View Full Version : All Motor
Pages :
13]
- DE-K Swaper(LIS-ONG)
- 00vi bolts and whatnot
- DE-K into fourth gen
- 3.5 Swap -> 3.0 ECU -> VTC possible with piggyback???
- Project: Tilton
- Clutch problem...
- What would be the ultimate IM design for the VQ?
- 3.5 cam spacers, cams, and sprockets
- 3.5 swap, problem with POS pass. side axle
- 12:1 heads from nismo?
- Kinetix SSV Prototype for 3.5 Alty
- 2k VI installed...Now what? (Long)
- Emu
- 5th Gen Trans in 4th Gen Speedo fix
- how hard of a swap is this
- RPM switch.
- Strange metalic rattle noise coming from hotshot headers
- Completely Removing Secondary Oxygen Sensors – Guru’s step in..
- Blown Headgasket?
- Rear LH valve cover vent, needed?
- Input on My Future Mods ?
- Clutches?
- motor weight anybody?
- General 00VI Question
- Anyone using Megasquirt yet?
- Timing advance
- Counterfeit 3.5 EBay Cams
- Guys running different Throttle Bodies (Pathy, '03, '01, etc) please read
- Aiming for the 200hp/200tq mark
- AC system removal
- Guys with anything to read knock (SAFC, R500, anything else) do you get knock at idle
- Could JWT Compensate?
- Why can timing not be ADVANCED with Emanage Blue?
- info on the 3.5 4th gen swap?????pics
- quick ?
- VQ30 Headers/ Do they fit on VQ35?
- Having starting issues, '97 with VQ35.
- 5 Speed Parts List
- 98 engine in a 96-won't run
- knocking on vq30de
- VQ35 Plenum Spacer
- 3.5 swap MPG's and emissions questions
- Question on other parts needed for mevi
- Running without EGR ??
- Anyone running w/o an IACV?
- Guestimate on VQ35 engine/tranny swap
- Just ordered Mevi from Nismo car parts where can i find the other needed parts?
- MEVI / 00VI swaps please step inside.
- VQ35 timing chain question
- VQ30DE-K camshafts in 4th gen maxima
- Guys Who've Done The 00VI
- Vq30dek
- A/C Compressor and PS pump switch to VQ35?
- Is my timing bad....
- ignition coil question
- What is the stock timing advance with stock ECU on a 4th Gen
- Cold start issues on '97 with VQ35
- tranny cooler
- 00VI questions/understanding options/suggestions please
- Mallfinder TB + jwt or techno ecu
- procedures for 3.5L block swap
- accessory pulley's for vq30de
- Hypothetical Question
- Any dynos of 3.5 with 3.0 components?
- Motor on stand, loud CLACK when crank is rotated.
- 3.5L 6spd question, clutch slave cylinder
- 3.5 swap procedure and FAQ
- EGR problem
- MSD Ignition upgrades?
- 00VI question.
- DE-K Injector harness splicing
- 3.5 swap questions
- Would the Plenum spacers that the Z/G guys use
- 3.5 heads or3.0 heads?
- How many people are using Digimoto for scanning and mod comparisons?
- HKS Twin Power
- Ignition timing with N/A 95 VQ30 JWT ECU
- 00vi setup verification
- Some questions for the all motor project.
- Score!
- need more information about the 00vi
- Help,Still 00VI problems
- Finally got a chance to to Timing Advance to my max
- Is a 95ECU on a VQ35 still the way to go?
- VQ35DE Block with VQ30 Heads.
- i regret doing the vi swap
- 2004 3.5 Engine swappable?
- DE-K Engine Swap?
- egr and coolant lines vi swap
- How much more timing with step colder plugs?
- help with evap hose on vi swap
- Ignition Advance logging after KS replacement
- Leavin NA section for awhile
- VQ35 in my 00 cali? waste of time?
- MEVI not opening under load
- If I went back to stock manifold, would I still need a tune as badly?
- SER altima engine?
- VAIS Solenoid harness?
- would oil cooler be needed to raise rev limit towards 8k safely?
- Laptop OBD2 Software
- doing 3.5 swap have aot of questions, pls read
- questions about upgrade routes. input needed!
- help with vias bolts
- those using vafc II
- Wiring my 00VI up.
- 00VI up and running ^^
- 2000 blow-by hose part number
- Quick Vi Question
- upgraded clutch w/ 3.5 swap
- Removing pcv system
- connecting a 2000 iacv to a 4th gen
- Direction of coolant flow
- jwt cam spacers for 4th gen 3.5swap
- VI switch...
- How Much HP????
- JB weld for the 00vi
- It's Back.........
- Ignition timing/advance
- Anybody used ARP cylinder head studs?
- Pathfinder TB
- Mevi Or Oovi
- Quick-ish 3.5 full swap question (yes, I've exhausted search)
- home made headers
- custom ITB for Maximas
- Any negative effects on running no thermostat
- My 96 is going to be a toy/drag car
- Is it ok to remove plate that ac compressor bolts to?
- 3.5 Swap Around Or In NY
- 00VI/VIAS Mystery Problem
- Proof that 00vi owns MEVI
- SAFCII owners: ur knock count?
- Can someone help me with my 02 sensor? Nobody seems to know what to do!!
- fed spec 00VI with my Cali spec car
- running lean
- 4th gen DEK intake manifold swaps and higher engine temps
- need basic info on 3.5 swap 56k to slow to surf
- 00-01 ECU in a 4th gen w/3.5 swap
- 550cc injectors
- 5spd Swap- Part II ***PICS***
- Whirring noise explained in detail. *PLEASE HELP*
- Spark plugs for higher compression engine?
- questions about safc II
- What are people using to monitor and datalog ignition timing?
- 00VI with missing ERG......Work involved
- Help with starting...
- help with intercooler endbanks
- Consult Scanning Software
- best bang for the buck??
- best mod question
- does the VQ33 stroker work and how much does it cost?
- just bought a vi00 quick question
- 201.33whp/191.27wtq MEVI/STOCK ECU
- Tips on pulling motor
- JWT ECU and SES Codes
- Vg30DE Fuel injectors in my Vq30 ?
- 95BLKMAX's DYNO - Something REALLY wrong......
- vq30de-k a direct swap for 4th Gen?
- ECU swap.
- SMT6 Now officially is working
- Full DE-K motor swap complete!
- 4.0 vq upper on a 3.5 lower.
- JWT vs Emanage Ultimate
- cheapest 00VI
- 00VI install begins soon...
- Aftermarket Fuel Pressure Regulator
- Using e-manage to actuate power valve?
- Big Problem with my VI
- Similar ECUs?
- 00VI vs. 01VI
- SAFC-II benifical being N/A??
- quick help with 00VI
- Trans swap questions
- 2k2 Fuel Pump Installed!!!
- Car is slower
- Wiring Up Summit RPM Switch
- 6spd on a 3.5L in a 4th gen
- 300 Hp
- Has anyone done a 2002 Max Engine/Tranny swap in a 1999 Max?
- confirming understanding of 3.5 swap
- So, what is the final answer on 4th gen timing?
- MEVI vacuum problem, Please Help
- 00vi installed with 1302 code
- Hard starts in morning
- Anyone have the part # for MEVI butterfly Screw?
- Upgrading rods and pistons
- It's in... without the built tranny.
- Can the timing chain cover be removed without removing the crank pulley
- Vq30de-k
- Little help with learning about my max
- 13s on motor?
- Do any 00vi write-ups exist?
- injectors
- 00VI running lean and aftermarket ECUs
- My enigine is dying...i think it spun a bearing
- Is this normal for jwt ecu?
- Problem with MEVI
- need some help with my codes that never go away
- $$ in all motor setup
- IACV and EGR
- questions about using 00VI upper with the 4th gen lower
- jwt ecu vs. piggyback system (emanage, SAFC)
- 97 auto 00VI Dyno
- Problem with Fidanza Flywheel Install.
- Question about intakes for swapped motors, TB's, and IM's
- Mounting Points for 00vi + 4th Gen Lower Intake Manifold..PIC provided
- 3.5 swap and california emissions (smog)
- those with complete 00VI motor swap in 4th gen
- BOOM goes the fuel line
- 5 Speed swap throws CEL
- What mod comes next?
- misc parts needed for 00VI swap
- anyone have part numbers for stock VI bolts?
- VQ35 swap q's
- EGR plug for rear manifold
- Why should I not build the VQ33 stroker?
- Nees some help w/ custom VQ swap, cranks but won't start
- 00VI question concerning IACV
- piggyback vs. stand alone ecu tuners
- need 00VI swap parts?
- *Microtech Engine Management Systems*
- VI swap, ? about EGR cooling and rear supports
- Just want to verify with peeps that have upgraded ECU's
- help with 0210 code with VI
- Is my fly wheel okay?
- news on catmann standalone headers?
- RSF50A or RSF50V, how to verify?
- 00vi question...please step in
- Traction control
- Hey guys need help?
- QUICK Question :: Can I use the Stock Air Intake with the 00vi
- Proven facts?
- Need help with 00' VI
- Can we Adapt a 350z Intake Manifold to a VQ30DE
- VQ OEM and Aftermarket Cam data
- VQ30+VQ35 ARP Studs Interchangeable?
- Transmission removal
- mevi or 00vi?
- VQ35DE & 4th Gen 5MT
- What involved in a 3.5 swap?
- EGR guide tube for 00VI swap
- Hood Spacers
- 3.5 on Ebay
- Spark plug repair on dohc heads.
- vg35de rods, piston, crank swap
- 00VI smog legal?
- Understanding compression
- What would cause this? Take a look.
- How Much Does a VQ30DE Weigh?
- Pathfinder VQ35 has same cam timing signal as VQ30
- Gearbox model numbers
