/ BBMAF
- Leaking Power Steering?
- Quaife DIYer's HELP!!!
- Start Requirements
- Will these headers fit 95 vq35
- 3.0 valve lash adjust after changing cams
- Which CAI? 95 w/ vq35
- Oil leak HELP....
- Looking for engine...what will work?
- Stock Injector Latency
- ?? - I DONT KNOW HOW TO MAKE A PROPER THREAD TITLE
- Tachometer not working - '98 4.5 6spd swap
- Wideband Placement
- 4.5 3" Exhaust
- c9 cams pistom 11.01 wiseco 95.5
- VQ40 92mm crank in VQ30DE block?
- Custom Intake Manifold and 87mm Throttle Body
- cDgRazoray's 95>02 VQ35 Swap
- e-gas pedal
- Want a Taller 6th Gear? Click Here
- DEK/VQ35 Hybrid Setup Qs
- help engine swap, 4th gen into 5th gen
- 6th Gen ECU + VQ35 + Osiris in a 4th Gen Swap
- VQ35 questions before starting
- PNP Standalone Ecu for 4th gens?!??!
- 7th gen swap in progress and old motor aftermath (slow uodates!)...
- 5th gen VLSD transmission in a 4th gen
- What's Wrong With This Picture ?
- engine Flush Questiom
- Why does no one do VQ35 rebuilds?
- 2k9 TB Adapater Plate
- VQ35HR cams w/DE VTC cam gears?
- Rev-up cams+3.0=oil leaks?
- look at what my friend found at the junkyard
- Cool Air Intake
- Longer o2 sensors??? anywhere?
- 6spd flywheel bolts
- VQ40 Hybrid *paging Trav*
- 3.5 Hybrid swap with a 2008 Altima.
- Litch's full vq35de engine swap
- Erratic MAF behavior/readings
- Hood Scoop + Air box
- 3.5 swaps in cali
- Oil pressure issues on a VQ35 swap.
- can you swap a 1997 maxima engine into a 2003 maxima
- 6 speed ring and pinion gears
- Rebuilding 6 speed from a 6th gen.
- LSD swap issue question
- K&N Apollo intake
- VQ30 or VQ35 Main Studs/Bolts
- Q45 MAF
- VQ35 Pistons in a VQ30
- VQ35 Swap how to tell if timing has skipped a tooth?
- E "clutchmasters" stage 2 clutch kit...FAIL!!
- Tools Needed for a VQ Motor Disassembly.
- this Y-pipe never seemed to have gotten addressed
- 6 speed noise.
- 5spd Auto Trans-N 2003
- SAFC2 ISSUE (3/21/12)
- obd port on 97 no power
- custom intake manifold materails
- JWT VQ35 ADJUSTABLE EXHAUST CAM GEARS
- cosmo pulley
- maximelt's all time build NA VQ35DE/HR hybrid
- cold valve lash adjustment
- safc2 issue
- 6spd_Hayes - 2k2 Engine build thread
- HR Springs, stock retainers ok?
- 372 WHP 350z, ITBs, Head Porting, Longtube Headers
- My Stage 2 VQ35 Longblock Build from IPP (Import Parts Pro)
- What does it mean for a transmission to be improperly shimmed?
- BOP, SSIM, & Intake Manifold Spacers
- 3.5/3.0 Hybrid Swappers Aftermath
- 00VI vs Z33 IM + spacer.
- Car won't rev out all the way.
- HR cam Timing for 3.0
- CUSTOM SSSI Manifolds-SPARKS03MAX
- Sentra 5sp tranny in a 4th gen?
- Should JWT ECU be reprogrammed after full DEK swap in 4th gen?
- can i use a 96 motor in 99 max?
- vq30de rebuild questions
- People with VLSD trans: Torque Steer much?
- Tomei Cams on Sale
- 3.5" maf & intake installed, Tuning issues
- VQ35 CRANKSHAFT MAIN BEARING REPLACEMENT
- Difference between catback and no catback
- 02 FWD VQ35DE Block + 2008 G35 VQ35HR heads Test fit, discussion, BUILD?
- 3.5 burning ol
- 6 speed swap issues: Shifter cable lengths
- cylinder hone question
- 02 IM on a 95
- Quick 'n Dirty DE-K Build.........
- Questions about VQ40 rods
- No spark and pulse on cyl. 1,2&4
- Guys running a Catch can
- Camshaft Bracket Part #
- new life
- getting the most out or HR/DE build
- Need advice for removing 00vi parts
- motor swap
- clutch problem, doesn't engaged well
- SCAM ALERT: Custom intake manifolds going into production
- Oil Pressure.
- rev-up oil pump good for AT 4th gen motor?
- Where did the tuning and afr threads go ?..
- specv trans, fidanza flywheel, but what clutch?
- emanage helping hands
- Installed Transgo HD2 Shift Kit Today!
- 4th gen map and maf
- Ranma's 2002 Nissan Maxima build
- Another De swap but no spark
- New product from NWP Engineering! 6th gen Maxima UIM EGR Block Plate Kit
- swap ideas.
- Max RPM with stock rods/pistons
- Guru's analyze this. 4.5 gen possible problems?
- Time for a thread...
- 3.5 Swap Q's
- Peak power of a vq30? No forced induction...
- Replaced the rod/main/thrust bearings.
- Rich Tune after Tranny Swap???
- Question about tuning...
- cam ?
- Aackshun's VQ35DE Swap Plans...
- car wont start 4th gen 6speed people come in
- The Definite BBMAF Thread
- Oil Pump??
- Request from 00vi Drivers
- New Innovate LC-1 Wideband Firmware
- EU install questions - 98 max
- 4.5 gen issues. Help Needed.
- What else would make a maxima not start?
- 3.5 Compression Test Results = Issues
- VG30 eating Timing belts
- OBD1 or OBD2... Which is moar bettah?
- VQ35HR Valvespring Spec?
- Hesitation/stuttering/misfire at low RPM/throttle
- Tuning 3.5 Swap
- Leak down test results and questions
- NEED a NA guru!
- E-Manage Autotune not working
- 6th Gen Transmission Swap (HLSD Swap) Questions
- trans issue upshifting please help!
- what do i need to run revup cams
- Header Wrap AND Ceramic Coating to OBX headers
- Android/Blue Tooth OBD II
- Speedo not working 01VLSD in 97
- VQ35DE Swap Questions
- DE intake cams in DE-K
- Which is best intake for PFTB on 4th Gen?
- Starter Destroyed My Fidanza
- Need advise on EM blue or VAFC II
- 5SPD Conversion + EU harness question
- header to ypipe gasket question
- VAFCII/SAFCII partial throttle corrections
- Maf sensor????
- HR head gasket question
- tell me its not the tranny......... plz
- Is there a right up on how to remove the engine out of a 4th gen?
- Could this engine get The worst VQ35 oil burner award?
- 4at to 6mt
- 7th gen vq35 in a 4gen??
- GI: 6Spd Timing Rings for 3.0 Timing.
- 3.5 SWAP ??
- Rev up cams in a VQ35de...help please.
- Connecting Emanage Blue
- How many of you are experiencing weird vibrations after 3.5swap?
- 00vi upper gains
- vq30de power?
- Help.. 2k3 Maxima Tranny or Motor Problem
- Meximax Parting Out
- TransGo RE4F04B-HD2 installation
- Using a 5th Gen. ECU on a 4th Gen. Maxima
- Altima eBay Headers installed (Hotshot knockoff?)
- 4.5 max got richer afr after 3" catback and y pipe
- does anyone know where to buy knock off cams?
- Injector Lag Time
- VQ Swap blowing coils...
- Custom intake manifold thread. Build, dyno gains.
- 3.5 swap. Shes a runner!!!
- VQ35HR head gaskets fit's on VQ30DE !!! Officially from JWT
- 02 SPEC V Tranny Swap, What Can I Use/What Do I Need? 4th Gen
- Altima L30 5th Gear and 3.65 FD and othe tranny related questions
- Full Swap harness
- 00VI RPM range
- dek swap questions
- fully gutted ssim with new elbow design
- Emanage blue on 5.5 gen
- Transgo Shift kit with Maxxtuning VB and opinions
- Stuck on 6spd swap
- Main Cap Bolts - 3.0 vs 3.5
- Cam spacer failure... solutions?
- Greddy Emanage blue or Ultimate
- Need info on Misc part
- Cam adapter problems
- Custom y pipe sizing
- Diary of a 6spd Swap in a 4th Gen.
- 00vi 4th Gen LIM Info
- DEK/3.5 Hybrid Possible?
- 3.0 NA bult
- Utec Wiring Diagram
- 3.5 swap, turns rough by hand.
- 7th gen swap into 4th gen
- SSIM improvements... just theorizing
- RS6F51R Transmission
- Need Multiple Intake Manifold Questions Answered!
- Engine Work
- STOCK VS JWT S1 VS NISMO CAM VS TOMEI
- Technosquare is no longer offering ECU reflashes...
- 5.5 gen + UpRev Osiris = ECU swap
- Full ECU 3.5 swap questions
- Are 96 and 2000 5spd flywheel and tranny is the same???
- Post your EGR CEL post Motor Swap fix
- MaxPR0908 vq35 + 5 speed swap....need help guys!!
- 96 ECU in a 99
- 5th gen 5spd swap question
- Slightly high Idle 00VI
- Rev-up cam timing?
- VQ30DE compression
- Buying a used vq35
- How do you adjust Pathy TPS?
- Ampire's VQ35 simple rebuild/ 4g swap log
- 98 vq for a 2k engine swap? what would be needed
- Revup or HR rod bolts work in DE?
- The free motor from 1991tsi
- 3.5 Swap now p0300 random misfire
- Problems.. Timing chain links
