View Full Version : All Motor
Pages :
5]
- LS4 Swap
- 95 Max need help with Vafc
- fans not work with EU board E
- FS - Matching 03 ECU, NATS, Ignition and Guages
- RPM switch question
- LOOKING TO BUILD A VE30DE.
- help with valve lash on rebuilt 3.5 w knockoff cams
- IACV allows too much air to bypass! i'm stumped
- Tuning with Safc and lc-1
- Happy so far!
- vh45 in a 4th gen?
- Fuel Pump Rewire for increased flow rates.
- Definitive 4th gen / 5th gen TPS info
- 1999 maxima with VI activation problem.
- UTEC - will it work with an A32 ECU ???
- VQ35 Swap Progress Thread
- Throttle Control from Blitz
- 4.5 Gen Problems. Possible Timing Chain. Please Help!
- EU installed on my 99 max...no start..please help
- Question: Vq35 tuning on Piggyback with 3.0 ecu
- Might be onto something!!!!
- Auto 1st gear holding me back. Anything I can do?
- DE-K questions
- vq30de-k build questions before I start
- Tell me why this won't work electronics guys...
- Greddy files for bankruptcy
- Anyone have a before and after dyno of gutted 3.5IM/SSIM vs non-gutted 3.5IM?
- emanage blue for 00vi question
- VE laptop tune/consult fabrication complete (video)
- UTEC is in..........
- 3.5 swap no start
- Emanage Ultimate assistance - larger injectors and MAF
- Timing Chain / Hesitation and Power Loss / Overheating
- FULL six speed swap
- Question????
- bbmaf question
- Why is my car running lean at low rpms.
- Cowl Induction
- ECU Pinout cheat-sheets (large images, 1000+px wide)
- Mevi Question: Not opening under load
- A/F thats best !?
- JWT Cams for the 4th gen
- If you're going to install rev-up cams.......
- Finally doing 00 VI install need help
- 00VI Idling issues: IACV? TPS?
- How To: Suprastick V4 install
- 3.5 Swap midrange LOSS!!
- '01 VAFC Diagram
- Transmission compatibility question
- Heat Wrap Screw up
- It's official. Cammed DE-K in!
- 3.5 oil burner
- 00VI Needed for Prototype Spacer Kit
- Which wideband to get??
- RE4F04A swap with RE4F04V
- Cylinder #2 & 3 arent firing
- Torque Converter
- Safe to re-use IM gaskets?
- Automatic to Manual Tranmission Conversion
- DEK swap crank, no start...
- Wideband installation questions
- Any Useful Parts Out of an 04 G35 Bloc?
- another 3.5 swap....no start...
- 4.5 Gen and EMU issues
- A PM regarding 3.5's HG's and timing
- MEVI questions
- 00VI Installed! yay...
- 3.5 cams
- Oil pressure... just a note.
- AFPR+Rubber Lines on a 3.5er...
- 00vi POWER!!
- 96 maxima SAFC wiring problem
- hard starting "IS IT THE CAMS"
- Power difference between '02 Max and '05 Alty SE-R
- Could really use some pointers...
- Shift_Fast wiring help
- 3.5 finally runs- Now a coolant leak
- zeitronix zt2 wideband installation questions
- Need info about shims
- Cammed VQ Spec fire up video.. :)
- 6 speed on 3.0L motor trany swap question
- Strange compression numbers..
- 5 speed sway in a 5.5
- 00vi help....(please)
- Misfire under load in swapped 3.5
- 370cc injectors on a bolt-on only Maxima?
- Weird Starting Issue
- Question for the motor guys
- "V-Manage" Initial Report
- VAFC2 doesnt "work"/communicate corrections
- VQ35DE with an HR Intake manifold
- 3.5 swapped 4th gen starting problems
- LPH of 4th gen stock fuel pump/ EKG of my Walbro
- VAFC II and DEK engagement
- OOvi question
- LC-1 wideband questions
- new project
- VQ35 valves in a 3.0?
- HELP---3.5 Swap with 4th gen Auto tranny
- safc / wideband questions
- (6-Speed MT) Transmission Issue
- 3.5 swap....wont start..need help..
- Excessively high idle issue - 4k rpm
- wideband o2 question
- 75mm TB without an adaptor plate.
- Tune-by-Tape, or fun with a stock MAF..
- Emanage troubles
- Fuel cutoff and pulses on a A33A stock ECU?
- Do all 2001 VIs have the cali smog equipment?
- Engine Block Prep for build?
- Have the limits of the stock 3.5 block been found?
- Help i need the FSM
- Completed '02VI Swap, Dynos inside.
- Injector lag time?
- FULL 3.5 Swap A/C issues, Anyone else?
- 00VI Site: What do you want?
- Passed E-test with the 4.5 Gen
- safc II intitial setting on a 2000
- 00vi swap
- 5-spd auto into 4th gen??
- MAF placement, TB to IM distance, Cam Pulse? Other Effects?
- 3.5 leak
- Has anbody tried doing a SSIM with a handsaw?
- rewiring maxima harness for 350z ecu
- Shift_Fast Question
- WB02 w/ emanage blue?
- SAFCII and Q45 Maf ?
- Emanage Ultimate Hell
- 00VI cup orientation (quick check)
- Weird MAP Sensor/ Engine Problems
- ECU pin diagram for a 99
- Getting a custom Y pipe made for my Cali Spec 99... O2 sim questions
- Whining under partial throttle
- 00VI help: Vacuum leak & A33 IACV?
- quick ques for 3.5 swappers
- 3.5 swap tps question
- All swap gurus, i have a question 4 u...
- 3.5 swap finally done...
- Check my mevi wiring schematic please. (large pics)
- SSIM... ?
- (00vi) What would you use to fill in LIManifold holes to port match?
- I made a boo boo (00vi problems)
- Timing chain grinding, daily driver
- Another N/A build
- VQ35 swapped SE-R video/pics..
- 3.5 swap cps question
- 2000 VI on A 3.5
- Bigger TB on 5.5 gen, what to look for?
- Some More Pathy IM Photos...
- Engine ate spark plug side electrode.
- afc tuning pros
- Decided to play with my intake - wheee
- Best Cams for the 4th gen
- Progress on 3.5L swap.
- Kinetix SSV
- Question about rpm switch
- 3.5 swapped auto having issues
- More 3.5 problems
- is there any way to by-pass the immobilizer in the 99s??
- First 310 whp and 290 wtq VQ35DE All Motor!
- 5th gen and 4th gen UIM and LIM
- Problem on my swapped 3.5
- 3.5L swap Q's, yet again.
- Performance coil packs for VQ35DE
- IM Spacers affect AFR a lot?
- Need Help w/ 6spd Swap
- 3.5 cam spacer dimensions
- WRONG PATHY TB??
- 3.5 swap in a 97 5sp
- Cheap rod bolt alternative
- SSIM mod powerloss question
- Good Mod for around $600?
- timing
- IM w/EGR valve question
- 3.5 swap issues
- Exedy S1 and ES Motor Mount instaLL
- Zeitronix wideband in and Tuned
- The 3.5 HR runs
- benefits of 3.5 cams in a 3.0
- Altima 3.5 headers in a 4th gen???
- EGT probe location for n/a Vq30de?
- injector upgrade for n/a project
- NATS/NVIS, Immobilzer, Key, Programing question..please help!!
- Aluminum 16Ga for dual exhaust?
- Gizzmo Launch controll/ Shift light
- AFPR Concerns....
- FWD vs RWD VQ35 Differences (Lengthy)
- Safe amount of timing.
- 3.5L Cam advance.
- 3.5 swap- fuel pressure problem
- what to do with a seized vq35...
- Innovate WBO2 Systems
- Bought 00vi parts, but IM nipples are broken. Need advice from 00vi experts
- my 00VI Part one (removal)
- Buying a used Apexi NEO
- VG33 or VG34 heads work on a VG30?
- Cams spacers for 3.5 swap in to 4th gen?
- What throttle body is everyone using on 00VI swap?
- 350z fuel pump in 3.5 4thgen....
- At the track, manual fans with auto-shutoff?
- Hit two milestones yesterday with 3.5
- Wideband Bargain? PLX R-300
- Got Problems??
- help 3.5 swap
- RB26DETT
- MEVI question
- Cobb AcessPORT for the 350z and G35 are being tested now
- going to dyno soon. need help deciding on a piggyback!
- Got my cams Installed.
- Where do these lines run to?......
- vq35 lower intake manifold Talk! Topend talk!
- Tell me what you guys think?
- Just got my 3.5 for $225 Got some build Q's
- SSIM dyno sheets
- Any issues using an EU with a 4.5gen?
- Curious , 5.5 Heads and 6th Gen Heads ?
- FULL 3.5 Swap questions about process and hardware
- clearance issues with z32 rods and pistons in a Vg30e
- Timing adjustment
- EU injector map
- How hard to convert FWD VQ to RWD VQ?
- Summit Switch wiring on 00VI
- Osiris from UpRev
- 350z motor, ecu and harness swap
- 3.5 swap- tb problems
- vh45de in a maxima?
- FS: '02 FWD VQ35 w/SSIM
- Wideband 02 Reader
- Learning to read runfile help?
- Distributor not staying in time?
- Trying to switch MAF to MAP
- Building a VG30E up?
- Making your own intake spacer ?
- Data Scan 1.52 - Graphs
- Wideband 02 Comparison and Other Info
- VK45 Pistons in a VQ30 engine = 11.x:1 compression ratio
- VQ35 s13 swap radiator/exhaust Q's
- DE-K+PF TB+4th gen IACV= problems
- SSIM: Gutting the elbow?
- q45 maf
- reliability/practicality of a 3.5 swapped 4th gen
- Fuel Line size and adapters when using aftermarket FPR?
- Pathfinder tb w/ 3.5 swap
- Need Help with 6spd swap
- 00VI startup issues,
- 6 speed starter bolts
- MAF Power problem, please read
- How much would a VAFCII help this AFR?
- Another new VQ35 intake from eBayz...
- MY DOMINANT 00VI SWAP!!!
